View Full Version : Hybrid / Engine Swaps
- Just got my H22 into CRX Hasport Mounts, just a few q's
- help solve this idle problem (searched)
- sr20 in honda?
- Starter cable assy. caught on fire?? WTH!
- LS vtec tranny issues
- can i put ARP rod bolts in with out taking the rods out?
- are LS or b16 crank pullys interchangeable?
- MAP sensor line routing on b16A swap
- cant pass smog p28 b20vtec, chip? cat?
- h22 driver side knocking noise in first what is it??
- sohc zc will it work with vitara pistons
- Ls block
- 97 JDM engine harness question!
- which timing cover?
- b18b1 with a z6 Head
- 92 eg B18c1 swap complete just one question..
- EK with LS Automatic Swap!!
- Engine swap help......
- harness talk
- Install an s2000 cluster in any honda - Check It Out -
- D17 in EG help
- best place in N.Y to do swap
- K20Z1 in a 1997 EK, ( ECU K-Pro problems ) HELP!
- is there a way to check an ECU?
- Will a intake manifold for Del Sol B16A work on a 00 Civic B16A2
- what are ARP fastners?
- Which cat?
- New to Swaps, need help, a couple questions??
- ls-vtec build w/future boost
- correct axle seal for my tranny???
- b18b1 or b16a2 (into an ek)
- Hasport EGH2 Mount Kit Question...
- B18A1 Swap into a 85 CRX Si
- Help me wire My gsr
- Wierd H22 swap issue......reoccuring code 9
- B series into EK help needed, first time with OBDII
- I NEED AN ENGINE SWAP DONE, LOOKING FOR SOMEONE TO HELP OUT
- y7/y8 mini code 14 after putting p28 ecu in? why!
- Has any one see this before a 3.47 Final drive?
- swap problem, i think my computers fried? help
- JDM TYPE R MOTOR IN 88 CRX tranny questions
- F20B tranny?
- FS thread
- Swap Guides?
- do i need to get a GSR oil pump for my LS/Vtec?
- b18c1 into 99 si
- B18C block, B16 head, black smoke plz help
- obd1 h22a into a 0bd1 accord need help
- h22 with euro r intake??
- ECU Question NEED HELP
- need help with wires
- OBD2 engine>OBD2 harness>OBD1 Car whats needed?
- Info on b-series swap
- H22 CRX camber setting?
- To eliminate or not to eliminate that is the question?!?
- Can I pass ref?
- dual point converstion? anyone ever have one load up on gas big time? no codes on
- LS/vtec block question
- got some codes...help
- ls/vtec head tapping
- Axels ??
- K series cams?
- What ECU to run on a stock LS motor?
- Exhaust system help..
- HELP....Engine immobilizer
- need engine swap advice
- B18b, B18c, or B16a, which one is faster?
- B18b1 into 2000 Civic Throttle Cable
- IAT ???'s
- Putting a B16A2 in my 92 civic
- msd external ingition coil and msd 6a in jdm h22 how too??
- external msd in jdm h22
- question on plugs on back of enigne harness for obd-0 harness for b16
- will an h23 or f23 manifold work for my h22
- h22 with a b tranny withought the h2b kit
- obd 1 codes?
- combining oxygen sensors? b16 obd-0 rebuilding engine harness
- FC3S, small block power
- wires
- b16a vs. b18c1
- OBD2 to OBD1 help.
- d16a6 internals into a d16z6
- cr/vtec running like crap - help!
- H22 Oil
- what ecu can i run
- Need help with wiring on obd2b to obd1 swap<<<<<<<< Please Help
- calling all people with 96-00 civics using the ekk1 k20 mounts!!! i need help!
- Opinions on B18b/B16a1 hybrid build
- What engine swap should i Do forstreet not track?
- Ls/vtec B16 head
- h22 eg Axle/Intermediate shaft question
- H2B turbo build for EG
- Engine immobilizer
- Help blow fuse after swap
- H22 in EG headlight problem
- i need your help i wtb a conversion harness !
- B18c1 into a 94 civic coupe
- h2b turbo build up....
- obd0-obd2
- (searched, came up with new solid definitive answers) how do i keep p.s. and a/c?
- JDM b18c (GSR) Help
- How does this price sound for an ls swap?
- H22 ek axle problems --- Help Please
- h2b tranny questions, thoughts, input, advice.. whatever
- CTR cams on B16 springs..
- Looking for Karconcepts?
- JUST FINISH SWAP!
- Frame damage or linkage problem HELP!
- please help wont start after swap
- H22 in EG exhaust question
- HKS ground wire kit
- Is there such thing as a B series electric VSS with power steeering hookups?
- my pics of the fresh h22 civic ek.
- Is it critical to grease axle splines before installing ??? (GSR)
- Can someone identify these plugs? Ek with JDM ITR motor / Si harness
- del sol tach quit working..help please
- Where is the CKP on a obd1 b16??? NEED HELP
- Need some help with wireing please
- b16/b18 Del Sol Swap Questions
- Speedo Problem!!!!
- ebay p13 spoon chip?
- h22a swap into 93 accord
- b16 swap
- DC4 trans to B20B engine
- HELP ON DECIDING ON A HEAD
- 93 Civic LX D15B7 Engine
- Pass. side Axle Play?? HELP!!
