PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 [113] 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. 91 CRX engine swap questions IMPORTANT
  2. high idle and knocking sound?
  3. best mounts for h22 92-95 civic swap? HCP? hasport? place???
  4. Swap, ready to give up.......help!
  5. Question about code 10 or 01!! Have a VX with GSR using VX wiring harness
  6. POS car still not starting
  7. GSR wiring harness for B20 swap into EG?
  8. ls/vtec superchrger or turbo
  9. need swap info!!
  10. Tranny swap: '93 DX to '97 EX. Will it fit?
  11. obd 1 swap in a 88si
  12. Can I have ac with a b20
  13. Doing some work on a JDM harness... Quick question
  14. OBD2 GSR in 2000 EK, car won't start because of climate controls!?!?!
  15. Where to find a complete write up on building a B20Vtec.
  16. NEED HELP PLEASE
  17. Axle boot clamps
  18. Where can i find...
  19. 99 Civic CX: How to do a Vtec Head Swap?
  20. help me compare: turbo h22 v. turbo b18c1 in 6th gen. hatch
  21. jdm parts
  22. tps gone baddd???????
  23. scrrrrrrrrrreeeeeeeeeeeeeeeechhh noise
  24. Getting a shop to do my H22 swap, but I have a few questions
  25. How to tell if alternator is bad or wiring is bad? (searched)
  26. need help about p30 ecu
  27. B16 swap timing belt tensioning?? Is it three teeth, a quarter turn, WHAT???
  28. Shift Cables seem to be too short!
  29. I Need Help Fast, Would I need this ...
  30. whats needed for ls vtec
  31. HCP ek-h22a mounts (pics for what was my problems)
  32. Is this item needed with swap?
  33. just swapped LSD H22A trans...HELP!!
  34. pin outs for obd0?
  35. GSR swap into 92 hatch, Skunk2 manifold, what Comptech Icebox?
  36. Already Searched Need Help....
  37. HOW DO I DISTINGUISH JDM B16 YEARS!???
  38. EK k20a drop in questions???
  39. just finished h22 in eg, but.....
  40. stupid question....
  41. anyone have a pic of their motor from hmotors?
  42. Anyone know b16a cable into civic hatch?
  43. Cable tranny b16 in 93 civic hx
  44. Question about swap 99 si motor into 92 hb civic DX?
  45. help me diagnose CEL codes... obd2 b18b/EK
  46. Anyone using the Skunk2 Drag Launch Kit?
  47. ctr piston b18a vtec help..?
  48. Where to purchase a 240sx swap?
  49. Help me identy these plugs
  50. Will a B18a work in an EG
  51. motor problems
  52. swaping GSR dizzy into h22 dizzy problem
  53. Bad throttle sensor?
  54. just started engine...funny idle....
  55. Just checking:b18b to ek wiring question.
  56. supercharged b16 in ef
  57. Help: Looking for p28chip to run B20vtec
  58. hmotorsonline!!??
  59. what is a knock sensor?
  60. first gen b16a into 94 civic need help
  61. Can somone PLEASE tell me what these wires do
  62. motor swaps (what to do)
  63. so what parts EXACTLY do i need to perform a gsr swap into my EK hatch?
  64. 96ek/hcp h22a problem.
  65. 95 B18C1 w/P54 AC bracket in 94 VX Which AC belt
  66. What rear T bracket for DOHC Civic Swap?
  67. F20C swap in 86 TOYOTA COROLLA GTS
  68. Broken timing belt!
  69. Vtec spool solenoid code in gsr'd eg
  70. Help identify these cams
  71. B16a in cx, which mount?
  72. Stock JDM GSR Shifter??
  73. Need help JDM B18C Type R in 00 Si
  74. 90'Teg or 94'Civic?
  75. H22***yellow w/black Wire***H22
  76. H22***Rad. Fans***H22
  77. Need Help with ECU
  78. gsr swap into a ek hatch
  79. smog on a b20b
  80. GSR Driverside Mount???
  81. h22 question about distributor!!
  82. eg with B16a vs eg with B18b Ls
  83. JDM H22 Distributor - Cap Replacement
  84. what shift linkage for h22a into 96-98 civic swap
  85. my horn is out
  86. H22 EK mounts
  87. code 19 on p30 ecu...?wha?
