View Full Version : Hybrid / Engine Swaps
- VX to B16 o2 wiring dilema
- Header on a B16 vs B18 - CRX
- I got a few ls/vtec questions
- Swap with IACV problems
- shop for swap in midwest
- JG intake fit on a EG b18C swap?
- Dang! Waiting list for LSD tranny...
- skunk2 intake manifold h22a
- Which turbo?
- How do I wire up the VTEC on a 90 integra with a B16 swap?
- Calling all wiring gurus - H22A USDM/JDM question
- what is the best motor to put in my 97 ex?
- jdm b16 ignition wires
- Pissed off about honda VSS sensor system, please help/provide input
- 4door Hybrid help
- throttle position sensor on jdm obd1 h22
- update on Si h22 1/4 mile times
- ls in ek..wont start
- need some help with an exhaust for crx swap...
- H22 wiring with 4WS
- NO FIT: JG Edelbrock Intake Manifold Into 87 CRX
- ls rod itr pistons
- nsx engine in an accord????
- my swap b18c
- crank angle sensor problem in ek
- VX ECU issues with d16z6?
- 2nd Gen Prelude Engine Swap Q&A, please help.
- Repining my ecu.
- my d16y8 is dead
- Shift Linkage for a 97 LS into a 96 EK
- Shipping a project car for swap...?
- Just a quick question...
- its dat code 22 woo woooo
- I kno you guys seen this topic but PLEASE HELP I really need it!
- heres a problem with my hybrid
- EG swap
- can i fit a nsx suspension in a 92 prelude si
- H22 Civic hatch?
- ZC (black cover) in a EG : what do I need ?
- Qestion about brake set up for my hybird
- 97 LS ECU Pin help!!!
- b18c into 97 ej8
- My H22 Update :)
- Interior Questions!!! GS-R Dash+Gauge Cluster into an EG Hatch??????
- h22 throttle body on bseries manifold?
- can this be done?
- b16b in a eg
- injectors and resistance for a pr4 ecu.
- Inputs Needed
- k20 n 94 coupe
- Covina Swap Shop vs Autolink?
- newman, got a ?
- h22sh into 92hatch help
- Obd 1 motor in OBD II car
- JDM D15 Info!
- Please help..
- Wire Harness Question?
- my friends h22 ef project
- all my CEL are gone!! h22ek is running its ass off!!!!!
- H22 Hybrid HELP!!
- Just finished Mini Me swap "Need Help"
- my ek22 eats gas like crazy...
- spoon p13 & v-afc
- Pics - B20Z with torque chamber clearance problems?
- Turbo H22a Civic, what tranny?
- h-series and f-series tranny's the same size/shape?
- JDM B16 Woahs!
- Del sol cluster into eg hatch!?!
- After market pulley kits for JDM motors.
- CAI intake for hybrid EG with B16A2 engine?
- radiator mounting and slim fan
- ls into eg
- H22a not revving past 6900
- WTB: H22A EG Swap Exhaust man gasket.
- How to mod the injector resistor for Mini-Me swap?
- shielded wire for swap extensions - details needed on what to get...
- O2 problems again. Y8 where a Y5 used to be.
- Type R head on gsr block?
- B20 w/gsr internals. Will it work?
- Why does my H22 not pull before VTEC???
- h22 header/civic exhaust
- skidplate for header
- need h23 vtec help
- throwing a code, map sensor
- Is a 90-93 Integra chassis worth it for a swap?
- block girdle for b20!?!?
- H22 HELP swap into EK
- new here, some ??? about crx hybrid
- Need Hybrid help (GSR/HATCH)
- help!!!!!!!! h22 into ls wiring diagram needed
- H22A P13 ECU: What is the best chip? Spoon, Mugen, or ?????
- B18C4 throttle body onto B16A1
- Has anyone run into this problem?
- Intermediate shaft and half shaft the samething?
- Major Mini-Me Wiring Issues! Where does everything go?? HELP ASAP!!
- Critique my LS/Vtec turbo setup
- quick ? just ordered new motor sir 2
- What code is this?
- Simple Q: Shift Linkage
- Exhaust manifold for h22 in a civic coupe 1995
- JDM longblock... b16a SIRII
- What head and block combo is best for a crvtec turbo?
- 1995 EX sohc vtec, engine went.. BOOM
- 98 LS in 96 hatch.. wiring the CF sensor by the pully...
- OBD2 -> OBD1 ECU conversion harness, need urgent help!!
- b18b1 swap into eg hatch...what throttle cable can i use?
- Code 4 CEL Krankshaft Position Sensor Help Please
- Water in the oil
- JDM OBD 2 b16a. no spool valve oil switch no CKA sensor, WTF?
- b17 crank and 00 si tranny please help
- First gen JDM B16 Compression numbers
- ****need help, vtec not engaging****
- b18c
- breaking in my 2.0
- Clutch Question?
- my hybrid sleeper
- reliablity of this setup
- Smog check validity
- My H22 Civic keeps dying!!!!!!!
- poor mans type r
- H22A with F22B loom?
- Competent Garage
- Piston/valve clearance question..
- gsr running lean
- H22 hatch loss of power......
- LS Idle Air Control Valve
- need help to do a ls-vtec on 90 ls
- Wanted..SoCal D16Z6 installer
- B18c EF is done. driving impressions.
