View Full Version : Hybrid / Engine Swaps
- Hybrid Radiator Talk
- n00b, i searched, can't find clear answer, Prelude S --> H22
- 2000 GS-R dash into a 95 civic hatch?
- B18C timing belt & water pump on a B16A...Will it work??
- h22 eg exhaust
- ****B16a block...B18c1 head****
- Alternator wires + AEM EMS
- can it be that i have obd0 in my 95'civic?
- JDM H22 LSD EG Axles
- Can i use H22a4 intermediate shaft please help?
- Mission impossible: Goodbye SI, Hello STI.....engine swap ???'s
- finishing b16 swap into 91 crx need help
- WHAT ECU IS BEST?!
- NEED HELP ! JDM PROBLEM !
- AC mount required for DOHC swap if no AC is to used?
- integra exhaust/bpipe alignment w/eg6
- OBD1 motor in OBD2 car, can you still use the port?
- Double swap help
- B17A? worth it?
- need some help on my h22 into my eg....please
- all people BEWARE of LANDSPEED RACING!!!!!!!!!! Rip offs!!!!
- anyone heard of arizona race and machine???
- d16z6 throttle body and distributor on b18a
- Toyota-Honda hybrid - already started might need help along the way
- B17 tranny fit a b20b block?!?!?!
- How do you take the knuckle off a integra axle
- '95 gsr stock motor into a '95 hatchback cx
- ZC swap info?
- B series civic header problem
- OBD2 motor into OBD1 car
- d16z head to a ZC block
- 1991 3 GEN PRELUDE JDM H22A PROJECT.
- My "thoughtful" build..........LS/VTEC oem
- 99 d16y7 swap into eg???
- '90 b18a' into 87'civic si
- installing a 96 vtec Ex engine into a 91 civic dx hatch
- obd1 in 97 dx. missfireing and will not idel
- Yet again...came to another problem
- b18b into a eg6 hatch
- Low budget underpipe
- K swap help
- Front Passenger wheel wont roll forward? WTF!
- What radiator hose???
- dpfi to mpfi car wont start plz help
- K24A2 into 5th-gen Civic
- ecu question?
- d16z6 swap in 93 civic vx crank angle sensor??????
- HELP!!!!! SOHC VTEC MINI-ME SWAP?
- Mid-Engine, RWD CRX w/K20
- 1st Gen B16 into EG?
- Will 96 Ls axles fit a 95 GSR tranny?
- H22 aftermarket pistons (Forged with FRM Sleeves)
- What to expect from USDM ITR EK SWAP
- obd2 distributoron obd1 wireloom
- Going to get a b18c1 for my 93 hatch Could i smoke a 93 gt ford probe ?
- help w/B18c into a 96 hatch
- got a ek with a h22a, which intermediate shaft do i use?
- difference in VTEC solenoids?
- Integra/ Civic bolts
- ls vtec problem
- honda pilot motor?
- How do you swap a sohc into a integra
- wiring distributor
- High clutch Engagement
- leaking problem, please help!
- just finish the swap now I need a little help
- H22-into-ef mounts
- Any body use Supertech high compression valves?
- LS/VTEC Electrical Problems
- b16 in CRX, just finished. cylinder 2 and 3 fill with fuel...maybe bad resistor pack????
- WTB: CTR steering wheel or gauge cluster for EK
- Got ?'s on trubo built Non-Vtec LS longblock into a 92 Civic EX..need some expert opinions..
- GSR hydro tranny pops out of 5th only...
- (Harness Help) sick of people not knowing what their talking about
- Jun cams
- Here's something Honda guys would probably give props too (Non Honda)
- s2k motor into a crx please help!!!
- Help please!!!
- how to keep Ac in this set-up..hybrid
- Who to buy from?
- b16a swap in a 95 civic ex questions????
- HASPORT EFB2 Hydro-CRX/Civic
- Electrical prob.HELP ME PLZ!!!!
- DSS H22 civic axle vouch
- B20B Civic EK Idle Issues..
- B18C5 obd2b into a EG4!! Help!!
- B16A-sir2 into Eg
- (searched) post your stock bottem end b20vtec setups.
- Field SFC with b16a and CRX wiring woes..
- ***searched will AEM FPR work ***
- map sensor code 5
- need help car wont start
- power steering pump problems
- Which clutch do i use???
- Does anyone know if a 4.7 final drive will go into a JDM Y21 4.4 LSD?
- best ecu to use
- Power Steering brackets HELP
- cable to hydro conversion on crx
- ECU decision B18c1
- HELP!!!! CHECK ENGINE PROBLEM CANT FIGURE OUT
- Any High-Perforance CRVs out there?
- will a b16a fit my 93 civic eg sedan??
- ls vtec bog
- Do SIR-G's Tranny's have LSD?
- k20 into EG mounts question????
- ECU pins and wiring???
- CEL on a ITR motor and now car won't turn over.
- Need some K series swap info for an EG
- b18b bloack with b18a head? and crank sensor question...
- Need help w/ IAT Sensor/harness... B16A2 w/ GSR harness.... Cannot get a good read...
- what steering knuckles do i use
- h22 crx
- LS/Vtec w/ 2000 SI head
- Fuel line
- b16a into vx EGR Q?
- ITR Tranny Rebuild Parts Help...
- what obd0 alternator do i need?!?!?!
