PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 [109] 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. LS/Vtec Question
  2. motor mounts
  3. H22 into a Ek, Shifter Questions
  4. what could it be with this swap??
  5. B18C1 -> 92 dx hatch..CEL #43 need some advice
  6. BAR Certification: Will a B18C1 (94-01 GSR) or B17 (92-93 GSR) Intake Manifold fit onto an ITR Head
  7. CRX Hood Clearance
  8. B16b vs GSR, C5 Opinouns please!!!
  9. 93 civic wiring changes from auto to man
  10. b16 swap please help
  11. cracked injector
  12. B20 motor destroked to 1.9L w/b17 crank?
  13. MARYLAND h22 EG SWAP
  14. tb vacuum
  15. vtec head on a F22A1 possible?
  16. B18C1 or B18C5
  17. Enough Already!!! GSR/HATCH
  18. TEG Axles for a swap, can someone plz measure them for me plz
  19. GSR radiator and A/C condenser fan for H22a swap
  20. I need help with my B20B into '95 LS swap...
  21. ek h22 swap link
  22. b18b in 95 civic ?'s
  23. B18B1 Long Block....Timing Belt Broke....Help
  24. how do i adjust traction bars?
  25. b18c 5 on the way (need input)
  26. Putting a JDM GSR engine into my 94 integra LS: HOW TO???
  27. PM6 - PM7 question
  28. kinda OT: can u order mr2 motors or clips?
  29. wiring help questions:
  30. Another B16 swap question
  31. HybridAutomotive.com mobile company
  32. jdmpower.net
  33. LSD and traction bar?
  34. K20A into DC2?
  35. DPFI to MPFI swap for vtec?
  36. Dx/vtec oil lines?
  37. d15b7 G/box match up with a d16?
  38. easier instructions/diagram to wire VAFC into eg w/ GSR swap??
  39. which throttle cable bracket do you use with the JG ED intake manifold
  40. Civic w/ Bseries ? Here's a cheap OEM cooling upgrade !
  41. Nj, Ny, Pa h22 people
  42. Does anyone have, or know where to get, H22 swap info into EK???
  43. what is the best turbo kit?
  44. Which belt do I use if I take out AC on my H22???
  45. gsr/eg hybrid alternator charging problems
  46. Death to the D16z6 92 civic ex the 1.6 that couldn't
  47. Which flywheel? Toda or Exedy?
  48. trailing arm from db8 same as dc?
  49. need pinout diagram for obd 2 p72
  50. Does this price sound fair?
  51. check engine light on B18 motor need help..........
  52. ls/vtec
  53. Idle fluctuation
  54. Question regarding mounts on 5th gen and B16A3
  55. upgrade preformance of 1987AWD Civic
  56. b16a2 questions?
  57. b16a2 in 98 dx hatch?
  58. Mounting 03 CRV block into 03 RSX
  59. H22 in 5th gen hatch - driving impressions and more
  60. Which friggin ecu???
  61. b17 into 1st gen integra
  62. H22 into 2g Integra
  63. is there anyone can do mini-me swap around central jercey?
  64. CAN ANYBODY HELP ME? 2GEN TEG WITH A 2000 B18C5 IN IT
  65. B16a into 94 LS, motor turns on but revs to 5k at idle?
  66. more recent pics of my race car!!
  67. vibrations from ek h22 when making right turns/curves
  68. CRX Swap Info
  69. H22 into EG/DC chassis questions... just a few!!
  70. H22A into 90-93 Accord...mount help...
  71. vtec pin?
  72. crx swap info
  73. All motor SOHC vtec ZC in 82' Civic 1300 hatch
  74. Running with out a knock sensor, hitVTEC?
  75. ECU PROBLEM IN EG
  76. cheapest place to buy b18c5 (b18c-r)
  77. ls/vtec swap into 93cx???
  78. Motorswaps in Virginia Beach Area
  79. in need of h22a ecu!!!
  80. just got a remapped GSR computer for a temp, how will it work with LS?
