PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Innovative's h22 -> civic a/c bracket
  2. too big halfshaft ? :S
  3. My best choice for engine?
  4. help with b16a2 into 88 crx hf
  5. aem cam gear bolts loose need help with timing
  6. GSR block b16 Head (poor man type R)
  7. cant get any power to ECT sensor on 90 integra obd-obd1 conv..code 6 ect. limp mode?
  8. Auto EWH into manual car?
  9. A/C and P/S with H2B swap?
  10. Saturated rc 310cc question
  11. when i start the car, the radiator fan goes on?! wtf
  12. B18b LS automatic into D15 DX automatic EG.
  13. 99H22 in to 97 accord
  14. b18C6 swap sensor problem
  15. 93 delsol b16A->b18cGSR swap questions: manifold, trans, motormount, ecu, CA SMOG???
  16. jdm b18c type r ecu
  17. help with my h2b
  18. N/A G23 hp/tq numbers??
  19. JDM H22A swap smog help
  20. NEED Help with headgasket and timing cover
  21. car vibration when in between rpm
  22. d series tranny question
  23. need wiring info OBDI dizzy to OBD2a dizzy
  24. tach drops to 0 after vtec hits
  25. alternator belt in b18c6
  26. H22 in a CRX.
  27. k20z pistons in f23 block
  28. 92 eg with h22a clutch question!
  29. f2b stock how much boost?
  30. differences between h22 and h23 midshaft (or intermediate shaft)
  31. b20 vtec problems
  32. GSR B18c1 into 96 EK
  33. DC2 Inelt v B18c1 question!
  34. Civic to Integra transmission mount change up?
  35. B20b block with Ls head
  36. B Series Swap:Which Rear Mount into A/T Civic
  37. f2b info
  38. H22 DEL SOL SWAP ( SHAKING A LOT AND LOUD!!!)
  39. obd2a ls/vtec question
  40. My Hybrid lost all power, and locked me inside...
  41. eg f22 mounts
  42. 96 ls swap is bogging down help
  43. F22B1 in EG Project/Info Thread
  44. running EG subframe in EK
  45. 99 Civic H22 Speedo not Accurate
  46. whats needed?
  47. Distributor wiring?
  48. 96 d16y7 auto to 95 b18b m/t what ecu ?
  49. AEM hybrid intake for civic in integra?
  50. help gsr internals and b16 head in ls block
  51. Altering S2000 odometer for a DC2
  52. ek with gsr exhaust quetion..
  53. help...need 2 pics of particular engines
  54. obd0 non-Vtec converted to obd1-VTEC, problem; motor stays stuck in VTEC!!
  55. evolution h2b kit question...
  56. f22a6 head on f22b2 block?
  57. B20 VTEC VS. GSR??????
  58. Has anyone used this for their home made motor mounts?
  59. Lost...searched, F22 in EG wiring
  60. b20vtec sandwich plate and oil cooler problem..please help!
  61. H22 / Civic swap axles
  62. LS/VTEC piston/valve interference questions.
  63. has any body tryed this swap?
  64. Stock fuel pump for H22 civic?
  65. problem with B series swap
  66. mini-me gas delima.
  67. GSR block - LS crank/rods w/ 84mm bore
  68. k20R swap issues
  69. 98 Civic EX harness with 98 B18C... IAT code 10
  70. B16A2 into Carbd EF9
  71. Help: F22B1 into EG Chassis Side Mount Bracket
  72. HELP B20/vtec vs LS/vtec
  73. How much does a H22 CRX weigh?
  74. lsv swap when should vtec kick in?
