- B16 build Q's
- kinser itb
- would skunk2 pro 1 cams work with 1mm oversized valves?
- header Question?
- Look what i sucked in..
- Exhaust Seat
- Input's please
- VTec.
- need help wit engine
- temp problem?? pleasse help asap!
- Cams B20 Vtec
- Skunk2 manifold issue
- What is the Best A/F for a NA motor
- all motor ls vtec header choice?
- Piston ring identification
- Cr on a ls/vtec
- b20 crank pulley which one is the best? help please
- skunk2 pro1 vs. jun3 cams
- Toda B series replica header?
- main bearing quesition
- lsvtec thread questoin
- New H22 goodies... Teaser shots
- Best high flow cat for all motor GSR
- H22A build, what should i expect?
- Stronger timing belt.
- LS/VTEC build
- H to B
- oil pan and pick up
- ITR vs. K20z3
- GSR head on a LS motor
- tip for removing and re-fitting piston pins?
- Stroker Kit With OEM Parts?...MOSTLY
- Pro 1 with stock ecu
- SHOULD I BUY
- Overheating Pissing me Off
- What Size Throttle Body for my Setup?
- LS with ITR parts question.....
- NEED HELP LOL ITB's
- ls vtec compression ratios
- H22 Cam Cap bolt quandry
- help needed! car is just dumping fuel :(
- Using 93 Accord Cap for external Coil
- snap a fuel rail stud
- Piston to wall clearances?
- b20 vtec oil catch can hose routing...need some advice
- tuning woes... wtf?
- OEM Cam Seal
- will this work for b20?
- h22 blox cam users chime in
- Clutch Engagement Problem
- Indications of head gasket failure
- when u spun rod bearing question
- what pistons is suitable for d15 block with d16z head?
- header design discussion. Cylinder pairing and tuned length
- DART talldeck build by DonF / DFE on E85?
- b20V ??
- dyno'd my first build
- poorman build
- Itb's post!
- b20 nonvtec setup, anything look like it wont work out?
- 2nd rebuilt done to the b18c motor!!! Dyno sheet inside!!!
- lsvtec dyno numbers... where is all my torque?
- LS Vtech Setup need help!
- HELP!!!! alright guys i need YOUR HELP BAD!!!! (d16z6)
- H2b distributor wiring help please!
- idle problem
- Very dissapointing h22 dyno! WTF!!!
- Blox cam gears?
- Can 410cc Injectors Support 240wh Engine?
- RMF narrow headers, which one is better
- b18 acl bearings in a b20
- Ls crank and rods in gsr block. What color bearings?
- B-Series MPG
- ls built
- Mismatched head bore to cylinder - Suggestions?
- b20v questions
- block guard
- tune?
- b18c5 getting bored
- all motor ls vtec noise???
- New engine, keeps losing alternator belts when i launch
- Phase I: Ethanol Material Testing
- Will it Blend?
- cam degree kits
- build the head or the trans?
- Have a look at this and give your opinion.
- b16 type r oil and water pump?
- 85/86/87mm bore
- my 200whp teg project
- quick question on vtec solenoid...
- Need help!
- launch control problem
- ECU Question
- B16A 92-95 (SiR-II) swap for EK!!!!!!!
- alternator help
- AN-R header vs Hytech headers
- p2v clearance please help.
- were to buy 3inch intake?
- oil light wont go off
- Can you reuse rod bolts? And has anyone ever used a Fel-Pro head gasket??
- My car dry start!Help!
- Building options
- f22b2 bottom end
- My 2.2L JDM motor has no way of checking ignition timing :( I need HELP
- Cams for b16
- cam help pls
- stage2 High CP base map
- someone explain how this happened????
- Poorman build help
- Humble Performance Built/Tuned SOHC street car - ALL-MOTOR
- Comp question regarding my GSR head
- B16B what can i do?
- B-series Gear Compatibility question
- verify timing for belt installation
- Oil light came on, Now my car runs like crap!!!
- ctr intake cam with gsr exhaust cam?
- line hone question
- Greddy SP2 piping
- sleeves
- B17a1?
- gsr build
- simple engine swap questions
- What is a Good set of header?
- ICV Help
- b17 running good but have some problems
- ODB0 ECU Starts Car with ODB1 Ignition
- Best OEM injector?
- crower 403 nonvtec's for daily..any issues especially in the winter?
- is 10.3:1 compression ok for an all motor b20zvtec
- Swap list?
- Questions on Troubleshooting CEL 1166, 1167
- H23 vtec issue!!! PLEASE HELP!!!
- ARP Head studs stripped my block?!
- ::::::::::::::What do CTR cam's look like :::::::::::::::
- any other way to tell stock valve springs apart other then color?
- Another Idle Question...... Ls vtec
- H22A rocker arm wear : Revisited
- cranking out 240-250 all motor?
