View Full Version : Hybrid / Engine Swaps
- what intake manifold is this
- h2b eg 4dr y0
- Question Relating B18C/CRX Swap With "L" Rear Bracket
- quick h22 civic quesion?
- AEM Cam Gear (Did Search and found nothing)
- h22 in eg issue please help!
- b18a into eg
- code 16 after engine install
- h22a tranny into accord
- H22 Suspension, lets drop the myth of weight
- NEED HELP...PLEASE!!
- skunk2 intake manifold injectors not fitting -- Help Please
- Dropping motor, motor wont line up!
- G21 engine build
- B16 vs H22
- need gsr secondary diagram
- help: 5 lug on a 1996 accord wagon ex
- please HELP SPEEDODOMETER not working no check engine light CIVIC
- H22 rywire????'s
- Wiring...
- getting opinions : has anyone bored a sleeved 1.8 b18b to 86mm/2.1L?
- OBD2 Ecu in OBD1 chassis
- OBD1-OBD2 wiring questions (for CA referee)
- H23 questions
- quick help guys... H22 in civic, axles?
- my H2B del sol... build..
- ***OBD1 B-18 in 96 OBD2 Civic*********
- clicky main relay on a 99 ek hel plz
- H22 Idle problem...
- b16 intake mani question----PLEASE HELP!!
- Motor mounts
- K20 swap...fuel pump priming issues?
- B16 and B18 seals
- obd1 gsr swap
- B16B swap into an 93 civic wiring
- H22a tranny questions, concerns, need advise M2b4 - M2L5
- HELP QUICK!! INNOVATIVE MOUNTS REAR TRANNY BOLT SIZE!!
- SR20 CIVIC?
- something a bit new....Fnonvtec-Dtrans/EF chassis...my ongoing build
- B16A3 with type-r internals question.
- will a d15b7 intake manifold fit on a jdm d15b head?
- LS motor in a GSR body....
- Dropping motor from the bottom, 96-00 EK stock motor-help quickkk
- b18a swap in my 95 civic
- H22 eg swap external dizzy wiring
- Exhaust Options?
- Swap Won't Start?
- Anyone using H22 Innovative Mounts for EK Civic? How is it?
- Quick questions about GSR swap
- Stock H22A4 or Built D16Y8? Need you inputs!
- Please help me confirm this.
- 98+ ITR motor into 94 GSR question
- p8r head on ls?
- distributor wire color got a question
- s2000 F20C into a EK hatch, anyone else done it
- Looking for Axles!
- GSR oil/water pump identification. Need a little help
- New Motor Mounts?
- H22 Type S swap into 98 DX
- ITR swap into EG
- PIC request - HCP AC compressor bracket for H22a into DC-EG
- auto ls into 93 auto eg...what axles??
- B18c GSR into a EG HELP!!!
- h2b turbo done EGK!!
- mounts needed for b into eg & auto to manual
- H22a into a 94 Integra LS - Just a few questions - Need clarification
- obd2 wireing harness with a obd1 jumper harndess and motor what dizzy do i use
- DC2, f22 block, H series head, LSD h22 tranny, boost
- obd2 gsr engine into 94 civic vtec IAB wiring help (butterflies)
- Prelude with V6
- help :(!!! need wiring information
- anyone used jpr motorsports in la
- JDM b16 & USDM B16a sensors
- axle problem!!!!!this is aggrivating
- What Pullys and belts with a b20??
- OBD2 H22 in a EK Civic? What's this immobilizer about? Any way around it?
- Is there a difference in auto and manual b series rear mount bracket?
- EK Civic H22 axles with Innovative Mounts?
- Whats a PR3-1?
- B18C + EF Wiring harness adapter (Help needed!)
- obd2 - obd1 confusion..searched, its not a problem.. just weird..??
- b18b1 in 92-95 civic OBD issue
- engine runs rough and back fires ( read for full scoop)
- axles for h22 swap in 94 teg ls
- EG Motor swap to LS-VTEC
- 93dx automatic getting ls ob2 manual swap-i need help bad
- b18b swap into 95 dx?
- Spoon Valve Cover with Motul Stamp [picture request]
- Please post all del sol/K-swaps
- Quick question...
- What ecu should i use to run my ITR motor p28?? or a p72??
- GSR Swap in 98 Civic
- LSvtec into 96 EK hatch
- 96' JDM H22 stock ecu vs p28
- Hasport Press release New Product for K-series...
- smog help please
- OBD2B CAR WITH OBD1 ECU what codes ?
- Weird VTEC problem
- please help me! swapped b18c !!
- s2000 Cluster in My Ek
- eg hatch k20
- h22a4 into ej questions
- EG + K20 = what exhaust?
- Had a question about rpm on an LS motor
- NO VTEC
- scan codes from a LS swaped 96 civic.
- CAn someone plz help me ??????
- integra
- H22 in EG , help to wiring
- Just Swapped In a B17 and Having Idle Issues---PLEASE HELP
- Fuel fouling
- ECU for B20b swap?
- 92-96 h22 with 97 up hydro tranny?
- question
- jdm b18c smog/butterfly
- B16A ECU/Wiring issues
- Power Steering bracket/mount top and bottom for LS/VTEC
- wire harness for jdm H22A into eg
- H22 Swap..... A\C???
- 92-95 Civic firewall *PIC* - What can be removed for K20a2 swap?
- built b18b wont start need help!!!!!
- tw - boosted blockfilled b20-vtec turbo
- hey need some help asap!!!!
