View Full Version : Hybrid / Engine Swaps
- I have a CRX thinking about D-Series SOHC VTEC
- Honda Civic that.......
- Mounts Fo H22 in 96-2000 Coupe...
- Knock sensor?
- 94 Civic Hatchback/What Generation??/Whats agood swap??/Best place to get the complete swap??
- H22 guys... what ECU you running other than P13?
- bleed clutch when replacing clutch before swap?
- Short ram intake for ek-22
- Code 20 and 41 Help!!
- Look, it's another H22 Hatch!!!!
- Questions about h22 in an EJ... that's right I said EJ
- where to buy a cable tranny
- d-series engine swap into 84-87 civic/crx
- Pics of the H22 :)
- ecu question
- First State Ref visit is now complete. Need some help :)
- Budget Swap for a beater
- Possible swaps for an EF Civic hatch
- EG, b18c1, skunk2 intake manifold and a god damn AEM cold air intake
- B18c crx hood shutting problems. Any tricks to fix?
- Going to add gauge pods to my Eg/GSR Hybrid! Need ideas on what gauges!
- JG IB 2.5" header for B20VTEC CRX
- Shift Linkage, and Axle In EK Question
- 88 crx dx auto -> b20/vtec manual
- to do list for b18b into 96 dx hatch
- Hitin the REF with this setup....will it pass?
- CPh22a/ek hybrid
- B16 in EG swap problems?? Please help!!!
- h22 swap idle problems?
- Anyone run extremely lean when going catless on OBD2??
- 01' USDM Type R ecu question
- question about jdm sec. gen b16
- LS into 93 civic VX! which heater hoses and throttlecable
- GSR Head
- problems with 93 accord auto->standard H22 swap NEED HELP,Won't Start
- question on hybrids and steering bias
- having trouble with jdm b16A swap!!
- 93' B18A1 block + 01' B16A head?
- b16a1 swap won't start
- what axles and hubs do i need
- IAS vs hmonline.com
- anyone know the exact differences between h22a and the h22a type S???
- WTB B16A OBD1 distributor for the swap: I know this is the wrong forum....
- Stock EG exhaust W/ GSR swap?
- started GSR swap and it sits at 4500 rpm
- Del sol shift linkage on 93 CX?
- Tranny question
- What clutch to use? b18c
- Which ecu to run in a b20z 6th gen. hatch
- Fuel cut at around 7700 RPMs on a B16A
- ls/Vtec setup ???'s
- where can I get a good p72 ecu?
- Need Some Smog Help
- Need some help here!
- vx 02 sensor into b16!
- auto to b18a
- HELP with my b16 swap in a 91 crx si!!!!!!!!!
- VSS swap?
- jdm b18c + p30 ecu = closes secondaries?
- h22 Type S Story. Car feels so much stronger!!!
- osaka motors whats the big deal?????????
- b20 question?
- Shuddering when accelerating??
- Confused? What is the most complete/cleanest D16z6 swap?
- bseries shift linkage!
- Help with swapping a b16a si-r 2 into 1992 hb
- H22 swap (cable tranny) question?
- h22ek enjo mounts??
- Need help about rebuild and swap questions--- please help !!
- b16 into 1st rex
- d16z6 head on d15
- 99 SOHC Non-VTEC swap into 88 CRX questions!
- When should I change the fluids (oil, tranny, coolant) on my new Hybrid? Eg/GSR!
- H22 Injectors- 1234 or 4321????
- White Smoke! [vid inside]
- Wiring Harness Problem...
- doing a b18b in a auto civic (99 dx)
- Engine swap on 92 civic hatchback ..
- Swapping a F22B1 into a 94 Civic DX Hatch
- Please give me a reliable company to order an engine from...
- Knock Sensor!!
- Coolent issue!! Please Help!!!
- Bought a motor..FINALLY!!!!AAAAHHH
- Hydraulic clutch line help for H22 EG swap!! ASAP!!!!!!
- My dyno's # for slightly modded B18c1
- what should this thing run?
- in the middle of b swap w crx hf
- need help about trannies!!
- 92 B18a1 in to a 93 VX
- my B18c fried to Ecus!!
- FIT OR IAC valve or both ??? EK w/ JDM B16, help
- Swaped LS/Vtec to B16a2 - won't start????
- P13 Code 14
- Help! All Techs and Swap Installers! JDM vs USDM Wiring Harness!
- zc swap help
- new motor what type of oil??
- Just Got My Swap!!
- axles for h22a swap
- Obd1 jdm GSR ecu
- D16z6 burning oil like crazy:(
- b18c JDM oil filter part #
- need expert help (about 2 drop a ls vtec with a b16 head into a 92 civic 4 dr
- Pics of my 92 VX hatch with B18c1 swap
- Hybrid civic speedometer not accurate with GSR motor??
- No Vtec in just finished swap! and running like crap
- 99 civic swap is done Pics inside
- p28 code 16 (h22/hatch)
- Code 14 problems HELP!
- what will this LS-Vtec run?
- Please post your high compression fuel setups???
- cannot get to the dyno, i need your help guys.
- Need help with OBD0-OBD1 distributer wiring
- IACV's the same between 92-00 for the 2 wire on civics?
- 1G CRX swap questions and compatibility
- compression test
- B16a1 Build help *few Q's pls take a look"
- What flywheel would you recommend?
