View Full Version : Hybrid / Engine Swaps
- Any good links for info on installing an OBD2 GSR into an 88-91 CRX?
- What throttle cable should I use?
- p28 help
- code 14
- F23 -> EG6 Swap Help?
- h22 swap info into 99dx2dr
- LS Swap pics and a few vaccuum/wiring questions
- what do you guys think about this...
- New Hasport?
- what happened to hondamotorsonline.com??
- Need Help ASAP with two Engine Swap Questions: EVAC Line & Vtec Wiring!
- OEM engine mounts for dohc in EF?
- OBD1 conversion in EF
- After engine install, do you pour oil in the spark plug hole before you start it?
- auto to manual conversion
- Teg radiator in EG questions
- H23 swap q's
- 3K redline
- B18c1 hybrid randomly stalls...
- Can somebody give me a link or "how to" on pulling b18c head
- B18A1 into a 92 civic DX Hb
- Pic request: top down view of b16a2 intake manifold (complete)
- First Engine Swap ~ Any Tips Off The Top
- door panel swap
- B18B in 98 Civic Mounts?
- Correct way to run vacuum lines for a GSR swap in an EF!?
- Stock B20VTEC dyno tune
- Traction bars/cross members for h22 teg
- will it pass visual test?
- 96 B18C1 into 96-00 HATCH HELP!
- HCP mounts vs Hasport mounts in a 92-95 civic with h22
- susp. ?
- j/w bout gsr block w/ ls head
- How fast
- Factory FPR question...
- 95 CX- LS MOTOR, and F-MAX turbo
- 2000 B16a2 into a 92 hatch wiring problems
- ITR swap in 5th gen....http://tech.hybridgarage.com/ a few questions.
- Burnt harness/ecu?
- removal of tps
- broken tps sensor
- B18C5 into a 01CivicLX4drAT SWAP
- Need help to fix my car " SPADE " maybe you can help
- 96 hatch w/ LSVTEC q's...PLEASE READ!!!
- b18c5 into a hatch
- prelude ecu to run b18c1?
- secondary o2 sensor question...
- Electric Oil pump to "Prelube" motor before starting.... any heard of this.
- Are my dyno #'s low? skunk2 stage 2 cams...
- AN-R header installed
- my H22 is in but I have a few questions
- Civic Type R?
- H22 or B18c type R?!?!!!?!?!!!
- H22 in a 4TH gen CIVIC
- wheel stud question
- vtec
- B16a Skunk2 Setup.. What do I need to change???
- Any experience with the K20's?
- Quick Stupid Questions about swap
- Half thru with JDM B16 swap... Wiring.
- For Sale: JDM 92 Honda Civic SI-R Coupe *Right Hand drive *
- what motor should i get
- putting B16 in 93 civic
- Coolant fan on all the time and still no vtec?!?
- h22 question (93 SR-V engine)
- Anyone have ecu pinouts for 2000 B18B?
- installation??
- Dropping Engine?
- straight d16z6 or d15z1-d16z6 mini-me?
- Our Old Driveway
- noise coming from inner CV joint
- best place to buy a motor online?
- H22 madness (long)
- To Honda tech members in Bay Area needing dyno tune!!! READ this!!!
- b20 true or false
- Good ECU for 2001 All motor ECU
- g a bitPreparing for POWER! (jdm h22a) ???
- B20 swap into EK...is stock fuel pump sufficient? Is this what causes them to run lean?
- h22a in 94 cx CEL
- Can I swap a 2000 DX motor in my 96 DX with no problems?
- Has Anyone thought about ...
- radiator hose
- Does any1 have ecu pinouts or a link to them.....
- question on engine harness
- 95 GSR harness vs 95 Si harness...
- quality of osaka jdm motor sports
- B20 block with Vtec head or stock GSR???
- injector questions/problems
- Wiring harness questions
- FINALLY VTEC a long wait!!
- relocating my dowel pins...
- are all d series auto tranny the same?
- LS Swap Problems>>>HELP!!
- Does anyone know what size the fitting is on the clutch line?
- Who has used a 90-93 LS block for LS/VTEC in an EG?
- LS swap: 96-97 EX ECU Harness
- how much can i sell my car for?
- Need help with SI mounts
- What happends when you put a GSR head on a B16 block...
- 2000 v6 accord engine fit my 4 door 97 accord?
- h22a intake control solenoid valve
- b20 question
- does the k20a JDM have a immobilizer?
- Newman
- newbee with some questions concerning b16 swap
- Throttle Cable Issue (B18C1 in EK)
- how do you know if vtec kicks in
- first gen b16 in 5th gen civic
- someone please help me out over here: About H22 and SI Throttle Bodies
- h22 axles
- new 2 this motor swap thing
- B16a Question
- ls/vtec = horrible, horrible mistake... what's wrong?
- piston sizing question
- how to tell if tranny is gsr visually, help quick!
- problem with my b20b. HELP! (long)
- need help with a 90 DX
- B16A2 into a 96 Integra?!..HELP!
- Hybrid Exhaust System
- Ls mastercylinder into ef?? any difference?
- Will 90 LS(B18A1) fuel rail fit the B18C(R) and is it worth it.................?
- Will 90 teg LS rear discs fit 88 crx si?