  88. stock jdm gsr header? or use the greddy?
  89. H22 Euro R mounts different from regular H22?
  90. JDM GSR Swap in to 97LS: ECU? best course of action?
  91. Temp gauge stopped working after swap
  92. Plans changed....now 00 b16a in 92 cx....help....
  93. I really need some help!!!!
  94. crx b16a first gen ecu question
  95. gen2 integra swap
  96. CV Boot
  97. Jimfab.com Crossmember(Traction rods) + H22 Swap = ???
  98. Need tranny help ASAP
  99. Will this be ok?
  100. Insurance and engine swaps
  101. Shifter sits to the left
  102. whats the site to HMO?
  103. Swap Guides
  104. Which Header for my B18A powered EF?
  105. where to get a f20b
  106. question for h22/civic people
  107. Misc. Stuff to finish H22 swap
  108. b20 hitting rev limiter @ 5500, p75 ecu, no CELs..HELP
  109. does the iab wire go to a ground or a 12v source
  110. picked up gsr swap in Monteal - observations (link)
  111. would a 2001 b20z be obd2 or obd2.5?
  112. Car Starts but wont move.
  113. f22 in an Ek/Eg ?
  114. is there such a thing as OBD2.5 to OBD1 conversion harness?
  115. H22a into an EG HELP....
  116. Timing issues. I'm still stumped.
  117. Running AC in a bseries swap
  118. Been searching for LSVTEC compression ratios...anyone have a caculator or link????
  119. B18C into 97 civic ex: ECU code 14 - iac/eac valve
  120. obd1 H22 distrib, wiring from OBD2 civic EK
  121. Anybody got a HighEnd H22a Allmotor header willing to part with (an-R-Prospeed-elite/hotshot etc)
  122. anyone ever run a p72 head on a b16?
  123. obdII b20 into 95 integra question
  124. Code 24??
  125. 91 B18A in 95 LS! need help
  126. assembling LSVTEC, have ????
  127. Free set of VX wheels and tires 4 wiring my swap. MD
  128. PLEASE HELP!!! I have been having some trouble getting swap to run right.
  129. How do I wire my OBD2 plug to a OBD1 distributor?~SEARCHED
  130. clear this up real quick (HCP mounts)
  131. OBD1 motor in a OBD2 car which O2 sensor plug?
  132. high comp management
  133. 1995 LS into 2000 civic EX
  134. B-series swap in '93 hatch which axles??
  135. b16 conversion questions (weird situation)
  136. Engine Swap for Accord
  137. picking up gsr swap, what crap to look out for?
  138. EG + B18C1...what do i need?
  139. stock CX harness or JDM harness?
  140. 1500 canadian ( 1200 us) for a b20z too much?
  141. n e 1 seen an h22 94 integra?
  142. bad gas mileage, cant rev past 6k rpms.No check engine light
  143. LSVtec or CRVtec all motor..
  144. b16a2 in 89 crix questions
  145. 2 h22 dc questions, yes i searched
  146. need a smog hook up in socal. test only
  147. what vtec head to use on b20
  148. yeah I just did my own install fuel pump related has anyone else here did too!
  149. LSVtec oil line fittings....What size do I need for the head and block?
  150. WTB: Cooling Fan Relay, 98 lude IACV, EG clock if you have it!!
  151. HX motor, EX auto ecu, LX auto tranny
  152. why not use stock motor mounts that come in complete swaps
  153. Will my harness work? mini me related
  154. 90 dx wiring to b16a
  155. transmission problems
  156. suspension on a 96 coupe with a C5
  157. i need japanese hands (knock sensor question)
  158. Where can i get B16a hydrolic lifers?
  159. running on 2 cylinders...Need help!
  160. B18c1 in EG Wiring?
  161. Exhaust question
  162. 1ST GEN B16 INTO 94 CIVIC ?
  163. baffling heat problem
  164. Rebuilding my H22a Tranny: Advice for component selection?
  165. 92 Civic Si Hybrid Cat Size?
  166. Someone convince me that OBD2 is soooo much cooler than OBD1
  167. H22 into a 99 4door DX
  168. 200whp H22a vs 200whp B18c5...
