PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. To anyone with an H22 in their Integra ...
  2. PIC REQUEST: Motor Mount Near Valve Cover for B-Series Into EK
  3. jdm b18C5 swap
  4. B18C5 W/OBD2 into 92 civic ??
  5. 2 wire to 4 wire O2 sensor conversion
  6. UnTap LS VTEC Setup
  7. do B16 head have a production date on them?
  8. Meters in a N/A setup.... HELP
  9. i have a couple compression questions
  10. 96 Civic With a B-series...what exhaust?
  11. GSR swap with blown motor
  12. Mini Me swap info
  13. why would this be cheaper?
  14. stumped!!please help!!extra plugs after auto ls to manual gsr swap!
  15. altenator how do i test it
  16. Scaled my car today... how fat is it compared to yours?
  17. a substitute for hasport mounts?
  18. ECU ???
  19. ecu genius'
  20. Which BrakeLines Do I Use?
  21. EF B16a Random Stalling Help!
  22. H.M.O gets a Thumbs Up!!
  23. Wire harness from 93 del sol to 95 gsr
  24. p72 hybrid gsr...obd1 what do i need to use this?
  25. d16y5 (hx sohc vtec-e) into 1992 vx. I searched, i have ?????'s
  26. B16,B18C1 or B18B Need help deciding
  27. Obd0 to Obd1 help needed
  28. ecu questions and i have no clue how this is possible
  29. B17/B16 what cans and cants?
  30. LS/Vtec VS H22a
  31. OBD0 B16 into OBD1 94 EG Civic , No plug for sensor
  32. ls vtec build up
  33. need detailed how to
  34. ls/vtec pro needed!!!!!!
  35. o2 sensor in headers
  36. LS VTEC Disributor Question
  37. Lossing Coolant after LS to GSR swap?
  38. DISTRIBUTOR PROBLEMS?
  39. lsvtec in crx not starting (electrical problem)
  40. 1994 teg RS 193k :(
  41. Help With a F20B Swap
  42. inital startup ?
  43. an-r header fitment..b16..
  44. ZC head on a Z6 block??
  45. 93 CX wiring for b20/vtec swap, I need help!!!!
  46. battery light stays on.
  47. P08 o2 Pinout Location
  48. Question: What motor mounts for a B20B?
  49. Have a Question on VAFC II
  50. 00 gsr motor into 98 HX coupe, 98 HX motor into 92 vx hatch, questions about wiring and mounts!!
  51. 00 gsr motor into 98 HX coupe, 98 HX motor into 92 vx hatch, questions about wiring and mounts!!
  52. Is there any reason that a RSX Type-s trans will not fit in an Element
  53. need to know fair pricing on complete b20 swap
  54. Will this exhaust setup work???
  55. IS there any Good Hondata Tuners in NOR CAL
  56. Need HELP removing stock pistons from rods, cant figure out how to remove the wrist pin
  57. I Need help I have h22 running on a h23 wiring harness and distributor
  58. Will d16z6 head work on d16y7 block?
  59. Significant Oil Loss - HELP! weirdness.....
  60. crazy swap in 2nd. gen civic
  61. GSR into 95 Hatch A/C Question
  62. Shop Press
  63. b18c into ek coupe .
  64. which exhaust to use with my itr swap in a oo ek? (searched already)
  65. wiring harness question
  66. D16Z6/D16Y7 internals...
  67. 270cc injector good or bigger?
  68. H22 transmission + F23 engine?
  69. h22 tranny help
  70. MISSFIRING PROBLEM
  71. Please help!! SI harness!
  72. which website to buy from?
  73. secondary o2 on a 99 civic?
  74. JDM GSR in EK backfiring
  75. K20 vs. H22
  76. 90 crx daul point to b18a1 how tto please help
  77. what ECU to use....?
