View Full Version : Hybrid / Engine Swaps
- b16a 90 crx si clutch cable issue
- Car Shuts off with new swap
- Help Please!!
- NEED HELP, NEW MOTOR
- Question on a motor build.
- Help needed too many diff answers
- What's the difference between these Hasport Mounts?
- tranny for h22 into 97 civic coupe
- h22 rear bracket question
- help with wiring and swap info
- OBD1 Motor In Obd2b Car(99 ex), ??
- Please help with swap... EGR valves
- D-Series Pistons
- Knock Sensor Code
- B16a2 Tranny into EG: what top mount do I use?
- fuel systems
- True LS VTEC
- H22 Hybrids...
- Auto Engine Harness
- gsr into ek
- 96 dx hatch...dohc zc obd1...
- Easy wiring idea, has anyone ever thought about this too?
- 2.4l ralliart civic
- I need help with my LS swap
- worth putting Z6 IM on D16A6?
- JDM b18c has no power, wtf???
- what are the sensor that wont let vtec work ?
- Doing a b20 swap into a 92 to 95 hatch
- Which axels to use..
- lsvtec ???'s pcv valve where do i put it
- 99 ls ACT clutch on a b16a cable tranny
- B16 cable tranny
- [Searched] Civic Brake Question: Asking Gurus for Help
- mini me question.. searched..
- What ECU to run with B-Series Swap?
- ARP head stud ls/vtec quick answer required (searched)
- Need feed back on Phantom Grip Lsd converstions
- h22 intake question
- Alternative for AEM CAI in a DC2
- which valves to use for all motor h22
- Are these all passenger side axles???????????
- which of these wires is the knock sensor? gsr swap in 92-95
- OBD 1 to OBD 2 or 3 not sure... HELP please this is the only thing holding me up.
- white smoke and the smell of burned oil
- gsr harness on a b16a2(need help quick, restoration process)
- which k20 is better?
- B16 LSD into a b16 transmission...
- Broken Bolts!!!!
- 1.6, 1.6z. 1.7
- '92 hatch swap
- B16B ?'s
- Please help... Sensor swapping.
- LS/Vtec Roll Call
- k20 help.
- Leaking oil around Vtec solenoid....
- What vtec solenoid assemb. is this?
- OBD 1 harness '95 civic to ECU
- Will a Type R Brake Booster and Master Cylinder work in a 93 Civic Hatch?
- Got my motor from hmo! will update this post with install!
- Engine Swap Questions
- Brand new to swaps just want to make sure I got everythin
- B Series in a EJ
- consequences for shift cable placement
- car not going into gears? only sumtimes? HELP!
- ITR lsd in GSR tranny?
- Wich Driveshafts for a Hybrid H22/EG with Yonaka mounts?.
- Tranny Problems
- z6 into 97 dx
- anyone have 0-60 or 60-120 times??
- LS Vtec Rod and Pistion Question
- CL to 94-97 accord?
- '95 Civic EX with '01 Teg LS engine Question
- Exhaust Question
- does the obx lsd have an washer type in the middle where the axle goes???not a stright hole like itr
- FS: JDM Integra Type R (ITR) Cylinder Head and Civic Type R (CTR) Intake Manifold
- Anyone anywhere NEAR Memphis???
- b20vtec problems
- What ecu to use with B16a2 in '98 DX hatch...
- Help needed with a 2000 ITR engine bay wiring harness!
- ITR Swap into EK Coupe????
- NEED ENGINE HELP
- 86 crx swap options...need opinions
- what T-belt to use with a b18c block and ctr head ?
- if i use a manual ecu with my auto tranny will i blow it up?
- B and D thermostats... same?
- Crankshaft End Play? mini me question
- 1992 h22 civic vx
- H22 Daily Driven?
- Help! Problems with auto to manual swap, Axle ground down
- fuel problem?
- Engine
- found a typeR motor cheap, newbie wants info.
- H22 Newb Question
- Possible Water in motor?? HELP!!!
- H22A running lean?
- can anyone give me feed back on syncromesh?
- wiring info
- Head Stud QUESTION, help me out please!!!
- Driveline Dimensions
- LS-vtec In a 1986 (wireing issues)
- Timing belt tensioner question?
- Drag spool question
- Studs vs. bolts. Plz help! h22
- Hypothetical question bout D16A6 and D15B8 and D15B7
- conversion wiring harnesss *not working help*
- Unsure of which fpr for my h22 to use...
- Need to buy axles/mount... have some questions.
- alternator help b16a
- 94 Integra LS VTEC TURBO Built
- Need Verification!
- Ecu problems
- Automatic LS engine harness on MT?
- people of so cal! well take care of your hybrid honda swapping needs!!!
- H22 wiring harness question
- B16a2 with JRSC in an EJ1 chassis
- Swap Help in MD
- Where did you get your Engine? Online? Junk Yard? A Shop? advice please.....
- P30 & P54 PS mounts??
- LS/VTEC boring?
- URGENT!!!! NEED TO KNOW NOW!!!
- Which oil pan? B18a w/ z10 girdle
- CEL's 2 and 41 on JDM B16 92 Teg
- 00 civic HX....what engine swap?
- Wiring Harness
- 93' B18A1 into 93' Civic Coupe EX - Please HELP! Wireing!
- pros and cons to the h2b
- SEARHCED PRIOR: Opinions on Avid Mounts, Linkage, etc.
