PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 [161] 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. teggy brake swap >> extended wheel studs
  2. B16 head w/B20 Block
  3. jdm club...good place to buy engines?
  4. HELP! Rebuilt motor and head leaks oil
  5. JDM B18C, which ecu to run??
  6. 5g LS swap problem!!
  7. How much hp loss???
  8. Integra brake swap - master cylinder question
  9. Pin layout for chipped P28
  10. Who sells STR?
  11. 88-91 Civic vs EG chassis...which parts will interchange?
  12. Putting 95 GSR Engine into 92 Si
  13. Suspension Techniques Front sway bar...vibrating on cat...
  14. Shifter Placement for civic H22 swap
  15. LS/Vtec Reliability
  16. b16 valve cover on 94 gsr head?
  17. Intake for hybrid hatch
  18. Acura CL 2.2 auto tranny TO Manuel
  19. OT: Thanks Honda-Tech!
  20. Greddy gauge bulbs ...... ( to match dash)
  21. Mini me swap into 91 DX
  22. anyone know of any good headgaskets for a 95 jdm h22a ??
  23. 2000 Prelude Targa Top conversion? Is it possible? Please look
  24. Ls into Civic coupe
  25. 85-87 civic/crx project?
  26. oil squirter question please help!!!!
  27. Any B20 blocks for sale?
  28. engine swap rates??
  29. R/S Ratio
  30. 90-93 into a 4th gen civic SI
  31. p28/w mugen program on b18c1 (single runner IM, and mild camshafts)
  32. ls crank ?
  33. vtec not coming on??
  34. Which CAI for hybrid EF?
  35. H23??
  36. Anyone ever shipped a motor?
  37. Other B20 pistons?
  38. Crower 403 VTEC cams
  39. fuel tank pressure sensor
  40. H22A Competition Axles, who can vouch for Raxles.com or driveshaftshop.com
  41. modifying ek harness for h22a obdI ? turning the key for the first time?
  42. ??
  43. S-2000 Steering wheel in 97+ integra? How To???
  44. Throttle angle sensor came apart on me when removing, anyone know how to reassemble TA internals?
  45. Valve cover question
  46. Where to get a B16 installed?
  47. Which timing belt do I use for a JDM B20b and a 99 Si B16 head?
  48. EXHAUST ON A 90 CRX SI
  49. CRX si with B16A - will a JR SC fit in there?
  50. How Much HP?
  51. h22 into '97 CX hatch
  52. S2000 engine in a RSX.....bolt in??
  53. will gsr cams make power in a b16 head?
  54. Need B18c swap Help
  55. Engine Swap/Which One? Why?Who?Horsepower?
  56. anything in specific I have to do to a B18c....
  57. mount question
  58. Help Please??
  59. help with 1 wire
  60. Is LSD in a mostly stock B16A worth the money?
  61. Different ECU's
  62. steering wheel and car very shaky after swap
  63. Wire Size for the swap
  64. 95 ls into 90 Si..need some help
  65. MD/DC/VA Area.... Read this
  66. B16 head/sensor compatibility
  67. When to Hone?
  68. what's the difference between 94 delsol b16 to 00 civic SI b16????
  69. vtec cyliniod gasket/filter keeps breaking
  70. AEM-CAI Question
  71. LS crank ???
  72. Question about InlineFour.com
  73. race interior
  74. Pics of my car and my dog =)
  75. Hybrid Luck
  76. Suspension how do u compensate for xtra weight
  77. JRSC fit my Hybrid B18c1 delsol?
  78. speedometer compatibility problem.
  79. ? on exaust for a hybrid hatch
  80. Non-Vtec distributor + Vtec head = ?
  81. Websites: Swapguide b16
  82. Stock Headgasket Thickness?
  83. Please help!!
  84. will B16a rod fit in a D-motor?
  85. jdm gsr hatch
  86. can you use these for a b20/vtec swap?
  87. trans id
  88. one of us in SCC
  89. 12,000 RPM tach? Apexi? Pictures? HELP PLEASE> THANKS
  90. DX EF9 Wiring to B16
  91. lsvtec youll love this bad boy
  92. mounts for Ls auto?
  93. AEM or ICEMAN Cold Air Intake?
  94. H22A Type-S or B20VTEC?
  95. Skunk 2 intake man. advantages?
  96. i have a suspension question
  97. changing Ls to Gsr, need help
  98. to all who have the SOHC VTEC in their EF.......... Greddy kit on the way
  99. bogggin
  100. Research on a b20/vtec going N.A.
  101. **MY LS REX WILL NOT START!! HELP ME!!**
  102. arp head studs for a b16?
  103. 3rd gen Teg brakes the same?
  104. Should I buy DC headers 4-1 stainless or a ITR intake Manifold and Throttle body?
  105. h22a Vs b18c5 wieght differences?
  106. B16a2 into a B16B
  107. GSR motor what would you do with extra money???
  108. New Gaskets when?
  109. B series cam changing tips
  110. Auto to manual on 89 CRX dx... need help bad
  111. anyknow know this dirt bag?
  112. Question about 310cc injectors
  113. question about wiring for swaps
  114. i can't believe i'm doing this
  115. I have a lot of questions
  116. Which header for EF?
  117. Engine Stand Bolts
  118. .............is the Hasport wiring harness pug/play into the PR3 & PWO???????
  119. hybrid exhaust question
  120. Poly-urethane engine mounts for engine swap? Should I?
  121. jdm b20b vs usdm b20b
  122. E-Town march 9th.
  123. Aftermarket for Hybrids
  124. Which VTEC solenoid to use? (pics)
  125. OBD II LS to OBD I Question???
  126. Good info for H22 Civic swaps
  127. rescue me... help with swap
  128. Cost of CRVtec?
  129. ITR CTR Pistons Compression
  130. The right drive axles
  131. engine swap?
