View Full Version : Hybrid / Engine Swaps
- ECU PINS ?
- What ECU to use in H22 EK
- ITR Valve Springs
- Engine harness help pleaseeee
- Engine code after engine code
- gsr swap with "jrsc" piston melted 1-4
- VTEC ZC parts...same as D16Z6?
- Auto to manual swap question!
- Please help with clutch line! h22 swap
- where is the pcv valve on a gsr motor?
- Motor Mount kit???
- Need help, knock sensor CEL randomly, engine running odd.
- JDM B18C into EJ DX Running Problems...
- Clutch question??????
- Shift linkage ?
- Doing a h2b but which b-series tranny?
- Whats so bad about this motor????? (H23)
- Starter and Alternator from D series to B series?
- axels for hydro tranny in cable car?
- I'm At a loss!! Car severly vibrates on corners and bumps!
- H22 wiring problems / distributor ??
- dyno my new ITR motor!
- maint req. light?
- Help with Obd1 Injectors
- b20a5 crank into a ls?
- HARNESS differences???
- Question about LS/Vtec setup *PLEASE GIVE OPINIONS*
- b20b specs?
- 1990 OBD0 LS EGR Valve?
- Crank pulley problem on H22 CRX
- b16a2 in 94 vx
- transmission P2A8-1003988 what the heck is it and will it fit please help.
- Parts list and diy for auto to manual swap in integra?? I searched
- Swap Question??
- 5 wire o2 sensor to 4 wire
- K23 turbo, by honda??? WTF?
- H22 EJ Skunk2 Intake Manifold Info Needed
- Has anybody swapped an OB1 motor into OB2 CAR?
- I have a 93 eg(civic hatchback cx).. I want to know the best swap for this
- Tranny Question
- High rpm miss...
- how much did you guys pay for your OBD2 b18C1 swap?
- Is there an oem or oem aftermarket cat to fit?
- what engine mount and bracket for 99 civic ex
- connecting rod sizes
- Knock Code, need help
- Wiring Question(Searched)
- Crankshaft Pulley
- Hybrid Engine Harness
- ARP head studs
- B20+GSRhead+JRSC?
- well doing a swap....
- B18C1 Swap help
- cost of K20 swap in a ef
- B16A CRX HEADER ?
- NEED HELP WITH HALFSHAFT/INTERMEDIATE SHAFT I.D.
- LS/Vtec - What would happen if??? ECU questions...
- Gsr swap stock p28 aftermarket fuel system hard to start
- B18B1 swap to 94 eg(dx): Hard or Easy swap???
- i need to swap from obdo to obd1 can nybody help
- Canada people Has anyone heard of these guys???
- Ask your H22 Questions Here
- intake manifold swap ?
- engine swap questions into 95 sol s
- what vehicle has the o2 sensor I need??
- swapping into a 91 accord
- jdm b16a reffing in california
- Gsr or H22
- Is it possible to swap an ls head for a gsr without any other alterations
- Knock sensor problem on my h22a
- Intake Manifold
- k20/k24 hybrid??
- where to buy JDM h22a tranny internals?
- K20 or H22 race car?
- The Most Powerful honda SOHC vtec motor
- B16A2 intake on a B16A engine
- Will a obd1 engine harness plug in to an obd2a car?
- damn my dislexia, stripped head studs
- removing h22 short shift adapter (neu speed)
- LS-VTEC BUILD
- Basic swap ??? but I can not seem to find it :( Any help on the boards tonight?
- starting problems, car battery dies when i crank it
- b16/gsr hybrid
- Resistor Box Problems
- Axles
- JDM vs UDSM
- B16 Ecu
- H22 in an accord
- Engine mount kit to put H22 into 88-91 Preludes
- knocking from where help
- B-series crankshaft - wider bearings better?
- need help on which h22 to put in a crx
- jdm ls into 99 cx
- ls oil pan on B16
- alternator question!?
- JDM OR USDM B20B
- h22, h2B!?!
- H22 EG DEAD
- ECU question
- Few last problems with swap. Any help?
- aftermarket intake mani?
- good or not?
- Ultimate daily B16 Hybrid
- Running obd1 injectors with obd0 ecu
- Online
22 posts [100%]
westville nj
1-18-2006
Report this post to a ModeratorAdd this post to
- H22A Auto to Manual swap
- Engine Swap Questions...
- Code #8 TDC sensor
- B18B with 37820-P75-A02 ECU
- Questions for those that have the h2b?
- BS2000?
- '06 Si TBW workarounds?
- b16a swap
- Engine swap...Possible or been done?
- *Wiring Question*
- quick engine identification question
- H22 into 90 DA?
- h/f swap into a ef civic. wiring questions.
- Please help. H22 swap, wiring help!
- h22 high rpms
- HELP! P28 Ecu question using JDM motor/A4 to D6 Wire
- Thinking about a SOHC ZC swap into my EF Hatch. Got a few ?'s.
- Please help! h22 swap
- How do I install a ex cluster into my eg hatch?
- I hae a D15b7....i need help
- Another simple question
- Hasport press release: H22 CRX mount kit is now shipping
- H22 into a civic coupe.
