View Full Version : Hybrid / Engine Swaps
- Motor question.
- looking for article/writeup
- gsr redline
- lsvtec in an ek, need questions about specific parts to fit in. please help
- What rear mount for swap in EG Civic
- Hasport mounts in EG - any issues?
- b16a pistons in my b18b (i have searched!!!)
- need to tune
- Help: need custom radiator (half size) for k20a ek w/ RBC IM & hasport ekk1 mounts
- Higher Idle Than Before
- 1988-1991 Honda Prelude Si Resistor Box for JDM H22A?
- Frank Motor Build
- Skunked
- a/c in 90 crx dx with b16a swap
- Last question need a final answer. Air conditioning+GSR swap+eg
- Difference in upper rad hose size?
- P0141 CEL
- B16B
- what ecu to use
- H22 Balance Shaft : Cut belt or completely remove?
- gsr bogging around 7k?
- h22 swap into 4th gen. and now ac/altentor belt doesn't fit...
- 99-00 si exhaust fit 99-00 hatch?
- H22 into a EK,..oil pan clearance
- springs for a eg h22 swap
- brakes
- b20 vtec question
- JDM ITR into 92 GS-R
- Part ID, Civic or Integra clutch line??
- Help, Can't start H22A4 using AEM PEMS
- Spark plug socket size for a B18C?
- h22 from an EG to a 4th gen accord
- F22b1 with h22 crank/rods ???
- Mystery connector on ef/b18b swap
- LS/VTEC HP/Price
- H22 EG Civic Cooling Fan question
- i need picks and advise on oil pickup
- throttle canlr
- Avid motor mounts?
- Alternator problem after swap! Plz help!
- Distributor wiring question
- h22 hatch header question
- 99 Civic B20Z swap problems
- 2001 Civic
- ITR into a EK hatch
- Stage III 400Hp H22 EG Axles for $200?
- motor swap issues
- Which Manifold & Downpipe for H22 -> EG Civic Swap ??
- help quick please h22a4 oil pan arrrghhh
- k20a in EG: Missed 3rd, Now I cant go into 4th?????
- Shaved h22 crankshaft pulley for H2B clearance!
- Swapped Motor with CA Emissions in San Diego
- Please help
- Need info on B16a build up!
- Vaccum problems on Ls-Vtec?? PLEASE HELP!
- baseline rsx motor vs. type s
- 98 b18c1 into 98 ek hatch...
- RSX to CL/Accord Brake Swap
- PCT ecu on GSR ?
- what needs to be done to make a B20 head gasket fit on a B16/ITR head?
- what would u do with u got a k20a3 for free??
- ECU wiring harness too short
- Shifter cables combatibility for K swap
- K series in my Accord
- my h22t wont boost
- What parts to buy for my B18C5?????
- 90 CRX Injectors not firing...but they have power
- On the road to becoming BAR'ed
- parts missing?
- axle question
- best place for a engine swap
- Another wiring question (97 SiR-G in 92 Civic DX)
- Do I need a new ECU??
- Help I need a new ECU, I think???
- My H22 swap into EF using Hasport mounts
- crankshaft sensor ,distributor, obd problem.... plz help
- h22 civics chime in 93 si w/h22..... header question
- ls/vtec question
- which motor for my 4dr
- OBD2 misfire codes on H22A engine
- Another B20vtec...A few ?'s too.
- i like to swap and need info
- Anyone seen or used THESE mounts for EG???
- H22 in EG Civic - Maintenance Question
- Avid Mounts for H22A into 93 EG Civic ??
- 1993 Prelude Through hell and back.
- 99 Civic SI swap in 96 EX
- Please help! No spark!
- Recommendations for any good shops near Phoenix? (engine swap)
- h23 vtec
- 93 del sol s b16 swap wiring
- Dx exhaust manifold
- Racing Sports Akimoto needs a donner K-series EG/EK/DC for test fittment
- Stroker parts list...
- 0bd1 b18c1 into 95 civic vx. I have 2 quick questions.
- failed the BAR, barely
- Identify this P72 ECU number....thanks.
- JDM GSR B18c into a 99-00 CIVIC SI EM1 Swap guide howto bible
- YS1 GSR CABLE TRANNY CASE
- H22 Passenger Side Tranny Mount Mod for EG ?
- Attention! Purchase h2b plate for 1999 ek civic!!!
- Halfshafts....H22 F22
- why B20Z over B18B?
- Opinions on XTD Clutch & Flywheel Combo for H22
- Help! I am throwing a codes 3(MAP Sensor) and 6(Coolant Temp)
- Turn key K series swap packages
- engine swap question.
- 97 Accord H22 swap code 12...
- ls vtec swap got bad advice PLEASE HELP ME
- AC in H22 EG
- B18C Swap Questions
- got the swap now i need the little stuff
- go from b16a to b20vtec?
- Need some help on 5 lug conversion????
- RC 440 Injectors from Eagle Talon
- What is the right drivers side bracket?
- ls/vtec question
- K series in a DA teg?
- d16Z6 OBD-0 DIZZY MODIFICATION
- what sensors/valves are not needed for h22 with a p28? IAB EGR?
- H22a JDM swap civic 93HB wiring problem
- botling b16 head on gsr block...another question..what head bolts.
- ABS light on, but won't blink!
- h22 eg mount question
- b18b==b18c for swap into 1993 civic dx
- H22 eg has a studdering problem???