  81. SWAP NOT RUNNING!!!!
  82. 93 del sol with a B series swap
  83. 92 prelude (swapping a h22a into) PROBLEMS W/ STARTING
  84. AC lines (please help figure out which I need)
  85. LS swap into a D16z6 SOHC
  86. CRV or LS??
  87. H22 rear-wheel drive civic hatch.
  88. Converting auto ECU to manual...
  89. IACV Wiring
  90. b18c5 into EK
  91. DOes this fit?
  92. D16A6 Questions
  93. question on type r swap
  94. 1982 civic With a zc Vtec
  95. the switch
  96. ECU pinout question
  97. JDM b16 compatible with 98+ ITR tranny?
  98. pics request: wiring b18c1 into civic
  99. Hydrolic to Cable Transmission convertion for 90 Integra
  100. b20z into eg
  101. If you guess what we're doing, you can pick up a free B20
  102. resistor box removal(already searched)
  103. head bolts for ls/vtec?
  104. power loss!?
  105. B18C5 into a 99 GSR ..need some swap info
  106. D16Z6 Swap Into A 1990 CRX HF
  107. K series into DC2 chassis
  108. b20 swap in 97 hatch
  109. ATTN: dallas peoples, need someone to swap longblocks. FREE ls/vtec motor
  110. LS SWAP need help!
  111. Can you use a Ls distributor on a vtec motor and stilll hit VTEC
  112. JDM B18C into EK Civic -- need help
  113. where should i buy my b18c from?
  114. 96 Prelude Si engine swap
  115. ? about my ITR Swap OBD and Disributor related
  116. Dx harness, LS distributor question
  117. HELP Ls into 99 Ek
  118. a few swap questions for both b16 and h22
  119. 93 civic coupe. B16 vs. F22b1
  120. swapping problems help please.......
  121. stock fuel pump
  122. proper exhaust for '94 b18c1 swap in '92 cx hatch
  123. SWitching exhausts when switching to a B series??
  124. Quick question regarding swap wiring!
  125. ECU question
  126. frankenstein k20/k24
  127. H22 group buy... gauging interest!
  128. tach
  129. '00 si swap into 96 ex questions
  130. Car will not start anymore!!
  131. b16a1 vtec solenoid gasket
  132. 92 civic vx swap question
  133. b16a 2nd gen 5 spd into 93 civic ex auto mounts?
  134. b16 into 88 CRX HF
  135. wiring guru's i need you help
  136. help with ls swap alternator
  137. what kind of distributor to use with b20??
  138. A/C MOUNT/BRACKET question
  139. B18C into a CRX..... Simple Question??
  140. Anyone in Orlando, Tampa FL area who can do an H22a4 swap!! Click Here!!
  141. my B20z hatch is having SOHC ECU withdrawls
  142. Need info on VTEC sensors ... pics?
  143. b16 auto question...
  144. HELP!!! motor swap into a 88-91 civic hb
  145. 99 gsr swap into a 92cx
  146. #Pic request# h22 hybrids with HCP mounts ---- how far to drill hole on passager mount
  147. Are OBD0 and OBD1 wires and pins interchangeable?
  148. i got a D16 Ecu with my 95 Ls Engine, will it work?
  149. OBD ? on 91 crx
  150. zc question what axels?
  151. h22 swap into 88-91 crx?
  152. Swap finished, Idle jumping up/down, no CEL.
  153. stock internals?
  154. Does an AEM short ram intake for a GSR fit an EG using factory mounting point?
  155. no flaming ...b16 questions ( SEARCHED )
  156. Need some help please. H22 in eg. Runability.
  157. Missing a mount.
  158. Running Super Rich and car won't stay started ( New swap) Please Help!!!!
  159. maryland shop that will do swap?
  160. JDM H22A California CARB (smog) Legal Civic pics
  161. obd1 LS in a CRX (wont start) NEED HELP my only car ^_^
  162. H23 head on a F22 block Please help I am desperate and generous $$
  163. B18B with B16A head...what head gasket?
  164. doing a auto to manual tranny swap on a 00 integra, need help with parts list
  165. 94 B18B1 into 94 GSR chassis--help with wiring harness
  166. turbo h22 in 6th gen civic w/ a/c
  167. Where does the collant line on a ITR throttle body plug in???????
  168. 99 b18b in 97 EK cranking but not starting.
