View Full Version : Hybrid / Engine Swaps
- ek coupe b20 vtec, p72 head.
- What injectors should I use on a crvtec project?, usin a p72 head with pr4 mani.
- Z2000 project 240Z with S2000 swap & Supercharged!
- auto d16y7 no start
- Gsr swap harness question
- 94 EG hatch w/ JDM B18b will not start, help or ideas please.
- Need help!! B18b turbo in eg wont start.
- obd2 crv intake manifold components on obd2 ls intake manifold
- h22a swap no longer starting
- type r or not type r
- new engine install
- b18b1 into a ek need help
- b20 vtec in a 98 ek coupe, which ecu should I pic up?
- I dropped a down-graded (OBD I) b20b into my EK sedan & now it won't pass inspection
- B18C1 into EM1 AC Question
- what swap should i go with in my 99 civic ex have funds just looking for big power
- LSV missing in low rpms
- B20-GSR Head..
- header for b20 non vtec
- B20 swap from 94 integra into 99 civic ek?
- f20b head gasket
- head gasket on 91 si. won't start.
- ls obd2 swap in eg hatch
- h22a with h23 crank
- 97 f swapped civic stumbling on acceleration
- SF Bay area swap Help
- Engine swap not starting/turning over
- Wiring questions... b18b1 in EG.
- 94 honda civic ls engine swap
- b20b vs b20z
- 92-00 Civic D & B Series Swap Guide
- h22 in eg swap cranking over hard but refuses to run
- H2B H22A OBD1 swap harness dimensions
- Cluster problems ?????
- ls vtec to b20 vtec
- LS Vtec Catch can question.
- D16z6 to H22A swap
- 95 Civic DX B16A to B18C (GS-R) swap
- ef teg hybrid
- Can I swap a B18 for a B16?
- Oil catch can setup b20vtec
- 1986 Chevy Sprint D16Y8 swap, td05 turbo and more...
- B18b1 With Skunk 2 Manifold?
- Intake Cam Seal leaking PLZ READ
- '94 Del Sol S B18c5 swap questions
- EJ1 LS swap question
- 98 Civic EK - B18c ODB2 Swap
- CRX to B18a1 Please help
- Few questions to finish my B18B into 96 Civic
- lsv aem cam gear install
- b20vtec
- Boosted gsr won't at startup
- B20vtec-turbo with B16 head...what compression ratio?
- lsvtec die out when warm
- B20b/gsr ??
- EK w/EG crossmember with B-series?
- h2b or not h2b
- Good fuel pressure gauges?
- Plateless H2b help
- LS Swap into EK, bogs when trynna rev
- engine wiring harness question
- obd1 LS swap in EK, fuel pump not turning on after swap
- Can somone please verify effective compression
- ls vtec b18a1 block with b16 head
- 1997 Civic EX - B18c swap questions
- b20b/b16 ek
- B18B1 in a del sol?
- Sensor plugs looks the same b18b... help, please
- AC/PS Delete Serpentine Belt H22A
- Mock Up of Engine Damper on H22 civic!! What you guys think?
- P0302 304 1300 1399
- H22 in a 93 civic hatch that was converted to a 5 speed
- Regarding ek coupe
- 2000 Civic w/ LS swap - how to verify manufacture date?
- getting ready to swap over to obd1 in my 97 civic jumper harness question
- Going B20 Vtec soon... A couple questions
- HELP: EM1 with GSR swap IAB wiring
- b20b in ek coupe
- B20 swap in 98 civic??
- What A/C system will work with '00 B18C1 in a '92 VX?
- K24 Swap
- 98 B20b4 in 93 hatch
- P8R Head on LS B18B block, what head gasket?
- OBD2a B18C into 91 CRX
- CRX with gsr swap: axle binding problem
- CEL (Code)4 on P30 ECM
- b20V swapped CRV wont fire up
- Help! Accord motor civic body/harness no acceleration
- CEL 20 & 36 GSR swapped 98 ex
- 96-99 jdm zc
- 97 Ek B18 swap wont go past 4000 rpm
- h22a only revs to 2k until warmed up
- My 98 CRV 5spd rt4wd. H2B inside.
- 97 LX CIVIC W/ 97 B18CR SWAP REV LIMITING AT 7000 NO VTEC
- h22 in my Ek
- hx 7 wire to 4 wire o2 sensor. y8 ecu, head, intake manifold y5 bottom end
- d16/b18c Powersteeing
- d16/b18c alternator plug wiring
- d16/b18c Keeping AC
- 2000 Civic Si with GSR..Help with BAR!
- destroked b20
- Can Anyone Identify These Mounts?
- ls swap ecu obd1 but i need to pass emissions!
- s80 4.7 fd on my b18 turbo??help please
- CIVIC SR3 (EG) RWD Conversion Build with SR20DET (many pict)
- 96 civic gsr swap info
- Need some obd help
- Rebuilt LS Vtec CEL problem
- F series swap eg coupe?
- Another exhaust related question... Bleh
- 01 LS b18b1 into 99 ek. Need a parts list/wiring info. Obd2B
- gsr swap...have some wiring questions
- conversion from stick to auto EF. do I still need the ps?
