View Full Version : Hybrid / Engine Swaps
- Weird looking chassis harness, can't fit it up.
- 95 VX hatch, K20 swap project.
- code 41 and 20 ?
- RUNNING A D16Z6 WITH AN LS P75 ECU...?(temporaily)
- SWAP question???
- Axles in a 92-95 civic Hatch (K20 question)
- Speedo troubles?!?!?!? HELP!!!!
- 97 accord in eg
- b18 swap..having map problem...please help!!!!!!
- B18C1 into EK - custom exhaust or cut the 'teg stock?
- Hybrid website
- b16 exhaust manifold bolts up to civic exhaust?
- b18a built up?
- What´s up with my ECU ?
- LS swap - dpfi to mpfi wiring/distributor problems
- GS-R block & what head?
- need info ASAP on h22 swap in 88-91!!!
- B20 trans mounts
- Code 22 - VTEC Oil Pressure, & Can't rev past 6500RPM P72 OBD2
- d16z6 in crx couple dizzy Qs
- 97 Civic hatch +B Swap
- H22 crx redline sucks.
- Whats my 1995 civic coupe worth?
- what is the diffirence between the blocks: B18c and a B18c1?
- What axles for h22 integra??
- h22 manifold differences...
- tranny question
- Which Password J´s copy is best for EF chassis ?
- Is this a LS/Vtec, and i need Black with orange flake paint job pics
- what radiator hose to use with an h23 in an eg
- Karcepts shifter kit for eg/ek/dc with k-series swap
- b20z problems help
- 90-93 Axles... w/H-Series Swap
- Ls/vtec
- P75 Water Pump on GSR? Also questions regarding B16 Head on GSR Block
- head swap question
- Transmission question
- LS/VTEC DC - Header is 1'' too Short??
- b18c
- K20A - Timing Belt
- K20A-Hondata into ES2 problem
- how to hook up catch can???
- B16a2 swap into 93 si del sol questons.
- h22 civic motor mounts in integra???
- Whose got a good b16a recipe??????
- Dropping the tranny out 2moro..
- help
- 99 CIVIC SI W/JDM GSR ECU????
- How much should I charge for h22 swap ?
- Where's Newman?
- no vt@akk j00 what could be the reason .....
- Mid-engine Mini progress.
- Prelude heater bypass, how to...
- ***JDMP72 ECU PINOUT SAME A USDM P72 ******
- A couple H22 Crx problems. Help please...
- Overheating R motor... whats wrong? Some help...
- delsol 97 engine swap general inquiry
- Will A/C and PS swap Work???
- YS1 Gears
- failed smog at ref - h22 in eg
- enginge/ecu error
- 37820-PR4-A11 for my b18b?
- Compression Too high in cyl 3-4 210-230 Help Please!
- front motor brackets for B series in EG
- h22 in ek track times suck why
- Running Vtec wires on a Non-Vtec engine wiring harness
- Does anyone know how to wire and obd1 head in a obd0 car? (da)
- b16 fuel rail
- Typically, how long would a swap take?
- 1997 Accord H22 Swap
- Stock exhaust piping?
- question about a clutch .....
- '91 CRX; swap B18C5? Possible???
- MIX MATCHING HHHHMMM!
- h22 into eg axle?
- im legal now
- WIRE HARNESS QUESTION 96-98 single DX in A 91 4door civic
- Noob question- Ctr swap
- b20 vtec, now no vtec
- cx to ex swap
- need my car smogged, help please!
- lines coming outta tranny?
- poor mans type r ?
- K20 into a EG6????
- b16a into eg??
- My first swap HElP
- Team Kickinit/RWDCRX.com K series race header
- car dies right after start up......
- 94 B18b1 in Ek
- swapping sohc zc non vtec to a cx eg
- B16 Block Type-R Head GS-R Tranny....any good?
- h22 swap into integra, car dont run right help???
- 1/4 mile time?
- new to honda's!!!
- 2000 b18c1 usdm engine in a eg hatch
- 94 civic dx harness schematic needed (Map sensor pin locations)
- 5gen accord swap?
- obdo<obd1 wiring
- Need help in identifying a delsol dohc obd1 intake manifold???
- can I use
- automatic b series transmission wiring help
- B18a1 into EG
- d15b motor into 92 VX civic
- help, motor mounts...
- I think my A2 swap is missing something....
- prelude, accord aftermaket shift cables?
- Replacement Urethane for my mounts
- wiring obd0 b16 motor into a 89 crx???? wont start...
- H22 euro r manifold
- 95 LS INTO 93 4DR poppen and boggen at 3k
- h22a wiring
- F20B-H22A Driver Side Mounting bracket Bolt spacing???? Need some quik measurements
- MINI-ME california people needed
- I need to identify an obd1 intake manifold from a delsol dohc??
- is the 96-98 d16y7 and 99-00 d16y7 engine harnesses different?
- b18c1 in a 93 cx starting problem ?
- h22 ek
- K SERIES SWAP INTO EK ?'s
- Best LSD for a Daily Driver??
- S2000 Driveline/swap Q
- k20
- Finding the right B16
- Getting ready for my heart transplant! plzz help!
