View Full Version : Hybrid / Engine Swaps
- b16a swap in a 1990 honda crx hf
- 2000si brakes on 90 hatch what tie rods?
- Need to clarify which axels to buy?
- K20A type R swap into a 98 coupe
- ECU ? involving D16Z6 in 92 cx
- 92-96 Prelude suspension in a 90 Accord???
- B20 misfiring under load
- JDM ECU's suck
- Are CAM gears worth it?
- Car can't keep constant speed during emissions testing - B16 swap in ef
- 18c1 motor questions
- ALuminum VS Titanium Retainers
- swapping S1 5th Gear
- top speed on a civic wit a b20
- h23a vtec whose got it in there ride.........
- axles for k-series into 85 crx
- i need torque lb
- "gentle" 5th gear grind in h22 hatch.
- drive shaft shop axels ?
- Hmm need help on swap transportation..
- k20a2 into a 7thgen ??
- AEM is looking for Hybrids...
- LS in to 00 Civic
- Where to get a K20a ?
- knock sensor
- Swapped D15B into 95 DX Code 20 HELP!
- swapping cams
- what ecu?
- Help! (Electrical)
- My project update
- VAFC : Do I still need ECU upgrade?
- front clips
- B18C5 into 96 civic dx hatchback
- IAVC wiring directly to ECU
- zc swap help
- ??Lsvtec altenator belt question??
- ATTN: 96-98 civic hybrid owners
- b18 into non-honda, please take a look, I need help!
- Rear tranny bracket question- EG/LS swap
- GSR throttle rotor???
- What number is stamped on the CRV a/c bracket?
- ZC/Si Hybrid tranni questions
- SiR (b16a2) into '96 CX. I don't understand obd2a vs obd2b
- CA b16 owners..
- 1st gen b16 probs
- HELP! TACH/ELECTRICAL PROBLEM
- HELP H & F Series Guru's
- Noisy head any ideas?
- h22a into 93 accrd lx auto
- HELP PLEASE!!! idle problems....
- Help? Energy suspension 2 torque mount insert or Prothane 3 torque mount insert
- swaps. question
- What B series swaps can keep AC in EG or EK hatch.
- h22 guys.
- B20Vtec fuel pressure
- best b series motor
- anyone familiar with datsuns??
- 99$ engine crane on maxtool.com
- H22 tranny studs
- B16A head same as a B18C5 head?
- Wiring B18C into an EF
- b16a2 swap info...
- rear brakes
- Civic VT, b16a1 --> b18c6 (OBD Question!)
- Axles for B16A in 3rd gen civic?
- S2000 civic swap
- !!!!!FRONT CLIPS!!!!!! DO PEOPLE WANT THESE?
- k20 into crx???
- Wiring up vtec w/p28 and obd 1 gsr
- second gen swaps
- ahhhhh sputtering b18c5!!!!!!!!!!!!bad.
- 90 accord h22 swap prob
- Where to buy K20's?
- swapped out JDM ECU for USDM...need help!!
- whats the weights?
- Sway bar question
- h22a4 in 95 civic eg shifter problems
- does honda still produce B and H series motors?
- YAY! Finally getting my b18c swap!
- HELP! ls into 99ek
- b18c JE pistons and pins
- a/c bracket question
- Engine mount difference between DC2 & Ek? (B-series)
- shed some light on crx suspension please..
- CHECK OUT THESE CLIPS, WHAT DO YOU THINK?
- fixing header dents???
- hybrid piston swap question
- honda TPS - throttle position sensor all the same?
- PLEASE HELP!!!!
- skunk2 ecu 2 rich
- D15B7 LX motor in 92-95 Civic CX?
- Which throttle cable? EG, B18C5
- What people around greenville sc do good lsvtec work?
- B18C hood clearance in EG
- IMPORTANT INFO FOR B16 1st GEN WIRING.
- what intermediate shaft and axles
- power steering question
- K20 into 2001+ Civics - free information
- Where to Get ECU side plug?
- b16a into 4g dx vacuum routing
- b20z swapped civic to be smog, I'm dead meat.
- Any one have an extra knock sensor connector plug?
- JDM B18C into 94' VX wiring (HELP)
- CALLING ALL B16A 1st GENS!
- engine running very rich
- intermidiate shaft question
- i have swaps for sale but cant post in classifieds......help?
- how do you post?
- itr swap -Should I change fuel pump????
- H22 swap questions in ek???????
- Rust rust rust....
- RJCtrading?
- Question with my swap...JDM B16A head w\ del sol B16A3 block...?!?!?!
- ??what head??
- ANYONE HEARD OF THIS SHOP??
- Any body got a twin motor project going????!!!!
- 2000 jdm itr!! How much wHP you think????
- Pro's and Con's of GSR and LS tranny
- Post mini-me problems, Please help me!
- need help diagnosing weird sound (long)
- 16y8 in 95 cx hatch
- D16y8 Questions
- hondata for h22 93 si
- VTECing a Subaru
- Do NOT shove stripped wires into the ECU connector....
