Suggestions on EMS Options for an E85 All Motor Project
Hey guys, so im really confused on what ecu to have for mu all motor e85 setup. Right now i have a gsr block with stock rods and ctr cone pistons with a b16 head with skunk2 dual valve springs and titanium retainers, i have blox type b cams and skunk2 ultra street intake manifold along with a 70mm throttle body. I wanted to go e85 so i bougnt 750cc rc injectors with aem fuel rail and pressure regulator. I also have a 255 fuel pump but i got a blox 300 e85 fuel pump but i was wondering if i can still use my chipped p28 with this setup without having problems on the dyno. Any advice to make this setup more safe??
re: Suggestions on EMS Options for an E85 All Motor Project
[QUOTE=Lau Cac Bo;51234992]E85 will eat stock fuel lines. Replace them all. From pump to rail.[/
my bad i meant without hondata
you can still utilize the chipped p28. I'd return the 750 injectors and get 1000+ ID injectors.
You can use any e85 compatible aftermarket fuel lines. better safe then sorry. car fires are no joke!
Moderator
750cc for NA is plenty. No need for 1000cc on an NA Car for that power level
Only if you have the hardware to change the tune of the chip that is already burned into it. Otherwise, you must retune in some way or form completely. Which means hondata. E85 doesn't have the same BTUs as race fuel and won't account for your larger injectors. therefore you must retune completely.
Engine management is the MOST IMPORTANT part of a custom build... it exists to synergize all components that you have brought together. You likely have made a substantial investment in the parts inside your engine... why place these parts at risk by using an online freeware program to "chip" your existing ECU ??? Hondata s300v3 is affordable... get one and do it right. As for the s300v1... ALL of those should be upgraded to a v3 before the internal battery fails and the system is rendered useless... so unless you get it from your friend for FREE, don't bother.
Have to use S300 V3 with GM flex fuel sensor as well as mentioned fuel lines. Im looking into using AEM infinity EMS instead of S300 V3
Brian_92GSR
10-25-2001 11:27 AM