- JRSC on H22 swapped EG??? Would it fit??
- Anyone have the Autometer Phantom Oil temp gauge?
- what sensor is this?
- o2 sensor woes, rough idle, hesitation crx/sohc vtec
- Help: 1G B16A in EH2
- LS/VTEC Questions !!!??!?!?!?!?!
- obd0-obd1 trouble shooting ??
- need help with b16a in '00 Si
- H22 in 92 Si quarter mile times
- Supply and demand.. Is the h22a swaps going up in price?
- GSR head onto a b20 block
- Hybrid Swap Shops in Minnesta
- What gauge wiring to use when i swap.
- GSR swap help
- swap
- EF alternator woes
- h22a into crx
- Shift linkage for B18c in 94 sol
- JDM sohc vtec problems???
- Where to buy USDM B16 engine? (needs to be smog legal, in CA)
- civic lx type r engine swap
- Help! My GSR swap is MISBEHAVING!
- I need some help from friends!
- H22 into EK civic, WIRING
- Heres my H22 EJ6 pictures!
- H22A distributor wizards, what cap do I use?
- getting 60 miles/tank of gas!!!
- How did most h22'er break thier axles??
- Its Here!!
- JDM H22a - emissions differences to the USDM ?
- H22 and EG swap --> accord fuel rail question
- My B20 into EK parts list
- B17A guys or YS1 Tranny guys!! What Vtec crossover do you recommend?
- Header Testing Help?
- 1981 Civic- Help with engine info
- JDM DC Sports 4-1 header?
- JDM speed governor - how does it work?
- swap B18A1
- Code 36? On jdm p13
- Does comptech intake for GSR fit B16/skunk2 IM?
- JDM b16A1 swap into 92 hatch
- Problem with 99 gsr ecu
- timing advance 2000 si
- 1995 Auto Civic EX, How do i take crank pulley nut off w/ out havign to you high dollar tools??????
- question for the tech heads...
- Thoughts on a 91 civic hb swap???
- Anyone in san diego heard of tribusracing
- Figured out my vibration problem. Hasport EG's unite!
- pricing????????
- Need some help....
- help PLEASE with obd0-obd1 conversion on ef
- 92-95 ls swap into 92-95 civic...
- How does this setup sound?????
- Stolen motors
- looking for a picture of b20z piston notch'd for valve relief
- wiring a OBD2 Distrubtor to OBD1
- Has anyone put a real motor into an Insight?
- HONDA EK H22 swap!
- Help!?
- eed help with a swap
- exhaust question
- eg6 conversion
- ok just ordered jdm b16a sir 2 from hmotorsonline
- who has ever ordered a motor from mark gearhart, the owner of jdmclub.com??
- swapping an LS to a gsr
- H22 civic guys: What tires are you running and what do you recomend?
- h22 in civic owners, what to use for blocking off shift plate hole?
- h23 in 00 coupe, what setup?
- technically a hybrid question, about s2000 doorhandles...
- 1995 integra gsr swap to type r
- engine swap (give me info.)
- Kock sensor install pic?
- Mr Gasket "The beast" crate motor 220 WHP
- h22ek guys!!??
- Longblock, shortblock...
- Engine Mounts Question for B16A2 Swap
- Del Sol vs. Civic hatch......H22 vs. B18c
- obd question?
- quick question. I need to know torque spec for headstuds on a b20 w/b16 head!
- your method of a odb2 Bseries in an obd1 car.....question
- obd2 to obd1 gsr swap in cx?
- A few ques. on swapping a 92' b17 into a 92' eg cx
- LS/VTEC oil leaking.
- D16y8 in 93 Hatch
- power steering with h22a in a civic coupe (searched)
- Best suspension setup for swapped 97 hatch????
- 97 civic 4 door....... what to do, what to do?
- obd2 to obd1: cel 3 map
- what shift linkage are you running in your h22a hybrid?
- B18C1 into 92' CX Specific Stuff
- Wiring harness differences
- rear mount for ls swap?
- Need a few good swappers advice
- need help with 89 hatch :(
- Swapping Engines for a 89 Civic LX
- interested in jdm dc5r front cut?
- what motor should i get for N/A setup in my 91 hatch?
- hmotorsonline.com...best service and prices
- wiring jdm gsr to LS body???
- This could be a sick Hybrid......
- Horrible IDLE and other strange occurances w/ my gsr swap.
- Finshed B20-VTEC setup
- H22 civic ecu question which chip you running?
- Guys/Girls with h22a swaps in 96-00 civic. Got a question?
- Knock sensor bypass?
- Several problems after swap
- What's up with these shady tuning shops? No one has any integrity...
- How much is a CTR diff worth?
- I need an H22 EG Vacuum Hose diagram ASAP!!!!!
- b16 into 00 cx question...HELP
- 88 Civic swap?
- Injector resistor box question....NEED HELP!!!!!!!!!!1
- B16 swap into a 94 coupe ex
- b16a1 into 90 teg ls!?
- code 54 and 22 HELP!
- h22ek swap/ place racing vs. hasport??
- *pic request* fuel maps for ls/vtec
- JDM conversion
- Obd-1 and Obd-2 Question on a swap.
- B17A Into EF Civic or CRX
- Problems with my b16a2
