PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 [130] 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. 91CRX swap ?
  2. Will an ITR AEM CAI fit a GEN 2 Integra w/B18c1 + skunk2 manifold?
  3. what color is KS on engine harness side for b18c1?
  4. Anyone running just a CTR intake cam on a JDM B16 SiRII?
  5. is it that easy for this swap???(b16/91 HF)
  6. Can I run GSR headers / cat. conveter in my Eg/GSR Hybrid?
  7. JDM B16 (Sir II) vs USDM 94/95 B18C1
  8. Need opinions on engine choice for my new project(LS vs h22)
  9. Would i have to use integra axles for a CRX with a LS motor?
  10. Eg's with GSR motors sign in!
  11. LSD Question?
  12. Yes or no on this setup please give detailed answers
  13. what pistons are good
  14. can b20 rods take this
  15. Which H22
  16. b18b1 bottom end?
  17. d16z6 In 91 Civic Cx Hatch?
  18. 96 DX w/ H22 won't rev past 3000, need wiring help
  19. intake manifold question?
  20. B16B into '92 Civic VX ... swap questions.
  21. car immobilizers
  22. B16A2 swap??
  23. vtec swap on sohc motors???
  24. HCP Engineering Motor Mount - GROUPBUY
  25. Need help...which wires????
  26. 2001 Integra LS ECU--B18b question
  27. hondamotorsonline??
  28. 91 Civic (EF) b16 swap help!!! What rear mount "L" bracket??
  29. Wiring IAB for B18C1 swap for cdn eg si?
  30. Import Auto Salvage is awesome!
  31. www.hybridrevolutions.com?
  32. anyone race an rsx?
  33. obd-0 swap
  34. P73 head w/ skunk2 I.M., vacuum lines right?
  35. simple question about ecu
  36. h22 pic request
  37. ls/vtec???????
  38. ecu troubles on swap, rev limiter at 6500rpms... someone help!!!
  39. Some questions relating to Dizzy and different OBD versions.
  40. what kind of times??
  41. worth while trade
  42. After swap...electrical problem
  43. SR20det swap
  44. Removing a block stamp?
  45. Must get rid of H22a LSD tranny
  46. tranny ?
  47. 1986 b16a swap questions.
  48. websites
  49. Summit RPM Switch... NEED HELP!
  50. '92 Civic with GSR engine.... short through shifter?
  51. 2K b18c1 into 92 eg....need a complete of things i need
  52. B18c in EG: Header? Cat?......just a couple simple swap questions
  53. b16a2 or b18c1
  54. New Project: 2.2L B-series motor
  55. A/C question. please read and give me advice
  56. vtec
  57. 94 to 96 engine, quick question
  58. 2000 si b16 weight
  59. pics of my motor
  60. Oil Leak
  61. 95 gsr harness question
  62. IAT sensor B16a2
  63. JUN type III cams
  64. B series into 92 hatch question??
  65. Which cat to use with my swap
  66. Type R inner valve springs same as GSR/B16?
  67. Tranny leak problem
  68. Anyone ever cracked a stock retainer?
  69. what to do with money to spend on integra engine
  70. canadian ITR cluster in 2000LS
  71. H22 AEM short ram
  72. ABS teg axles in non-ABS civic?
  73. B16a crx - which cat-back?
  74. Double swap question
  75. dyno numbers (all ls/vtec ppls)
  76. HELP! DPFI to MPFI for b18a1 swap!
  77. B16 motor swap in Del sol........shift linkage?
  78. 96 gsr brakes on a 88hf
  79. b20 in ek???
  80. B16A2 cams in B18C1 head???
  81. H22A EK help
  82. Shift Linkage Length?b16....EF
  83. what is needed?
  84. ITR calipers on 1990 EX knuckles ?
  85. Got hit... got insurance money... need new motor
  86. 97 accord v6 motor/tranny into 2nd gen teg
  87. What's the deal with hybrid garage?????
  88. Need HELP Quickly!!!!!
  89. Wire IDs for secondary O2 EK sensor used as Primary O2 sensor
  90. Jacksonville FL , swap
  91. Suspension and the H22a
  92. 94 GSR +97 Hatchback=no more heater..help i'm cold
  93. B20 in EK, which ES motor mount inserts to buy? Best place to buy?
  94. B16a...12 second car?
  95. Hydro B16 MOTOR and TRANS ONLY $1500
  96. Doing Anything Wrong on a Ls Swap??
  97. Can H22 Civic keep a/c and power steering?
  98. tranny question. need help
  99. whats needed for manual pedal swap?
  100. A/C compressor
  101. 91 LS integra vaccum digram
  102. any one have a clue about ecu programming?
  103. chipping a p13 auto ecu
  104. If the H22 is so monsterous in a Civic...
  105. B20 intake manifold, is it.............
  106. Clicking injectors?
  107. h22 head h23 block
  108. Where can I find shift linkages at???
  109. Converting from OBD0 to OBD1
  110. are b16 rear mount bolts the same as b18b bolts?
  111. how to remove pins?
  112. Please help me put a B18c6 into my 92 vx
  113. whats the easiest swap for del sol?
  114. 1st gen b16a into a 2nd gen integra LS
  115. K20A Numbers Block And Tranny
  116. h22 wiring???
