View Full Version : Hybrid / Engine Swaps
- Aftermarket pistons in stock h22 sleeves
- Project J.R.S.C rwd b18c5 Del Sol
- B series or H series on h2b
- The turbo diesel D series build...
- jdm D15 B vtec
- couple h22 questions..
- G23 Turbo???
- Experts: What's this green/white wire for?
- D16z6 Block, D16y8 Head + Dizzy, S300, Obd1 harness - Crank position sensor CEL
- ITR swap into 94 integra ls ?'s
- H2BJON's Spoon Inspired A/M Street Eg (Build Thread)
- Gsr into ek wire harness
- GSR supercharged to CRX si swap can it be done
- Smarter to go boosted B16 or boosted ZC.....
- Need a picture of how to route crankshaft speed fluctuation sensor wire
- LS VTEC Crank Pulley?
- H23a V-tec Blue top cam question
- D-series Zc intedmediate shaft adapter
- Motor ran fine, but now wont start up with map sensor pluged in
- p73A0 pistons into LSvtec question
- needed mini me advice! y7/d15b
- K20 Motor Swap: Immobiolizer necessary?
- f20b block took a crap on me thinkingof the g23????
- Bisimoto F20B Piston and Rod Group buy!!
- b16 head b17 block head studs?
- FD2 cam performance vs EP3 cams???
- Need some help on new build
- hcp h22 eg questions
- ek h22 turbo manifold thats ac and ps friendly?
- sleeper h22 ek
- Performance Rods For Ls/Vtec
- Type r Throttle body on gsr ek
- Another Slow H2B Build
- BrownKid Avid Racing H2B 67mm Build
- Will ep3 oem axles work on k20a ???
- What o2 to use?
- Parts list for b18 into del sol
- Fuel Line Fittings For H22 swapped EG??
- F20b integra help!!
- LS/Vtec Idle Bombing and Surging
- Full hydro conv in a da
- Da j swap
- H22 timing belt slideee!
- EGR block off plate upgrade?
- D15Z6 to K20A - EK3 EUDM swap
- Poor Man's Type-R CRX won't idle.
- K-series Alternator on a B-series Possible?
- LS/Vtec Breather Box help
- hybrid racing shifter box and cables onto a h22a
- M2B4 synchros grinding
- EG H2B build
- Mixing Valvetrain components... Intelligent discussion only
- b16 motor build HELP!!
- obd2 b16 in my obd1 da?????????
- 98 dc b18b1 swap into 95 eg harness and ecu question
- F20B Rod bolts
- how do i adjust timing on h2b
- h2b gsr tranny??
- CTR 5 Lug
- ef zc swap into eg race car
- H22 swap in delsol SHAKING BAD ! helpppp
- my skunk2 cams ok or no good???
- H22 wont run after obd2 to obd1 swap
- b20 vtec oil streaming out
- F22b1,b2,f23 Block/G23 Questions
- k24 into dc swap coolant temp sensor??
- B18b swap - OBD1 issue
- F20b into Civic
- D series vss on h series trans
- B20b in 95 Civic, axle keeps breaking
- evo h2b kit mounts
- k20a3 with k20a internals and head?
- Evo h2b plate and hasport mounts?
- h22a4 swap
- obd2 to obd1 external coil wiring h22
- JDM B18C into 96 EK P73 o2 wiring, code 41
- B18C1 has no power aftr 3500 rpms
- OBD0 to OBD1 d16z6 swap,,, I need help:(
- bar question
- K-Swap DC2 - No Power to ECU / Ignition Help
- B18 ls swap questions.
- low idle cold start high idle when warm
- same bolt size?
- Car won' start, main relay OK, blown ECU?
- How can i make my d16y8 faster
- F22 cam gear specs?
- F20b Build NA
- lsd in b17 tranny?
- hat to look for buying H22a eg coupe
- should i stay poorman's or go b20vtec for more power?
- just another h2b
- b18b1 struggle after high rpms
- B18b into 00 civic si ecu immoilizer
- h2b need help asap
- F22 swap. 1 question please look
- f20head f22b block
- Main cap bolts
- ricertek's F2B EJ Thread.
- 91 civic si w/b16a2..will NOT pass emissions, i need help-->LONG Story...
- Ka24de in a civic?
- G22 Headgasket??
- H22a Swap - Stuck on Wiring, Mounts, Shifter
- Trouble with h22 idle and code 16
- 97 Ex harness for 2000 B18C1? Need a clear answer please!
- b18c swap into 91 prelude
- 92-95 H22A in 96 Accord LX Issues, mostly idle
- Favorite Body to K Swap
- dpfi-2-mpfi 2-step @2k rpms: (searched)
- Gsr turbo?
- Anyone in IL Hone H22A FRM blocks?
- B18C swap into EJ6 sedan
- f2b FTW crx
- em1 engine swap begins this week
- Micro Polish Crank?
- whats the fastest anyone has seen a N/a Integra 4 door go?
- Evolution Industries B2D kit? anyone?
- Gathering more info about H22 to EK
- Q? H22a4 to obd1 for crx
- Engine Swap?
- Help on my Kswap es1
- B18c into EJ6 issues. identify these sensors!
