PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 [123] 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. 94 eg swap? help me please
  2. Can JDM motor pass smog legally
  3. b20vtec swap...throwing code 45
  4. Block Numbers????
  5. Need Help 92-95 civic radiator in 88-91 Civic
  6. best way to connect wires to ecu harness?
  7. Need info on motor swap please?
  8. arp head studs
  9. skunk 2 is it safe to take it to 9gs stock
  10. r is thehow can i find out if it is legit????
  11. why do i live in cali
  12. A/C mount bracket question
  13. Si alternator question
  14. 95' b18b into 93' sol si (could use a litlle advice)
  15. need some help here??swap wont start??
  16. Need Help... code 23
  17. which cams be best ???
  18. crx w/gsr problems
  19. Cheapest Place to buy an H22
  20. b16 into 1st gen crx carbed.
  21. Black smoke-bad gas milage after swap
  22. Osaka motors
  23. H23 in civic?
  24. supercharging a ls/vtec any advice?
  25. car shut down and wont start.. what could it be.
  26. b16a oil pick-up vs. b18c1 oil pick-up
  27. Not sure about these plugs?
  28. Starting car w/out connecting wires
  29. What is this sensor?? 2001 GSR??!!
  30. HELP! Which speedometer cable do i use for a hybrid CRX?
  31. Vacuum/Coolant Line Questions
  32. ... h23vtec... how-to's?... suggestions?... (did search)...
  33. B 17 head swap onto B16A1 block
  34. A few Hybrid engine questions....
  35. throttle cable
  36. B18a block with a b16 head
  37. D16z6 into a D15b2 89' HB problems
  38. www.bfastracing.com
  39. Why would a JDM motor have lower miles than a USDM?
  40. MY swap 91 STD TO OBD1 SIR II *pics* 56k Alert
  41. H22A swap - 95 civic
  42. Wiring radiator fan to toggle switch! How many Hybrids doing this?
  43. how do you bypass the imoblizer in the type r ecu?
  44. LS/VTEC strength/durability questions
  45. type r ecu
  46. Cant get get temp needle to work on my Hybrid
  47. Possibly Newbie Raditor Q
  48. Need opinions and help with a possible build up
  49. My Car is Almost DONE?!!!?!?!
  50. How to identify GSR cams?
  51. Fired up the b18c1 today, and it won't hold an idle.
  52. B18c dizzy,alt,positive ground problem??
  53. DSS Axles for H22 in Civic: Correct Lengths...
  54. b18b? b20? bwhaaa?
  55. buying a b16, I need help
  56. swap still wont start???
  57. Hatch swaps what do u guys like?
  58. vx. vs si/ex 5th gen civic
  59. crx swap
  60. bolting up a non-si engine with a Si head??
  61. Engine Identity/ B20 for $150!?!
  62. All-Motor Daily Driver
  63. 00 b16a2 into 98 civic dx swap problems
  64. id ecu? manual or auto
  65. H22 help. Which belt? and Heater hose help.
  66. Ek with a ITR or B20 V-tech??
  67. type sh or not type sh
  68. any good "How-To" sites on motor installs
  69. how can you put ls vtec on a 86 integra with stock d16a1
  70. 1 swap, 3 questions.
  71. Is there a difference in the cam profiles of the A/T b-16a and the manual transmission b-16a???
  72. Which distributor does the 1st gen b-16a use???????
  73. swap,need help try search but found nothing!!!!!!!!!!!!!!!!!!!!!!
  74. Which Axles for a B20 SWAP
  75. b20a5 into 81 civic! need ecu wiring help.
  76. rough idle in a b16a2 swap
  77. b20z in 89 dx, no workie? help
  78. CAI for eg b18c???
  79. HELP! frying my motor!
  80. Will Civic short shifter fit Teg shift linkage?
  81. Help!
  82. B16B what does it take
  83. good condition dohc vtec full swap
  84. difference between jdm'88-'91 b16 & jdm '92-up b16 block
  85. CAI for H22 in 93 civic?
  86. Help me out guys quick simple question.
  87. Conversion harness wiring
  88. Russell Fuel Filter
  89. B16b components into a B16a ?
  90. supid question about lifting motor
  91. Swaping a b20 head into b18a
  92. Honda Civic EX 2000 into a Honda Del Sol 94' (NEED HELP)
  93. New to swpas, what do i need?
  94. tps sensor
  95. what swap should i do on my daily drivin EF hatch??
  96. obd2-obd1 injector differences
  97. ECM layout
  98. LS to B20 >>>help
  99. How do you change an auto P30 ecu to a manual?
  100. D16Y8 into 97 HX(D16Y5) ecu wiring, probs?
  101. Got a question about swapping a B16B in a 92 vx
  102. ECU and injectors
  103. b16b into 2000 civic ex
  104. Need help with swap!!!
  105. Did someone sell me the wrong mount??
  106. good tires for 14's for racing?
  107. Hybrid Swap....First time cranking the motor up....
  108. O2 sensor is driving me crazy! help
  109. Vtec p61 ecu pin outs?
  110. First swap HELP!!!
  111. need help w/ idle
  112. How much diff in tranny
  113. axles
  114. what wires do i connect for ls swap
  115. What should I gap my Plugs to?????
  116. ** HELP! code 14 - IACV, please help **
  117. anyone running a turbo 18c1 with an LS tranny?
  118. everyone with a h22a swap in a 96-98 civic, need your info.
  119. Which is the best Valve spring and retainers I should get?
  120. Long block help. Experience needed.
  121. H22a Setup- Tranny, axles, etc...
  122. 98 gsr motor runs REALLY bad in 92 integra. HELP!
