K-series Alternator on a B-series Possible?
Re: K-series Alternator on a B-series Possible?
its not possible without some work. your going to need the rsx alternator plug. then your going to have to figure out which wires do what on both the rsx and integra alternator to match up the wires so that you can use the bseries harness with that alternator. other then that it should pretty much work the same i havent looked into its specs to see if it outputs more power. thats something u might want to look at.
whats the purpose of this? you want more power or u need a replacement alternator and happen to have a kseries alternator around?
its def has more power and more efficient just tryin to see options what can and cant go making a plan which alot dont do
