help with build b18b1 with b16 pistons
Old 04-16-2018, 08:53 AM
JDMDC41996's Avatar
Default help with build b18b1 with b16 pistons
I want to do a b18b1 with b16 pistons and a ls head what do I need to do in order to build it right and not have it blow on me? what baseman can I run ?
Old 04-16-2018, 07:15 PM
Moderator
TheShodan's Avatar
Default Re: help with build b18b1 with b16 pistons
No basemap. Use zeal calculator with your measurements (most are pre-selectable), and calculate it out. Make sure you adjust for head milling & block decking.
Old 04-23-2018, 09:41 AM
JDMDC41996's Avatar
do you know if I will need a b16 crank pulley ?
Old 04-23-2018, 10:05 AM
Moderator
TheShodan's Avatar
Your crank pulley from your LS is perfectly fine. Has nothing to do with the pistons you're using.
Old 04-27-2018, 08:16 AM
JDMDC41996's Avatar
and what octane gas will I have to use ?
Old 04-27-2018, 09:44 AM
Moderator
TheShodan's Avatar
Always use the best fuel in your area from the pump, be it 91-93octane. Even compressions of 12.0:1 have been done on 93octane fuel without issue. But that depends upon your tuner's abilities in addition to your own mechanical inclination and machining. Go through that Zealautowoks calculator and plug in values to find out what your " 'round about" static compression you'll be.
If you're thinking you can run on "cheap" 87 octane fuel for any of this, please stop now, and just run the car stock.
spens 91 Ef
25
01-29-2017 09:14 PM
adam00
02-12-2009 04:57 PM
CO_CReX
04-26-2006 11:03 PM
xDicktonesx
05-25-2005 12:31 PM
zCivic
11-13-2002 05:37 AM
Quick Reply: help with build b18b1 with b16 pistons
