PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. throwing solid cel (no code) with p28 in an lsvtec
  2. B series motors?? somebody help!!!!
  3. B18A1 into 94 DX w/YS1 tranny????
  4. wat happened
  5. H22 into 88 EF
  6. Strange sputter issue
  7. Swap costs?
  8. need a b-series knowledge, anyone have a B20 sitting around? Need your help
  9. Emisions with my Hybrid.
  10. Question bout my swap
  11. Poormans R ?'s
  12. Does it matter ??? OEM or aftermarket motor mount bushings
  13. Which alternator for H22 swapped 93 hatch?
  14. obd1 b18 swap into obd2B EK chassis wiring issues
  15. few h2b ?s
  16. Hasport Press Release - K-Series mounts for 94-97 Accords
  17. 1-4 wire o2 still with CEL 41
  18. Fuel injector problems, need advice on diagnosing problem h22
  19. I got a few H2B questions.
  20. help h22 swap
  21. b18c wiring help
  22. H22 in Del sol Weird engine noise.. Any ideas? (sound clip)
  23. is there F.A.Q. to indentify fuel injectors .....
  24. DC5 Brembos onto EG?
  25. b16a2 trans on gsr motor
  26. need coolant line help!
  27. IACV 3 wire to 2 wire (help me please)
  28. H22 coil cap
  29. Eg H22 suspension
  30. GSR into a 1991 Prelude Si
  31. H22 Into DC4 Checklist
  32. **OFFICIAL H22 INTO A 97-99 CL(FaQ)**
  33. Timing Belt? B18B + B16 Water Pump
  34. Can I reuse EG4 motor mounts when doing a B-series swap?
  35. Need some H22 Help ( parts)
  36. B20 intake in 91 civic
  37. Converting JDM OBD1 --> US OBD2b
  38. h22a swap axels..
  39. b18c1 in ek
  40. Rear Brake Conversion
  41. F20B Base Maps
  42. Any info on H2B into 90 Integra??
  43. K20A VS. B18C5
  44. K20A VS. B18C5
  45. Z6-->EF purge cut-off solenoid valve on the z6 mani
  46. Auto matic B-series tranny into EF
  47. H22 into em1 wiring problem
  48. * H23 problem PLEASE HELP *
  49. b20 in 92 hatch
  50. Gsr Cams in Si Head.
  51. b16 swap quwstions
  52. which arp headstuds do i get???
  53. NJ Emissions and high NOx
  54. Motor Swap
  55. gsr with d16 ecu
  56. Swap to another car
  57. g23
  58. k24/20 in crv
  59. Wrong Engine Mount?
  60. Question obd1 b18c and Hondata....
  61. my swap
  62. CRX b16/ which throttle bracket is the correct one???
  63. redrilling rotors prelude vtec or type r?
  64. What fuel rail?
  65. Going Cheap on H22 in hatch. What Axels?
  66. JDM b16 intake manifold help! Not sure what this is or what it does
  67. Is there any such thing as a cheap K20a2 in northern California.
  68. 92 VX o2 wiring for 4 wire
  69. can't find info. . h2b into 90-91 da or do i need 91-92
  70. Toyonda :D15 Powered 91' Toyota Tercel
  71. swapped y7 for y8 in dx and there is extra int. mani. tit on bottom right
  72. h22 into hatch?
  73. what oil weight for an lsvtec swap??
  74. JDM motor swap whats needed
  75. itr vs. ats vs. mfactory FD's?
  76. OBD2B Y7 TO OBD2A GSR WIRING ISSUES!!!
  77. Couple of B20 questions
  78. wireing question.. HELP..
  79. header question
  80. k24a4 head swap
  81. how do I hook my slave cylinder to my cable clutch transmission?? 93 CX
  82. B18ba Ek Harness problems!
  83. What Primary Parts Can Be Swapped Between B16 Genartions?
  84. i need a list of parts for a swap from an integra
  85. CRX b16 JDM RSR header
  86. B20z swap del sol ?
  87. need answer...b16 cable trans to gsr???
