View Full Version : Hybrid / Engine Swaps
- burning oil
- which is best engine...?
- WTB- B16 Transmission
- B16 Legality in California
- Waiting sucks
- compression ratio on stock internals?
- Header
- Prove me wrong, is there such thing as a
- Yo Everyone i just found a sweet site for engine swap!!! www.hondaswap.com its sweet
- Anyone have interior pics of their hybrid??
- need advice on lean B16
- What are good suggestions for a lowe budget Motor Swap?
- CEL code 13- barometric pressure
- H22a in a CRX
- Motor Swap hepl please...
- H23 block w/ H22 head
- how much of an extension on a exhaust for a gsr swap in an eg?
- car won't start
- HELP! Flywheel cover. Clutch cover? b16a into EG hatch with type R lsd tranny
- b18c1 into a 00 ex
- Can running rich cause car to smoke?
- best fuel pressure & ignition timing for LS/Vtec?
- Motor swap
- Would there be any benefit to putting a B16 head on a B18C block?
- some pics, B20B pistons/rods vs endyn/wiseco&eagle
- Help Please...B18 into VX 92...
- LS/Vtec oil galley plug leak ... WTF!
- Engine swap on '99Civic DX!!!!!!!!!
- b18c1 wiring in eg. problems, have searched
- H22 into a 93 Si?
- 15:0:1 Compression on a ZC WTF !?????
- Salvageable parts from B16 to LS/Vtec
- ITR exhaust on 92 hatch
- Need help on DC2lude
- 0.25 over, any modificaton needed ? Head, gasket ?
- B16 head + gsr block= lower compression with no modification ?
- 6th gen civic swap info...
- will a d16y6 wiring harness fit on a d15b sohc vtec?
- Head milling questions..
- OBD1 GSR swap in a 99/00 Civic hatch.....lots of wiring??
- help on picking car, etc...
- WTB ek b18c
- Best place for a GSR swap...
- I Love Vtec!!!!
- B20B a/c bracket
- need help with sir
- p03 on a JDm SIR II
- How FAST...95 cx hatch with 95 LS motor all stock
- JG Edelbrock Intake or ITR Intake
- LS/Vtec
- OBDII GSR ecu pin diagram?
- help with a h22 in a 91 civic
- H22A header
- what mounts & brackets for b18c1 into 92 cx
- Pics of my hybrid in progress.... Type S/EG
- What Intake manifold are you ppl using in crv/ls vtec??
- b20a/vtec better than ls vtec or crvtec?
- Bsereis engine in a Del Sol, swap help please
- My B18C1, and Teggy-R cams......
- skunk 2 obd2->obd1 conversion harness question?
- Prelude AC into 96 EK w/ H22A swap
- Steering rack from an NSX or S2K in a teg?
- Spoon crank pulley and lightened flywheel.
- Engine Buildup
- Building a motor, what parts should I buy to boost to 12 psi?
- best header for use on B20Z (NON-VTEC!)
- Is there a way to tell if a PG7 ecu is auto or manual by looking?
- All motor or Turbo, which one should I go for?
- P28 ECU diagram
- B20 8.8:1 pistons for boost in a B16A?
- What tranny should I use?
- How can you tell a CTR TB from any other TB?
- 91 JDM B16 vacuum lines
- Best CRX swap
- b16 swap into a 89 integra
- What a weekend! But still no Vtec!?!?!?!?!?!? Any ideas?
- Vtec spool solenoid valve circiut?!? what is this?
- 98 b18c1 in 92 hatch
- wiring B18B on 89CRXSI
- obd2 to obd1
- Trying to find out what my hybrid is worth if I sell it...
- what to do a type-r head/b20b bottom hybrid
- h22 civic, how to get 13 flat???
- Need HELP Installing a TPS SENSOR??
- b16a2 or d16 w/turbo
- 99 Civic Si Swap in a 98 EX
- h-22 into civic....
- Which AEM Intake??
- golden eagle sleeved 84.5mm gsr or b20vtec??????
- Its that time, SWAP TIME.......b20 into a 95 civic
- b20 vtec/ lsvtec...
- Where does oil go?
- OBD2 to OBD1: 98 B18C1 into 95 EJ civic coupe
- Will a B16A2 intake manifold bolt directly onto a B18C1?
- B20vtec in a teg
- B20 in an Integra
- Any Swap gurus in Mideast?
- Shift linkage ???
- B20B / VTEC ARP head stud ???
- skunk2 manifold for B18C1's?
- What else do i need after the B20 longblock to finish everything?
- Newbie help: D16/B16 physical differences
- Where did you h22 hybrids get your radiator fan??
- b18c into 92 cx?
- Frankenstein Swap, any overheating problems?
- B16A in EG Civic and I don't have any pressuer in my radiator hoses.
- B16A in EG civic and I can't get it to idle under 3000rpm!
- New here...Who here is a simi-oldschool hybrid member? Tech Question too...
- Just finished my swap and have a few q's about CEL's
- 2000 Integra GSR Tranny Question - Tranny Experts Needed.
- confused about h22a swap
- Quickie: throwing code #43 as well as horrible gas consuption...
- Website for CRVTEC CVCC
- Question About Y1 LSD Tranny
- How to check CEL Codes??
- Wiring, I'm confused.
- Radiator swap...
- trouble with mini-me
- Motor mount inserts!
