View Full Version : Hybrid / Engine Swaps
- h22 swap info
- dumb ek swap questions
- vtec bogs out
- For the California Guys, BAR related
- b20 in an ek wont idle properly
- 01 ls swap into 96 ek
- sorting out distributer wires, how do i know what's what?
- hmotors ZC swap into 97 dx?
- Please help!
- AC in h22 ek
- h2b b series wiring harness?
- H2B Oil level question
- Iacv
- 16head on gsr block(t-belt)
- b16a into ef running on 2 cylinders
- CEL pin ?
- Password JDM "whale penis" intake fit ek h22
- best motor choice
- K20A2 - Some CELs and a couple problems
- b20 w/b18
- No VSS plug on my mated loom *H22 EG*
- B20 Crank Into A LS Block
- Sleeves; B18b LS/Vtec Question
- B16b iacv help!
- hondaZvic's EF'n h2b, FINALLY!!
- doing my swap NOW! Couple of questions.
- B-series into EK mount clarification
- b16/b18c/ctr wont idle properly
- 00 CTR B16b into 97 GSR
- obd2 to obd2 help
- JDM B18C with Type R Head Hesitate at full throttle
- Two Ways To Look At This
- OBD2 B18C-R into my 89ED8 CRX HF
- Converting to Coil Packs Possible?
- Need help on what ls/vtec pistons!!!!!!plz
- B20vtec Dizzy
- H23 vtec head swap questions
- what ecu for b20
- lsvtec max cam lift
- F20B dohc vtec valves
- Problems with new ls vtec bogging & miss fire
- DC H22 swap heater control valve
- b series swap want to retain a/c what do i need?
- lsvtec dizzy timing and fuel pressure help
- what alternator for a lsvtec
- k20a2 92 cx hatch swap - No start + 4 CELs
- 96 spec JDM ITR motor (OBD2a) into my 00 Civic EX (OBD2b)
- Help! d16z6 head on d16y7 block not receiving fuel
- Ls Vtec Pct Piston question
- hybrid technology with Hydrogen
- Engine harness question
- b16 head b18c block power steering???
- what will i need to do b20vtec
- 92 Accord w/ dohc swap POWER STEERING ISSUES
- h22 swap problems need help
- B20vtec - ITR HEAD ISSUES WITH STOCK B20 PISTONS
- ITR pistons into B18B block?
- Please help...DC2/EG9 mix and match
- can you use a HX harness on 97 CX with lsvtec?
- vx head on ex block
- b16a2 into 96 dx hatch: obd2a-obd2b question
- d16z6 distributor obd1 to obd2 help please
- b18b -> EK - parts list
- JDM B20B Swap in EJ1- Throwing a Code
- Problem: What clutch cable for JDM B16A in 88 CRX Si?
- h22 valve springs in B series head
- Del sol w/ B18c....I need AC help!!!
- H22 guys need help here
- Coil On Plug?
- 00 civic si b18c5 swap code p0171
- what alternator for jdm b16?
- LS_VTEC Tech Questions Tread
- h2b question
- High Idle after finishing b18 swap.
- Rwd wagovan conversion/d15b with d16z6 head...?1 help me
- compression ratio
- 88mm bore f23 block-?
- ls-Vtec question, please help :/
- Are all EG / DC front LCAs the same?
- type r engine in a 92 civic sedan
- Motor Mount Hardware
- What head studs for LS Vtec?
- i have a h22a darton sleeved block!!!!
- H2b help!!!!!!!!!!!!!!!!!!!!!
- b20 swap throwing out CEL
- B series / H series / K series ...???
- H2b question
- b16 block with b16 rods and ls pistons????
- JDM H22A swap questions.
- LS head on a B20 Block
- B18a1 92-93 obd1 in to ef help!
- b18c skunk2 manifold on b18b?
- H22 injector prob.
- LS/Vtec fuel pump?
- v-tec harness
- Lookin for help on choosin motor ...
- What to do w/ evap on jdm b18c1?
- urgent help! car sputtering after 4k rpm
- EJ1 with Ls Swap- Throwing Code
- 00 SI engine wiring harness running a nonvtec motor
- OBD2B to OBD1 CONFORMATION
- B-series Hybrid motor
- OBD2a harness plug info.... Help!!!
- obd 1 cel problem
- h series to d series Alternator
- supercharge
- question about qsd kit hydro in ef
- B16a2 with ITR I/M & T/B, CTR intake cam w/ itr exhaust etc...need recommendations
- B18A1 into a 97 hatch
- wiring harness question
- B16a1 oil filter??
- Motor mount nightmares!!!!
- Are HF injectors 240cc's? same as Si's?
- help : poor mans type-r flywheel
- Pics of Latest HASport Hydro Conv. kit on EF?
- I think im a NOOB , b16a into 96 ek hatch
- installed ES mounts..
- Cast No. Do I need it
- Hood for LSVTEC in CRX
- Evo turbo
- Delsol with B18c...what steering parts are needed?
- What CAT for JDM B16A in 88 CRX, bolt-on?