- lsvtec help
- How to keep power steering with swap?
- how to keep Power Steering + Cruise with B18c Swap ??
- h22 swap in 97 civic hatch problems
- My EG H22A parts list and cost : not cutting corners
- H22 swap in EG 4 door, axle hitting shock fork......
- jdm b18c1
- Need Help Obd2-Obd1 distributor wiring (searched)
- B16A2 into '94 Del Sol with Auto Trans?
- Tps problem plz help!
- got my ek help with GSR
- lsvtec build ? do most people use plasticguage to check clearences
- 98 integra rear hubs will they fit on 99 si rear brakes?????????? help !!!!!!!!!!!
- H22 bog at WOT. Most likely a fuel issue.
- H22A4 in Integra (need help)
- JDM GSR SWAP INTO 99 EK
- Where can I pick up a stock S2000 steering wheel?
- H22 engine with F22 tranny (build question)
- WHICH AC-SYSTEM TO GET?? PLEASE HELP
- Quick question about IAB's
- h22 EK owners
- putting b16 head on gsr block...which headgasket do i use...timing belt..//etc,..
- hasport ek k20 wire harness need help ASAP - wire identification
- p28 ECU question already searched?
- NEED HELP REV AT 5,OOORPM WANT IT AT 7,500RPM ?
- ls w/ teg type r head
- what is the easyiest way to remove a rev limiter ls motor?
- Odd Question: Do ITRs have Aluminum P/S pump mounts?
- F22A Crank Pulley on a H22A (searched)
- Can a H22 head work on a H23 Block??
- **Official H2B Discussion thread **
- TEST
- OEM Cat for ITR swap in my EG Civic
- how to keep A/C and Powersteering
- h22 idle problem
- h22a7
- b16 starter need help
- IACV Fix Question and Help
- Anyone have iss's with AVID MOTOR MOUNTS?
- 98 civic B18A1 swap with a 5-speed swap at the same time
- h22a swap
- h2b into Del sol
- Swapping a K20 into an eg.
- JDM D15b...?
- Need some mini-me timing help
- FRONT END EARTHQUAKE
- OBD1 engine in OBD2 car question
- b16 auto swap
- HELP - B18A Engine SWAP - 93 civic
- Code 20, electronic load detector, need help fast!!
- EM1 + GSR Swap
- Engine Swap Decision Help O.o
- which P/S Bracket for Ls/Vtec?
- ITR brakes on 1996 Hx Hatch
- NEED HELP!!!!
- ls/vtec
- Excess heat???
- will k20 ecu work on k24?
- 96 EK Hatch, is oem ecu obd1 or obd 2 ?
- ? engine swap? wiring?
- lower tranny bracket need question answered ASAP since engine it out of car
- smoke
- 88-91 h22 swap question need help asap
- difference between OBD2A and OBD2B??
- H22A EG doesnt start when its cold?!?!
- question about h22 in a 96 accord
- No speedometer, Blown ECU fuse, Limp mode, no CE light
- d16Z6 OBD-0
- NEED INFO!!! Swapping 2000 D16Y8 Into 91 MPFI CRX What ALL DO I NEED!!!
- Headers for B16 with GSR head on 96 EK
- NoOo
- Best ways to get following misc. swap parts? B18C into EG (Not complete)
- b20vtec: what throttle cable?!?!
- h22 in eg won't start
- my car didnt came with sway bars... which one do i need? (97 civic)
- rsx seats
- squealing=[
- Please help. Big spark, blew something.
- need info on d16y8 into eg hatch
- ls swap eg civic need help???
- S2000 cluster question
- H22 Swap into EG, trans hitting frame rail.
- VTEC will only engage with VAFC 2
- 4G63 Powered Hatch (325HP) For Sale
- head help :)
- B18b dizzy on B18c Head???
- how can i tell
- 4g63 Into Civic
- D15Y5 HX into CRX Si or HF Will It Work - how hard to do ?
- ok, im sad now... frankenstein
- PR3-3 ?????
- Anyone using Innovative mounts?
- Do all DC2 ITR suspension parts fit on a Civic EG4?
- b18 block, b16 head help
- ek swap alternator + dizzy question
- Radiator Question
- i looked all over (k series)
- h22's owning b18c's
- Intermediate Shaft Auto/5 spd b18b1 the same?
- Brake line adapter needed
- B20Z into a 90-93 integra
- H22 Swap: OBD 2 to OBD 1
- B20 BLOCK or B18C5 BLOCK for MY B162A. need advice!
- B16a gen 2 obd1
- Quaife LSD?
- 93 ex harness/97 USDM h22 <----how to wire dizzy and coil?
- B16A1 swap into 96 Civic HB - Confirmation questions before buying
- b16 swap guides?
- can anyone identify this mount
- do they use the same wire harness ?
- b series cranks swap
- Engine Whistles
- Gage Cluster question...
- obd1 motor in obd2 car
- aem fpr fuel rail lsvtec b18 upgrade all motor worth it?
- B18A/B cranks and rod interchangability
- Check This Out
- rear wheel drive civic
- y8 manifold on y7 head question!!! HELP
- P30 Ecu Chip Possiblities
- Question about 3 problems on my type R swap
- Please help runnin on 3 cylinders
- OBD2A motor into OBD0 car
- How to tell difference between obd1 and obd2 ecu
