JDM H23a Vtec /USDM F20b cams
Whats up HT? Working on my H2B del Sol build, and came across a good deal on a set of cams from a 92 USDM manual prelude with an F20B. The motor going into the sol is an JDM 01 H23A Vtec blue top stamped PDE HF-1. Wondering if its worth the time and effort to put these cams into the H23?? Going to be a mild all motor build (Ported stock intake, 70mm tb, KS balance shaft delete, HiEnd Tri Y, 3'' catless exhaust, rc 440 injectors, tuned on s300 mated to a b16 tranny) I know the valve reliefs are shallow on the H23's piston, but cant find a clear cut answer if the F20b cams would be a worthwhile upgrade from the stock h23 ones. Just dont wanna miss out on a good deal.. Any input is appreciated Thanks!!
Re: JDM H23a Vtec /USDM F20b cams
If the F20B long block is from an automatic, the cams will not be of any help. However, I believe the manual F20B cams are the same as H22A type S. You could Mic these and compare to online Type S findings. Also, if the F20B in the prelude is still using the stock TB, the following would determine if the long block is from an automatic:
The F20B automatic TB was smaller than the manual version. I want to say the manual TB is 62mm. Futhermore, the auto throttle rotor should have a place for a kickdown cable for the auto trans.
If you determine you have the manual F20B, that's for sure an upgrade. The cams will work fine with H23 blue top pistons.
90% of the F20Bs that get sent to USA are Automatics. So watch out. As stated TB larger on the Manuals and Have Type S/EuroR Cams and Valve Springs. All Retainers are same on the H/F20Bs. You can also Mic/Measure the Vtec Lobe of the camshaft to tell if Manual. Now if you have a F20B Auto and H23Vtec Blue Top which only comes Auto. They share the same Intake and Exhaust Camshaft Part #s.
JinMTVT
09-12-2001 09:50 PM
