View Full Version : Hybrid / Engine Swaps
- car jerking after swap problem
- crank sensor question
- USDM ITR Header question
- F22a1 with a H22 head???
- H22 Headers with 2.5" collector: DC VS Greaddy
- Quarter Sports Drag H2B Kit
- BLOCK MOUNT QUESTION.
- Oiling System in a B20 Vtec Conversion
- Need a little bracket help--- already searched
- B18 into 92 EG Hatch
- Problem starting B18Cr swapped CRX
- plenty problems with this swap.. please help if you can
- BIG problem!!
- HELP!!! OBD1 b18c into 98 CX Civic, Clean Swap, but a few problems...
- Stolen
- H22 start up problems??
- b series linkage question
- HCP H22 Users, Anybody making 400+ with them?
- B20VTEC...What octane to use?
- Quaife LSD in EG H22 hybrids
- Respectable Price
- Swapping hybrid G23Vtec into EG.........anybody on here done it?
- Adding + lengthening wires? How and where?
- help me out guys, what is this electric peice on the bumper??
- axle nuts for h22 eg swap
- h22a1in eg civic
- can i use ls rings on standard bore p30
- Help w/b16a into 88 civic dx
- h22 into EK, how to add more grounds?
- b16a2 in a obd2 integra
- just got a type r motor wat do i need to get it runnin in a db8
- cable or hydro tranny
- OBD1 GSR swap into 97 EK coupe HELP ME
- Need help b16 obd0 throwing code 6 when i put it into reverse
- b20vtec supercharged...
- k24 with k20 head
- b18 vs h22?
- will this work? rotary crx
- 00 ITR cams
- V-AFCII air/fuel settings
- B18 in EG ==> hood hits valve cover
- What timing belt?
- which is better gsr trans or b16 trans
- f series?
- Installing a b16a/ITR LSD into a b16a transmission
- whats the diff between a b18a and b18b both obd1?
- h22a aem ems
- Accord 4x114 on EG/EK/DC chassis?
- power steering consfusion
- crx d16 a9 to change b16 a2 what i nedd
- Help!!! Del Sol H22a shifter cables too short
- obd0-obd1 wiring help. (already searched)
- D15b vtec in a CRX, the stock DX manifold doesn't fit
- My First Swap, Q & A's
- which half shaft and axles do i use? really confused here. please help.
- Is doing a H22 swap into a 2.3 CL like an Accord swap? Anyone done it? lmk
- Intake Manifolds for H22 in EG hatch????
- 92-95 HB owners with B Series Swap...
- B16A Swap hesitation problem
- Where or what web site can I buy a vss for a jdm b16a
- H series convention?
- JDM b16a1 obd0 into 89 crx throwing code 6
- LS/VTEC question???
- cleaning the engine bay
- h22 tranny rear bracket in eg question. will h23 rear bracket work?
- Lsvtec Header ?
- b16 and b18
- GSR Valvetrain in b16 head?
- srs model year question...
- IDLE... (All Issues Viewed)
- Euro Civic Type R 5-lug question
- Strange b16a came with p/s and a/c
- LSVTEC: Timing Belt Covers
- What happened when there's no transmission oil????
- b16 tranny into a DC
- Need help with del sol asap
- Do i order SI mounts for my EK?
- Tranny parts cause weird idle?
- Knock sensor question
- my car does not run full potential, h22a4 in a dc4 with odb2 ecu. 290cc vs 345cc...tech head get in
- transmission cases
- ITR Tranny swap
- b20 swap
- QUESTIONS!
- ECU problems with LS swap
- Swap
- 93 LS SWAP: Using OBD 1 Saturated Injectors on 91 Civic Dx....QUICK ???
- Question about R swap into 96 EK
- B18C Power steering question
- Question about wiring harness for my swap?..Please help
- D16A motor
- Evo turbo manfold on a F22?
- GROSS POLLUTER... now what???
- Need some clearification on a 2wd civic wagon/ integra swap. Help if you can.
- SOHC VTECH Distributor Wiring to 90 SI
- IACV Wires reversed?
- Need some guidance/suggestions......
- The F22b DOHC?????
- CEL 14 iacv. chime in here people just a quickie.
- will this sway bar fit my EJ9?
- Does a P28 ECU look for an EGR sensor?
- SR20 del sol...WTF??
- H22a8 98' ODB2 engine into Prelude gen 4 pls help
- K24 water port elimination options...
- will I have any problems using a light flywheel with stock clutch
- B2O SWAP
- Need help with crx to ek hatch swap
- Axle slipping out of transmission
- Falh Options...buying a swap?
- USDM vs. JDM B18C?!
- B18 bored to 84mm discplacement, on stock sleeves or resleeve?
- ITR backbox on B18 EM1
- Password JDM cf Intake question...
- Axles (stock or aftermarket) for H22
- clutch, pressure plate; cable, hyrdro
- Ek b series swap mount- have a look
- NSX brakes on a Civic
- Throttle Position Sensor Wiring
- JDM B16A 88-91 into 92-95 civic eg
- Bar....impossible for me with this motor?
- Which ECU (h22 help)
- Removing Golden Eagle dowel pins from my head
- how much is the adapter plate???
