ej_jake's quest to create a H2B/H22A4 build for a street/strip purpose
Hey guys I'm looking into building my h22a4 h2b da9. I'e looking into good way to build the head on the a4 and seem to have a good set up for it right now. I' just looking to see if anyone has a better set up? Wanting to go street/drag car. I'e looked into pro 1 cams skunk2 intake and throttle body and skunk 2 retainers. Anyone have a good set up besides this one? Mainly looking into all motor builds.
re: ej_jake's quest to create a H2B/H22A4 build for a street/strip purpose
Pro1 cams work well. Valve springs and retainers.
I'd recommend a gutted and ported stock intake manifold and a 70mm throttle body.
Are you wanting to run the stock bottom end and head ports?
youre on the right track. guys have gone 10s on stock block h2b setups. pro 1 or 2s with porting and a good intake/throttle body would work well together. you will need to upgrade valve springs (at a minimum) to use cams that big. I recommend contacting 4 piston cylinder heads and just getting a complete head package.
even if you buy a head package from 4p you will still have to bolt in the cams and degree it yourself. they would only be assembling the valves/springs/retainers/etc. or you could just pay them for porting and buy the rest of the stuff on your own, either way, cant go wrong with their heads.
Pro H22 CNC Head | 4 Piston Racing
Pro H22 CNC Head 4 Piston Racing
I did a h2b a few years back, use OE type s pistons and a single layer head gasket comes out to like 11.2 to 1. I ran a crower cam with springs and retainers all crower. I prefer tool steel retainers to anything else for the street. Eliminate the balance shafts, KS has a kit- i did mine with a tap and plugs as the engine was out. Ported (gutted) stock intake with a bigger throttle body- don't recall size.
Head was also ported and I ran a tri-Y stepped header. My clutch was a big puc style, which sucked for the street. Tranny was a 98 ITR with OEM LSD. Konig feathers and some sticky tires.
Fun car, but was a terrible daily. rattled like crazy but never lost a race. never tracked it but it was quick.
Re: ej_jake's quest to create a H2B/H22A4 build for a street/strip purpose
Pro1 cams are super small, too small for a 35mm valve and bigger than 89mm stroke H series. Start with pro2 cams for stock block. I dont have much experience on H series but from what i've been seeing from friends/associates is that those ported manifolds do work on those H series. If you know what you want for camshaft duration and depending on your budget, you could also go custom camshafts.
For those people running 10s what kinda fuel were they running? Do they have bigger injectors? For the pro 2 cams would it be best to run a bigger injector and better fuel rail and bigger fuel pump. Itd be best with a tune but what other mods would anything fuel wise be necessary?
the stock block guys running 10's (high 10's) have very fancy cylinder heads and induction to be honest. it would require alot of money to get into the 10's. if money isnt a big deal you would need a ported head, pro 3 cams or similar, kinsler itbs, a nice race header and methanol (m1, m5, ftw black.) methanol has huge fuel requirements so most all motor guys are using around 1300cc injectors with methanol compatible fuel systems which can cost upward of $1500.
yeah I sorta figured it be something like that. I was just curious. I may go with the pro 2 cams and skunk intake with 70mm throttle body port the head and tune. Be a good idea to go ahead and re ring it too probably since I would wanna rev it pretty high. Any one have dyno sheets of a setup similar to This? Would love to see power and torque gains even if it' just a little. Right now stock I'm putting 171 wheel and 145 torque. Really wanting at least 220 or so if possible from that setup
I predict with worked IM(intake manifold) and good header, e85, B series trans, e85 and pro 2 cams you should see over 220 even on stock block. Pro 2 measure out to be about 260/266 duration at .050 but these cams were designed for B series using 33mm intake valves. I dont see why with more stroke and slightly better flowing head with bigger valves why a 260/266 cam on stock compression wouldnt warrant good power when I had a friend make over 200 on stock b18c type r block with pro2 cams. Those worked IMs seem to be the ticket with H series engines even on stock cams.
for a street engine pro 2s are pretty good. big enough to make power, not so big that it isnt streetable. with good supporting bolt ons and head work, 220 shouldnt be difficult at all. if you look in the hybrid forum theres a sticky at the top labeled h2b/f2b faq. theres lots of dynos and info in there. i think there is actually a separate h22 dyno thread as well. search google instead of the HT search function.
edit: i think you could still clear 220whp with 93 octane. e85 would just be a nice 3-5% bonus.
e85 can be beneficial with any compression ratio. with higher compression you stand to benefit more because of how much timing you can run. ideally you should replace the whole fuel system (pump, lines, filter, injectors) but there are guys that run e85 with stock fuel lines. with e85 you wouldnt need the same size injectors as you would for methanol. you could get away with 750-1000cc. ethanol compatible pumps arent too expensive either. if i lived where e85 was plentiful i would definitely have my car tuned with a flex fuel system. its race gas for $2/gal and you can get it at the gas station. doesnt get much better for a street car (unless you live where its super cold.)
Unless the engine you have is burning oil, I would not re-ring it. H22s have FRM sleeves. It isn't as simple as just honing the cylinders like it is with other Honda engines that have iron/steel sleeves. Some shops do not have the equipment to work on FRM sleeves and the ones that do charge A LOT to do it.
pro2s can make power to 9k but valvetrain is what allows you to rev that high. Choose quality springs etc. You can use any brand but it's hard to go wrong with ferrea dual springs & 6000s in my opinion.
the bolt ons you choose are just as important in making power that high up. A stock h22 intake won't support power that high up. Port the oem one and remove the IABs, get a skunk 2, or use a k series adapter and use an RBC.
^^ Excellent advice here. the ported manifolds seem to unlock performance in h series engines. I think RBC will work too seeing a ported one on a k24a2 with regrind oem cams supported 272 on a friends 87.5mm setup with low cylinder compression lol. The RBC was ported though.
BTW when i used e85 i used oem fuel lines just whatever else is needed for the car to run on e85. But on 93 octane pro 2s and h22 should do well.
