PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Gasket Kit - Are all b-series gaskets interchangeable?
  2. Fuel lines upgrade for H22 turbo CRX? 400-600hp
  3. Do I keep or lose the resistor box? *fuel question, H22 CRX*
  4. looking for full write ups on the different swaps for and EK.
  5. Looking to swap a h23a-vtech
  6. f22 engine in integra
  7. alternator reloaction
  8. is the z6 timing belt the same as a y7 or y8????
  9. will 1993-96 Prelude VTEC Peak and hold 345cc injectors fit a civic rail?
  10. help me and my friend diagnose...
  11. will a 99-00 em1 harness workin a 96 98 hatch?
  12. vibration hell...
  13. Failed BAR. Please help
  14. b16 or b18 swap
  15. Eh? C213 connector 2 wht wires... which is which?
  16. real purpose of BARing a swapped car?
  17. Gearbox mating!!!
  18. f22 sohc vtec in a EG CIVIC HATCHBACK
  19. wiring ? b18b swap 99 hatch
  20. h22 wiring HELP!!!
  21. Wire harness question
  22. Trying To Pass Emissions
  23. AVID shift linkages...B series into EG
  24. OBD2 b18c1 into 93 civic dx
  25. b16b/a mounts decision into ek 96 ???
  26. I know it is not a Honda...but I thought it was worth sharing.
  27. H22 / H22A4 Type SH W/O ATTS into EK Civic OBD2
  28. k20's and its's
  29. ECT problem
  30. Need help ASAP Code 43
  31. OBD0 to ODB1 conversion (LSVTEC)...searched now just need confirmation
  32. Silly quick question. Wiring diagram OR DIY for wiring Knock sensor + pressure switch + heater
  33. h22 eh2 Wont start, CEL 21
  34. ATTN: K series owner
  35. Local Swap
  36. A/C IN A H22A EG???
  37. Could I have any worse luck!
  38. B16a2 Block/B18c1 Head Few Questions!
  39. 88 integra will 91 LS motor drop in ???????
  40. help choosing a FR motor
  41. k20z1 into an EK swap
  42. anyone upgrade stock fuel pump and notice a difference?
  43. k20 swap into eg
  44. California Hybrid Dreaming
  45. Question about fitv and obd2/1
  46. Which mounts are these, and which one do I use? HELP PLEASE!
  47. Wiring question (extra plug) *pics*
  48. H22 OBD ?
  49. Gsr FPR Question into Eg
  50. which Radiator Hose to use for ITR/CTR swap into EG Hatch
  51. jg manifold
  52. radiator problem.
  53. obd2b to obd2a conversion
  54. Map sensor issues B18c1 in EG
  55. After swap questions
  56. HELP ME!! IM GETTIN ANGERY!! H22 into EG
  57. h22 head swap questions
  58. nagasaki engines from canada
  59. hift linkages
  60. This is a Hard one. HONDA TECHS please read. wiring/ecu/dizzy signal/ h22a4 EJ
  61. jdm b16 into a 94 del sol
  62. vtec solenoid and map sensor problems- ls swap in a 5th gen
  63. American B18 GSR or JDM B16A2 Si-R?
  64. OBD 0 to OBD 1 Wiring Conversion
  65. K-Series Mounts HASPORT OR HYBRID What Would You Chose??
  66. swaping 93 ls into 92 auto civic
  67. swap in 98 ek ex , lsvtec
  68. B16A block, GSR head - what head studs?
  69. LS gearing in an ITR trans? Compatible?
  70. jdm vs usdm swap ?
  71. Show me your B series swap Fuel setups, Please
  72. Help h22a4 into 98 civic coupe
  73. Hasport H22 mount kit (Eg/Dc)
  74. Rough idle- CEL Fuel System B18C Swap in EK
  75. Advise on intake elbow for EG airbox with a gsr motor.
  76. H22 in 93 COUPE front mount ?
  77. Question about what timing belt to use on y7/z6 combo.
  78. D16A9 from a EF into a EG
  79. Rear motor mount (T bracket) question.
  80. Catch can!!!
  81. looking for gsr block
  82. STR throttle body return spring broke!!
  83. Vtec Problem...
  84. H22A4 with ATTS into Ek, need axle help
  85. CHECK ENGINE LIGHT ON BUT NO CODE....... SEARCHED
  86. h23 head on f22 block
  87. H22 IN DC?
  88. b20vtec into a del sol
  89. h22 civic ek transmission slip at the track last night please help details inside.
