View Full Version : Hybrid / Engine Swaps
- Need help with b20 swap
- What are some common things people forget to bring for a swap??
- Need to know for sure, if i need motor mounts.
- D Series Wiring
- quick question
- sensors on obd1 94-96/97 ob2 & up b18c1 the same?
- D16Z5......
- Need info on B18/B20 swap into EK hatch
- Which header for H22a EG?
- shift linkage help!!!!
- vx to si swap questions???
- WhAt ShOuLd I dO????
- Can N E 1 Help Me Out with My Swap?
- OBD II to OBD I conversion kit
- List of required cables for b18c swap
- ek mount mix up ????? help
- What to do? PLEASE HELP
- jdm h22 vs jdm b18c5
- anybody out there with a 97+ or obd2 jdm h22a in their 97-96 accord????
- jumper harness
- LS/VTEC Idle problem
- Prelude Resistor Pack help?
- jdm b18b
- Should I go for a swap?
- anyone in illinois know where i can get a 0bd2 gsr ecu??????????/
- H22A prelude motor in a 00 hatch civic? what do I need?
- how do u tell if it has LSD in tranny?????????
- Are adjustable cam gears worth getting or what?
- 94 Del SLO Si +ITR swap = questions on swap
- What in the world is a P5M ecu?
- u asked and here is my hybrid (pix)
- h22 guys help w/ passenger side axle
- SOHC VTEC help...
- 99 Si motor into 95 Si, ecu question
- A little OT: Websites for these tools?
- Honda newbie needs to know the diffrence between engines
- Which rad. hoses for my swap
- Spoon 70mm throttle body .....
- LS to gsr
- Big list of Swaps and required mounts, linkage, ETC....
- hybrid cat length
- Engine swap or Transmission swap? How much for transmission swap?
- to chip or not to chip
- Best ECU?
- Got some parts from UPS, including my SMS header
- LS/VTEC my built B18A
- 92-95 OBD1 GSR Wiring Digram for anyone that needs it
- My CTR, what car would it be the easiest to put in?
- Best Sale Ever
- OBD1 or OBD2
- Usdm B18C vs Jdm B18C
- JG Cam Gears???
- B-series ECU's
- ctr cams???
- H22 redline
- h22 Fan question
- what kind of cat are you guys/girls using that have a jdm b18c swap?
- Motor mounts?
- what is your email address i am the guy with the 90 crx dx im trying to put a b16a engine in it and
- Fuel tank swap
- H23A VTEC????
- 1st gen b16a into a 92 hatch?
- Will a h22 swap into a 96 hatch be as reliable as the stock engine
- dx, ex. friggin letters!!
- It is all coming together. What special tools do I need for the swap?
- Camshafts? obd1 gsr in my 94 cx
- To those that have swapped doing most of it yourself
- H22 Civic wiring harness
- h23a
- B16 Head VS GSR head for Lsvtec
- Wisconsin Hybrids!! --> DMV problems - laws, etc??
- Price for 5th gen??
- what shift linkage should i use
- I got pics of my swap that should work now
- mounts?
- staying all motor?
- 99-00 ex p2p ECU
- K20C into a eg6 civic?
- b16a into 2000 ex please help
- JDM 88 ZC Si into 93 civic cx hatch?
- Harnesses
- I *almost* miss my single cam...
- 94 b18b into 96 hatch?
- 1990 Accord: 1995 JDM H22 Swap Pinouts?
- Why are people so stupid?
- Hybrid Cable transmission questions
- Code 9 jdm pr3
- what to do to quiet exhaust
- how to swap
- B18c/B16 How-to
- F/S: GE sleeved B20Z
- 84-87 CRX B16 Header/Exhaust ?s
- head swap question?
- b16a3 in a 90 integra
- Can someone vouch for JDM_DOHC_Sir?
- hybrid engine question good/bad
- Where does the vaccum hose from the cruise control go?
- Before I install the juice...
- Anybody know any good shops on LI?
- b16a1 in 93 cx hatch
- B18C5 in my Si
- Integra shift linkage
- ??? for any body that knows
- NEW: HCP EK Driver's side mount
- Various questions about weight: swap, hood, ex. mani,
- 93 ex sohc vtec into 88-91 hatch
- Quick Yes or No question!
- 96)Civic w/Integra front end&motor
- b16a in 90 crx
- OBD0 harness adaptor to OBD1/2
- B18C EG wiring
- Lifetime Warranty Axles..
- AH.. earls tap for ls/vtec striped.. help
- what else will i need? h22a swap into a 94 civic ex
- h22 vs. b16a2
- ATTN:OH & MI ~~~~~~~~~~~Dyno Shootout~~~~~~~~~~~~~~
- anyone in illinois, need shift linkage tomarrow
- ? about integra ac compressor
- Gsr throttle Body size???
- 60mm INNER DIAMETER header gasket?
- Guyz check out my times.....?
- H22!!!!!!!
- what is HMOL new website? anyone?
- Cluster Swaps
- which aem CAI?
- what harness should i use?
