SavageEm1's B16 block rebuild progress thread
Just had the head rebuilt at the machine shop for my em1 to factory spec, then a week later I go to put it on and on the way home I spun a bearing so I'm rebuilding the block too. Woohoo. Looking to get a bit more power out of it now. May as well since I'm in there.
Looking to get about 180-200 (if possible) horsepower out of it at the end of the rebuild. It's totally factory currently, not even lowered or exhaust. It's my daily driver. Just not quite fast enough for my liking I intend on keeping it N/A. I plan on rebuilding my b16a head I got laying around once I figure out everyrhing else. This is my first rebuild and here are the parts I'm planning on using.
Cylinder hone
line honed/bored
decked
crank micropolish/balanced
cleaned obviously
Nippon ctr high comp pistons
hastings piston rings
oem rods
acl race bearings (rod and crank)
oem head gasket
oem head bolts
Does this seem to be a solid set up for the block? Anything else I need to swap out or have checked? Any parts I should replace? Got a spare b16a head I'm also going to rebuild later on once I know the block is good. I've never rebuilt an engine so I'm just making sure everything is done correctly Any help would be appreciated. Thank you
Cylinder hone
line honed/bored
decked
cleaned obviously
oem rods
oem head gasket
oem head bolts
I like the tuna here
re: SavageEm1's B16 block rebuild progress thread
ARP head studs may not be required for your build but they are cheap insurance, along with ARP rod bolts. Other than that it looks pretty solid, I used the Nippon USDM ITR pistons, Hastings rings, and ACL race bearings rod and crank in my LS-VTEC and it's still going strong with zero issues.
You'll probably want to upgrade cams to reach your HP goal, if I'm not mistaken you can use CTR cams on the stock B16 valvetrain, but you may want to confirm that with someone more knowledgeable than I.
I'd personally put in the extra work and few hundred dollars to put the pistons and different rods into a B20 block, and do a B20V setup, but I'm sure there's a lot of variables you're considering for your own car. The extra torque down low for a daily driver would make it a lot more enjoyable.
180->200WHP for a B16 is no joke. You'd need full bolt ons and probably at least CTR cams, or a set from Skunk2/Crower/Buddy Club or whatever.
Unless you meant 180->200 to the crankshaft, which could probably be accomplished with some pretty mild upgrades.
ctr cams you'd have to be running ctr springs and retainers. I'm gonna go with s2s2 and supertech springs/retainers
Re: SavageEm1's B16 block rebuild progress thread
I'm going with s2s2 cams, supertech valves/springs/retainers, custom 2.5in exhaust, edelbrock intake manifold with a 70mm throttle body. I'm just not quite sure what to use as far as injectors go or a header. But I feel like I'll be pretty close to my goal. This is my first rebuild so honestly as long as it runs good I'm gonna be psyched haha. I'm skeptical on the b20vs I've seen a few people I know destroy them. Then again they're reving it up to 8200 with no mods to the b20 block. Lol