- mount problem
- i got a couple pricing questions before i build my engine up....
- h22a in civic///need my ac
- H22a Transmission / Axle Issues
- ecu need remapping??
- itr vs si master cylinder
- clutch line
- quick swap help....obdII to obdI
- best motor to swap in an ef
- gsr block - no engine code??? p73?
- ***Whats the L3 ecu?***
- d16z6 swap
- The ITR forum is for ** ITR ** owners
- H22a Swap... Which engine Harness? dc2
- best mounts for h22 in integra?
- B16A2 in 6C Civic Wiring Questions
- K20 power just got more affordable.
- noob question... jdm b16a(obd1) long block swap into 00 si(b16a2 obd2)
- post pics of your motor mounts
- obd2a--> crx Q's
- best catback for b16 ef hatch
- New LSVtec Setup
- OBDII Distributor plugs
- PLEASE HELP: LAST ENGINE CODE
- NEED TO RE-WIRE MY H22.....
- OBD2 B18C1 Swap/EG
- B16a1 Swap Into 90 Acura Integra
- ODB-2 to OBD-1 Alternator wiring problem
- distributor cap for b16b distributor?
- jim fab mount pics please
- decrease the throw on a h22 in a eg.
- Calling all h22 crx guru's. Help!!!
- IACV Fix Hummm??
- Car doesn't go past 5 grand.
- OBD1 H22a into OBD2a civic swap.
- B20 Boosting
- Spring Rates 92 Civic Si/Intregra GS-R
- B20 Crank Position Sensor Problems.
- 94 ls with jdm itr motor wont hit vtec
- obd2-obd1 injectors?
- H23 Motor and a F22 Tranny?
- LS/Vtec
- accidently put 87 octane in my ls/turbo....
- Ls motor with ITR transmission
- What headgasket do I need
- where can i find a b16 p30 wiring diagram?
- h22 in an eg, issues
- axles to use with prelude sh block and normal lude transmission
- simple transplant question..
- Axel fitment
- Distributor problems....
- problem after swap
- help!!!! the car use to start, but ever since i drove it, it wont start no more, help
- valve on top of b16 TB?
- PLEASE HELP
- help me identify this transmission?
- OBD Question
- JDM ECU OBDII??
- resistor box wiring ???
- Billet Aluminum Torque Mounts
- B18c problem ! ! ! NEED HELP ! ! ! Engine won't start
- lsvtec feed line Length
- oil in my radiator
- HELP......i got screwed with the axles i purchased.
- ITR K20A2
- pm7 pistons
- LS/Vtec
- B20 OBD1 Help
- d15b into 88 civic hatch dx... what do i need???
- 94 GSR injector plugs on 88-92 Si
- right hand drive b16a2?????
- ???Crank Angle/flux Sensor???
- going to the smog ref in a few weeks ......got a question
- Anyone get there swap from a front clip?
- DPFI to MPFI
- ls vtec swap gasket prob......
- best exhaust to run on a h22 with spray?
- Engine wireing harness?
- Rear Lower Control arm bushing size?
- >>Headstuds F20B / H22A The Same???
- ran my h22 eg for the fist time **need advise**
- OBD1 P72 CHIPPING QUESTION.....NO KNOCK SENSOR
- H22 Accord swap ?
- jdm p72 ecu/93 cx/ b18c1 wire for vtec ?
- how to tell 1st gen head from 2nd gen
- Conversion harness's
- B18C1 or B18C5????
- please help...i've seached
- axle stretch.
- b16 oil pressure sending unit
- B18A in '94 DX.. need help with vacuum
- Exhaust after Swap
- B18B in CRX Help
- Blinking Cel Question?
- some help please!!!!!!!!!
- suggestions, opinions, anything.... need help
- B18B Swap In Del SOl Axles Problem
- ???Fuel System Question???
- 98 B18B in my 99 EK.. will the LS ECU work?
- Remove Knock Sensor
- Anyone know Good Places To Buy a Engine in the Uk??? (or that will ship to uk)
- high idle after swap... please help
- eg h22 radiator
- Type R swap in florida????
- JDM gsr header, eg apexi world sport exhaust. What cat will fit??? Searched
- Rear disc swap rear brake line question
- jdm p72 WTF!!!!!!
- B16A2 swap. a couple of questions....need some help!
- who has a 2.5" collector header in a swapped 96-00 civic, and how is it hooked up
- Stupid Question Please Help
- 6th gen F23 motor w/ H22 tranny, what needs to be done to correct speedo to match actual speed?
- intake compatability question
- 2001 ITR B18C-R into an EG
- Direct Port Nitrous set up on a JDM B16A
- Avid Racing Axel/Mounts in my EG
- P14 H23 ECU with B16 in 00 EK.. Possible?
- New to swaps, please assist...
- oil leaking from ls tranny
- No CEL but engine stalls
- EG BAR/ Legal Swaps...CA????
- 93 ex gonna swap b18a?
- No map sensor plug???? B16 into 94 dx????
- are obd1 and obd2 fuel pumps interchangeable? and how do u reset ecu?
- my car stalls when i hit throttle
- chipping a p75
