PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 [174]
  1. Emissions?? how the hell do i pass em???
  2. Radiator for a 4 gen civic si b16a swap ???????
  3. LS-VTEC VS B16A
  4. Anyone here ever heard of DHracing out in california?
  5. Does anyone have that front mount intake system?BAD or GOOD
  6. What should a 97 Civic Hybrid run in 1/4 ?
  7. first run with car at drag strip
  8. cable to hydro conversion questions.
  9. What do I do with my GSR sway bar?
  10. SWAPING Tomorrow ALL DAY Baby >>>>>
  11. need opinions on setup 4 EG?
  12. GSR swapping ?
  13. O2 sensor problem
  14. What Tranny to use?
  15. Will new RSX Type S engine be swapable?
  16. Will new RSX Type S engine be swapable?
  17. Swap: LS+turbo or GSR?
  18. crx hybrid fuel injector question
  19. What's the going rate for dyno time?
  20. '87 Acura Integra swappable?
  21. Swap Info: b20z in EG
  22. FS: '98 B20B Block
  23. swap or rebuild f22
  24. poormans ITR??
  25. Experience with GSR p72 ECU on b16a???
  26. what tranny will fit my 97 LS integra
  27. what tranny will fit my 97 LS integra
  28. problems in B16A?
  29. Type R Cam in a GSR head?
  30. Type R Cams in a GSR head?
  31. !! i need all the help i can get!!!
  32. How to 'LS 5th' your tranny
  33. Car Boggs mid power band (GS-R Coupe)
  34. H22a specs?????
  35. vtec oil line
  36. which axles and halfshaft for Hasport cable--->hydro kit...?
  37. What is target compression level for a B18a?
  38. GSR swap
  39. Type-R sway bar in EG....problem?
  40. Check List for 94+ LS swap in 92 Civic Hatchback
  41. H E L P !!!!!! MOTOR SWAP IN GA....I NEED HELP!!!!
  42. My planned CRV/VTEC Setup, what do you think?
  43. GSR motor :thumbup:
  44. vtec in 90 integra GS
  45. How to go about building a Hybrid!?
  46. used turbo..yes or no?
  47. B16A in a 90 civic
  48. h22/23..direct fit?
  49. Stroking a B16A by swapping B18C block?
  50. Y1 trans, and a couple questions
  51. will 90-91 teg knuckle fit EG's??
  52. Which throttle cable to use for b16a2 swap?
  53. Anyone have wiring diagrams to wire OBD1 distributer into OBD2 harness
  54. did search! still have ?'s about LS/VTEC
  55. whats faster? b16a or b18b?
  56. Swap is in, cranks over, FP is good, and no spark. Need swap/electrical info.
  57. GSR front and rear swaybar on 5G hatch
  58. what kind of clutch to get?
  59. Code 41-02 sensor?
  60. b16a ac adapter? and power steering?
  61. Cam gear specs?
  62. Quick question...
  63. Can a '93 GSR Harness (complete) replace a '88 CRX Si?
  64. So, you know your hybrid stuff? Lets see.
  65. smogging a JDM b16a....will it pass?
  66. what is the best place to buy an engine.
  67. B20B with an ITR head??
  68. 97 ex and 00 si ecu questions
  69. which harness for a d16a6 swap...
  70. B16A wiring into a 4th Gen question
  71. people should get charged for this
  72. SOHC vtec or DOHC non vtec??
  73. 1.5L SOHC 16-valve motor upgrade questions.
  74. GSR front Brakes into 93 Civic hatch
  75. ANYONE WITH LS/VTEC OR CRVTEC FOR LONG TIME???
  76. B16a into 90 HB...parts needed?
  77. Swaping Heads???
  78. Good idea or what???
  79. integra type r engine into 92 hatch....little bit of help needed
  80. header swap???
  81. Web site for LSVTEC
  82. What engine should i get?
  83. Hybrid exhaust ?
  84. Engine Stand??
  85. I NEED ENGINE MOUNTS
  86. idle problem
  87. Good engine swap shop in Seattle?
  88. How much for engine swap?
  89. All motor question
  90. Whats the best year hb for a b18c1 or b16a?
  91. how much do places charge to install?
  92. I test drove a 92 Civic hb with JDM b16a...
  93. best parts to use
  94. Please post your pics and engine swap info
  95. clutch noises
  96. Black Sheep (B17) ECU Question
  97. How fast are Prelude powered Accords anyway???
  98. Need Help on ZC swap!!!!!
  99. Tranny rebuild shops... suggestions?
  100. h22 Power steering
  101. Pic of the crack in my tranny case
  102. VAFC settings for LsVtec's
  103. '93 D16Z in 89 CRX...
  104. I thin kI got gipped.....help!!!!!
  105. Oil Leak ?
  106. What is the potential of stock CRX SI?
  107. Performance Shops in Central FL that do engine Swaps
  108. Maybe Selling the Hyrid : (
  109. knock sensor -> ecu signal....... please help?
  110. Ls/Vtec Questions
  111. I NEED A B20Z BLOCK!!!!!!!
  112. vtec inside a pontiac grand am?????????
  113. b17a in 96' civic coupe, motor mounts????
  114. axles for a b18c1 cRx????