  88. browntop zc to obd0 wiring question.
  89. diffrent ecu's diffrent probs
  90. Wiring for type-R easier or harder then i think?
  91. Wiring easier than i thought or harder?
  92. A little Type-R wiring help needed
  93. Some Type-R Electrical Help Needed
  94. Anyone using OBD2 ECU for F20B swap - need CA emissions advice
  95. SI or GSR
  96. Static compression ratio question.
  97. What belt do I use?
  98. b16 ecu Question
  99. B16a swap throttle cable
  100. Another H22-hatch question...
  101. wondering if this is possible
  102. question for 93 hatch swapping h22 into it
  103. Projekt DC2 K20A is complete !!! dyno vids @ Westech Performance Group
  104. OK do not hate me i neeed HELP making a 00 Type R teg to a automatic
  105. d15b7 bottom end with a d16y7 head
  106. KA24E Nissan Motor into a 95 Civic Hatch. Possible?
  107. Reputable places to buy B Series swap........?
  108. LS VTEC manifold
  109. h22 compression test
  110. NEED HELP! ls swap into ef 4 dr. WIRING!
  111. h2b in a 1st gen crx
  112. clearification on codes
  113. what ecu should I use for h22 in eg
  114. h23 vtec vs. h22
  115. Toyota MR2.. Vtec ?
  116. f20b Cams
  117. Evo H2B
  118. question.....
  119. tranny noise when clutch is pushed in
  120. B20 Swap Question???
  121. HCP H22 A/C Bracket into DC/EG
  122. Ek Swap Wiring Info (Sad to have to ask this)
  123. f22a/h23any one done it
  124. will a d15b dual vtec head work on a d17 block?
  125. smog question
  126. HELP ASAP, how do i take off shift linkage!
  127. Help JDM Motor Troubleshooting.
  128. D16y8 Swap question
  129. Torque Mounts on H2b swap?
  130. what valve springs? NEED HELP!!!
  131. car wont start...ls vtec
  132. Ls vtec help...
  133. Possible to swap F20C into a 89 Civic?
  134. i have a crazy question to ask take a look
  135. LS Swap into 94 hatch!!!!!
  136. I am looking 4 EKK2 mounts
  137. would u recomend doing ls vtec or a pure vtech motor
  138. Compression ratio
  139. Throttle wheel spring tension
  140. H22A alternator belt
  141. LS Vtec Head Gasket
  142. obd2 b18c1 knock sensor location?
  143. 89 CRX Si w/ GS-R brake, what trailing arm?
  144. Little problem with clutch engaging arm(?) sitting on pressure plate, wont back off.....
  145. Another H2B Build.....My Kiwi Green Coupe Project
  146. Difference between b16b timing belt and b18c timing belt ???
  147. Civic Type R crank pulley...what belt do i use???
  148. motor=obd1 ..wanna convert motor to obd2
  149. J32A2 (Acura CL Type-S engine) dimensions?
  150. What part of the harness/wire is this? H22 Accord
  151. b20z2 vs LS intake manifold swap!
  152. GSR hatch header/test pipe question with pix.
  153. poor mans type R suspension question???
  154. K24A2 vs. K24A4/A2 hybrid
  155. b20 differences? b's and z's ?
  156. f20b dizzy wiring
  157. Wiring People I Need Your Help h22/cd5
  158. WHAT DO I NEED TO DO CONVERSION FOR MY 95 SI HATCH?
  159. b18c swap help needed
  160. B-series oil pan interchangability
  161. Need help with B20 swap, CASH for help!!
  162. Questions on a LS Swap????
  163. motor swap is in but has problems need help!!
  164. h2b ready but which motor best for my year?
