PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. FS LINK: WELLS FARGO FINANCING available on a one owner original virgin B18C5 w/ 28000 miles
  2. ls/vtec power loss
  3. 94-95 LEGEND GS CALIPERS on a gen3 integra
  4. 98 LS VTEC Auto ?'s
  5. need opinion on what swap to get.
  6. block#s and vin tags and inspection.
  7. EG swap mounts?
  8. can my ls/vtec use the ls alternator and starter?
  9. OBD0-OBD1 conversion list...I need it
  10. question about a ctr exhaust
  11. obd1 motor swaping in an obd2 head
  12. b18c1 vtec head
  13. ek h22 costs
  14. shorter shift lever = quicker shifts?
  15. silly auto to manual question (searched and read a TON)
  16. F20c into anything other than S2k!
  17. h22 to b series tranny
  18. How can this be??
  19. LS/VTEC worth it?
  20. 93 coupe, b16a jdm, want a gsr, help me decide
  21. b16a block question
  22. 94 SI into a 90 accord: last few bugs
  23. Engine mounts for k24 into 2001 Civic Dx???????
  24. h22 integra?
  25. valve seals from h22 work on b18b??
  26. K20 into FR/MR cars?
  27. gsr block b16 head what timing belt to use
  28. what throttle cable to use??
  29. D15B7 -> B18C4 in EG, but how about the airco?
  30. D15B7 -> B18C4 in EG, but how about the airco?
  31. CRVTEC questions
  32. had gsr swap, now need d-series
  33. Swapping 94 civic w/OBD1 B18B with 96 civic w/OBD2 D16Y7...whats needed?
  34. Ls/Vtec Block prep
  35. tried in tech but no help
  36. Buddyclub stage 4 portflow springs
  37. anyone know where i can find some successful hybrids...
  38. F22B2 to H22A Swap
  39. H22 tranny TO B series Tranny Adapter plate????????
  40. B16 si motor swap into 95 hb
  41. K Vs. B
  42. B16 build up from the ground up...
  43. intermediate shaft and axle mounting Q's
  44. civic cx engine harness, large yellow wire, what is this?
  45. Engine Code 20 Electrical load....i need help
  46. Can this head work on a B16A2 Block
  47. 94 ls gear swap
  48. Specs of Kseries Type s vs ITR trannies?
  49. B16/LS Quaife lsd into GSR tranny ???
  50. Need Help from the gurus
  51. b18 --> 89 DX CRX
  52. D15 mini-me question
  53. serial communication link malfuntion?
  54. b20a5 block b18a1 head
  55. repost from all motor. ATTN: LS/VTEC GUYS... SAFC baseline maps?
  56. 99 hb wire harness arcing guestion
  57. PLEASE HELP: B16a into DA PROBLEMS
  58. Swaped 1.6L Si SOHC motor into a DX crx. no spark.
  59. fuel pump ?
  60. semi built b16 fuel pressure...TUNING ADVISE
  61. 99' B18B Leakdown test Fuckery!
  62. d15b intake mani.?
  63. Wiring b16 into 96 dx ... easiest??
  64. Hydro Tranny with Hasport Cable adaptor
  65. Need help on a decision
  66. h22a1 mounts
  67. Question on b series eg swap
  68. B20 Vtec in a 1990 CRX SI
  69. Ls/Vtec in 2000 Civic SI
  70. what's the diff between k20a2 and the k20a-r
  71. Is it worth me spending the extra $1000 for a gsr motor ?
  72. Rubbing Alcohol Trick?
  73. rear stiffener.. important???
  74. h22 in 97 acura cl
  75. white plugs
  76. Need Ecu for 3 stage D15b VTEC motor P2J
  77. putting a supra motor in a 90 accord,
  78. Swap running after six months!!!!!!!
  79. Type R in a crx fuel ?
  80. tranny mount...
  81. did i do this right
  82. vtec wiring how to?
