View Full Version : Hybrid / Engine Swaps
- paperwork with swap
- yet another break swap question
- VAFC dyno process Q's
- need swap help
- Will an OEM b16 Exhaust manifold fit on a B20?
- h22a tune up questions
- Where to buy and how much? B18C5 into EG hatch
- people with h22a Eg's--Questions
- d15b cylinder head question....
- h22a swaped civic intermediate shafts?
- whats the cheapest way to improve 1/4 times?
- crank pully removal ?
- Comparison of B20 and B16 AC Compressor Engine Mounts....
- Gettin a B16 GSR engine for my 92 Honda Cx Hb, need help on power mods!!
- Q about radiator hoses on gsr : EG
- I thought this was cool...
- crank angle sensor (CEL 4) 00' b16a2 in a 96' EX
- My car is misfiring... help!
- about how much hp should this setup put down?
- swap trailing arms = wheel rub???
- Thanks Poison and Rice Classic!!!!!!
- P28 question ?
- 2000 Si cylinder head
- Engine Mount Question.
- 1st gen crx
- type r clutch in my jdm b16a..........
- EG and DC subframes - compatible?
- D16Y7 (96+ CX) into 92 CX?
- NOS vs. Venom
- Wiring Diagram 4 Mini Me Swap
- B18C1 cranks, but won't start!
- anyone ever bought from dh racing.com?
- ls swap
- need 00 si ecu wiring pinout diagram (P2T)
- cleaning, spray-painting block questions...
- zdyne gold controlling ls/vtec set up
- cams for a b20
- H22 Drivers Side Mount Needed.....
- Tranny for B16A
- What AC mount to use for B18c1 swap into 92 hatch?
- where to buy block studs?
- jdm b16a ecu
- gas milage
- Would B-series OEM exhaust manifold bolt up to a D-series cat??
- hoses question
- been searching and can't find...
- Any strut bar fit HPC H22 EGs? and question about the swa...?
- 5G Wiring Problems
- R1 coilovers 2nd generation
- JDM B18C (Spec R) clutch question
- tranny questions
- B16 vs LS tranny wise....... discusion about RPM factor of daily driving.
- Skid plates for b-series????
- 5th gear popping out b18c
- Motor shops
- Mini Me Swap
- JDM B18C (spec R) in 99 ex
- check out my new header
- P72 or P28 for B18c1 (GSR)??
- Newbie looking for suggestions...
- what ecu for my b18c1/hatch project?
- CEL problem. what now. help me out please
- h22 head swap
- help finish hoses for swap
- Swap info
- B20B BUILD UP!!!!(going in on friday)
- B20?????????????????
- GS belts with B20B bottom end???
- Ek h22 Cam gear Settings with MUGEN H22a HEADER
- axle interchangable issue
- Swap: legal & smog issues in CA
- shipping longblock
- wtf? f20c hybridded Toyota?? this is just insane
- Differences in bare blocks...
- b20 alternator??
- zc cams?????????????????????
- LS/VTEC safety issues?
- California Smog stories.
- Engine installer in NJ
- Need a custom I/C kit or CAI for your hybrid ? Check link !
- what exhaust on a H22A EG sedan ?
- GS-R Tranny vs. Si Tranny
- I got screwed over by this punk selling a beat down 92 CX
- which mounts to use? (96+ civic)
- legend engine swap possible?
- help with '00 si swap into a '96 ex civic...wiring issues here. help please.
- b20b idle problem
- B18C5 in 2000 hatch
- crvtec civic hatch for sale........................
- What ECU for JDM H22A? not p13
- Baseline (ish) hybrid dyno......
- power steering in gsr eg??
- motor mount question
- ls vtec b18 coupe whats it worth?
- anyone in my area?
- engine swap
- How safe to downshift a B20-VTEC ..........
- The hybrid is back and better than ever! :P :)
- LS motor with mods or GSR ?
- Just completed a swap over the weekend - here are some pics
- Can a d1678 use obd I???
- ELD check engine light?
- Anyone running LSVTEC with GSR head and CTR pistons?
- how to calculate compression ratio's?
- need to know witch engine mounts are needed
- Flywheel/Pilot Bearing problem....help!!
- skunk2 cam ?? Need answer asap!!
- Pop quiz hotshot!!! Will this fit? (
- b16 cranks but no start, started fine earlier (no fuel pressure)
- PINOUT Help! Prelude S to h22a1 swap help!?
- How much did everyone pay for there H22 swaps and where from?
- If you hydrolocked your motor and had $3300.....
- JDM Engines
- What tranny should I bolt up to the B16A????
- OBD0 w/ OBDI H22 ECU ???
- Those with LS/VTEC. HELP!!!!
- h22 knock sensor ??
- Witch I/H/E
- ACL bearing... what is known about these?
- Mechanical / Elec. Speedo - 91 Civic
- i want to keep my PS!!
- Field or Apex'i Vtec controller?
- idle problems after Skunk2 intake mani install
- B20Vtec opinions please
- stock b20 block + stock b20 head...reliable?
- New HCP EF Crossmember w/adjustable Radius Rods
- Ls/Vtec Help
- dc sports exhaust?
- My Car sticks in reverse Help!
- Can somebody HELP me????
- 1988-1991 civic AWD wagon swap
- My car weighs...