- best head for a b18c1
- i need a walkthrough on a swap
- Need Help on wiring (need help quick last thing to do before engine goes in the car)
- i know this has been asked alot
- B18C swap into My 96 Civic ex...
- b18c5 swap 2gen integra
- Failed smog....what do you guys think?
- Thinking about purchasing a B20 swap.
- Wiring IAB's
- b16/ls
- Whats the best swap for my EG9?
- BIG b16a swap problems
- H23 SWAP INTO 93 CIVIC HATCHBACK...NEED HELP!!!!!!
- b18b1 into 1990 crx dx help
- Swap Axle Problems
- Leaning out...
- h22 swap. code 24?
- B18A1 OBD0 motor in a 92 CX Hatch OBD1- will not start and pissing me off
- h22 lsd ek problem ...help!!!
- LS/VTEC !!!!!!!!!!!! QUESTIONS!!!! Check this out....
- B18C Into 99 Si Civic - Evap Quick Question !
- b16 tranny removal for clutch in a crx
- Coolant mystery.......
- BACK to the honda!
- 99 Si needs new head...
- OBD1 motor in OBD2 car
- Which model and which swap?
- all lights dim
- B16a2 in 99 ex?
- HOW to B16 you crx.
- Motor mounts vs. Inserts
- eOut with the b18a1 in with the b20b now CRX not starting PICTURE!
- GSR into 2000 HX Coupe
- Got Some Quick LSVTEC Questions... Opinions, suggestions...
- NEED ANSWER ASAP!!! EX rotors, calipers, brackets on CX knuckle.......
- Help??? H22 Transmission banjo bolt?????
- Ls/vtec
- obd2 Jdm H22
- JDM DC5 type r brakes onto a del sol
- GSR cluster into a 99 si?
- HELP: 2000 GSR engine into 92 civic hatch (IAB QUESTION)
- will my b18b 89 civic CX be guttless on the highway????
- ls rods and d16z6
- K20 da mount kit
- basic swap question...
- Hasport Kit and brand new Cable... WTF ???
- I really NEED YOUR HELP!!
- 2K coupe rear leather Question??
- Trans swap from 92-99 cx....?
- gsr front clip, 94 civic shell...just some questions...
- Having a problem wiring MPFI on 89 DX
- tranny
- d16y7 and d15 vtec (jdm engine) whats best combination for more power
- does anyone sell a swap kit for a fwd sr20 for a 92-95 civic?
- b18c2 into 89 model crx!!! NEED HELP!!
- k20z1 swap into a DC2? name all the things i would need to make it work!!
- So i broke... AGAIN
- need help quick
- D16Y4 SOHC head swap to D16Y6 VTEC
- Will a b18b dizzy work on a b18a engine?(electronically)
- 94 EG8 ls vtec swap
- just installed an h22 and drove for a week and now it wont start. help!
- NEED HELP MOTOR SWAP ?S
- B18 Swap in '95 civic
- resleeving??? ls
- Eg Moter mount in EK ?
- h23 question...
- rear mount braket(plz help restoration process)
- ITB's on j32a2 possible?
- Code 9 on JDM H22?
- itr swap problem on 2000si jumper harness problem? need help! bloomslang problems
- B series wiring in Mini
- NEED HELP PIC REQUEST FOR REAR MOTOR MOUNT
- Swap Opinions?
- HELP!! My engine damper broke
- b18c5 in em1 ?
- Need Help, GSR swap in a Auto Civic...... asap...
- B16A cam caps........
- D16Z6 VTEC/ECU problems wiring
- Question about engine harness
- anyone wanna help me do a swap?
- K-Series Transmission Table
- d16y8 tranny bparts compatability
- which clutch master cylinder would best suit my car?
- time to upgrade, ls/vtec here I come! Suggestions...
- F-20C swap into my 95' TT-RX7 ?
- 5 cylinder honda!!!!!!!!!!
- subframe install- need diagram
- GSR Motor in an EK9
- Power Steering HELP!!!
- EJ2 H22 hybrid problem
- Radiator Hose that fits 97 Civic with a B20B
- h22 ej6 to low?
- h22 in my ek, was running fine, now issues, clutch related?
- gsr rear brake conversion
- CHECK ENGINE LIGHT AT 7000 RPM IN THIRD ONLY
- Please help, h22 into teg questions
- issues after swap
- need help
- JDM B16A to pass emissions?
- k24 swap?
- 95 dx coupe/ h22 swap? instrs? info?
- k20 in a civic? how hard
- purchasing a GSR motor, please help with questions
- swap trouble
- K20a swapped VW Bug??
- How do I add A/C to B series Swap?
- Some motor swap/ obdII-obdI questions
- Few Questions on a JDM B18C1 Swap
- reffing a JDM b16a questions
- B18C1 to 2000 Dx Hatch Throttle Cable Problems
- question about japanesse headers and usdm cats!!
- OBD0 to OBD1??
- Looking for another motor
- NEED HELP! Rear Disc swap question
- b18c5 with b20 or b18a/b head
- Simple swap ?'s
- craziest swap ?
