View Full Version : Hybrid / Engine Swaps
- obd2b18b1 into 94 civic ex?
- Exaust for a h22a 92 cx swap?
- F20C swap
- What tranny bracket for h22 into eg w/ accord tranny???
- B18 swap mount question
- Vtec Question Simple
- Evap question
- Injector wiring problem.
- COOLING ishue in a B18C OR B16B into civic EK 96 swap??
- B20z work with ls B18b ecu?
- B20 Install problem
- Before I drill, how does the location of engine mount look??
- '93 HB Civic w/ Integra suspension swap....
- Z6 IM on Y7?
- y7 ecu swap
- Any old schoolers from brevard county still on here??
- d16 vtec solenoid wiring
- 91 b18a1 into 95 hatch
- EK B18C complete changeover
- 93 integra swap
- Mount problem.
- Will A 96 Integra LS Stock Intake and Box Fit into 96 EK? California Bar!
- H2B DA Integra questions
- limp mode? knock sensor, oil pressure sensor
- need help getting ecu codes gone. help me fixxxxxxxx!
- H22 Breather setup vapors???
- 98 accord swap
- So dissapointed w/ my H2b, any advice?
- Civic EK H22 swap with a crazy problem need some expert advise.
- simply IACV or worse ?
- s2000 cluster into ____?
- K20A2 or K20A head with k24 block
- H22 sounds like a WRX....troubleshooting help...HONDA EXPERTS have the only shot here.
- Getting all my ducks in a row...SIR II B16a into 92 Civic CX
- EP3 Hybrid Question
- H22A into Obd2B 99 Civic Wiring??
- K20 fan switch questions for 2004 Civic DX swap.
- Mini-me
- torque numbers
- ls/vtec
- civic to prelude motor swap
- f2b
- auto-manual swap??
- i have a d16y8 and a 95 coupe
- Has anyone used these mounts or axles from ebay??
- Would the tsx DBW throttle body fit on a RSX intake manifold?
- buying a b16
- Do I have an LSD tranny?
- obd2- obd1 b16 questions
- B18b1 swap into EK mount ? (part #'s specifically)
- PLEASE HELP... H22 dizzy for a EK.
- D series valve and seals
- h22 or h22 with f series trans
- h22
- cable to hydro.. who sells the slave bracket alone?
- will a d16y7 head fit onto a y8 block?
- real quick head/header question
- k20 swap in eg6
- WHICH K24 TO GET??
- Vtec Wiring HELP? Obd2 to Obd1 P28 Vtec ECU
- I present you "floyd" poison's K20 EG project
- need help diagnosing symptoms obd0 b16a
- H22 auto adjuster
- b16a wiring questions
- Which wiring Diagram is Correct??
- H22 Integra VTEC issue.. Chime In!
- ECU VTEC
- H2B F2B question
- Fuel puddle in my intake manifold...gsr
- Low Vtec Oil Pressure, ANY Ideas!!! ls/vtec
- Kansas City Shuffle (h2b inside)
- v-tec cam into d16y7?
- h22a swap help
- advice on what engine..suggestions?
- OBD1 to OBD2b distributor wiring diagram
- Why won't my power options work in my 1997 EX with a 1997 D16y7 swap with y7 ECU?
- 1992 EG K20 swap
- b16 head on b18block
- SOHC Vtec head---> DOHC ZC?
- Distributor Wiring Issue! Need Help!
- H2D F2D How To
- b18c5 wiring into ek
- H2B Distributor problem (come on h2b guys)
- VERY touchy throttle
- code 6 and 10 please help!
- Picture Request, JDM H22 IM Vacuum Hose routing
- tsx k24 in eg?
- Underbody Skid Plate???
- H22 in 4 door EG
- code 4/10/14/15...HELP!!..91 dx obd1 ls
- code 16??
- can I use d15z1 egr on the h22?
- Could somone identify these motor mounts?
- Service manual for swapping and repairing ??
- B20Z Opinion
- turbo lsvtec
- H22 Injector question / swap into hatchback
- 9:1 compression ratio ?
- h2b not bolting up!
- better h2b kit
- can i use a 90-97 accord shifter box on a EG k swap?
- i need help finding a b16 head
- Del Sol engine/coilover swap opinions
- TSX engine in an EM2: Having starting problems...
- damn swap wont start (starter doesnt catch?)
- b20 vtec problems
- Gauging interest on a new jumper harness adaptor..
- Anyone have the AEM hybrid intake in their swapped whip?
- B16 tranny vs. B20 tranny in a B20 vtec?
- so i'm guessing the reason my car wont even turn over
- What sensor is this? (GSR IM)
- can you use the stock 95' dx wiring harness+ecu for b18b swap?
- P28 and P72...is there a difference?
- Having Problems with 99 H22A4 in 92 Accord
- what intermediate shaft is this? b series
- OBD => OBD1 conversion question
- EK swap info needed
- Swap an f22a eng/auto trans to a k24a4 eng/auto trans.
- differences between b16 and d16 injectors
- Easy question
- hey there, new to the board, just wondering what your opinions are.
- H2B - How Much Oil Should Appear On Dipstick?
- H22 EG civic weird idle
- questions about sleeves
- Cold Air Intake fitment question
- Can I please get some help? Passenger side axle and half shaft.