  123. Need MAJOR Help. H22 wiring.
  124. H22a Hatch
  125. cam question
  126. CEL 43
  127. adding ac into a ek ?
  128. VSS Wire question, can someone look up in Helms for me.
  129. H22 swap to EK...gas line hose?
  130. b16a1 clutch question
  131. cluster problem
  132. r/s ratio of h22a
  133. What ECU mods can I do for about $300 bucks??
  134. b18c into del sol...will stock exhaust+cat match up?
  135. 1st gen b16a CEL problem (i did a search already)
  136. 2.0 vtech help
  137. 2 SERIOUS PROBLEMS!!!!! h22a swap !
  138. Knock Sensor Pin #
  139. b16 tranny wont fit on C5 help(searched)
  140. **how to tell if its TYPE R CAMS AND VAVLE SPRINGS?**
  141. Help from the experts
  142. H22 auto
  143. help h22-ek not running right????
  144. Are all B-series tranny casings the same?
  145. Are Integra type R and Honda civic si(Us)/sir(can) clutch kits the same?
  146. what brand pistons to use????
  147. b18b forums?
  148. b18c1 into an EF?
  149. need help finding a B20 200mile radius of NYC area
  150. how do you set the camshafts at TDC?
  151. b16b into 96 ek...ecu wiring???
  152. b16 into EK mount questions
  153. HELP swap wont start, no spark!
  154. cant get it to turn over
  155. 3500 for engine and install???
  156. Trying To figure out what im going to do?
  157. What intake fits for B18C in EG Civic
  158. Anyone know of a website that has Honda vacuum diagrams?
  159. hooking up vss to a crx
  160. Hard to get to timing belt EG+H22?
  161. 1st Gen Integra Engine Swap..
  162. Hybrid guys help my b16 swap run
  163. ok, here is my frustrating fuel problem.
  164. Is it my master cylinder or my slave cylinder going out?
  165. For those that have had parts installed by shops?
  166. any one ever here of an H22b1?
  167. Another Tranny Question
  168. jspec ecu vs. usdm ecu
  169. H22A swap almost as easy as B18C swap?
  170. which diffs?
  171. what is needed for a h22 swap into a 92 prelude?
  172. JRSC'd and turbo B18C1 (EG) hatches please respond
  173. EK Harness Question and Problem...
  174. Ls motor help... stupid question but what the hay!
  175. b20 buildup
  176. H22a4 questions (HELP)
  177. What year b18b is obdI?
  178. will these axles fit?
  179. question.....swap b16a or b18b..more details inside
  180. VTEC does not engage on B16B engine...help!
  181. jdm b18c w/ LS tranny
  182. internals for h22?
  183. JdmFaze.com???
  184. Emmisions hints!!!!!
  185. 2.0L VTEC opinions
  186. crank angle sensor
  187. Difference between Y7 & Y8 fuel rail?
  188. Wheres a best reputable shop in So Cal to do motor swap in my 92 eg?
  189. what do i need?
  190. is a mini-me a hybrid ?>
  191. will these guages work??
  192. What Trannies work with the LS engine??
  193. question
  194. What should i do??
  195. i have a b16A2, B18 vtec hybrid...am i getting full power here???
  196. 2002 Si engine into an EK
  197. B16a CRX Si Intake options
  198. ob2 distributor on a obd1 b18b1?
  199. ctr pistons in a jdm B16a?
  200. My poor hybrid... 56k, ouch...
  201. VSS on Y1 tranny
  202. CIVIC EK w/ H22 swap
  203. What ECU/chip?
  204. 00 B18c1 into 96 EK wiring help
  205. broken Bell housing what can I do?
  206. guys with h22 swaps???
  207. got a question
  208. new engine
  209. H22A vs. Ls/vtec in 92eg?????
  210. tranny and clutch
  211. Do an LS swap with 200,000kms???
  212. B20 or H22? need more torque!
  213. and i have how to put a h22a in an ek
  214. Can anybody answer a few questions about converting auto to stick?
  215. Update to distributor issue with h22 hatch.. Part II
  216. spark plugs have green tint??
  217. b16a head for LS/vtec
  218. Honda Hybrid Fanatic gets engaged!!!!
  219. engine surging...anybody ever heard or experienced this problem....?
  220. Link to Hybrid Hatch video?
  221. Mounts for a B18 in an EK
  222. ForSale:Brand New Raxles.com Axles for 92-95 Civic HB
  223. B18b1 vacuum hose question
  224. 99 b16a2 OBDII into a 90 Integra?
  225. Where did YOU tap in to wire the IAB (secondary intake solenoid) for vtec???
  226. 88hf to zc wiring?
  227. Eg / GSR swap is almost complete! Few various Q's with pics inside!
  228. Acura TL v-6 in EK hatch...
  229. removing and switching ecu pins
  230. 93 accord h22 swap which mount do you change if any?
  231. B18A swap on EG hatch
  232. URGENT!!! Clutch question.
  233. how long did you have to wait to receive your motor?
  234. ***help!!!! just finished swap but.....
  235. b16a2 into 94 civic ex cooling prob
  236. OBD-0 with OBD-1 computer
  237. Is it me?
  238. obd1 h22 into a obd2 ek??
  239. Pics of my B20vtec EG
  240. Swap ? Rear motor mount on my EG
  241. obd2 gsr swap into obd1 ls ???????????
  242. Anyone with LS/b16 tranny??
  243. Technical smog question. I am running out of ideas, maybe you can help?
  244. 95 Hatch with 75 Shot
  245. which D16 model have intermediate shafts?
  246. What about a B20 in an EG?
  247. Engine Swap for a 1998 CX
  248. Im stumped!!! wiring harness
  249. axles
  250. Canister under GSR mani