- b18c1 in an eg
- b16a into 94 civic hatch, need some opinions please
- H22a mounts for a 96 civic hatch
- ITR LSD fit in a 2000 Si trans?
- h22 conversion
- h22 wiring newbie
- Next upgrade is brakes, what options??
- 1996 JDM H22A authenticity
- Help, which shifter stabilizers bushings should I get.
- b16a block & b18c1 head...which head bolts? b16a?
- 3k redline...NOT o2 sensors or angle sensors (already checked)
- Question for a friend. Help!
- PowerSteering H22a in EK Coupe?
- the cheap guys know what i mean
- vtec wiring
- DOHC ZC Specs.
- total cost of h22a swap?
- Our dyno results..
- Place mounts for H22 EF's ?
- 94 or 95 Hatch w/ B18?
- jdm b16a vs usdm b16a2
- need wiring/vac info pix b18a1 into 88 crx hf
- Do i need aftermarket rods?
- short block and long block
- All my h22 hybrids, how are your cars running??
- slugs lookin intake...J'sRacing?
- H22 in 88-91 Prelude
- b16 distributor to 92 harness
- Hey Osaka got a question for you!
- b18c or b20 vtec?
- 97 Hatch With H22 Help
- At what point to I need to have my block sleeved? (ls\vtec)
- D16Y5 and/or B16A2 O2 sensor wiring diagram please
- B18c or B16a
- B20 VTEC..or should I stay with my C5?!
- Good places in Frisco/Sac to get custom engine mounts?
- H22a in $300 EG Hatch
- Help!
- OPM Motorsports LSD
- n00b-type Q--ITR sus in EK 4-door
- How much does a b16a1 bottom end weigh?
- h22 swap guide
- gsr swap in hatch??
- h22a question
- Newman
- Anyone have pics of rear teg/civ susp?
- For all the cold weather locations... What fluids do YOU use?
- d16z6 Swap and Rebuild questions
- Cheapest way to go LS/Vtec
- need help w/ a D-series
- 98 civic HX w/ B16 wiring?????
- suspension height-weight transfer ?
- AN-R header vs JDM 4-1
- where can i find J's Racing intake for gsr???
- need help!!!
- 2nd gen jdm b16a
- 3.0 4cyl VTEC
- 99 Civic EX gauge cluster for sale
- B18c1 in 88-91 honda civic
- ITR IM on a GSR head
- Acura Legend swaps
- 2000 civic to 2001 GSR swap
- pointing out problems to a motor
- front tranny mount: reuse civic 2 bolt, b series 3 bolt
- Any swaps for 84' Civic
- Where to get JUST a B18C5?
- B18A in a 89 civic hb
- JDM ITR aluminum AC bracket for hybriders
- D16 SWAP!?!
- h22a lsd... how do I know
- what tranny for b20 not the usual question??????
- testing the idle air control valve?
- civic and integra mounts
- What tranny are the b20vtec running??
- Anyone get their immobilzer removed from jdmhondaparts.com?
- B16a1 Or B16a2
- ZC Tranny Seals???
- JDM P13 ECU Automatic Tranny VS. 5-speed Tranny Differences
- Coolest Golf Cart I've seen!... It had PA temporary tags on it.
- o2 sensor codes
- What Throttle Cable To Use on b16a II??
- Tach inaccurate/inconsistant after swap?
- 2000 si wiring 97 chassis 2k b16a2 question
- 02 Civic with K20A motor...
- Pictures of my B16A swap from Osaka
- anyone done b20/vtec
- b20Z into del sol questions..
- info on how to do a h22 swap into a 92 civic si hb?
- anyone using a Zdyne ECU with a b16?
- osaka jdm motors?
- Re-use parts?
- B18A swap into 93 civic
- newbie questions........
- GSR radiator in a ek hybrid?
- insurance and engine swaps...
- GSR into a 93 Civic Coupe, what tranny mount?
- o2 sensor causing limp mode
- 2500rpm redline!!! After B16A2 swap into coupe
- Starting the 'GSR IN AN 'EF' CHASSIS' roster !!!!
- 97 hatch with h22 swap
- obd0 plug color?
- pics of my swap
- Automatic with B16-18?
- Just got a HB 92 VX
- Broken tranny bolts.... What to do???
- could i run mid 13s wit this setup
- 92-95 HB considering swap w/ B18C1 help
- Question I didn't know the answer to regarding B18B1 swap into a 93-95 EX....
- OBD1 LS replacing Obd2 LS....
- help with EVAP can, did search...
- engine went out, need advice
- Got a couple more GSR into CRX questions!
- Anyone running a Hytech on their Hybrid?
- any good links or ideas for this swap
- H22 in 88-91 Civic ???
- LS block, b20 Crank
- parts needed for a b18c5 crx swap?
- gsr head b16 block in eg hatch
- Fast Idle Valve on B18B1
- yes another dyno analysis request...but different than others
- Please HELP !! H22 civic with ecu and vacumm problems!!
- Ecu
- PR3 ECU w/ LS block, need 12.5% more fuel?
- which alt. belt for swap???????