  90. PLEASE HELP me sort this out guys..once and for all.
  91. i search and couldnt find it
  92. GEO engine swap
  93. need big time help on 83 civic engine swap
  94. B18 swap in a 99 coupe.
  95. Is there a adapter kit for the h22 motor/b-series tranny in a 92-95 civic?
  96. DSS Axles interchangeable?
  97. How much ground clearance is lost from a b18 to a h22 in a integra dc2?
  98. 1996 GSR motor into 1999 Civic Si...ECU/dizzy/harness issues?
  99. BIG BIG PORBLEM. GAS IN OIL + NO START!!!!! WTF!?!?!?
  100. B20 Block for $100 bucks
  101. Wire vtec GSR in 93 civic hatch
  102. B20b Swap help please!
  103. Question About H22/Prelude Transmissions
  104. 00 Civic Si with ITR motor o2 sensor question
  105. LSD Markings question
  106. SEARCHED..no luck on dizzy question.
  107. OBD0 b16a into EK Hatch...
  108. going from euro obd2 to obd1, few questions about alternator.
  109. h23 block on f22 block
  110. ls to b18c
  111. can a h23 head be put on a f22 block?
  112. Why would you swap in the GSR motor instead of the ITR motor?
  113. another obd0 - obd1 with a twist question...little help.
  114. Car wont start
  115. What fan are you H22 into Ek guys runnin?
  116. GSR Heater Hoses
  117. Irratic idling problem, not the typical one
  118. ITR suspension swap Question
  119. obd2 alternator wiring.
  120. B16A Auto Swap
  121. CRX/B18B throttle cable bracket?
  122. Will a TPS off of a D-series TB bolt onto a B-series TB?
  123. Which shift boot + bracket for h22 integra?
  124. ek stock civic motor swap
  125. h22a4 obd2 to obd2 wiring distributor please help ht
  126. ***New rotors and pads for 96 itr 4X114 lug conversion
  127. HVAC Stuff EF w/K motor
  128. Crx obd0-obd2 Alternator plug conversion questions.
  129. Iacv wire colors?
  130. Putting an OBD2a motor into an OBD2B car?
  131. "poor man's type R" - ??
  132. Problems wiring dissy and coil on ek obd1 h22 swap
  133. ATTN: H2B Users... Need Crankshaft Pulley Clearance?
  134. what will swap into a 74 honda ?
  135. B16 into 97 Ek (d16y8)
  136. Rebuild?
  137. BEST SWAP FOR DA? NOOB AT WORK
  138. D15b in del slo
  139. how to tell the difference between two d-series heads?
  140. B16 head on b18a block
  141. throwing codes 71-74 with b18 in ek
  142. iacv!!! what two wiress??????
  143. d-series differences....a/c compatibility and crankshaft particularly.
  144. GSR In 90' CRX Info
  145. JDM B16 IN A DA
  146. Civic 4wd question ?
  147. umm first of many posts here. F20c swap help needed
  148. B18b1 in 96 CX Questions
  149. P72-901 ECU Pinout
  150. Whats The Difference Between LSD and Non-LSD Transmissions?
  151. h2b h22 in a b16 del sol
  152. Here is an interesting thread to watch...
  153. H22 EG Avid cv boot problem
  154. coolant problem
  155. B20 Vtec quetions?
  156. ABS removal!!! 1994 Civic Si non abs into 1994 Integra ABS????
  157. f22b1 in a 97 civic lx
  158. block posting?
  159. front LSD for a AWD CRV 5spd?
  160. H22/H23 90 CRX Si Questions
  161. B swap into vx - wish me luck
  162. 90 CRX Si intake on 95DX/B18C
  163. Smoging a jdm b18c5 in california
  164. the best deal on earth for a k20a!!!!!!!