  75. big difference? b16/ctr piston
  76. Help b18c into my ek won't start!
  77. Quick D Series Question
  78. B20 compatability Questions
  79. lsv ecu help
  80. D16z6 swap into EK
  81. ctr piston into jdm gsr motor
  82. f2b swap in eg9 info
  83. Q's about Head work on my H22(valvetrain)
  84. first acura Ls-vtec
  85. b18C-r swap into civic EG6 vti
  86. b17 with b20 crank
  87. EG B18C Wiring with ECU Jumper Harness
  88. B21a1 cams in my b20z/b18/b18b
  89. F2B/H2B handling? Input from people who have ACTUALLY done it.
  90. Can I run without an EVAP purge solenoid valve?
  91. F22B2/F22B1 swap problems
  92. JDM civic.... JDM H22a
  93. Hybrid engine question-
  94. Skunk2 Manifold or keep GSR Manifold?
  95. G25A/1/4 Swaps
  96. b20 reliability
  97. B20B question
  98. v6 swap
  99. H22 auto-manual tensioner conversion help
  100. My idea for a build...
  101. Can i use b18c1 springs and retainers in my b16 head?
  102. Swapping my ek need help...
  103. 2 Head Gaskets?? High Compression?
  104. lsvtec piston oil cooling problem solved :P PURE DIY oil sprayers
  105. LS/VTEC into 94 civic DX questions...
  106. 2000 usdm Integra GSR --> OBD2 jdm CTR ecu ?
  107. swapping out CVT transmission out for 4spd automatic
  108. JDM H23 VTEC swap ECU help
  109. JDM H22A Accord or B18A1 Civic hatch?
  110. Replacement Harness for '88 HF CRX w/h22
  111. Which heater hoses with B18C swap
  112. Ek Kswap Questions. HELP.
  113. d15b..power steering bracket and pump??
  114. OBD2B gsr swap into a OBD2a Civic help
  115. 96 - 98 civic dash in an 90-93 integra conversion
  116. Honda Swap into a different car: emissions/obd2 questions
  117. wiring questions about h2b into a DA
  118. j35a8 into ej1
  119. B20 Vtec question
  120. B20 ON TO A LS BLOCK
  121. 1987 crx hf want to make it fuel injected
  122. h22 help
  123. Hybrid B-series SWAP HELP !!!!!!!!
  124. what iacv do i need for edlebrock mani?
  125. h22 swap...problems
  126. EGHAX CV boot
  127. Code 9 (CYP) JDM B18C '98 Civic DX
  128. Question To: Those Running H-Series/F-Series in EG/EK
  129. skunk2 pro series VS. edelbrock victor X.
  130. B18C5 in EK Smoke in Intake
  131. D15Z1 Motor in 1996 Civic EX Harness Plug Problem
  132. need help?
  133. For MPGs, VX swaps!!! Need help please!
  134. ABS Swap.... Yeah.
  135. B20B swap ECU question
  136. can't find the thread
  137. h22a swaped ek with v-tec not working
  138. lsvtec help
  139. Help! 00 EX lower radiator hose on b16a2 and 2 more problems
  140. h22 powerd dc2 integra starting isuues??
  141. Why Buy Name parts.
  142. gsr back bracket Q
  143. 99-00 civic b18
  144. after swap no rpm
  145. H2B Dyno Chart H23A 203/165 Bone Stock Longblock never touched, dropped in as is
  146. obd2 b16a into a DX EK...
  147. Help on trying to identify a transmission???
  148. yonaka swap axles(e-bay)
  149. FAIL: bisi slave cylinder
  150. still need help b18b1 obdII into 98 ex
  151. OBDII B16a2 distributor plug and EX harness
  152. Blue smoke at random times??? long story
  153. D16Y7 harness for H2B help
  154. Anyone Running Fuel Efficient Maps?
  155. GSR weird rev limiter prob
  156. dc2 vrs da front upper control arm isuues
  157. Z6 in EK chassis...IAT problem
  158. Car wont start all of a sudden...please help!
  159. EG h22 axles and EK h22 axles
  160. 91 Integra: OBD2A full electrical conversion idea?
  161. JDM H22 Auto Transmission on F23
  162. b18c... how to tell if it's a type r ....
  163. H issues out of nowhere!!
  164. b20b does not rev pass 1000
  165. F2D 4wd is it possible?
  166. b20 swap..pcv issues
  167. REAR L BRACKET QUESTION
  168. H2B Baffled sump/oil pan
  169. h22a1 ej1 dizzy help
  170. will b16b s4c starter work with h2b?
