Best upgrade for hp on b18c-R? Street car
Im still kinda newbie sorry my first b series engine
JDM b18c type R 98+spec
Head
brian crower valve springs and ti. retainers (BC0020)
ferrea flat valves
the rest stock
Block
Stock block
stock IM,headers
gonna tune it very soon..
My goal is 220whp still with a/c and power steering for street daily drive (i use it like once or twice a week)
i want to upgrade my cams to skunk2 pro2+, but can it run on a stock block?
And what could be my next upgrade that can reach my hp goal? That not really cost that much? Thanks
Head
ferrea flat valves
the rest stock
Block
Stock block
stock IM,headers
Last edited by stephendizon1; 11-02-2017 at 02:57 AM. Reason: Forgot some other parts
Re: Best upgrade for hp on b18c-R? Street car
Head
ferrea flat valves
the rest stock
Block
Stock block
stock IM,headers
Head
ferrea flat valves
the rest stock
Block
Stock block
stock IM,headers
Anything other than Skunk2 tuner stage 1 will be too much for stock compression. From what i have read that is. You need upwards of 12:1 compression to make good use of stage 2 or higher cams. Also need upgraded valvetrain whcih you already have. I suggest getting some beefier rods since thats the weakest link on the motor. Also tuning. Will for sure need a tune if you get more agressive cams. And i believe bigger injectors, i couls be mistaken, im going strictly off memory here lol. But there is tons of info on this
Btw, keep in mine, the Skunk2 tuner stage 2 and Skunk2 pro stage 2 are two diferent cams with diferent lifts and duration. Go to their website and see what the specs are. The Tuner Stage 1 are more agressive than the Type R cams and with a tune should yield youore power, but nothing crazy.
there's no real consensus on what cam selection is best for stock b18c blocks seeing that a stage 2 can be anywhere from 252 duration to 266 and usually those advertised that high are at 1mm not at the .050 mark. a friend of mine made over 205 on stock type r block and head with pro 2 cams and pro 2 cams when degreed were 260/266 which is smaller than what Jun 3 is advertised as well as skunk tuner 2(which are smaller than 266 at .050).
Stock rods are just fine, rod bolts are the weak spot....the R rods/bolts will handle what you can throw at it though if you don't want to upgrade to ARP (cheap insurance)
Upgrade to a set of RDX injectors which will give you better power out of the box and better efficiency as well.
Is toda cams good for this build? Because im going to japan i might order, toda or jun? And what specific model thankssssss <3
You're gonna spend some money with TODA cams, valvetrain, timing belt, etc. I mean if it were me, i'd go elsewhere(secret lol). But hey if you dont mind, go ahead.
Moderator
I've gone through that discussion on my setup from over 6 years ago, and in the end, the determining factor for/against using them was Purpose Of Use. From a "peak power" point of view, yes, there are other options, but for Purpose of Use for Circuit/street, Toda Racing works great even with their age. An M14 Rifle may be older, and there are other options in weapons out there, but you still have soldiers in special operations today, who will still use a 50 year old designed M14... because it just works..
Well I didnt mean that TODA stuff doesnt work, just that its expensive. He could just buy pro2 cams and skunk2 valvetrain for cheaper unless he just wants TODA stuff for quality reasons.
hondaman177
10-18-2017 05:26 PM
Gsrmemo
11
11-04-2015 08:53 PM
Y2K Si FBP
51
10-11-2004 07:48 AM