  165. ls- vtec bogging at full throttle
  166. IAB on D16Y8 harness
  167. Hooking up vtec this sat. one quick question
  168. problem with tps need a little help?
  169. de-ghettofying my car after the swap
  170. HELP! '90 CRX w/ B16 won't start
  171. H22A4 Turbo EG Overheating issues
  172. aem v2 on b18c5 in EK civic
  173. F20b into a DA questions.
  174. Anyone make K series mounts for DA???? besides Hasport...
  175. f20c
  176. Where can I get a HCP H22 mount kit
  177. A/C for a b-series swap????
  178. I think ive been stiffed :S (b18c)
  179. K20 questions??
  180. ** I NEED IACV HELP** please?
  181. B20 Swap or not
  182. one last ls swap question before I make a booboo
  183. 1991 prelude, 99 b19b motor
  184. help: obd2-obd1 dizzy & alt wiring!
  185. wiring harness
  186. ***H22 NA BEAST H2B***
  187. 96 LS swap into 96 EX (auto)
  188. GSR > 95 DX swap. (Throttle cable question-searched to death)
  189. 98 ek w/ gsr swap
  190. H2B- header choices
  191. Need Help.
  192. poorman's type r build
  193. b16 linkage?
  194. JDM H22 not sparking. got fuel. no spark. HELP! *searched*
  195. will a h22 fit in a civic/integra/crx??
  196. Innovation aka Rick
  197. Civic hatchback shifting problem
  198. crank sensor wiring diagram..
  199. AEM V2 Diameter / AEM Hybrid
  200. cam shaft id.
  201. VSS the same for 94-01 integras?
  202. yonaka axles? a cost debate...
  203. h22a tunning
  204. iacv code...checked everything....need help!!
  205. quarter mile runs on a ek coupe with h22
  206. H22 swap passenger tranny mount ??
  207. NEED HELP WITH IDLE PROBLEM!!!
  208. swap A20 (carbureted Accord) into carbureted 86 civic
  209. torque mounts
  210. searched, but: are all D16 blocks made equal?
  211. Knock sensor wirring info
  212. H22A4 into 98 EK Qs radiator
  213. H22 EF CRX sway bar fitment issues?
  214. 1st swap.. im very confused!! (searching while asking) please help
  215. JDM engines close to Kentucky?
  216. 99ls swap into a EG???
  217. 94 Accord H swap question?
  218. Going from LS/Vtec to LS/Non-Vtec questions.
  219. does anyone know where the F I can get new bushings for my innovative based mounts??
  220. h22 in a 93 civic coupe
  221. H22 cuts out at 6500 rpms, drops out of vtec, bouncy tach
  222. will 98+ spec JDM Type R axels, half shaft, motor mounts and engine harness fit on my 99-00 Si ?
  223. 90 crx si gsr swap
  224. Knock sensor bypass
  225. New RDX swap
  226. Bar'ed K20A2 in a EG chassis?
  227. ECU HELP FOR AN F20B
  228. Exhaust Help
  229. S2000 CLUSTER SPEEDO AND TACH IN EG HOW TO (VOLTAGE CONVERTER)
  230. B16 SWAP.... does D-series radiator\water hoes fit?
  231. 3-stage vtec d15b head/d-series block
  232. S2000 power!!!
  233. Axle swapping
  234. fueling
  235. clutch cable
  236. gsr into del sol vtec?
  237. b-series AC system in an EG w/ a b-series swap?
  238. h22 in a 96 hatch? help??
  239. WTK: JDM Type R tranny parts into USDM B18C1
  240. No crank, no start
  241. I need a brief parts list
  242. obd2 b18b into an EF with obd1 ecu?
  243. jdm B16a(2), map sensor????
  244. what could be the problem
  245. B18c1 Into 97 civic EX...Having problems with VSS, Rev Limiter, Overall Performance
  246. Where to find just a K20A head!!??
  247. password jdm engines????
  248. i have ls vtec what do i get the head studs for
  249. h22 eg 1/4 et.'s
  250. ? fitting ac in an lsvtec ek will ls bracket work if compressor is already dischagred ?