  78. just install walbro 255lp HP
  79. Axle Problems?
  80. Need info on swap?
  81. Crank bolt torque procedure?
  82. Please help.....
  83. H22A EG Valvetrain problems.
  84. 95 ls motor in ek
  85. H23
  86. H22 Ref
  87. HELP!! ABS light on. k20a into dc2.
  88. need info on 86 si swap
  89. gsr head Vs. si head
  90. b20 block ls head
  91. VX motor into 1997 EK Coupe motor mount question
  92. Which ecu to use?
  93. What lower hose for eg with gs-r?
  94. NEED HELP! '00 SI harness ECU plugs!
  95. d16y8 mini-me conv., "r-1 racing stage 1 cams" installed?
  96. GSR dipstick?
  97. k20 integra pics inside!
  98. Few Q's on B18B into EJ8 ('99 ex)
  99. goin turbo
  100. Help. Fuel problems on k20 swap.
  101. K20 swap wiring and mounts??
  102. LS/VTEC QUESTION
  103. K20a axles in a EG/DC2
  104. jdm h22a stock harness+p13 w/ obd2 car?
  105. Full AC B18c eg?
  106. Suspension ? 90-93 integra suspension into 92-95 civic hatch?
  107. ITR swap wiring questions
  108. Stock LS Pistons on LSVTEC #'s help
  109. Do I need tochange axles when converting to ITR brakes?
  110. need help for a b16 swap
  111. I need a 2.5 exhaust flange
  112. ECU pinouts B20/VTEC
  113. rmp's jump and vtec kicks out in 3rd gear
  114. 4G63 CRX
  115. Putting a PCV system on a B20/VTEC...
  116. search down..please help b16 into civic
  117. will a stock CRV K24 + K20A2 head be ok on the race circut, or only for drag racing?
  118. jdm distributor wiring
  119. what are my options for k20 ek mounts, exles and wire harness
  120. NEED A GURU FOR MY B16 SWAP QUICK!
  121. LS engine
  122. obd1 wiring question - pin B8-PSSW???
  123. Will a JDM P13 work with a USDM H22A4?
  124. need some swap information
  125. Former toyota nut seeks guidance in the Honda way
  126. PLZ HELP... HYBRID MOTORSPORTS??
  127. vtec issues
  128. JDM swap, wiring info needed
  129. Do Pre-1996 JDM B18C motors already have the VTEC pressure switch?
  130. Passing Smog Test w/ Hybrid Swap *HELP*
  131. sohc dizzy fitting dohc?
  132. idle surging! help!
  133. looking for the rigt head z6 or y8
  134. K20 immobilizer question
  135. b18c in 91 rex fuel pump not kicking on
  136. Is anyone runnin a ITR final drive with a J1 tranny!
  137. Wiring Questions?
  138. compression test on stock ITR?
  139. JDM p73 pistons on LS rods, whats the machine shop cost gonna be?
  140. Spoon GSR engine
  141. video of my h22 civic 4 door
  142. Which ECU?
  143. DA LsVtec ECU PR3 Hookup
  144. Drive axel Leak!!!
  145. k20a2 swap in 99 ek... what ecu???
  146. street imports h22 motor mounts?
  147. H22A into a EG starting issues.
  148. Imagine Header
  149. people who've dealt with Venus Auto
  150. Replacing my D16Z6 with a JDM B18C5 OBD2a and need help
  151. b18a1 driver mount on eg?
  152. 4G63 swap anyone??
  153. ITR motor in civic HX
  154. is this autoparts store correct?
  155. JDM B18C into a 95 GSR....which ecu to use?
  156. Avid Racing T-304 Stainless K-Series Header.
  157. Valvetrain Noise
  158. b20 eg
  159. VTEC not hitting hard
  160. RaVer Motorsports in Visalia...
  161. just blew motor,need advice
  162. Mini Cooper w/ a b18c1 engine
  163. which to pick?
  164. Ball bearings fell out of engine hoist!?
  165. wiring gsr into eg
  166. selling RSX tranny
  167. b18 into ek using hasport kit-which rear mount bracket??