  169. will dx axles work with the b18c1 swap
  170. anyone with an h22/civic have a short shifter?
  171. Type-R into 92-95 civic
  172. How to tell if distributor is bad?
  173. finally got the h22 started, but...
  174. rod bearings need help!
  175. Urgent help needed in DFW.
  176. GB II Atr Crank Pulley: See link
  177. Damn VTEC problems...HELP!
  178. how can i use my ac in my ek with an h22a??
  179. I need to know everything, i need for B18b1 in EK
  180. YS-1 LSD Trans fuild help ( I know this has been done before )
  181. I did a search and no luck....
  182. Help!! Car won't start after swap
  183. Need help installing possible OBD-2 GSR TB on OBD-1 car
  184. Wiring in Knock Sensor?!
  185. LSVtec Reliability?
  186. o2 sensor question
  187. B18B into a CRX...help me out
  188. H22a1 distributor
  189. Please help me!!! Problem after problem...
  190. H22 Swap for my EK
  191. Best suspension for my "H" set up...????
  192. places to buy swaps
  193. Driveshaft Shop Axles Problem...
  194. where can I get sheilded wire for the knock sensor? Or is there somebody that can just make the setu
  195. throttle cable?
  196. where can I get sheilded wire for the knock sensor? Or is there somebody that can just make the setu
  197. Problem with wiring in my new swap. I have pics.
  198. Fuse Problem
  199. need pics of b18b1 in EK haven't been able to find it on search.....
  200. 92 civic, dohc, can i use automatic rear mount bracket?
  201. d16y8 and using OBD1????HELP!!!
  202. Type R piping on an 92-95 hatch........??????
  203. Non VTEC B18B1 EG 1/4 times ?
  204. Trading in a Hybrid?
  205. purge on swap
  206. b18c in 1990 teg, what do i do about MAP, IAB and EVAP
  207. OBD 2-1 engine/chasis harness compatibility question
  208. 14.09 1/4 mile H22A Hatch with out 3rd gear Comments?
  209. searched but still a little confused about obd conversion
  210. 93 civic with 97 b18c1 obdII will it work?
  211. Civic fuel line on GSR motor?
  212. Sputtering Problem:::SEARCHED ALREADY
  213. H22A EG6 Bad Night at Texas Motorplex. No 3rd Gear.
  214. Swap for a Dodge Stratus and 92 Eclipse
  215. wiring help for H22 swap
  216. WRX/STI engine in 93 impreza?
  217. h22 type s
  218. Swap problems
  219. My H22A Compression #'s
  220. STILL can't check CELs!
  221. 92 GSR Cluster ina 90 Civic
  222. Ls/vtec w/ many mods vs. my beloved H22
  223. k20 into 92-95 chassis
  224. Engine swap fo a 97 Dodge Stratus
  225. What will fit in an 2000 Civic EX?
  226. h22 running like shite
  227. Help me with ITR swap in my 00 Civic SI
  228. Just came across an idea for all you H22 Civics with vibrating issues....
  229. Advice on radiator...dual core auto radiator?
  230. Vtec controller!?
  231. What shold a CRX w/ modded jdm b16a run in 1/4
  232. Urgent swap help needed! missing bolt for starter/tranny
  233. B20 swap, tips/info?
  234. Engine hoist and engine stand question....
  235. Frabricated ITR CAI
  236. Anyone here using totem motor mounts for their h22 hybrid?
  237. AEM CAI for a gsr swap with jg intake manifold in a 96-00 civic?
  238. help! motor decision
  239. Starter....
  240. H22 Euro R Intale Manifold in a Civic?!
  241. h22 civic/ b18c5 civic question--->>>
  242. Pic of my broken hasport h22 driver side mount
  243. CRX or HatchBack for b18b swap
  244. Vehicle speed sensor wire
  245. What does hybrid know about 5thGen Prelude auto to man swap?
  246. what OEM intake for hybrid hatch
  247. B16A swap into 92 hatchback..BRAIN FART..
  248. hopefully last h22 question before im done
  249. Rad Clearance w/H22a in my teg! PLZ HELP!
  250. Swap Question (things i am missing)