- Idle HELP!
- 92/93 YS1 and 94-01 Y80/S80 - 5th Gears Exchangable?
- $$$Hondatec1"s race/street killR$$$
- are b18c and b16a headgaskets different?
- Refereance: D15b block with a d16z6 head uses a y7 / y8 cam gear for correct timing
- OBD1 motor in a 2001 Integra Type-R
- b20 swap need help
- Throttle cable prob....
- Another A/C bracket question
- Couple questions on the b series swap into a CRX
- H22A7 into EG from Italy
- Please help!!
- HELP! : Poor Mans Type-R, Harness?
- H2B type S from down under * Australia
- Passing NYS inspection with jdm motor/ecu, obd2
- my h2b setup. just finished it
- f23/h22a question
- no spark
- d16z6 d15b2?
- f20c swap in civic ej9
- y7 head on a d15, confusing problem
- Deck height B18a/b VS. B20b/z?
- Diagnostic tool not working on JDM ECU
- Here's my situation.....
- D14A4 Head problem
- NEED HELP! B20/Vtec
- ls swap into ef hatch help?
- h2b/f2d oil pan
- Ls swap headache
- few LS Vtec questions that i just cant find a answer for
- Mini Me help.
- D15Z1 internals and head into/onto D15B7 block?
- Having some axle issues H22 EG
- Will NOT go into any grear!!!
- b-series oem outer valvespring colors?
- prelude b20 crank in b18c1? anyone know?
- d16a6 into EJ6
- just finished my b20vtec build....
- B17 in EG...axle questions
- AHH!! IACV issue or what now!!
- Power steering belt size for swapped eg
- h22 into 99 si distributor questions
- LS/VTEC with no VTEC!! Please Help!
- Cluth works off and on grinding!!!!!
- h22a makin it 2.4
- updating stickies...
- Does an h22 obd1 swap require a resistor box?
- 2001 ITR engine questions
- Oil capacity
- post hybrid builds
- 2000 h22a4 into em1 Bar legalizing questionSS
- 2001 USDM-CA B18C5 swap into EG. Bar legal please.
- Trans question
- Swap B16 for 97 Del Sol Si (D16Y8)
- What ECU with 3.2 V6 Swap?
- build thread #1: F2D on the cheap
- What catalytic converter and flange do i need?
- sleeper b16
- Does anyone know anything about JDM Diesels?
- Please Please help-
- ls turbo crx wont start
- 2 cars 1 problem
- H22 rods F23 crank?
- compression ratio? z6 head on z1 block..
- Sloppy linkage, LSV in EK hatch *update, Still sloppy*
- H23 Question
- Power Steering and AC Question
- H2B which alternator belt?
- help with mounts h22 hasport eg
- B16a engine!
- j32 or j35 into EG
- LSV in car. Plug and starter issues!! PICS ADDED!!
- G23 da9 integra
- CRVtec + SMOG ????
- 93 eg cx trying to get bar'd
- 90-91 vs 92-93 integra wiring question. guages.
- B18C5 rotating assembly into b16a block
- exhaust do i need
- Need help identifying block and head type.
- Engine Cleaning
- K series tranny options?
- Help EG loom wiring
- EG H22 + Driveshaft contacting damper fork
- Request: K series swapped pre-00 chassis with functional A/C
- First time at track with h2b and broke axle??
- ls vtec idel prob
- Honda-tech swap gurus only!!!
- Wiring too complicated please help.
- eg hatch with abs and swap question
- h2b just finished and ran like sh***t
- h22 into DC integra with auto tranny
- crx k24 swap
- H2b Swap fueling...
- Ls Vtec Piston Question
- Ls Vtec. What ecu???
- ls sleeved block gsr crank what bearings
- concerning F23 hyb. compression
- Looking For an Opinion on my H2B setup...??
- Need K series shifter box measurements.
- motor mounts
- eg swap
- Different swap
- B16 bottom end with LS head what timing belt??
- Fully built AWD EG Reinforced wagovan tranny + GT28/40
- b20
- CEL #15 Help
- Help w/ JDM B16A w/ ITR intake manifold in EF (88 CRX Si)...vacuum lines etc...
- Can't figure out how to delete threads so this is it.
- Wiring troubles, someone please help!
- Can you pass bar with the f20b?
- 99 honda civic ex with LS motor
- Wiring help b16 into eg
- B20-vtec Q for CALIF drivers
- sensor help....
- B16a bottom ,98 GSR Head
- Help w/ GSR Swap into EK Civic
- k24/20 vs k20? please help
- 99 si swaping block?
- H22a in 00 coupe aftermarket intake clearence, who knows for sure?
- F29 tell me what you think
- HELP! B16A3 in 1995 Civic LX 4-door!!!
- few questions about J in Del Sol
- OBD0 or OBD1 Small Injector.
- Which should i do?!? B20vtec or LSvtec?
- HELP: I blew a motor, but I do have options...maybe.
- Innovative Cable to Hydro Question
- map sensor
- question about d15b ecu