- Pre-Swap preventative maintenance checklist?
- OBD1 b18b integra motor into 92-95 civic eg
- Electrical problems....car wont start on its own
- Axles are too long??
- crx wired with obd2b and aem 1010
- 97 dx coupe with B16a2 swap complete. Couple of questions.....
- Y8 intake manifold on JDM D15
- 97sohc vtec into eg shell.
- Vtec NOT kicking IN
- eg gsr hybrid exhaust
- Is there supposed to be play in your axel?
- this is my new dream vehicle ...
- B20 vtec vs H22: Performance and Handling
- What head to use for an LS/vtec?
- b16a price/timing in EG
- For all the B20's in California?
- Brake swap on a EK hatch?
- Crankshaft Timing Belt Pulley Shaft Diameters
- Civic Swap W/ Jdm H22 ?????
- 200 WHP on my B18C in an eg
- (help help) which harness for my swap ?
- Auto Ls halfshaft work on 5 speed?
- 99/00 Wiring Harness?
- Acura Integra /w V20
- H22 Guys using the Hasport EGH2 kit- Axle talk....
- Lsvtec problems
- Apexi N1 Pro Dampers HELP!
- Why is my new B18CEK slower than my B20EF?
- TB and iacv motor questions here .
- F series, B series, H series "HELP"
- Will a B18C1 swapped EK hatch pass smog in CA LEGALLY?
- Ls/Vtec hood clearence?
- Need to get 99 LS BARD, HELP!!
- manual tranny onto auto engine, anything different?
- Wire Harness help please..
- Please Excuse the riceyness of this question. thanks
- how to get ruber hangers off civic
- Head Tollerances for b20 Problems...Help!!!
- obd1 b18c GSR into EF civic?
- car wont go into to gear??
- IRS for the Lude
- GSR INTO INTEGRA PROBLEMSS
- Transmission POS??
- D15B into 96 Civic EX. Had spark, but it went away. =(
- B16 in 00 ex..3 ecu codes..
- ENGINE INSTALL H-SERIES
- My car... what to do to make it legel in california?
- Transplant Q?
- HCP h22 into eg tranny mount ??
- OBD1 Swap Issues b/w H23a and D15b
- f23a1 into civic... inquiring info..
- need help with k20 swap
- Need help... Questions on an F22 powered civic.
- B series parts swaps
- Code 4 CKP, Help
- b18c in an eg Axel? Please help asap
- Acura Legend, 2.5-2.7?
- hybrid-racing opinions.
- B18 Install in EF (bay area??)
- 94 h22a accord parts on 97 civic
- Need help figuring out which VSS and sensor needed for my H22
- master cylinder
- H22 PROBLEM
- Driveshaft questions please help ASAP!!
- gsr swap into ek
- HELP 99 h22 head on 93 h23 block asap
- h22 civic
- Avid gets a A++++ from me !!
- Tad update on the LS1 FC
- alternator question
- OBD2--->OBD1 Harness?
- no heat fix after b18b motor swap into civic ek
- Motor swap done....
- Extra plug after swap??!?
- h22a ej and vibration problem.
- h22 in DC
- low cylinder compression
- Harness RE-pinning
- 96ek 99 gsr swap HELP!
- B18 swap
- B16a vs. B18c I just dont get it, help me decide :)
- Need help finding somewhere that has a driver's side motor mount for an EJ8 instock
- Where to buy LT1 or LS1?
- which ecu to break in build?
- b18 into my civic coupe
- Mount Bolt Question, Bolt Guru Needed
- to k20 or not to k20
- Rear bracket doesnt fit on B16 in EG, HELP!!!!!!!
- whats all comes with a complete head?
- computer queston
- obd1 Dizzy obd2a harness problems
- Purge control valve
- need help quick!!
- H22 and K24 swaps
- again ....auto to manual wire conversion...HELP
- 93 hatch with 99 si swap
- motor swap question
- First Pass with H22
- JDM D15 dizzy onto OBDII Harness
- Should my friend make this choice?
- Question about Hmotorsonline.com
- need help.......can it be the timming or the dizzy?
- H22A Civic Shift Linkage Problems. Any idea for you H22A gurus?
- B18c5 Swap Problem
- OBD-1 B18B into 92 Civic SI
- AXEL PROBLEM
- AWD Type R with an LS6!
- HELP
- AEM CAI Problem in an eg
- HCP EK H22 tranny mount?
- could i use a p2t ecu in a 90 integra with ls/vtec?
- CRV A/c Bracket, B18C Swap
- 93 integra and 91 crx steering crossmember?????
- JDM B18C needs different wiring harness?
- quick h22 into eg wiring question
- 88 hatch back with 91 LS motor, i need axle help
- GS-R swap gets no spark....
- H22 EG w/ RMF Header clearance/fitment??? Better Recommendations???
- What Exhaust Setup are you running(EG's w/ B18c1)??
- <<< What year B18?? >>>
- H22A Civic Swap problems... Any ideas
- need some help with poorman type r buildup!!! HELP. PLEASE
- swaps and idle problems..
- Alternative to sleeving H-series block?
- b18a VS h22 in 91 crx
- trying to find a header with 2.5 in collector for my H22 swap
- ITR swap into EK questions
