B16a won't start when its warmed up *SOLVED bad starter solenoid*
Old 06-17-2018, 03:10 PM
AnonymousHatch's Avatar
Default B16a won't start when its warmed up *SOLVED bad starter solenoid*
Just started my car after not driving it for a while and it started up right away all the relays clicked fuel pump primed everything sounded good. Then drove it for 10 to 15 min then parked it tried to start it again and it didn't start. Double Checked main relay in my buddy's car with the same setup and works fine started his car. It seems like when the engine warms up its doesn't want tostart.
AnonymousHatch is offline
Old 06-17-2018, 04:12 PM
Audripulls's Avatar
Default re: B16a won't start when its warmed up *SOLVED bad starter solenoid*
Does it click when you try and start it?
Audripulls is offline
Old 06-17-2018, 06:14 PM
No it's just silent when I fully turn the key to start
Old 06-17-2018, 06:34 PM
Audripulls's Avatar
Well if it's not the main relay, check for good connections at the starter, I've had some vehicles when the car ran after a while and we're shut off, would not start. Turned out to be a starter problem. I don't wanna confirm a starter. Usually when it's something like this I've had main relays that were bad.
Old 06-17-2018, 08:42 PM
JRCivic1's Avatar
OP, you didn't state the chassis year, model and trim level... but if it happens to be an EK... or even an EG... the next most likely power distribution besides the main relay is the electronic key switch. It is not uncommon for heat to affect the solder joints in these switches... when failing, they tend to work better when cold and worse once warm.
JRCivic1 is offline
Old 06-17-2018, 10:33 PM
I found out the problem guys its was a bad starter soileniod got a new one and it starts everytime no problem. drove it for and 1 hour and it started right back up again no issues
91tegrals
02-12-2012 09:03 PM
JDM_d15b_eg8
10-11-2007 03:55 PM
ef9_pr0jekt
10-07-2007 06:15 PM
progress
28
01-15-2007 10:42 AM
Sexy_Chantal
10-28-2004 04:18 PM
Quick Reply: B16a won't start when its warmed up *SOLVED bad starter solenoid*