- b20 vtec oil question
- loud exhaust ticket on Thanksgivin Day!!!!
- Second Generation civic swaps??????
- b18 ls into a 93 cx hb
- how can i fix these mount points???
- JDM H22A
- K20 into DA?
- ATTN: S2000 powerplant FS thread
- 94+ Teg shell or 92-95 Civic hatch hor H22 swap?
- help deciding on engine swap
- how much for a wiring harness
- Swaps in California
- 92 LS into 93LS swap...IT WONT START HELP!!
- LS VTEC ?????????
- Anybody install a 94 gsr dc sports 4-2-1 two piece header on a b16a crx/civic?
- ORLANDO,FL ENGINE SWAP
- Dased and Confused
- Best pipe size for H22/EG swap!!!
- Searching for WORDS of Wisdom, Experience, Comfort/Consolation, etc. etc.
- will a 94-95 integra alternator work on a 2nd gen b16
- B-SERIES V-TEC CAMS
- Fields sfc vtec controller -- any hp ++++ gains possible??
- D16y8 swap
- Which car GSR into sol
- wiring up tach
- wiring guru help
- what exhaust to buy for 95 civi coupe w/ h22a?
- Looking for race lugnuts for h22/civic..
- OBD2 distributor
- tranny swap question?!?
- what program should i use for p72 h22?
- ECU and OBD on D15b Vtec?
- which throttle cable to use on EG w/ B18B swap.... PLS HELP...
- few ?'s about b20 vtec (dowel pin and torque specs) no flamers please
- set-up for gsr.....????
- jdm b16 block and gsr head
- k20 in to a ek hatch
- question about sponsor
- Engine importer out of vancouver, or any other western provinces?
- jdm P73 ecu and differneces in them from year to year???
- obd1 d16z6 into a ef dx
- Ek wiring information SWAPS
- 2001 GSR swap into a 97 Civic DX question.
- obd2 into eg
- mini me swap
- buying a block
- What o2 should I get?
- When swapping is it necessary to get the following......?
- today is my first time pulling an engine. I have a few questions?????????????
- Quick Harness Question
- JDM itr axles in gsr tranny??
- ? would a b18c block go good with a b16a head?
- Planning a B16 swap into a 90 DX
- H22 swaped into a 98+ accord.
- swap?
- Good price or bad price for 2000 GSR motor???
- predicted 1/4 time
- Thoughts
- WTF:about to LIGHT my damn car on fire!!!!
- To all B18C swap tech's
- OBD2 LS into a 90 CRX DX
- CRvtec throttle cable question?
- 93 hatch, B20, CTR header, Tanabe cat-back... how will I connect 'em??
- How much did you pay for your B-series?
- GSR in EGsi ...spark/fuel/compression....not starting
- problem with my Tach?!
- I need everyone's help for a gsr swap!!!
- went from lsvtec to crvtec help
- Vacum leak w/ ITR IM and TB
- 97 JDM ITR steering wheel into 95 civic ex. Need HELP PLEASE
- coilover question????
- OBD 0 to OBD 1 Injectors Removing Injector Resistor Box
- Has anyone ever swapped a small block chevy into their honda?
- Which tranny!?PLEASE RESPOND!
- Need an honest answer quick!
- d15b
- WTF, cant figure this thang out
- whick axles for hybrid replacement?? HELP PLEASE
- VTEC HEAD
- B16a1 in a EG4 (90hp) ?
- Knock sensor for JDM B16a gen 1?
- b20b with JRSC will not idle, dies if you let off throttle.
- slim fan for h22eg??
- What Exactly is a Wiring Harness?
- B18C or B18c1???
- Everyone with a swap....
- H22 Harness questions
- K-series in EG
- B18c in a DA
- Do I really need to get a new throttle cable?
- need to know what mounts are needed for 93 cx ... 99 si swap....
- Utah
- quick wiring harness question
- What Air Intake fits 88-91 CRX with B16?
- H22/Civic Swap & IE Header Pics!
- Wiring Harness question?
- B20A1 < ZC CRX
- re: fan
- question about swap
- [SEARCHED] Will a 97+ Oil Pan (h22a4) fit a JDM h22?
- stock b20/vtec seems slow, what to do?
- EK OBD2 ECU SWAP???
- ignition coil problem on swap????
- obd1 to obd2 question
- h23.h22 head swap
- itr 5 lug conversion w/92-95 civic struts?
- K20A1/2 (S/R) differences
- Will a GSR header fit a b16??
- H22 Sol with A/C & P/S.
- what ecu is a p2e
- Opinions Megan Racing cat-back?
- B16a sir 1 tools list?
- What do you think of www.japanmotorimport.com
- Need axle help for h22/eg project!!!!
- B18C1 in a EJ
- jdm itr swap completed, but there is something wrong!!!! HELP PLEASE
- Cam Caps on a B18B LS
- home maid pvc pipe intake??
- CRX to Integra spedometer cable
- Help
- integra les b18 motor in a civic
- Teach me... LS?
- axle squeak/click
- Tranny Questions
- Sound coming near the valve cover.. what is it?