- h22 supercharger?
- Accord swap question
- got a k20 swapped but no spark? no.1 coil pack gets super hot??...chances are...
- h22a ek swap help
- h22a ek swap help
- CRX S2K cluster swap - VSS wiring problem
- opinions on BBK H22A intake manifold
- Anyone know which clutch and slave cylinder?
- H22 Skunk 2 mani and throttle body problems
- H22A Del sol Help on axle noice. Brand NEW!
- HELP: 1995 civic with h2b swap
- ls swap BIG PROLEMS
- 93 Civic With F22B1 wont turn over PLEASE help!
- b18 swap problem
- 1999 Acura El H2D .... HELP
- Weird JDM H22A Problems...
- b series into 92-95 civic mounts and brackets???
- obx itb's ej1 h22a swap???
- h2b header? all discontinued?
- h22 help!!!
- complete swap
- B16a engine with b18c type-r 96 head Which ARP head studs do i need?
- Awd eg civic Question
- H22 in a 97 ej6,couple cels and bypass issue
- LSvtec wiring dilemma
- z6 block with b7 head
- f20b f2b em1 few questions
- Injector Help?
- h2b question
- 92 prelude motor swap
- Need to find a K-Pro and ECU for a good price...Where?
- Is a K20R swap into a 94 Integra a good daily driver?
- h22 h2b iacv hose question
- New distributor info for LS/B20 swap into '99 - '00 Civics
- A few questions
- H22 OBD2a Wiring - ECU - Random Questions
- LsV head removal
- h2b probs
- h22>eg reverse light sensor question?
- stroker kit
- Best Place To Plumb In Oil Press. Sensor?
- question regarding hydraulic clutch in GS-R transmission
- H22 issues
- VSS Problem
- Ls Vtec help
- h22 delsol running like hell
- H2B EJ1 all motor/nitrous build
- Clearance issues. F20B Swap
- K Series in EG R Crew Harness Instructions Needed
- B20vtec in eg questions
- s2000 FWD?
- 97 EK with JR supercharger will it fit?
- QSD H2B Halfshaft Issues, Not Fitting!!! -_-
- eg-h22 am i able to keep cruise control?
- oil pan gasket help for h2b
- are there any f22 swapped del sols?
- H2B crx...cooling problems!
- B18b into 2000 hatch - Not running right! PLEASE help! WATCH VIDEO
- 1992 F20b Honda Hatchback Won't start?
- My H2B w/ Pro2s Dyno Tuned 249hp 182 TQ
- Kaizenspeed H2B oil pan pre-pay list
- h22a1 engine and harness into a 5th generation Civic?
- PR3 pistons and rods in a B18B1
- KS Balance Shaft plate question
- hey, i need some help
- obd2a to obd1 evap swap?
- Swapping OBD 1 Non Vtec Distributor internals into OBD 2 Vtec Housing....
- 98 civic/ H22a, egr code,low power, need advice
- h22 ek swap, ecu issues
- Honda Legend Diesel swap!
- b17 crank in gsr?
- Throttle Cable H2B
- D16A6 help
- B20b swap in 95 hatch
- h22a in delsol wiring help for egr
- H22 Crank Pulley
- h2b build advice
- poor mans type r pass smog?
- Aftermarket cams with stock h22 block
- Let me no what u think.First Honda build (h2b)
- h2b obd2a dizzy question
- F22 head on B20B block? Possible?
- b16a2 swap in ek hatch. temp gauge doesnt work?
- Plizz help with f20b swap
- KS balance shaft elimantor kit question
- H2B and hood clearance in EG with QSD kit
- Which lower radiator hose to use?
- H2B EK Headers,what do you have?
- obd0 ls dizzy on obd0 b16 head ok?
- QSD H2B bracket question
- please help!!! rebuilt ls/vtec oil light flashing. oil pressure at 4psi
- Stroking my h22
- EK H22A swap Fair Market Value
- 96 civic obd1 b16a sputters
- Shifter cables??
- OBD2a to OBD1 electrical issue
- Resistor Box ??
- Lookin to boar and stroke
- H22/F22 Single Crank Pulley Question
- EF swap wireing
- My stock H2B Dyno tuned
- RWD/AWD 96 4dr accord
- Trouble with h22 swap
- Contacting Qsd?
- k23a exhaust manifold
- F22B in Civic Eg/EJ wiring question.
- primary o2 sensor question for dc2 swap???
- 98 GSR SWAP???
- d16z6 mini me crx wiring
- D16y8 in place of d16z6
- h22 in an ek
- five lug with k series swap
- f2b question
- Euro R conversion
- PLIZZZ HELP MY SWAP WONT START!!!!
- Innovative Mounts FAILURE
- F vs H blocks for build?
- B17 oil pump question
- tighter C.A.R.B. rule rumor ?
- H22 swap, heavy vibration, wobble
- J32A2 vs J32A3 ECU question
- Milling H22A4 pistons for F23A?
- O2 Trouble
- p75 head with 33mm valves?
- swap D16 to k20
- eagle rods or shot peen stocks? help
- torque the head
- H22 in 2000 civic shell
- intake manifold vacuum line question