- spoon ITR pistons in B18c GSR block!
- irratic idle
- HELP wiring for B18C1 on 95 cx
- HELP!!!!! URGENT!!!! NEED TO KNOW SOON..... Vtec pressure switch!here is
- built ls or gsr??
- 99+ SI wiring diagram?????
- integra shift linkage for crx...
- h22 wiring help...
- looking for J1 trans parts
- B16a3 into a 93 civic coupe, linakge problems?
- I have 89 b20a5 motor. How much is it worth, and can I use its parts on my 95 b18c1 motor?
- Just got back from Palmdale...
- Doing swap anyday now, need reassurance
- Just to make sure... Which ARP head studs for crv/ls vtec
- what o2 sensor for b16a in a crx?
- H22/Civic dudes....read.
- Alrigth geniuses.
- attn: anyone with knowledge of the h22 swap in a civic
- o2 sensor problems?
- Rim size for slicks?
- Vtec pressure switch??? Where is it on the head.... any pics?
- honda motors online?
- Getting really mad.....
- B16a wiring help!
- which mounts??
- Fuel cells?!?!?!?!
- differences between OBD1 and OBD2 B16 long blocks?
- Anyone running their 5g civic with a ZC motor?
- Way OT: but I'd like to know the difference between......
- LS in a CRX 1/4 TIMES??
- 94'B18B1 Swap into 2000 CivicHX
- Need ECU help fast!
- h22a/Civic...last minute questions.
- jdm wiring question
- Has one put gsr in 98 civic?????
- Throttlebody Question?
- Connect the dots.......vacuum lines that is
- installing heater and AC.
- Lower Octane Gas in hybrid....
- What does it take to drop a b18c1 into a 00 civic EX?
- burning oil
- I love my swap!!
- What spark plugs do I need to buy for my b20/vtec?
- how you know what ecu to run.... please read
- H22A into a GSR?
- Questions on H22A into an Automatic Civic EX coupe:
- VTEC Crossover Point
- will a 9 LS ECu work on the B20B/Z?
- Need some good info...
- GS-R in a 94 hatch wiring questions
- Autometer Tach install on 93 Civic B18c1
- iac valve(idle air control valve) problems
- Did a search, still have questions about CAI.
- Hybrid suspension setups/ideas.... Tell me what works and why!!
- infinitemotorsports.net
- so info in the 92-93 gsr cablee tranny?
- Will 88-91 civic SI knuckles fit in 92+ civic?
- wiring problem
- striping black euro ITR, lots of JDM stuff!
- speedometer wont work
- b16 wiring diagrams
- GSR in a CRX
- B16a(1st gen) Intake manifold fit a B20Z?
- radiator ? reservoir
- Want to make a hybrid as a daily driver
- Fuel tanks
- B18B1 swap into 2000 CiviC
- pyr pr3 ecu question?
- is the B20b/z head & ls head the same?
- How do I know for sure that my p72 gsr ecu is odb-1 or obd-2???
- Converting OBDII B20Z into ODBI
- Help Injectors?
- Any teg owners with an h22 swap?
- High Idle in B18A!!!
- anyone with a gsr in crx? pics.
- Is $600 too much for a swap labor?
- Oil leaking from VTEC solenoid
- EG with B16A1 - Crazy idle, help!
- wiring 5g civic ecu to 4g car
- Is it possible to get no VTEC although the ECU is not throwing any codes?
- Frankenstein project
- Hybrid project begins..
- 1st gen b16a into eg ..please help
- Talk about hybrid, u guys gotta check this out ---------------->
- will an h22 pass smog in cali?
- 1/4 mile times @ Palmdale
- Auto tranny upgrade?
- is this right?
- B18c into a crx, HELP?
- help with axle removal
- wiring help
- Jdm GSR ecu question
- 5g b18c swap questions
- ls/vtec intake/header
- which block to get
- Will stock front shocks/springs/upper-mount work with ITR suspension setup?
- Hop ups for b16a2
- ctr better than itr?
- ls/vtec
- what else with lsvtec
- Last Try...Anyone in South Bay/So Cal Help Removing V-AFC?
- All parts bought/ordered!!! Will begain on friday!!!
- Exhaust help
- b16 head bolts in LS/Vtec.
- Any one in my area (milwaukee WI) do engine rebuilds
- is this possible? help asap
- Calling all h22/eh2 Hybrids!!
- SLOPPY shifter with Y1...WHY!!!
- D16Z6 into 89 CRX
- need help on intake manifold
- NEED Help!!! crvtec attemp going wrong!!
- del sol intermediate shaft????
- B20, California Smog? Anyone tried to get a BAR sticker? Intake manifold issue?
- JDM 130hp d15b question
- Which Fuel Pump to use?
- i got yall lots of b20 help !!!!!
- i got yall go lots of b20 help !!!!!
- 87 Civic SI
- building a block
- hooking up an electronic speed sensor to a cable tranny
- Will a header for a 91 LS fit a 95 LS?
- anyone from the cali bay area???
- Getting rid of the swap for another swap...
- heads... and cams.... really really want to know... help if you can answer 1 of my questions
- cv joints? b16
- Del Sol vs. 5th gen Civic harness.... are they the same?
- DX to SiR(b16) wiring?
- B20 oil pan same as B16a oil pan?
- V-afc question, check engine light!!!!1
- distributor leak
- everything needed for gsr swap??
