- ITR valve angle/ widths?
- looking to buy new internals
- need help new h22a4 build
- exhaust question
- Fuel consumption suddenly high.
- Best Piston/rod combo?
- main bearing clearence
- b18c-r struggling occasionally only at low rpms
- best cam for high CR
- LSVTEC Dyno 82mm
- Timing on a semi 11.6:1 gsr
- 12.8.1 compression run on 93 pump?
- TIMING !
- LS Cams...whats best for my setup
- what intake manifold and TB for my set-up?
- SOHC ZC Runs Rich..NO CEL
- 80 cvcc new B16 N/A Motor pics
- 80 cvcc new B16 N/A Motor build
- Heater setup on n/a b20vtec question.
- .....Help!! Real or fake Hytech headers?.....
- b series rocker arms
- Priceing my swap
- The best method to get more power out of my B20VTEC -- 186whp/146ft-lbs
- Ecu related problem
- Searched but still stumped...can someone ID these cams?
- ProFunction and Kinsler Present: Epic All Motor Bseries Manifold Testing
- head porting...
- what manifold and tb for my set-up?
- Composite Manifold
- How much can you bore an F23 block to on stock sleeves?
- Need some input with my b18a1 build.
- rc injectors
- All motor b18c1 piston selection
- TWM ITB injectors help
- 00 civic ex d16y8 help needed
- lsvtec wont crank new battery new starter new terminals
- Aftermarket cams identification please help !!!
- toasted a piston..
- D16Z6/P29 Build Idea... Thoughts?
- glass bead blasted my s2 manifold...fail?
- h22 build
- BLOX Valvetrain Experiences
- h2b kit prices?
- Piston pin install
- Any use for adj. cam gears on a built ls/vtec w/ ITR cams?
- Itr cams in stock GSR motor.. Any good?
- d15b2
- some help with main/piston clearances
- Header ?
- B20 VTEC
- question about switching heads (UNGENT HELP NEEDED)
- Initial cam degree recomendatations M24X
- ITR Throttle body measurements.
- d16 vtec on a d15
- B18C-R - Jumped time.. o_O
- what exhaust is this?
- Can anyone identify this valve cover?
- My LS/VTEC Engine Build on a Budget
- High oil pressure at idle after oil cooler install
- Timing belt tensioner
- 04 Si wont go past 4 grand
- d16z6 and d15b vtec
- tuning for power and fuel economy
- Maxxim works header over rmf narrow rep?
- gsr motor build
- anybody know why i need this?
- 2 different cams?
- Bellhousing missalignment
- b20 vtec sleeves?
- Looking to built b20 Vtec all motor need info!!!
- b18c spec r question!
- idle problem ( video inside )
- injector/cam question
- what did you do 1st?
- DC Header 2.5 collector Mod Or E-Cutout?
- What effects c/r???
- ctr pistons in ls
- unknown wires
- Super Confused b20vtec.
- B18C5 Header
- Building my own B bomber intake manifold
- need help on building a gsr block NA for 200-225hp
- wet track 1/4 mile times
- b18b1 all motor non vtec 250whp????
- intake porting or honing?
- skunk2 pro 1's camshafts question!
- engine stalls
- stock b20 swap - worth it?
- Ebay hytech style header?
- b16a valve train Tips what retainers???
- built block turning torque..
- LSVTEC breather box?
- Fuel rail problem
- For those of you running E85
- would i need biggger injector for my set-up?
- 2.5" exhaust,ots or piece together?
- My GSR build... Dyno results
- Edelbrock camshaft for my b20vtec !!
- filtered oil
- Can someone identify my intake manifold?
- cams for all motor buddy club or bisimoto?
- Vouches for work recieved, tunings done etc etc.
- Double checking arp head stud torque
- H23 vtec.
- mini me fuel rail question
- lol.. whats this look like to you guys.
- Water Temp Sensor Adapter
- my build thread
- ProFunction Presents Bseries Intake Manifold Tests Version 2.0(L) Endyn Edelbrock ITR
- Best Universal 2.5" High-Flow Catalytic Converter?
- High compression with low duration cam?
- Blox Intake Manifold V2?
- cars and rocket science.. idea?
- DIY Write Up - HOW TO CC YOUR COMBUSTION CHAMBER
- B16 head,...which valve springs should i use? itr intake?
- Need advise on Header Design.
- VTEC KILLER CAMS VS SKUNK2 PRO3
- im trying to understand gearing and picking right transmission for the motor
- WHAT THROTTLE CABLE IS USED FOR A GSR IN A EG HATCH WITH THE VICTOR X MANIFOLD
- golden eagle sleeved block cracked from timesert....??
- Deciding on a few parts, opinions/tech info welcome
- stock b16a 1/4 mile theory...thought this would be fun
- Stock vs. Upgrade
- B16, what should I do?
- Looking for info on modified PerformerX Manifolds
- Need help with some header design options.
- B16 camshaft holders WANTED!!!!!!