  83. my friend wants to make hosrepower on his eclipse
  84. jackson racing header
  85. 92 eg wiring problem please help asap
  86. Prelude suspension???
  87. TSX swap to a civic
  88. H22/Civic Dyno Results - 185 whp
  89. **B20B Questions**
  90. JDM GSR Ignition Starting Problem?
  91. to all veteran and fast car lovers in the fastest v4s-v12s
  92. Integra Shift Linkage for Ek GSR Swap-*PLS Help*
  93. Price Estimate on K-Series Swap into an Ek
  94. Uberdata
  95. dc5 type-r or dc2 type-r engine
  96. help need info, possible bent axle in gsr cx
  97. Is the weight of the H22A worth the hassel?
  98. Would a bad main relay cause these things to happen??
  99. semi built b16 wont start!!HELP
  100. 96 gsr motor obdII swap in a 91 crx
  101. B18C1 into EH3 problems.. can't check code (good grammar!!)
  102. midpipe question !
  103. h22a civic/what size rims recommended??
  104. new home made intake
  105. missing a sensor?
  106. Got BAR?!? ITR EK
  107. Is Crvtec reliable for daily driving?
  108. h22a4 differences in sh model
  109. Install shop in Houston, Texas or Austin Texas area
  110. new guy needs advise
  111. H22 into 99 civic ex questions
  112. Confused!!!! Obd0 B16 swap into Obd2 civic (distributor) need HELP!!!
  113. Ls VTEC trouble please help.
  114. ***D16 Mini Me Swap Write Up***
  115. H22 transmisson question
  116. ITR swap into EK
  117. tv's on my spinners
  118. h22 guys.... WTF happened to my motor, DAMN!!
  119. what mounts do i use
  120. integra brakes on 91 CRX
  121. Solid motor mounts
  122. k20a into a DC2??
  123. obd2 to obd1
  124. ITR tranny w/ D16
  125. USDM B18C5 Clip / Swap Sourcing
  126. NEED HELP ON A SWAP!!!
  127. need a job
  128. B18A1 Swap Into A 89 Dx hb ((((((((((( NEED HELP!!))))))))))))
  129. Will ITR spindle fit on non-ITR Integra knuckle/trailing arm?
  130. h23 dohc vtec owners
  131. black box w/ vacuum hoses - near the middle on firewall? (92 vx)
  132. jdm 1 wire vtec solenoid - will it work with usdm ecu? vtec not workin
  133. wiring 96 h23 external coil dizzy into 95 cx hatch using cx harness
  134. Can I pass Emission test
  135. State Ref: h22a4 into 97 integra, egr issue.
  136. K20 into DA integra
  137. no heat
  138. f22 in eg hatch?
  139. a question to all the veteranz
  140. Non Vtec dizzy on Vtec
  141. H22 Injector question
  142. A 92-95 hatch with a F20C Engine?
  143. K swap info needed
  144. Steering Column Options for an EH2
  145. AVID mounts?
  146. WHAT DO I NEED..AND I AINT SEARCHING..JUST TELL ME IF U CAN......99 LS SWAP IN 00 CIVIC...COUPE...
  147. quick OBD 0 - OBD1 code question
  148. b16a timing belt part #
  149. Harness
  150. Made a Mistake Need more Info: Skunk2 Stage 3 Cams
  151. to all those fast kar lovers whats a good spark plugs cost to make real horsepower (HEY CESAR)
  152. D-series tranny diff question
  153. GSR Axels?
  154. H22/Civic idle fine w/o IAC, but surges w/ IAC ???
  155. Questions about OBD-0 B16 swap into a EG
  156. Oil pressure gauge on b16a. where should i put the sender?
  157. EG H22 SWAP... Headers & Exhaust...
  158. sorry to bother but anyone have a swap "guide"?
  159. ? on s2000 motor...... more like b series or like k series
  160. Will a '94 gsr powersteering hose fit a '98 civic hx?
  161. '95 LS engine and tranny into a '87 Prelude?
  162. itr intake manifold
  163. hood clearance with K20A/K24A frankie in DC2 Integra?
  164. h22 in 92 eg question please help
  165. *help* obd1 b16a2 into ek swap
  166. ls swap into an eg
  167. anyone willing to help in mid-tenn area (shelbyville)
  168. what b-pipe should I use?