- 03 Civic Hybrid Codes and Install replacement parts question
- OBD1 H22 swap into eg question
- K20Z3 into an EG Questions Concerns HELP
- OB0-OB1 Distributor wiring problems?
- b16 in eg
- harness guide
- b20z2 obd2b p75 problems
- jdm b18c-r swap 2000 civic si start problem
- eg hatch hasport mount problem
- H22A JDM
- b20 cel with bigger throttle
- 99 Obd2 auto LS in 95 auto del sol
- PLEASE HELP!! Cant find an answer to this!
- knock sensor
- Ecu?
- h22 in a 92 cx. some advise please?
- Hasport mounts questions
- F22 swap EG Sedan completed! raises interesting questions
- h2b clutch opinions
- *Video* H2b dyno
- h2b questions need a little help???
- code 9 ls obd0
- h2b header problems
- FiRst BuIlD h2b need some help!!!
- What ecu should I use for a b18b (obd2) into a 98 civic (obd2)?
- What ECU is this?
- Auto-Man Quick radiator Q
- ECU/Loom Questions with PICS
- Is this a B-series transmission torque mount bracket ?
- 1995 Integra LS to B18C5 Type R JDM swap help
- help with swap plz
- '99 HX Preparing for turbo build
- No power in VTEC
- B Series Tranny Websites
- Does the b18b1 carry thrust washers
- Anyone familiar with JDM Engine World in Queens NY?
- Code: P0170
- h2b ek, ac and ps?
- 2000 ex coupe swap problem!
- USDM vehicle weight list
- H2b ek h23a injectors And wiring question
- Civiv HB 1.5L engine in Accord
- B20 Swap
- need help MAJOR!!!
- HELP! Missing Torque Mount stud!
- Auto EG F22 Swap
- Back in the Game, B20 Question
- Can you fit a stock EM1 air intake to a stock GSR TB and IM
- EG gsr
- What to do to get this bad boy up to 350hp
- Y8 / Y7
- zc/z6 mini me
- F20b With H2D kit
- EG H22 rear motor mount question Innovative
- Gsr stroker compression
- B18c into EK Civic
- GSR into EM1 NOOB. HELP!
- 00 Civic/GSR-16a2 Swap- Fuel Questions(Fuel Rail, FPR ect )
- b18c Manual into an Auto eg..??
- Hybrid-Racing H swap Radiator Hose's
- Swap H22 for a K series?
- plz help?
- 2000 civic b18b swap need help
- b18c5 on em1
- J swap 97 hatch
- 2000 si ls/vtec need help with pistons/rods
- d2b adapter... what else??
- b18a1 swap in a hatch problems
- skunk2 or other?
- 96 Civic hatch/jdm itr swap - bogs, chokes, dies
- h22 swap in eg
- b20 swap
- auto to manual electronics guidance needed
- 00 Civic/GSR swap - Help Understanding CELs after leaving dealership
- b16a1 crx questions
- Is it worth to do a H Series swap?
- what motor to swap into an EM1?
- b18a1 into a 93 hatch
- What Throttle body
- Help with my h22 ek axles
- PLM h2b kit
- B20 injector swap
- I need with an engine swap with my 99 gs integra i don't know if i should go with an
- 92 Civic B18c Swap problems
- white smoke from a new jdm d16 vtec?
- 0bd2 gsr into EF sedan
- Mini-Me Y8 / Y7 knock sensor code
- problem with ek k20z3 sawp
- help please !!!!!!
- Dx to vx swap (eg) question
- B20b swap in an eg hatch help!
- 93 civic dx - which ecu to run an LS/vtec
- Eg ls swap
- skunk2 pro series throttle body
- H2b project
- No AC and PS with K20a Swap?
- 88 Crx swap info needed
- OBD2 LS auto into 92 Civic CX manual (bay wiring ?s)
- B swap in 95 Del sol questions
- 99 si b18c1 swap distributor issues.
- What ECU???
- need help with z6 swap fast please
- What exhaust manifold and down pipe do I use for my h22 civic
- H2B Questions
- how do i fixs this
- 00civic emission questions
- Help!!!!! Please
- evolution+qsd mix (will it work?)
- 1995 civic eg k swap axle trouble
- 99 civic with b18b1 swap
- Help me identify these hasport motor mounts:
- EP3 or DC5 radiator for EM2
- need help
- SlowB16's H2B EG, 221whp/177tq Stock JDM H22
- 97 Civic/H22a swap questions
- ls swap civic with code 41
- 1st gen b16a h22 lost motion assembly washer opinions
- Engine build, Gatta beat a Rustang
- 91 CRX Si - How wire obd0 chassis to obd2 b20?
- need help fast!
- b18 to Del sol problems
- Jspec Auto or HMO?
- Have some questions about a swap. Help!!
- Harness
- New kind of G23 - do you think it will work?
- K24w (2013 Accord engine) questions..
- fresh b16 obd0 to obd1 swap car will not rev
- B20b swap
- bank 1 o2 and bank 2 o2 Replacement
- If you run lsvtec chime in
- help me decide to buy car or not?
- 1995 d15b jdm swap into a 91 ef auto. cable tranny different?
- B18C1 Starting issue
- PLEASE HELP ME ? !!!!
- B18A into 89 CRX Si questions
- b20b jdm automatic swap into a 91 ef auto?