  115. DPFI to MPFI
  116. arp head bolts
  117. Looking for b16a swap.....
  118. axles for a 91 b16a swap
  119. Help me find the cheapest ALL MOTOR formula for 12's
  120. Yet, more updates. Tranny leak fixed, but HAIL damage!
  121. what's the technical difference between the b16 generations...?
  122. My Territory (J-series swap)
  123. F/S 95 Civic Si H/B
  124. Crvtec a good Idea?!?!?
  125. Street duty CRV-VTEC buildup... Opinions wanted..
  126. B17 or B16
  127. Hybrid swap completed!
  128. B16A1 CRX won't start.
  129. Charging problems???
  130. what can i do to a b18c to perform like a b18c5?
  131. argh!
  132. R cams in GSR
  133. fuel rail/fuel injector question HELP
  134. h22a obd2 - obd1????
  135. hybrid instrument cluster
  136. aftermarket adj. shift-linkage or custom integra one??
  137. Not exactly Hybrid Question... (Head, Valvetrain)
  138. 92-95 SI HEAD SWAP ON A DX. NEED HELP
  139. I should Finally get the Blue Meanie back today.
  140. is it possible to go ahead and replace 1992-1993 GS-R to a 1988 CRX Si Harness?
  141. Wiring Harness Question
  142. times for 92 hatch with gsr motor and bolt ons?
  143. Rear mount for swap? not about a kit though...
  144. Ls turbo...what is the best tranny?
  145. ECU NUMBER?????
  146. Some Basic Hybrid Questions (CRX)
  147. HELP HELP "High Idle"
  148. which helm's for a 1st gen b16a?
  149. Engine Freight Company?
  150. Help important SWAP coming up >>>
  151. Energy Suspenion mount kit for 97 HB w/ GSR motor?
  152. Full width radiator in eg
  153. Which Helm's manual do I get if I am a Hybrid?
  154. Swap for a Vigor
  155. How Hi is too Hi.
  156. Need a 4-wire O2 sensor.
  157. Hey guys, b20b is going
  158. EX Swap???
  159. Question about going Hybrid in a 93 civic LX 4door
  160. Bad tranny or clutch
  161. ITR INTAKE MANIFOLD 4 SALE... FITS B16's
  162. EVAP Canister hook up?
  163. Spoon wheels
  164. exhaust help, 95 hb w/ greddy sp made for the 96+ but its a hybrid ???
  165. Mount kits for a b16a into a 4th gen civic...help
  166. cable to hydraulic tranny?
  167. B18a running rich
  168. Low budget swap
  169. Hybrid owners...what did you do with your original setup?
  170. Swap update...
  171. Skunk2 OBD 1 ECU for GS-R
  172. OBDII
  173. Is B16A/YS1 LSD for $1400 a good deal? Good for 89 CRX SI?
  174. This isn't relavant to this forum but i was wondering ....
  175. to complete a ls/vtec.....
  176. b16 rear mount...?
  177. B18C1 Questions
  178. ENGINE SWAP INFO, MORE TO COME www.kennewickimports.vista.com
  179. who has a 1st gen b16 in an EG?
  180. B20(b or z)/b18c valve train.
  181. Already thinking of a new swap!
  182. how to find out if block is legit??
  183. helm reset not working
  184. Need Help on Engine Swap in a Del Sol Again!!!!
  185. Please HELP!!! just did sirII swap
  186. d16y8 in '90 crx Q's
  187. Need Help on Engine Swap in a Del Sol!!!
  188. swap's which one should i get?
  189. 98 h22a ecu into 95 accord??possible???
  190. hybrid vs. hybrid
  191. Changed my timing belt and water pump. Installed my header...
  192. I'm Putting a V12 into my CRX Si !!!!!!
  193. 98 H22A into 95 accord lx
  194. B18a spap in CRX. Getting a code 12 ...
  195. I was going to buy a used Tanabe RM cat-back pretty cheap, then...
  196. Legend 6 speed
  197. h22a into 95 lx
  198. uk vti owner needs engine swap advice
  199. LS-VTEC costs?
  200. Attn: H22A EK HB owner....
  201. How much am i looking at?
  202. B16a w/ greddy 15g turbo???
  203. 6spd LEGEND/NSX Tranny, bolt to Last Gen TL?
  204. LS/VTEC Knock sensor
  205. Help with axles for B-series swap
  206. vacuum line diagram for b16a
  207. 1994 AccordLX - Hybrid project help!
  208. can you swap tbs
  209. starting problem
  210. What do you think???
  211. Tuning Field VTEC controller
  212. I'm thinking of taping my swap this weekend...anyone interested...
  213. need help with ls swap
  214. Mini me swap
  215. Which head to use for turbo?
  216. Will an LS/Vtec clear the hood?
  217. ZC Zdyne Ecu
  218. JDM b16a SirI vs. JDM b16a SiRII??
  219. code 14???
  220. LS or 1.6 vtec Turbo
  221. Dose ITR head fit B16A1 block?
  222. new hybrid owner
  223. Papers w/ B18c1 Swap?
  224. high flow cat
  225. Swapping pistons?
  226. Injector help pleaze
  227. What is your Fav CAM??
  228. b16a bottom end with b18c1 head?
  229. Anyone looking for an ITR motor?
  230. JDM B16A1 Wiring Questions or Vacuum Questions?? LOOK HERE!