- Difference between h22 shafts?
- Upgraded ecu recommendations
- Inner fender frame braces Anyone have one what they think of it
- converting down in OBD's
- chipped p28 in my gsr ---> solid CEL
- power steering question
- Anyone good at wiring in the Philly area?
- b18c is it JDM?
- H23A-EG shifter problem...
- makes wires
- B20Z2 oil pump VS B16A1 oil pump
- integra shell wanting to motor in it
- 95 ex SIR 2 b16 swap, wont start, help pls
- S/C K24A2 into EP3
- Type s pistons in h22
- D series tranny on a b series motor?
- Which ECU should I use??
- Vtec Kicking in ?
- D16Y7 in a 1990 Civic DX hatch...what is needed?
- B18b into 93 hatch......bolt up to stock exhaust?
- Another B20 Swap Question
- CRX b16 Swap
- ls/ vtec questions
- s2000 motor in a civic
- Converting to OBD2 posible?? EG4
- interested in seeing a mugen k20a ecu vs. kpro?
- What All Do I Need To Put A B16 Head On Ls block
- S2000 motor into a 1990 civic si
- Some help for my D15b ek swap Please
- I NEED HELP WITH WHAT MOTOR MOUNT WILL FIT IN EK (droppin in b20b)
- WTF-new clutch install now motor falls in a "hole" at 7,500
- Dragging the K24 EG...
- B16 block with gs-r head??????
- $6,000. Enough for a K20 in my EG all said and done?
- HELP!!! what does this go to?
- ** B18C5 ITR into 98 GSR-IDLING PROBLEMS PLS HELP!! **
- Starter trouble
- Help Idling Problem on B18B CRX swap
- quik ?
- what head gasket for CTR pistons into b18c?
- NEED HELP WITH FLYWHEEL PLEASE
- misfire dealer cannot fix it
- B16A2 DOHC VTEC Wiring Harness.....
- fuel problems
- h22 into 94 teg Qestions^^^^^^^
- what tranny
- b20vtec with some type r internals
- H22 guys... update on the hatch...ground clearance.
- Best swap for eg 4 dr
- 00 Si radiator. Is it dual core?
- Hasport Mounts!?
- starting problem
- knock sensor wires in a swap
- Hasport Press Release: EF K-series mounts
- hastings rings for ITR pistons
- Will a 99 gsr muffler fit on an EG?
- CTR Head
- K24 (TSX) motor in my 95 hatch.
- anything positive out of removing a charcoal canister?
- TSX Engine/Tranny into Del Sol
- Head casting numbers
- eg console with h22
- 93 accord engine swap
- some MORE IAB help
- ls vtec axles
- h22 shifter
- Fuel line for my h22 swap
- b18c with hydro s80 tranny in ef crx, axle question
- 92lshatch
- b18a into 93 ex
- eg h22
- rcrew sucks, they abuse customer's karrrrr
- fuel pump not clicking on with h22a in my civic
- LS/vtec dowel pins don't fit....Am I missing something?
- 1st gen b16 valve lash specs????
- ls to type R
- '97 USDM H22 into '96 Accord
- Hatch engine hybrid Help
- New kid from jdmu, need some help hit me up wit infor or inputs
- ls vtec + b20 vtec owners..........gas?
- tsx k24 question (searched)
- b20 ecu...?
- h22 into 96 ej?
- 2000 gsr into a 1995 LS
- accord, h22 problem
- p28 pin layout for injectors
- wiring a B18C in a CRX
- Machine Shop in So Cal....
- (((D15 into lx coupe SEARCHED))))
- HX b16a2 o2 wiring help
- ITR motor is in and no check engine codes, but whats wrong!?? =(
- B16A2 engine swap chart
- Looking into getting CRX then doing b16A swap... Many questions!!!
- k24 (accord)/ k20a2 head...new pistons??
- ZC gearing question
- boost question
- H22a1 INto 94 civic hatch to do/get list..
- d16a6 in to dual point injection civic
- reliablility of ls/vtec
- Will this swap work? OBD 1 ZC to pre obd question....
- different IM on b18c1?
- Raxle Axles (98 Integra with H22A)
- need to go to state ref, which location is more easier to pass?
- Do I have everything needed for B18C1 swap in 90 CRX HF? OBD1/Hydro
- EK with gsr swap. check engine light is on
- whats my rev limit for my combo?
- newbie need a quick reponse if possible
- Emission Test Results on my hybrid
- question about vtec solenoid
- B18 Engine Light Lean ITR ECU
- Problem with 93 Accord LX with JDM H22
- 180-200ish NA ls/b20?
- swapping a jdm b16 into a 92-95 civic coupe
- CRVTEC swap parts list?????
- b16 into a 98 ex...obd1 or obd motor?
- FWD to AWD Conversion
- b18c exhaust that will fit EG6
- B20B CRX INFORMATION!!!!!
- need help with h22 CEL and tranny
- K series in to delsol ???
- d15z1
- h22a question on 3 hose lines
- jdm d15b comparison?
- car wont crank over help please
- code 23, b16 in 5gen
- K series into EG header
- Unplugged ECU and now no spark!??!?!?!??!?!?!?!?
- golden eagle kit head gasket?
- b20 with b16 head, compression question?
- ZC Swap Question
- Stock b20 in a eg hatch v.s. Stock ls in a eg hatch
- Hybrid swap