- EK wiring problem GSR
- i want for k20
- Question regarding short shifters in hybrids...
- JDM D15B into 94 Integra LS - Possible to get BAR certified?
- b18c b series gsr swap into crx transmission bracket
- h2b vs ls on boost
- What do i tell the auto parts store?
- b18 into ek leftover connections?
- Intake Manifold Question...
- energy shifter bushing install?
- Moroso Oil Pan on H2B?
- HELP
- leakdown/compression
- H22 OR F2OB
- h2b reliability
- f22 in EK
- JDM B18C/USDM B18C1 parts compatability
- What cams to go with in JDM b16a
- obd0 into a 93 cx
- OBD2B Remove Immobilizer?
- PRO's and CONS
- 2000 Civic DX LS Swap Questions???
- b16 SiR II 96+
- b series into ek (o2 sensor - am i right?)
- Flywheel cover question.
- gsr into ek
- b18 swap that chokes, need help
- Will a stock unchipped p28 start and run an obd1 H22?
- need engine help asap
- JDM OB1 B18C into, 94 Civic Si
- h2b hyrdo
- BAR Requirements...
- Ca Ref Question
- H2B clutch suggestions or recommendations
- My B16a swap.... PICS INSIDE
- HELP wiring up a OBD1 GSR into a DPFI OBD0 89 EF
- H2B alternator bracket
- Intake for bseries EG
- K swap in eg??
- please help OBD0 plug question
- k20/k24
- 0bd2a ls swap into 96 ex
- Gsr/EG bubble back
- A problem after GSR swap.
- Couple Cr/vtec questions please help
- Pressure Regulator Cuttoff Solenoid Valve - Needed for GSR'd CRX?
- bug16
- D16A6 pulley.. Rare ? need Help ASAP
- 1995 Civic Sedan LX ECU help for HX/VX swap/auto trans
- need help with swaped ek civic
- Is it possible to put an ARC box into a K20 swapped EG6???
- H22a EK Needs Help With Misfire Issues, Got A Video Too
- HT props.
- Wiring diagram
- harness question--->OBD2a engine into OBD1 chassis?
- Will H22a Automatic Fit My Civic?
- CEL b20b...?
- ls/vtec running on non vtec ecu
- CRX B16 ECU WIRING....MISSING PIN IN CLIP "A".....WHAT TO DO???
- DPFI OBD0-OBD1 Conversion Troubles, Engine wont rev past 3K NO CEL
- ticking noise at start up
- b18b in an EF
- LSD question help for b series
- H22 swap in 97 hatch using chipped p75 coverted to p72. Starts and dies instantly
- Which brake lines for 92 EG w 99-00 Si brakes?
- OBD 1 LS into a 97 hatch help*
- Del sol B16 into EG?
- not your typical b16 v. lsvtec
- ITBs for an LS head..?
- gauge cluster?
- [Help] - Eg h22 alternator problem
- EF hatch with DA swap n dash...HELP!
- B16b pistons in my B16a
- B18C5 swap in GSR, running a P72 ecu??
- no vtec
- 95 civic ex engine in a 96 dx body.
- H22a in a EG Pictures requested of Drivers side
- mini me question
- My LS1 + S14 build
- I NEED THE 8 ARP FLY WHEEL SPACER FASTENERS FROM THE QSD H2B KIT.
- Compare my numbers to yours: B18a with PCT pistons, out of the hole measurement?
- MY EM2/EP3 Type R Hybrid , first in the UK
- Ran the F20B EK last night in the 1/8th, got some times.
- F20B Wiring problems
- Calling all motor swap gurus
- K swap in and eg
- Help me choose my motor!!! Built D16y8, Stock B16a3, or Built B20vtec
- sooo i got my h22 running today
- I started my engine with no oil.
- obd1 gsr harness with h22 dizzy?
- f2d f2b
- oil pump ?
- P13 ecu bad? In limp mode, need some advice.
- Avid H22 Eg/Dc billet motor mount kit... Part # AC-MM-002 Severe Problems :( look inside...
- Which is Shorter? sir1 or teg int. shaft
- axles... extended?
- these the correct resistors to use with peak and hold injectors?
- H2B in eg with a/c (searched)
- h2b question
- Honda Hybrid Hybrid???
- b18 dizzy
- b18c swap help
- 1990 CRX SI W/ obd1 gsr swap, fuel injectors are not spraying
- Questioning the strength of an Ls bottom end
- what front forks do i use for a h22 swap in my 88 ef?
- Need Help Getting a B20b Vtec to pass state referee smog test
- Getting a B20b Vtec to pass state referee smog test
- lights dim after swap??
- jdm h22a ?
- Crank Swap LS to GSR
- LS main caps
- burnt ground strap
- Which is the better OBD2 ECU to run for LS/VTEC?
- 89 CRX HF LS VTEC swap won't start??
- GSR swap help. (EG)
- FOR THOSE IN NOR CAL WITH ENGINE SWAP
- no alternator, solid cel, keep blowing alternator sp fuse.
- FOR THE H2B GUYS PLEASE HELP
- B18c into CRX wiring isuue! Please help
- Are CKF sensors OBD proprietary?
- Head Differences
- H22A Swap into delsol
- 89 civic DX engine in a 92 civic vx
- knock sound H22