- Need Help!
- F*CK. wrong pistons=8bent intake valves.
- b16a1 help?????
- Need Help
- 99-00 civic green plug ecu pinouts
- 00 ITR motor with AEM ECU into 92 EG...
- wiring help h22 in 91 accord (searched w/o answer)
- can some1 please give me the ups and downs of ls vtec......
- Any experience/input with an H22 motor using an F22 tranny, can it be done?
- shielded wire for 02 sensor
- b18c5 and the b16a which head runs harder on an ls block??? hummmm......
- b16 swap throwing code 1 and 19
- question
- what is the hp on a f22a?
- cai for an h22 swap
- LS 5th in b16(J1) tranny...
- piston to deck height
- H22 guys.. why are my axles crooked?
- Need some advice with possible b17a purchase.
- Speedo is waaaay off after swap?
- VAFC tuning with b20vtec...need suggestions
- Few questions About my D16Z6 Swap in 1991 crx si
- Code 41. Help!
- v2 eg b18c???
- urgent info needed for gsr ecu
- H22 in a 90-93 integra DA possible?
- JDM p30 ecu FACTS---MYTHS, HELP Me!!!
- Swap Needs? (what do you need for complete swap)
- Which motor would you use?
- CTR pistons in a B18 block?
- Swap Suggestions
- pcv system help for ls/vtec
- ls question. what year and eng code?
- What size nut for a obd0 02 sensor bung
- jdm parts interchangable wit US specs?
- 99-00 swap guru's need help fast!!!!
- how to tell a USDM b16a from a JDM b16a by looking at it?
- h22 civic problems
- Quick: D16A6 (4th gen) into 5th gen
- What color is this hatch
- How to indentify a 90-93 Teg intermediate shaft?
- LS block question???
- secondaries manifold on GSR
- emission and smog in washington state
- CTR pistons on ls rods
- high pressure fuel pump (searched)
- B20VTEC into hatch?????
- will a p28 chiped run 370cc injectors
- dual friction clutch??
- Civic b18c NA time slips???
- Need help b20a3
- LSvtec CRvtec ecu's??
- Buying CRVTEC....is this good price?
- Hasport and Hydro tranny?
- b18 swap info about tranny
- b16a1 into 1991 Integra LS *What is needed?*
- Need Site w/ECU pinout
- HELP NOW!! jdm HIDS (wiring)
- hooking up vacum lines for hf ctx to skunk2 intake manifold on b18c
- Shaking crank pulley??
- engine wire harness question?
- lsvtec or crvtec
- mounts for a turbo h22 in a eg?
- Why can't I check my CEL's?
- best header for a JDM B16?
- H22a euro r intake manifold install????????????????/
- ls-vtec
- obd2 to obd2 swap
- Thermostat ground?!
- final check list for my h22a swap help me double check
- b20b into d16z6
- code 36? h22 eg
- s2000 swap?
- subframe under EG H22
- does anyone know how to hook up a 02 senor on swap
- Car running real lean help!!!!!!!
- quarter mile times
- h22 eg guys w/ lsd... can you break the tires lose in 2nd or 3rd?
- how much can i sell a complete d16z6 (95) for?
- My Sawp Is Completed
- ls/vtec pistons
- h22 civic quarter mile
- B20VTEC or B16a?
- b18c w/LS ecu obdi
- LS turbo, fully built ls or b16a gen 2
- HEY!!! Need info on intake manifold swap
- b16a1 in a 91 2g integra
- CAI for h22a EK
- 89 crx hf putting in b18c1
- Will this distributor work?
- Updated dyno of my crvtec/b20 vtec
- J's racing Intake?
- CAI for EG w/ H22a - what fits?
- Can I use my vx radiator fan with a Teg RS radiator
- Need D16Z6 installer/engine in LA area
- TMRm'zine you are not forgotten!
- Help: Will a non obd d15 work in an obd1 car? READ
- 98 ITR into 5g si
- ECU Questions
- RPM going UP and DOWN
- Hybrid Tranny Video finally made!
- Who makes these motor mounts?
- A/c of civic in a b18a motor??
- swaped...now clutch wont engauge???
- B18B1 into 2G teg
- ecu problem with gsr swap HELP!!!
- Help identifying D16Z6 Head!!
- H22 is running :)
- B18B into '95 EX coupe
- 91 Si D16 swap wiring question?
- ***Quick LS/VTEC question***
- axles and other misc. parts for for h22a engine swap
- CRVtec cost
- Crank Fluctuation Sensor question
- Car is running now. H22 story.
- How much do b18b's go for complete.
- Q's on swap...b18b in 95 hatch
- ls swap from 99 integ into 96 ek dx hb
- b20b3 / b20b4 ?
- anyone have some good tech on adjusting Cam gears??
- ls/vtec help
- type r cat?
- from D15b2 to B16a2 electrical problem
- H22A or B18C5 in an EG?
- obd1 b18c1 jdm
- Cam Timming
- B18b eg Vacuum line question
- 6500 Rev limit, vtec problem?
- need help with a 99 D16Y8 swap into a 97 hx...please
- LS into del Sol
- where does the plug go to
- P30 Auto ECU w/ JDM B16 SIR-II CEL Code 19