  165. LS-V swap into non-honda
  166. Need help with B16A2 swap into 1997 Civic Ex. (I reasearched really hard found only pics) Please h
  167. h22 integra shifter
  168. Local Tech Help
  169. b20 in 95 si hatch
  170. Sensors on a B16?
  171. H2B PROBLEMS!!!!!!!!!!!!!
  172. need help with trans mount asap!!!
  173. JDM B18C swap into Del Sol Rev Problem
  174. H22 backfire, cam timing correct
  175. RSX type S inner cv boot is the same as a k20a2 swap axle inner cv boot?
  176. b16a6
  177. Motor swap guide?
  178. Crank sensor on a B16a Jdm spec ?
  179. computer and wiring question
  180. New Hybrid Driving Technique
  181. b16 Swap in 95 LS HELPS?!?!?
  182. My H2B Thread (picture intensive)
  183. question about trans.
  184. GSR TB on d16y8 REALLY need help! please! (searched)
  185. b16 oil pan
  186. TypeR vs Skunk2
  187. p28 in a obd0, distributor help
  188. B Series Interchangeable Parts USDM/EDM/JDM
  189. Broken Diff?!!
  190. F20B... H2b orrrr F2b :)
  191. newbie b18a1 swap
  192. help D15B not vtec tunning
  193. ITR intake/airbox for EG?
  194. My dc2 H2b swap 56k take a nap
  195. EG/DC H22A Mounts ESP build thread
  196. Insight W/ Kswap ( baddest ever)
  197. Jdm H22 from HMO motors awaiting transplant to 92 hatch
  198. ls vtec engine wiring harness??
  199. B16 SWAP HELP!
  200. 94ex to obd1-b16. can you just use the ex harness?
  201. Poorman TypeR
  202. K20z1
  203. 98 ls into my 90 gs
  204. F22b1 vtec swap into 88 accord dx ??????
  205. itr and b16a2 fuel pump different ?
  206. 92 civic with 5 bolt TYPE R conversion
  207. traction bars for a eg with h22a swap
  208. b16a longblock into 94 LS?
  209. putting my B18 turbo setup from my DC2 into my EG, need some help
  210. LS Swap Wiring Help...
  211. two eg B18C-R swaps, both have 1050rpm idle?
  212. ls vtec timing question
  213. DOHC ZC w/Vtech Head
  214. JDM B16a trouble codes ?
  215. my swap
  216. which engine for EE8 ( EF8 )
  217. B20Z2 swap ez to build?? help
  218. Help... should I do OBD2a to OBD2b or OBD2a to OBD1?
  219. prelude swap help
  220. p28 ecu
  221. Key removed, K20a2 keeps running (checked ignition) (95 Vx)
  222. The 1999 Civic Si B18c Project...
  223. 1993 H22A Civic won't pass emissions. Need advice!
  224. h22 in eg questions plz help.pistons and headers
  225. 1989 Integra zx <Insert engine here> Swap !??
  226. What is needed to swap my GSR set up into my b16a hatch?
  227. What would be faster?
  228. Do any f23 cranks have 50mm Mains
  229. Can I get away with it?
  230. k24....
  231. K20A INSIGHT by LHT Performance
  232. EK22 PASSENGER SIDE AXLE QUESTION
  233. Rear motor mount
  234. Gsr block with b16 head
  235. HEEELP
  236. trying to swap gsr into 91 civic si. Help?
  237. B16a won't start need help!
  238. B16 swap into 96 EK hatch, alternator mounts?
  239. LS-VTEC
  240. need wiring diagram
  241. K20a Fit
  242. F20B Basemap needed please!
  243. poor mans R injector problems
  244. General electrical questions regarding engine swaps.
  245. egh22 mounts pictures (issues with my swap)
  246. H2B PEOPLE: WHO STILL NEEDS A GOOD HEADER?
  247. H22 with K20 tranny
  248. H22 problems.
  249. k20 vs. h2b swap----which is the way to go??????
  250. anywhere i can find an rsx s mtr?