- Intake and Exhaust B20v
- man on a mission need feedback
- GSR Main/Rod Bearing Selection
- I NEED A TUNE!!!(SO_CAL)
- does anyone still build LS motors?
- '94 GS-R - performance and daily driver challenge
- Best cams for stock bottom end b20v
- k20/24 oversize bearings - clearances
- BC5 Primary & Secondary Full Specs
- Is this a real Skunk2 cam? (pics)
- Free Dyno Day Chicago Area!!!!!
- Compression Ratio - Help!
- h22 bolting torque specs????????
- H2X race motors: what oil pump gear are you using?
- RM M22x/Supertech valvetrain question
- B20Vtec build completion..Input?!
- what rings can I use on b18c R?
- 97 accord lx 5spd
- F20c head resurface limit
- I Need Help Identifying These Cams Please
- All Motor D16z6 PIston Question
- Cam Advice
- good deal for itbs?
- Do I need to re-hone? Pic's inside.
- Intake Manifold choices need opinions????
- Cam gear replacement bolts?
- H22 swap that is boggling my mind! Please Help!
- ECU help. unwanted resetting at high rpms
- Combustion chamber size VS bore
- Do you guys think it's worth it?
- im looking for a high qulified engine builder.
- What saturated Injectors do you use?
- Should I sleeve for LS/Vtec?
- b18c6 max rev
- Aftemarket b16a cam ID markings
- high compression question
- Skunk 2 Cam gear cracked.
- How much would a B16 v-tech go for??
- identifying cams?
- circle track rules
- h22 all motor need advice
- d15b7/d16z6 mini me part ideas?
- non vtec P8R head question
- Some White smoke and a little Hesitation....yes i searched.
- B20B del sol build need suggestions
- requesting more of this set up
- Running carbs with stock Distributor
- Car safety tips
- A thought for the H22 guys about a 97mm crank
- mini me question
- what are the best headers for N/A?
- Leaking Oil Cooler? B18c5
- Help with determining compression
- cam selection help
- b18b1 head gasket question
- leaking gsr 98
- Trying to get my N/A setup quieter!
- Need your opinion 99 civic si ls vtec
- b16 head/b20 block built idleing problem
- OEM vs ARP/GE MAIN STUDS!!
- Help Identifying Cams
- B16+ Pro 1's+ 24* BTDC=p2V contact
- piston-head clearance issue
- b20v or a different swap? : ?
- different motor swaps?
- Just dynoed my freshly built LSV....Need some input please
- Seimen Deka injectors - do they use stock O-rings?
- possible fuel problems? totally stumped
- Vented Valve Cover the same as a PCV setup?
- B20vtec w/ DC 4-1, dyno or wait?
- Skunk2 Intake Manifold for Blox Stage 2 Cams
- Spec for actual volume Supertech flat valves decrease combustion chamber
- b16 engine oil requirements
- Kinda new, what are some good cams...
- ls/vtec w/pro1 idle problem
- B20Vtec, 200+whp, Clutch options?
- I really need a 1995 acura integra gsr b18c1 type intake manifold wiring connections
- fresh b20 build - need spec- the right way
- Rebuilding reliable B18C1
- 50mm piping long tube header pics
- Noob questions! b20v
- Replaced High-flow cat with Test Pipe, What did others gain?
- LS Vs GSR
- Best source for F23A1 short block
- all motor d16y8
- b16 advice. should i get cams or go b18c block?
- 13.5.1 b20vtec..cam choices...
- How many miles or 'cycles' are aftermarket valve springs good for?
- b16b ctr piston in a ls block
- S2 Pro2 degreeing
- Forged Performance Honda Civic Header?
- Hydrolock damage - Is block still usable?
- Any good for honda builds!
- Question about my ODB0 Head with odb1 engine build
- Cam choice help and cam question.
- Replacing piston rings in my LS/VTEC. Anyone have experience using the BRM Ball Hone?
- Port & Polish P72-1 Head
- finishing temp lsvtec need some input...
- what is normal for h22 valve noise, dhr v.t. sk2 cams
- Wich engine oils are good on a B18A1 block with a B16 VTEC head
- My frankenstein DC2 Integra build
- visual differences: b18 and h22
- 3" exhaust is obnoxious
- good cam for my b20v
- Itr header rep help
- Lets see your Intake manifolds + who built them
- B16 Head damage - What needs to be done? Pictures inside.
- Motor bogs/ revs down when accelerated
- swapped b16a cams for gsr..now sluggish
- b series carb setup question *not itbs*
- K20 head
- Engine Swap Ep3 DC5
- Skunk2 Pro series camshaft users
- B18C1 parts list good?
- My future project motor?
- ►►SEPT-OCTOBER | All Motor Classifieds | FS & WTB ◄◄
- Any experence with this tri y header?
- b20 vtec full build questions....lots of them!
- where can i buy cam caps? do i have to line hone?
- LS crank in B18c1 block
- Which manifold to port Skunk2 Pro or AEBS
- How to install a B16 VTEC head on a B18A1 block properly