  168. poor man's type-r
  169. P28 and P72 ECU Wire difference (OBD1)
  170. swap wiring help asap *pics*
  171. B20Bomber build-up for winter project GOT ?'s
  172. b16a2 swap help>>>
  173. Need info on 1982 Civic 1500
  174. obd1 swap in an obd2 car
  175. gsr swap in to 92 ls
  176. Weird problem (thinking ignition related see inside..)
  177. Help!!!! lsd broken? k20a
  178. Engine Post Mortem!!!
  179. 84 CRX 1.5 carb auto want to make Sohc vtec?
  180. h22 hatch o2 sensor wiring
  181. F22B1 swap in my 1g '87 CRX Si!
  182. GSR SWAP IN THE EK QUESTION
  183. need help on wiring h22 with h23 block into 92 cx
  184. f20b 96civic swap should I upgrade fuelpump
  185. b16a1 in to ef3 civic (wiring loom problems)
  186. b16a swap...wiring with Si harness??
  187. Slippy shift linfage
  188. Does d series throttle body fit b series?
  189. stock 2nd Gen B16a head on 83mm bored B18C block ????
  190. Linkage question, Just need to verify.
  191. WHAT TYPE OF HEADERS FOR MY B20?
  192. LS Vtech
  193. OBD2 in Pre OBD Car
  194. mph gauge dont work
  195. si vs gsr intermediate shaft
  196. Quick Q: B18C IM and other parts on a B18B
  197. Hondata
  198. Which throttle cable?
  199. Cable B16A in 91 Integra, Quick question!
  200. swap help!!!!!!!!!!!!!!
  201. Whats the highest Stock K20R output ever seen by you guys?
  202. question on mc and brake booster swap question
  203. www.totaljdm.com
  204. Stock K20A tuned by Chruch's
  205. Best Swap
  206. any shops that will install lsd on the east coast?
  207. vtec wiring ? i searched.
  208. Another first comming out of Denver(the opposite of the ls v-tec)
  209. does anybody know any reputable engine builder/tuners in the vancouver area??
  210. What Exhaust/Intake should i run 4 my 90si w/ B18A?
  211. for everyone that has had a CEL code 4 (ckp sensor)
  212. 01 GSR in REX Help with crank position sensor.
  213. k series swap to 99 civic coupe
  214. Skunk 2 or Blox?
  215. WHat headers are better for a b17??
  216. B18b1 club. Click on in!!!
  217. need obdo to obd1 distributor pinout (help)
  218. NEED HELP LS SWAP WITH FULLY BUILT GSR AND ITR ECU THROWING CODE
  219. QUESTION: B18B Rods in a B16A to Increase Stroke?
  220. Need Help b18c in 91 CRX HF
  221. upper and lower radiator hose collapsing
  222. New Complete LS-VTEC/CRVTEC Hybrid kit on eBay... Good stuff or not???
  223. shifter bushings which ones?
  224. best swap for a crx
  225. GSR swap help! please
  226. h22 Idle problem
  227. How Long your swap took?
  228. Hybrid Lowering Springs
  229. H22 EK Axle Issues
  230. 90 b18a into a 89 crx hf (engine harness question)
  231. ECU and bar inspection?
  232. VA/MD/DC shops?
  233. Stupid question for the day... H22 Oil Change
  234. Mugen **Race Use Only** ECU
  235. ot: need a Mecahnic in San Diego to fix my h22 motor
  236. i got exactly $1,000 to spend for my Hydrid gsr
  237. Info for H22 into an EF (tried searching)
  238. Engine Harness Question B16
  239. hybrid gsr into civic coupe 95, need help with radiator replacement
  240. OBD2 shell with an OBD1 motor HOW DO YOU CHECK THE ECU CODES?
  241. any swaps that dont include 3 billion headachs?
  242. Transmission into EG compatability question
  243. LS PR4 rod interchangeablility???
  244. H22 Swap: Need Help
  245. quick wiring question
  246. K24a2 TSX hybrid Dyno sheet.
  247. alignment needed
  248. K20 Type R
  249. Gsr swap into a del sol
  250. D4 flashing on 97 Civic EX with a B16 with an Acura LS Auto tranny swap