- B16 crx SI = B16 crx dx
- I got a VTEC issue!!
- 93HB D16Z6 daily driver swap
- Axle Issues
- OBD2 3 wire IACV to OBD1 2 wire harness Help
- will d14 tranny fit to ZC swap?
- V6 C27 C32 auto to manual ?
- b16a/b18c no spark
- 3 axles in 2 days HELP
- What's the best Air/fuel ratio to shoot for on stock H22A motor?
- Exhaust Question for you hybrid gurus!
- my new lsvtec bulid tell me what u think
- H22a1 block and H23a1 head. Will it work or what's necessary?
- P-28s
- is a k20a2 street legal in a ek9
- ls mounts b16 motor(need a quick answer plz)
- How much should i pay for motor swap labor?
- Mini me ina 92 vx questions
- p30 ac bracket for an eg b18 swap?
- auto 97 dx -swapin in manual gsr obd1?
- H22 EG w/ skunk2 manifold?
- SWAP QUESTIONS PLZ HELP GUYS!!!!!
- Del Sol tranny swap
- How to identify if a B18C engine in a Civic?
- has anyone been able to keep abs after swapping a B motor in a D car with ABS?
- Car won't start, just backfires.
- crvtec vs h22
- 1st gen. B16 IM work on a 2000 CRV motor?
- h22 in a 98 ex coupe , wat am i looking at
- b16 swap getting code 36 jdm p30 traction control
- throttle cable help
- Need Some Help on Code Issue
- what ecu?
- having minor troubles after the swap
- Progress of my buddies DC2
- 1st gen or 2nd gen b16 head?
- Brakes Swap s2k rotor with legend calipers on a civic
- K20A2 Into a 98 EJ Brought to you by Twelvesorbetter & HybridKoop Coming Spring 06
- distributor
- 2 Intermittent codes
- shops in sacramento or surrounding areas
- rally crx
- h23 help me
- 0bd0 to 0bd1 jumper
- When doing a b18b1...
- automatic B20 vtec
- p73 ecu question with obd2 gsr harness
- LS-v in a 1986 Accord Hatch (need axle help)
- will a eg auto tranny work in a ef civic?
- Need help with H22 EG shifter cables!! any Custom Shifter Cables???
- CAI for a H22 in DC?
- wondering what to do?
- How do i tell if i have the correct distributor
- FAQ: Common swap problem AND general troubleshooting!
- Engine rebuild prices? Overcharged-Average-Cheap
- D15b to D16A6 swap trouble
- Engine Harness and more
- motor mount bolts
- 90 std hatch--->00 B18B1 swap OBD2A converted--> tach problem
- H22 into a 2001 ACCORD!!
- zc swap questions
- dynoed my car
- What To Get For EF
- Good Socal Swap SHop
- swap is complete, trouble starting....
- B20b - running, but not like it could/should
- Need info on JDM b16 swap into a 97 dx
- right size p.s. belt for b18b in ek
- assembly guide d series
- Need help quick: Vtec Solenoid plug question
- Itr swap into an 88 crx si
- why does my PGM-FI relay ground at the computer have positive power???
- OBD1 engine in a OBD2 Car HOW?
- how to install obx lsd to delso b16 tranny??
- H22, no spark
- h22 guys need help! strange knock sensor situation...
- why would someone swap an ls non vtec?
- H22 header options in an EF
- will an obd1 engine harness work on an obd2 car?
- Attempting first swap this week
- Could I use the EVAP wiring for IAB's?
- How to make Custom Axles
- the weirdest swap. I am lost. don't know what to think. Please help!!
- LSV converstion questions?
- Proper way to measure custom axle length? Working on a few hybrids.
- prelude shifter cables question???
- Help with B17 swap into CRX
- MISSION... d15z1... EG Sedan... super MPG....
- GSR IACV & Skunk 2 Intake Manifold
- cylinder heads
- Quick Accord/Prelude Hybrid Swap Question and Concern
- b18c1 gsr swap in eg VS H22 prelude base model. Both stock, who well win . Also going run a type
- Code 1... How do I get rid of this????
- H22 EG peeps i need your HELP!!!
- OBD0 o2 wiring help
- Integra radiator in civic........ fan question??
- b16a2 in 97gsr (need help quick, restoring process)
- IS IT EASY! A6 Block/ Z6 Head - Stay OBDO and Booooost!
- question about "salvage" titles
- obd0-obd1 conv.
- h22 swap
- disributor
- 97 gsr motor, JDM SIR tranny with lsd in 95 Civic DX Hatchback
- gsr block with b18a1 head???
- super touchy throttle and iacv not working correctly i think.
- Will this sensor re-usable
- EF: Si engine harness plugging into DX ecu harness?> I did search
- Triple Checking, LS VTEC GSR HEAD uses GSR head studs right?
- H2u5 tranny what mount should i use????
- CRV B20B w/ LS B18A1 head?
- D16y8 Head onto a D16z6 block. What does it take to make it work??
- Could ECTS be my problem?
- WILL A SOHC BLOCK MOUNT FIT B SERIES
- D16Z6 ON D15Y7
- speed sensor
- Shops in Connecticut?
- Anyone have ECU pinout for 1998 Integra LS (Non-VTEC)?
- B18C1 Swap 98% Done - Three Questions (Pic Posted) - Need Help!
- K20A2 in a civic
- USDM ITR Header question