  169. 99 ex into a 93 del sol... help
  170. B16b in a 99 civic si
  171. B20a1 block + B18C1 head
  172. B16A1 into 90 LS
  173. b20/b16 question plz help.
  174. Q for those that swapped in a b18c in place of you d16
  175. powersteering hose question (already searched)
  176. question on h22 in 92 hatch. please help
  177. question regarding obd0 and obd1 map sensors.
  178. Engine harness
  179. Integra Springs on a Civic
  180. g2 Teg swap to civic
  181. To rebuild or not to rebuild my tranny
  182. FUEL CUT PROBLEMS?????? HELP PLEASE!!!!!!
  183. 1994 teg rear disc on a 1995 civic
  184. 95 hatch auto to man
  185. Compatable ECU's and wire harnesses for JDM D15b?
  186. ls vtecd civic
  187. Need help car runs well cold when it warms up doesnt.
  188. H22 type S questions
  189. H22 Civic..ECU Codes 21, 36 and 4
  190. need b18 tranny help
  191. LS Cranks how good are they?
  192. taking off p/s pully
  193. Need help. Re-pin/re-wire distributor. obd2-obd1
  194. torque specs
  195. K20A into EF9 Shift Linkage Question
  196. H22 Axle?
  197. Did a swap and now throwing code 5 (map) and code 14 (IACV)...
  198. why is my clutch sticking?
  199. GSR SWAP....HELP
  200. b18a head on b16a2 block
  201. b16 swap in 92-95 civic coupe with cable trans???
  202. vacuum question
  203. Someone please answer this about dizzy wiring for h22 swap...Ive searched
  204. WIRING GURU'S I need your help!!! OBDIIB to OBDI questions...
  205. need a GURUS opinion on this !
  206. Sound like a bad knock sensor?
  207. best plugs and wires h22a swap
  208. fs 91 crx wid 95 convert Fresno, Ca
  209. DOHC in a 96 EK questions
  210. jdm d15b problem
  211. Help me locate a part
  212. WTF is this **** Hasport is doing
  213. JDM K20A-R or USDM K20A into a 99 EK9
  214. ecu question about swapping a gsr
  215. NEED HELP...93 jdm h22a in 96 accord, distributor wiring, already searched a lot
  216. 9
  217. Is a k series swap worth the money??
  218. obd2a-obd2b? difference in harnesses
  219. please help me with my swap, take a look?
  220. K series mounts for DA
  221. b18a swap into 91 hatchback....mounts???
  222. TODA K24 Headers
  223. New guy needs help with VTEC controller and H22 head on H23 block
  224. F22 motor, D Series Trans, where can I get an adapter?
  225. Prelude clutch line in a del sol?
  226. B18c1 into 99 Civic Coupe
  227. jdm h22 plug wires
  228. Shift linkage... HElP
  229. B16a2 into 1993 Civic 2dr: What Axles?
  230. Distributor Question
  231. VaFc Ver Question
  232. Riddle me this: How do you get a J32A2 into a 4th gen Accord (1996 specifically)?
  233. brake swap-> master cylinder brake booster combo?
  234. 98 h22a accord, a new dillema
  235. K20A vs B18C5: Engine and Tranny Weight ???
  236. where to buy a tranny
  237. I'm A Do-It-MySelfer, but haven't attempted anything big yet. Please post links to any B16A into DA
  238. Help Needed! Car wont pass BAR inspection!
  239. H to b series adapter plates!!!!
  240. Swaps in California? Anyone know where?
  241. Need help on RPM reving????
  242. any shops in New York or New Jersey area that have done k20 swaps NY NJ PA MA
  243. obd1 / obd2 question
  244. I Think There are Two Different D15B VTEC Engines - Anyone Care to Debate?
  245. CRX Gen 1 K20/H22 anybody that has done it here?
  246. Del Sol (CRX 3rd Gen) Engine swaps
  247. 98 B18C1 OBD2 into 94 civic si OBD1 and KEEPING obd2
  248. 4G63T (dsm) swap?
  249. Spark Plugs for first Gen b16
  250. kind of a turbo and hybrid Q