  171. MINI-ME VTEC HELP *** PLEASE *** D.D. Down and Out
  172. K20a3 engine harness on K20z3 swap...
  173. k20a2 or k20z1
  174. need help on b20 vtec setup please
  175. G23 for the automatic accord
  176. already prepped ls Vtec head back onto vtec block possible?
  177. QSD H2B Instructions; whose got ne?
  178. WHAT IS LS VTEC???
  179. B16A - I want to buy a book on this engine. Suggestions?
  180. B16 IM onto GSR
  181. Element potential-engine bay
  182. K&N air filter for F20B
  183. 2000 civic hatch with itr cluster
  184. can i rev 9k
  185. AC Problem
  186. Looking for K-Series IN EG with complete wire tuck BAY AREA
  187. d15b2 mini me timing help
  188. G23 vs H22A for a daily driver
  189. EG6 K20 - Drive shaft question
  190. What do these wires go to on the engine harness
  191. Fuel pump/harness issue h22 eg
  192. full h22a swap VS h22a h2b swap??
  193. rhd swap?
  194. NO SPARK-EXTERNAL COIL!!
  195. H2B EK Civic Power Steering?
  196. Calling all H22 CRX owners? (with hasport mounts)
  197. Type r ek hatchback owners with experience wanted
  198. y7 block/ y8 head issues. help anyone?
  199. ? about ctr intake cam.
  200. QSD H2B Spacer?
  201. H2B EK civic Crank pulley Clearance
  202. trying to go h-series need info
  203. Ebay Poly engine mounts anyone use them?
  204. ls vtec quik questionns...
  205. Building a frankenstien need some advice.
  206. h23a bluetop help ej2
  207. B20vtec valve broke what could have happened?
  208. (Rebuilding Hydrolocked LSV) Do I need a block guard?
  209. H22 Head/H23 Block- Timing Belt jump??
  210. Quick Question. parts for b18c1 swap in EG
  211. EVERYONE NEEDS TO KNOW THIS ABOUT EK BSERIES SWAPS
  212. JDM Prelude Type-S camshafts in a F20B
  213. b18c type r swap in 90 integra-ecu throwing out CEL code 26 WTF!!?? HELP!!
  214. H2B alternator bracket (Ef chassis)
  215. d15b8/d16y8 mini me into 96ex HELP crank sensor?
  216. 2000 CX converted to obd1 d15b swapping 2001 jdm type r complete
  217. b18b 96 civic ex wiring??
  218. i need help
  219. Wiring question?? gsr swap
  220. h2b clutch slip
  221. no rpm after obd2 to obd1 swap
  222. H2B TURBO RUNNING HOTT HELP!!!!!
  223. gsr swap into dc harnes question
  224. 2001 GSR into a 2000 Civic EX
  225. h22 civic needs help
  226. H2B EK 1996 Hasport EKSTK mounts problem
  227. simple ef/da motor mount question
  228. HELP h2d with h23a in ej2
  229. H2b Flywheel ACT Streetlite vs ACT Prolite
  230. High Compression d15z1
  231. GSR into DA wiring and tranny questions??
  232. poor mans r
  233. obd2-obd1 issues
  234. obd1 LS to 99ex coupe
  235. Timing belt tension on LSVTEC, loose.....HELP PLZ
  236. The Ballad of TotalJDM (torontojdm.com)
  237. Clutch for H2B
  238. help me honda acura gurus help my brother
  239. b16b vs. b18C (jdm gsr)
  240. h22 in 2001 insight
  241. H22 EG Mounts Help
  242. H22a into 00 EK DX Hatch - Full Swap (Please view)
  243. zc dohc in ek?
  244. vss speed sensor help
  245. Anbody using the revised Evo inustries kit?
  246. please delete this thread
  247. New setup question b18 to b20. b16 tranny. Is it worth it?
  248. Finally received my Bisimoto Header!
  249. What mounts, Clutch and Flywheel are recommended for EK H2B swap
  250. Evolution h2b kit