- Speedometer and vtec
- what distributor cap fits sir1
- which tranny for b20
- clutch pedal
- LS swap Question
- Tranny problems: hard to shift, what's wrong?
- Civic rad fan better?
- Building a b16B out of a b16a1??
- b16a1, pr3 ecu in 89 si
- Help?
- ITR muffler on 92/95 hatch ?
- Your setup.
- How can I tell that my b20b is JDM??
- Prelude wiring (searched)
- How can I tell if its a type r fuel pump?
- 1/4 mi. time question
- ls/vtec loud crossover
- b16a1 into eg civic can i use 90-93 intgra mounts?
- Y8 head swap to a D16Y7
- Any legal Problems putting in an older motor?
- How can you tell JDM or USDM motors?
- Quick GSR into 92 DX Qs.
- CTR Piston on B18C1(block and Head) and Skunk2 stage 1 cams.. clearance problem?
- GSR Fan in a 92 Civic?
- can a japanesse engine get bar label to CA. vechicles
- h22 and h23 wiring harness
- B18c into 2000 civic, need help?
- who has built a b20 w/ a vtec head....Q's
- Need Help! 95 B18B into 91 LS integra
- my b20b is in and I have a question.
- Where to buy body
- noise coming from inter shaft
- Home made engine hoist
- how to convert a non obd b16 to an eg
- would a front crv brake kit (everything needed) fit a 96-00 civic?
- All B series fly wheels the same??
- How to tell the old hasport mounts from the new?
- 5th Gen with b18C1 header to Exhaust Q
- Lookin For H22 changover
- civic98 best engine
- jdm swap
- Has anyone have any problems w/ kenjii chipped p28 ECU?
- Wiring up a h22a into a 92-95 civic
- CALI ppl: CBI Custom Built Imports????
- h22a into a 92-95 civic fuel injector question
- aem intake pics
- Place racing shifter box for H22 in to EG?
- ls/vtec should I buy or build?
- d16zg in to cx hatch (94) wiring problems
- Sensors
- GSR Turbo vs Type R All Motor
- 93 Accord w/ H22A swap info needed...
- has anyone changed a clutch in a H22/Civic?
- 99-00 SI/R ecu, harness
- b16a vs. b18a oil pump
- 1st gen B18A w/ B20 Head
- b18a will it work?
- Did a search found nothing K24A RSX Swap?
- need some help please!
- Ok, u got ur JDM motor in...
- ghetto big brakes
- sensor broken
- carbon fiber intakes pipes?????????????????
- OBDI engine with OBDI harness to go in an OBDII Civic.... HOW???
- 00/gsr bottom 00/si head can.....
- Just finished swap...but I don't get a spark, why?
- what c/r with this set up
- 94 1.6 Vtec to 99 1.6
- ZC head on Z6 block?
- b20 head?
- b16a2 eg rear mount bracket
- Which way to turn the crank pulley bolt?!?!?!?
- D16Y7 W/D16Y8 HEAD?
- B16 into my 96 EX Coupe
- hasport mounts
- hYBRID Guru Challenge
- Hybrid Help!!!!!
- USDM b16 block with 1st gen JDM b16 head any problems??
- Legally swapping block's...
- b18a1 into 90 si hatch
- noise from B16
- H22 axles
- BIG THANKS TO Hondamotorsonlone They Rock!!!
- obd2 in to obd1?
- ECU pinning..where do I get the pins?
- H22 in 90 integra??
- will an apex n1 fit....
- ECU question
- help with 93 civic cx swap????
- All JDM ITR hybrids, what ECU do you use for the crappy 91octane gas?
- Info needed on axles and wiring harness.
- high compression gasket for non-vetc motors ???
- Searched and read, LS Vtec...more tech please
- swap/conversion is almost done...
- Any1 know what US wheel bearing will fit a JDM ITR hub?
- GSR DOHC vtec cams ??
- Is it possible to use stock mounts....
- ls/vtec or crv/vtec ??
- lowering h22 teg
- should i trade my b18c
- cheapest gsr full changeover......
- Please HELP! Need compression stats!
- 4 wire O2 sensor question, help needed!!!!
- 94 auto to manual axle difference
- H22 shifter cables?
- www.osakajdmmotors.com???
- H22EK runs, but won't rev past 2k? CALLING ALL WIRING/H22 GURUS! PLEASE HELP?!
- CRX B18A1 Hybrid
- ITR Intake manifold in a B16 CRX
- torqing down the crank pulley bolt..
- what block will fit 99 Si engine? dumb question
- OT: Need a 1.5L Civic motor
- 94 teg knucke driver side, 95 civic si knuckle pass. side? safe?
- 92-96 H22 in a 93 Cx???
- b16a into civic
- What short shifter to use for a 97 civic coupe with gsr motor?
- H22 vs LS/VTEC
- How streetable are Skunk2 Stake III's for a daily driven b16 CRX??
- civic harness on an ls engine?
- Need someone to do my swap...
- B-series EF daily driver buildup?
- 96 2.2 vtec prelude engine into 95 honda civic coupe
- Questions on B18B swap into 96 hatch
- lookin for a full h22 swap
- What motor mount inserts do I need??
- H22 or SIR 2nd gen. swap