- 1ST GEN B16 WITH 99-00 SI INTAKE MANIFOLD
- From the beginning - N00b B20Z (LS)
- D15B Swap
- ?WUT THE HELL IS WRONG HEAR?
- obd2 ls vtec
- Fuel pump?
- JDM H22 in a EG swap Axles
- how to pass emission test in chicago w/ a swapped engine?
- b18 LSV wire harness
- avid mounts for k seriies awap into eg
- Eg swap help
- Please help h22 swap wont start!
- axles and engine swaps. ???
- Help...
- axles
- D16Y7 -> B18C1
- Delsol rear disc on a EG coupe
- another h22 issue need fast help please.
- rear nsx caliper 1991, on integra 2001, fit ??
- scat rods "LS" do i use factory rod bearings
- Question about h22 swap wiring
- Installing C-pillar bar in rear deck of EG Hatchback...(Help on Install)/as posted in Civic Forum
- Clutch not disengaging fully Help!, 93 b18a1 in 93 ex 2dr Swap 99% done
- b18a1 running rough. please help!
- Swapped K20a2 in Eg....Question
- Couple questions: LS swap in Civic
- yet another vtec wiring question, exclusively for 92 civics/delsols :D
- B18c5 into EK
- cam gears
- Vibration/axle issues on H22 3rd gen Prelude swap...after swapping inner join.
- wiring help - B18C JDM into 93 EG hatchcrap
- Can I use a P61 ECU for a P72 swap?
- my r swap with pics.
- civics with a v6 underneath the hood. Is it possible?
- injector filter/restrictor question?
- Putting a D16Z6 head on a D16Y8 block...what do I need to know?
- ??? Anyone know which ALTERNATOR PULLEY to use with a JDM ITR alternator ???
- b20 swap to a 96 sedan
- will an accord o2 sensor work with an h22?
- ls swap+ gsr valve cover
- Overheating issues... Could it be because of the wrong headgasket?
- JDM B18C1 OBD2 into 96 EK Wiring Harness Question.
- h22 stutters when i turn ignition off??
- b16a2 in a gsr, how to hardwire rpm
- help me with my r swap-pics
- lsvtec pistons????
- EK ITR Swap, What ECU To Pass Emissions
- Smog/Ref Question - jdm itr/p72 ecu
- Emissions Question - Swap+FI
- 90-93 DA Integra H22A motor mount kit, yes its a bolt in! :)
- b16 swap cranking but not turning over
- need help b18b in to a 91 crx si please help
- H22 distributor firing order
- b18a1 in 90 std civic hatch catostrophe....
- 95 usdm gsr into 92 si plz help.
- H22 Integra not sounding too good. Help.
- What companies online are good for JDM ITR motors
- B16C motor in a LS equipped Integra
- mini-me cam gear
- LSD Trans Problems NEED HELP
- IACV 2 WIRE TO 3 WIRE, help please
- obd2b rpm signal wire to 0bd1 ?????
- h22 in civic radiator question will the ek radiator keep it cool enough?
- b16 swap
- please help if possible
- VX INTAKE MANIFOLD ?
- H, D, B, series injector flow rates?????
- quick tranny gear ratio q's h22 swap civic
- Insight w/ ?rear disc brakes?
- '05 RSX-S Blown Motor - What now?
- b20vtec power steering problem
- K20A swap into a DA integra
- PR4 ECU code 4 in a base model hatch
- might be a stupid question
- Need help with battery cables-starter- h22 swap
- any bought an engine from this place?
- Swap problem, continued
- obd2a/b question- wtf to do w/ 99 itr swap
- started h22 ek have issues need help please?
- Help!!-Big Drivablity problem- 98 Type R swap!!!!!
- Gauge Cluster
- H22 H2B EG Civic Project has started. (56k, go swap a motor)
- k series in eg foor door anyone have one
- already searched and read 40 pages cant find answer hasport axle what mid shaft?
- B16A swap in 96 civic, need little help!
- $2600 installed for LS swap with GSR tranny, worth it?
- turbo H22 del sol
- Which Mini me is better?
- obd 0 motor into obd1 car???
- H22 CRX no fire
- Mount kit for H22 into JDM EG SiRII?
- Car starts to struggle...
- clucth pedal
- ls vtec build
- please help hasport axles ? for h22 ek i dont know shit about axles.
- 99 JDM R engine into 00 USDM gsr shell
- crank pulley??
- h22 block what to do?
- H22 CRX part weight differences
- Poor man type r, which plug is best?
- Water pump on 96 itr motor
- b series cable tranny in ef problem.....
- whats the best mini me combo?(d series)
- D16y8 on A6 block?
- Anyone have Pictures of B-series?
- Steering
- What is a good crank to use in a B20 LS/VTEC??
- Sleeved H22a pics
- first gen b16a pistons into b18c1 block?
- ok i need some wiring advice! b18c obd2b
- motor swap troubles
- which one is A9
- Failed Smog...Please Help
- my b20b EJ build
- VX eng in EX car, EX eng in VX car...Help please-
- nybody done this swap d16z6 or y8 in an 85 crx si
- evap code
- b16 head
- arrr fucking h22 axle bullshit (i think ) help please
- B16 head on gsr block
- 99 Si brake calipers on 94-01 integra
- how to wire a 5wire o2 sensor into a 4 wire o2 sensor
- ls vtec kinda slugglish