- help with swap from d16z6 to b16z2 sir 2 (j-spec)
- 2nd gen b16 half shaft qs???
- How long can a motor sit before bad things happen?
- Which ECU do YOU use for your LSVT ?
- 92 cx 1.5 to a 93 vtec si
- H22 in eg
- need some advice
- Debating on tranny. Y21,S4C,or S80???
- Ordering B16A Sir 1 from hondamotorsonline,need info guys!!!!!!
- jdm b16a gurus, please help!!!!!
- Can anyone tell me how long it takes a motor from HMO to arrive in Atl,GA?
- should i trade 2 cars for 1 car?????? Please read
- 96-98 ecu plugs different than 99-00 plugs??
- H22 EK Civic-- Wiring Question
- B16A and B18C mpg in a hatch
- dumb ls/vtec Q.......Vtec controlers on ls ecu
- LS timing belt on ls/vtec can it mess up intake cam timing??
- quick q: going rate for b18c1 swap and itr tranny.....bay area
- whats a good price on a b18b longblock?
- Anyone using LS distributor on LS/vtec
- how to install my lsd??
- what to look for in a h22 EG?
- Anyone see this swap before?
- How many of you did your own swap
- CRV + CRVTEC People? 1/4 mile times?
- My project hatch finds a new heart!
- do i need an engine mount kit for this??
- which brake line.....?
- Help With Plans
- Now that its time to maintain my swap I have a ???????
- crv bottom block $$$
- Need help about using ECU P72 with a B16A2 swap?
- Mini Me swap
- Need help.....I'm in the middle of my swap
- car starts sometimes .help!!!
- Obd2-1 harness Pics are IN...
- Compression ratio on d16a6 block with d16y8 head?
- B20z throttle body problem
- How do you Check CEL codes??
- Secondaries not working.... Any Ideas??
- H-series motor questions - H-series experts please help!
- good sites to find engines?
- FOR SALE: TWM individual throttle body for type r/ b16 head..........
- Car wont start .... sometimes
- valve clearance w/ ctr pistons in a gsr?
- Swap Question????
- MSD Ignition for DOHC ZC...
- LS/VTEC Knock Sensor
- Bone stock b20vtec dyno chart
- any goood shops in south cali????
- speedo cable, vss, b16a, crx88
- H22, Civic EK hatch, and 2000 Si engine wiring harness.. HELP?!?!
- when does vtec kick in on everyones gsr??
- Major Problem!!! PLEASE HELP!!!
- Shortblock vs Longblock
- H22 in a CRV
- Story about JDMCLUB.com
- H23a in CRX or EG?
- what do engine "papers" look like?
- distributor assembly
- Do not deal with Landspeed Racing
- CEL#6 Engine coolant temp circuit
- should i trade a 94 gsr block for a 00 b16a block ?
- Quick question TANABE Racing Medallion.... diameter 2.5 or 2.75
- IAB Question
- How much vacum is ur engine pulling at idle.
- OBDI LS ECU + OBDII B20Z = what harness do I need?
- Msd Distributor cap on B20/Vtec
- kinda funny and cool, but need help
- resleeved b18b or stock b20b?
- B20 Intake Question
- Difference in JDM b16 heads ? ? ?
- using saturated injectors...
- Coupe with b18 ls vtec for sale!!
- enormous shaking at 27-30mph
- Shifter stabilizer bar b18 in civic, which ones work?
- need quite exhaust 89crx si b16a dc 4/1 header
- stock fuel pressure for B16a2???
- Couple B20Z-->LS Intake Manifold Questions
- Recommended spark plug for b20vtec n/a
- ecu question
- Using a PW0 ecu w/ Lsvtec setup?
- Theft Alert! NorCal please read!
- str8 B20z in an EK checklist
- Step by Step Swapping information.
- What A/C Bracket to use
- H22 in 6th gen hb?
- CAI question for motor swap
- Need Advice Quick!~!!!!!!
- I Need a Diagram of a OBD1 GSR ECU
- Need help B20b/B16A
- Wheres the best place go get a GOOD, AFORDABLE SWAP in soutern CALI???
- very bad shaking when i get on the gas at higher speeds
- Wire harness differences
- somthign is wrong here. its weird. what could it be?
- Code 41 , O 2 sensor?
- FS: Brand new SI wheels
- Unrealisitic question but want a Realistic answer about SWAPPING engine
- EZ ?
- GSR crankshaft pulley bolt is satan !!
- stupid newbie question...but need answer fast...
- help needed..b20z in EF..engine codes :(
- How do I tell what year my motor is
- New Fuel Pump??? 95 civic, jdm gsr, 55 shot ZEX
- help ident? obd of harness
- 2K1 Civic D Series Exhaust mani same as 92-00?
- Searched but cant find...b18c1 vs b18c5
- bay area: where to get b18c1/itr tranny, + install
- ls/vtec timing problem(timing marks not lining up)
- I know this is supposed to be in the class. section but I have a ITR block and Wiseco pistons for sa
- code 5 map sensor. changed map sensor, still code
- Rear Trailing Arms the SAME on ITR and EG??
- it wont start
- h22 civic people- Hasport VS HCP
- jdm 98-00 ITR in a 98 dx hb
- Swap help
- JDM Engine Differences?
- What is B18K