- NEW SWAP IN MY 93 SI AND I AM HAVING O2 SENOR PROBLEMS... HELP!!!
- Hasport Performance logo contest! Hasport mounts prize!!
- swaping h22 p/s and a/c
- will paypal 20$'s who can help me with my problem (99 ek owners )
- B18C5 / ITR motor in an EK...throttle cable?
- Heads almost off...
- 1.7 sohc crank
- IACV re wire ls motor in 96 civic LX - idle issue
- Type R brakes on a 91 Civic Si
- f20b w/h-series mount?
- OBD I Wiring problem plz help
- b18c-r swap
- H23 Vtec questions
- Help me identify this ECU! Please!
- Whose all NOT running front torque mounts?
- How do ypu adapt a b18c5 0db2 distriibuter tp 97 rk harness?
- 99 Acura Cl H22 swap Question!!!!!
- b18c ecu question
- Ls/vtec-knock sensor-where'd you put yours?
- 2000 obd2 B16 into obd1 chassis
- Need a k20
- obd-0 ecu
- B18a1 help!! *VIDEO*
- what ps bracket to use?..
- What do you think this is worth
- Valve Cover? D15B7 -> D16Z6
- what dizzy?
- burning a quart in 30 miles....
- Official (sort of) All Motor B20/Vtec Thread
- eg k20 swap into EK?????
- My b18b swap. I need some help.
- how hard is to find a 5 lug itr rear trailing arms ?
- axles binding after Hasport mount install h22 into ek hatch
- Universal 4 wires bosch o2 sensor for obd1
- D16Z6 swap question
- gsr swap help
- F2D / H2D F20B swap build thread for my 94 hatch (now H23VTEC)
- B20 in 1st gen teg.
- LsVtec ?
- b18c1 h beam eagle rods in lsvtec?
- Is a pr3-3 a type r head???
- need help asap
- obd2 b20 in a g2 integra
- gsr swap question
- h22a into a 94 integra gsr...
- Does anyone have info on swapping a cl-s v6 into a prelude??
- opinions on RDX guts into an ek??
- obd2b-obd2a?? HELLLLPPPPPP!!!!
- HELP WITH SWAP... GSR B18C1....
- are ls plug wires sufficient for a b16?
- b16 swap vtec problems are stressing me
- Traction Bars in EG with K-series!?!?
- ************help please, question on longblocks***************
- Flex Pipe or Spring Bolts??
- DataLink Connector missing, how to hook up new
- EF B16A swap help ASAP
- i need help determining my tranny
- ls/vtec question
- civic hybrid vs camry hybrid
- Question on HASport 96-00 b-series mounts.
- F22 in a 98 civic ex with h22 trans!
- quick question<emissions>
- engine cutting out in 5th
- throttle cable B18c5 into EK
- obd2b to obd2a question??? easiest way to swap out a obd2b(searched for days)
- Have anyone seen "How to swap" dvd by Art of Speed Production??
- Check out this van its great!
- Type R LSD & Final Drive Swap
- K-Pro in a K20a3...Limp Mode, Cannot load map.... HELP!
- H2B question ~_~
- GSR - Accord - Legend brake caliper in my EG?
- Evolution H2B in EG
- Honda motor dimensions
- k24 question
- How to take off charcoal can/IAB's on a H22'd EK?
- B16b into Mini Cooper
- high compression ls/vtec question
- EPA H22
- b16a2 into 97 hatch swap
- What transmission is this??
- which engine harness : lsvtec swap in 96 civic dx ek
- ls/vtec cam question
- abs axle....
- Bogging going into vtec
- Help Quick!!!
- shitty luck leads to this headgasket question
- Is h22 Ez 2 Be put in ek civic
- b18c1
- 95 civic w/b16..
- H23 to H22 vtec lil help plz!!
- ECU/Injectors Messed up?
- 1998 usdm h22a4 into 92vx hatch
- JDM H23A DOHC VTEC swap into a 99 Accord issues
- h22 with 5 lug swap.. Quick axel question
- question on el cheapo b18 header for my swapped 93 civic
- B16 Distributor?
- 88-91 DPFI to MPFI engine code
- B18C5 91 CRXsi
- b18a flywheel missing
- STILL can't get this GSR swap running, do I try to sue Typerman2001?
- Double check my research please
- Fitment: ITR calipers behind 00' Si rims
- B20 Help
- Are these 99-00 Si mounting brackets?
- eg coupe b18b
- 2 options... put together an unknown B18B1 or swap in my low milage JDM B20B (obd2 in 96 teg)
- d16z6 w/ d16y8 head?
- LSVTEC ECU Question Please Help??????????
- not getting power to the ecu ?need help plz
- b16a with J1 tranny
- RDX INTO A 2004SI
- Bseries in EF engine swap info (CA Referee)
- Can Someone Help Me With My B18 Swap
- S2k F20c Powerred RWD EG Civic
- Fuel pump question on my b18c Eg.
- Brakes soft after 5lug brake itr swap HELP!
- where to get a decent priced GSR long block in so cal
- Help, daily driver exhaust?
- ENGINE CODES??
- does this sound like a bad main relay problem ,help plz
- LS vtec block options questions
- Anyone knows which 02 sensor to get for ls/vtec with p73 ecu(obd2) to Obd1 conversion?
- Ok, need serious HELP... Code 6 coolant temp sensor
- swaps for a 89 civic
- Which o2 sensor to get??
- Crazy Cel Code 14 won't go away on EK/b18cR Swap (PLEASE HELP!!)
- GSR TRANS swap in 90 integra