  132. H22A MAP Sensor Question
  133. zdyne one wire conv. or pr3 with chip?
  134. Why 3" intake for B16? doesn't make sense?
  135. release fork
  136. 85 CRX Si + JDM B16A + turbo ?
  137. How to tell if a B20B is JDM or not?
  138. JDM GSR guage cluster
  139. b series cam specs
  140. B20VTEC swap difficulty??
  141. Funny Idling problem...
  142. Which Motor For Swap
  143. What has more potential?????
  144. Throttlebodies and other parts interchange (B series)?
  145. Fuel pump for CRVTEC in CRX
  146. Someone Help Please!!!!!!
  147. anyheard of auto adventure? (west cost)
  148. Longblock question???
  149. swap shop near North Carolina
  150. B16a complete swap into 92-95...SHEEP.
  151. new Vtec setup, cheap trick, wiring advice needed!
  152. Question about rod to stroke ratio
  153. FS: OEM ITR INTAKE
  154. shipping costs
  155. Choices Choices, Help?
  156. vtec crossover, y1 tranny ?
  157. buying from jdmclub.com-the accordclub guy?
  158. JDM DA6 gauge cluster - help
  159. crv-tec ?
  160. will greddy turbo kit fit??
  161. check engine codes
  162. B16A into 90 Teg
  163. Converting '98 OBDII GSR motor to OBDI??
  164. Questions about a Hybrid 2.3 Vtec???
  165. 91 CRX Si B16A1 Swap...car will turn over, but won't start..story inside..any ideas?
  166. EK interior in EG? (Dash , door panels.....?)
  167. B series cams the same
  168. thinking of relocating my powerplant.... issues
  169. 99 civic Sedan Swap help!!!
  170. HELP need a wiring diagram please
  171. Things forgotten on B16A swap?
  172. Anyone buy an engine off of Infinitemotorsports.net?
  173. GSR vs Type R oil pump?
  174. Missing b16 parts
  175. are b and d series eacv's the same
  176. drag gen III kit fit on my hybrid sol?
  177. can anyone help? code 15
  178. ? H22 swap/help
  179. Swap Gurus: I've ran my vtec and knock wire in from my b18c5 swap already and...
  180. 89 CRX Dx to 91 CRX Si?
  181. whats the proper h22a civic drivetrain
  182. B16A2 Swap. Do I need Master Cylinder??
  183. I always want to go faster!!!!!
  184. ls/vtec done!!!
  185. OT: 3/2/02 Rich, VA hybrid meet
  186. where'd my VTEC go? WTF
  187. poor man's type-r easy or not?
  188. 90-93 Integra brakes in 92 DX hatch?
  189. b16a to obd1
  190. LS tranny on D15? Possible?
  191. b16 swap into eg
  192. can i use a LS headgasket with a B20 block
  193. gonna do a GSR swap in the hatch,what clutch.and some other ?'s
  194. Will 99-00 Si axles work?
  195. replacing D16Z6 with D16Y8
  196. SCAMMERS
  197. Gs-R cams in B16a
  198. ECU Chips
  199. STR blockguard with CRV block?
  200. B16a Check Engine Light
  201. someone build me a hybrid for 4g's
  202. CEL with chipped ECU?
  203. secondary o2 problem
  204. Injector Specifications and upgrated!!!!!
  205. I need some help locating a b20z block and crank
  206. a question about making my ls block 2.0 using crv parts
  207. gsr manifold on a ls head? does this work and would i benefit over the stock ls?
  208. how to bypass the second o2sensor on obd2
  209. I found a 4 door gsr... b18c5 swap?
  210. infamous balljoint...
  211. The shiftlinkage pin?
  212. which mount i need to swap a b18c in a 1999 4doors civic
  213. JDM Type R swap question
  214. Question #1 - accelerator cable removal.
  215. pictures of my broken civic :(
  216. B18C1 is laggin (help please)
  217. any recommendations for who/where for Upstate NY swap install?
  218. For Sale: Skunk2 Intake Manifold for a GSR Head
  219. Trade a JDM Type R motor for a B16A straight up?
  220. Question!!!! Intake Pipe!!!
  221. 88 CRX what engine
  222. pics of my car
  223. EF-B18C/P72 ECU-VSS
  224. Some vids of my car.. Comments welcome.
  225. My spare motor.
  226. B16a in a 5 gen hatch with PS and AC
  227. No Vtec?
  228. Help installing skunk2 intkae manifold .... ???????????????????????????????????????????Install ing to
  229. Like a phoenix from the ashes...(B18C1 into EF pics)
  230. what kind of whp numbers are you getting w/ b20block/b16 head in integra.
  231. weak vtec?
  232. AEM intake w/ B16a in 91 HB
  233. haha, another Knock Sensor "?".....i kno you guys will say go do a search, but so far i c no answer
  234. 91 std---->b16a question.
  235. Pics of my del Sol (same as EG forum post)
  236. Forgive me
  237. Mount studs
  238. A few questions about B18C in a 98 Civic hatch
  239. Catalytic converters...which works best?
  240. CAI for B18c1 in 95 Civic Coupe....
  241. hyperducktuning?
  242. Newer b16a head on older block???
  243. pedal question
  244. D-Series Cam Gear - Worth it?
  245. CL headlight conversion??
  246. B18C5 turbod?
  247. B16a in a 86 Civic DX
  248. price?????help
  249. which ecu to use???
  250. People that have swapped the H22 into a civic/integra...help!