- New engine build - B16B2 engine - need input on partlist
- fuel psi question
- LS Vtec Dyno
- B16a2 options for alittle more power..
- Tightening bolt bolt using stretch method
- ls/v or a poorman type-r
- stock fuel rail enough for 200whp goal?
- ...:::: What parts do i need to make B20B block reliabl ::::.....
- How much HP can you get out of an all motor b series
- good valve train to go with toda b's?
- gsr cam centerline?
- Converting Carberated engine to Fuel injected ?
- ALL Motor Question on Poorman's Type r
- RDX or TSI injectors?
- Cam gears moved on first startup ended up @ +10 deg exhaust and -10 deg Intake
- wiring harness for ls vtec?
- MY GSR, DYNO WITH GRAPHS
- Timing belt 1990 Acura Intergra.. Skips, on intake cam!!!
- Cam install with new cam seals and still have oil leak.
- injector clips
- Shortblock break-in: Rings v. Bearings
- Building up my b18c1
- ls/vtec oil line parts
- another NON-VTEC B20 Dyno results
- cleaning up head caseing and bowel chambers
- Rough Idle, Stalling when warmed up
- B20 block / B16 Head build?
- GSR question
- My gsr build
- new built motor
- Engine hesitation at WOT
- Need help for doing an all motor setup for my B16 98 Honda SiR
- Advice on my street build,b20 or gsr block?
- build a gsr with b20 crank or crvtec?
- 9:1 pistons ?? input please
- which pistons to use on my b18c1 block?
- all motor e.g wont idle. HELP!!!
- ITB's on a daily drivin car good Idea or not or can it be done and how
- ITR on b16 block
- tranny decision
- 2000 usdm stock itr tune (header and tb only)
- blox hsl cams for my build??
- All motor h22 setup with a hydro tensioner?
- Dynoing - 4th Gear Pull v. 3rd Gear Pull
- Do b16 pistons fit on ls rods?
- crank pulley...
- gsr bogging when accelerating!! help..
- tired off getting home with a headache!!! please help!!!!!!
- Buddy Club VI (6) vs Skunk2 Pro2 Stg II
- B18C1 vs B18C5 crankshaft?
- crank rotates, but binds at a certain point. Is this Normal?
- Aftermarket valve train possible problem
- toda c cam question
- 93 Octane vs. E85 Dyno Results on a Naturally Aspirated Engine
- main and rod bearing ??'s
- how much smog CO and HC will be reduced with a cat?
- adjustable cam gears for ls/vtec?
- need advice on which header to use
- H series intake manifold testing brought to you by IMPORT SPORTS
- LS/Vtec CTR Nitrous?????
- E85-fueled vehicles in competition?
- V2V
- help with recently built motor - searched
- new engine break in/ecu
- better all motor platform h22 or f20?
- LSVtec Clearance Issues?
- h22/n20 12.0:1cr pump or e85
- Post all 300 WHP(NA) and above Builders and Specs
- noob ? about muffler shops...installing cat/resonator/test pipe
- b20vtec build ... what kind of internals should I use ?
- 84mm sleeved ls/vtec..which crank to use??help!
- gsr (tdc)
- OBD0 VTEC Solenoid BEST? spool quicker ????????????
- In need of help from your group with my 2.1l gsr setup!!!
- Rebuilding b20vtec after harsh driving how many miles
- NEED HELP AND SUGGESTIONS LS/VTEC
- Best OEM Vtec Cam Setup?
- Throttle body
- Cams for my N/A setup: H22A7 Accord Type-R
- need some advice on engine setup
- what kind of rings do not need shaving?
- d15z1 head on d16z6 block help
- options for tuning after a fresh re-build?
- Slick Size questions
- Locking vtec for cam degree??
- b17a1 block with b18c1 head?
- JDM b16a rpm dropping to zero while driving.
- Skunk2 Pro 1 cams (b-series) "other recommended camshaft specifications" at what lift?
- b16 for $200
- b16 build
- How to block off/route heater hose lines for a drag car? (no heater) have pic.
- ls/vtec using B16/GSR head gasket.
- Cam sugestions for daily driver LSVtec
- Thrust Washers...
- Intake Manifold
- for some other reason i still got a leak problem?
- rocket motorsports valvesprings - are these good enough for pro2's / pro3's?
- d series quad throttle body carby carbies how to do?
- Type R internals?
- do underdrive pulleys help?
- all motor h22 eg need help, and i searched
- DA integra b18a
- quick valvtrain ?
- piston ring installation
- S2000 Issues - Need help! Misfire codes
- rs*r exmag I & II question
- AFR is a bit lean
- Best cam for my 1.8L setup 11.8 c/r setup.
- Acheive more low end power B18c
- Exhaust guidance needed.
- Halfshaft from cable b16 tranny to hydro b16 tranny