  169. nice vibrator.. oh you mean my camshaft!
  170. IAT and IACV swap?
  171. B16a2 swap shipment weights A LOT! Why?
  172. need help with swap
  173. obd2 to obd1 ls motor going in a lx 4 door 94
  174. h22 into crx info!
  175. 97 LS into a 00 Civic HX Please Help
  176. need to swap a b18c into a del sol, and auto to 5spd
  177. 90 integra t body on 94 civic ex
  178. anyone build LS vtecs
  179. 89 car - 93 motor please help!
  180. Is it legal to swap a JDM engine into my car that I daily drive???
  181. help me get this shit box running!
  182. Code 36?
  183. just put my LS in the hatch...but idles really low...
  184. b18c1 crx won't start (obd1)
  185. 89 CRX high idle
  186. Stock B20 VTEC which flywheel and clutch?
  187. grinding because of an axle???
  188. Do all 1992 Civic Models come with the VTEC wires pre-wired?
  189. OBD2a VS. OBD2b Distributor Plug Differences?
  190. TECHIE HELP needed: GSR Manifold on a B18A1 (LS)
  191. 2000 Honda Civic SI - Swap Smog Prob
  192. comptech icebox w/ an h22 eg
  193. shop that dose swaps in jersey?
  194. start up...should i be concerned
  195. what tool did you use to seperate the ball joint from the control arm? besides a bfh
  196. B18b IN EK PLAYERS: wiring/sensor questions
  197. VAFC OR chipped p28
  198. light my car on fire!....
  199. code 22.... anybody know how to fix it?
  200. Integra brake booster?? 94-00 any different?
  201. F20B Oil pan Same as H22?
  202. LS motor in 96 hatch
  203. i don;t know
  204. Civic Suspension on 94-01 Integra
  205. no power or pulse to injectors after b18b swap...HELP
  206. jdm/ ecu question
  207. LS/VTEC Swap
  208. 98 b18c1 into a 93 eg hatch, stuttering when hard on gas, need help
  209. Measurement of Integra axles for an eg swap
  210. Good Deal?
  211. b16 swap
  212. OBD2 into HB?
  213. LS/vtec into 88' CRX Si
  214. B18 compressor in an EG ? How much did you pay for....
  215. swap question
  216. h22 civic
  217. motor mount
  218. 94 Civic DX GSR Swap. NEED HELP AND OPINIONS
  219. how much would you buy a eg with a swap for?
  220. prelude head on ls block
  221. 93 Accord H22A Cold air intake?
  222. prelude swap
  223. EF9?
  224. pulling motor out from bottom
  225. sohc 1.5 tranny fit on an LS?
  226. which intake do i need?
  227. Okay, now the master cylinder?
  228. Code 20 and left over wire from ITR swap
  229. Have you guys seen this??
  230. b16a swap into a crx/civic howto
  231. where is the engine stamp on nissan engines (sr20det)?
  232. Can I use an engine side harnes form a d16z6 on a b18 swap?
  233. Engine Mount Question?
  234. Swapped Integra lower f-arms into eg hatch, shock mount seems off ??
  235. v-8 in an accord??????
  236. h22 oem header help
  237. '94 GSR Swap (complete) into '92 Cx
  238. 97 JDM ITR in a 96 hatch with Auto EX harness???
  239. (EG 95 H22 swap) What do u guys use to fill the hole cut for the cable and shifter box so exhaust sm
  240. New England Area Swap Shop
  241. Engine mount tricks
  242. D16 Vtec with i/h/e running 15s?
  243. Are all non-vtec b series dizzys the same?
  244. Engine Transplant Queries... NSX
  245. conversion harness
  246. F22b
  247. B18c secondary runner question
  248. 99 b18c5 into 00 civic si??
  249. B20 (CRV) into '92 Integra
  250. sr20det..?