  117. 90 crx with b16 pre obd swap, getting a CEL need some help here.
  118. B16a sir2 difference with B18C1 worth the money? Help please
  119. gsr crank in an ls block?
  120. LS valvesprings on ZC...urbanlegend?
  121. Renting an Engine Hoist/cherry picker???
  122. H22 ECT switch wiring!?
  123. H22 EG civic; how do I clear the stock fuel filter??
  124. Vtec solenoid is good.. but still CEL 21..
  125. ls LSD tranny?
  126. Just curious, can you swap into EF wagons?
  127. ls/vtec
  128. My dumbass oil pan question about B series
  129. wheels spin in neutral..???
  130. need feedback/criticism on this setup.
  131. Am I gonna need a throttle cable??????
  132. OBD1 distributor....differences (LS only)
  133. h22 into eg hatch..parts needed
  134. Engine Codes Listed for Gs-r obd2
  135. shift bushing question...
  136. 94 dx gsr swap
  137. PR3 ECU problem
  138. Help plz Vtec doesnt work
  139. h222 eg
  140. H22 Tech
  141. ecu wiring in h22a
  142. cluch question
  143. EG/H22A Header Design
  144. ac removal ?
  145. Electric water pumps, before and after dyno #'s
  146. ls/vtec smog issues?
  147. 95 ex into 90 crxhf
  148. year swap?
  149. GSR or Baby type r
  150. b20 timing cover
  151. Question about Polyurathane motor mounts..
  152. Alternator belt won't fit my B17a!
  153. 98 itr into a 2000 ek
  154. Is the b16a and b18c's front driver lower torque motor mount different?
  155. Which ECU for Euro R H22a(JDM)
  156. B-series Mounts in a 98 ek coupe????
  157. Removing stuck axle, suggestions?
  158. b20 swap wont start!
  159. Whats needed for a B18c1 swap into a G2 Integra LS?
  160. MOney FOr my H22a
  161. R into a delsol
  162. EK with R swap. which a/c bracket?
  163. LS Vtec Turbo in a EG?
  164. Cost of Machine work.. whats some good prices?
  165. anyone using gsr rods in their ls vtec?
  166. jdm usdm h22a
  167. H22 obd ?
  168. what swap to do on my 90 SI hatch
  169. b18c1 to b20
  170. Integra brakes + HX 14" rims = ???
  171. Can i use my current short shifter???
  172. prelude tranny problem
  173. Need help with wiring...
  174. 1st gen CRX carb to Fuel injected swap
  175. TPS and 1200rpm idle now
  176. best fuel system upgrade?
  177. H22/Civic Fuel line question...
  178. Miles On Your Swap
  179. Gude Bullfrog throttle body for a B18A1
  180. what trans for a b20
  181. Custom axles for h22 into a EK coupe
  182. installing a b18a
  183. question about torque motor mount?
  184. Spoon 1.8 stroker
  185. Swapping difficulty
  186. Dilemma... i need your help.
  187. What do i do now?
  188. I bet my car throws more codes than yours
  189. Anyone with B20 JE pistons?
  190. anyone have experience with jdmhondaparts.com?
  191. A/C in 95 Hatch w/GSR--what bracket
  192. shipping problem?
  193. wiring problem with b18c1 in 99 ek
  194. B18B Swap into 00 EX wiring question..
  195. knock sensor queston?
  196. civic ex abs unit question?
  197. Accord questions please help
  198. CEL 14 and 21
  199. JG Intake manifold on a First Gen B16A?
  200. auto to manual swap help
  201. is anyone running the jim fab rear and two front lower motor mounts?
  202. Help me with a website
  203. ?'s should i get a helms manuel for my swap?
  204. good deal??
  205. what happens when a motor falls apart (lsvtec)
  206. whats beating on ur motor??
  207. block girdle??
  208. Is it safe to drive with a torn engine mount?
  209. Error Code 10 IAT sensor problem EG Civic
  210. will 96 delsol b16 distributor fit a jdm 2nd gen b16
  211. miscellaneous motor swap needs?
  212. B16A2 w/ B18C5 head?
  213. what makes more sense to you?
  214. :::someone please help me on motor swap:::
  215. f22dohc into 93 prelude si....
  216. H22a Diagrams
  217. best motor for a 88-91 CRX (Serious street to full race)
  218. Usdm H22a
  219. zc start up prob
  220. How much $$$ for an LS/VTEC swap?
  221. teg vs custom axles
  222. Teg vs. Customs axles
  223. Driver side mount bracket from the 99-00 Si
  224. ls/vtec pistons question
  225. 2000 b16a2 motor w/ obd1 gsr harness
  226. HASport vs. Place Racing EK stock replacement mounts
  227. HELP!! Does a f22a1 distributor work in a 1st gen h22a?
  228. Check list for B18C swap
  229. quick question for b series swap!
  230. Going to get hybrid emissions inspected this weekend in VA.....
  231. H22 in Civic?
  232. b18c1 civic.......suspension questions
  233. h22 cat + civic catback?
  234. why vtec doesnt sound the same
  235. NSX engine in a chopped top Signal EK
  236. Manual IAB activation?
  237. ecu question......2 ecu's?
  238. no spark???
  239. Evap Purge Solenoid
  240. Any shops in north nj/nyc can do a h22 into a ek?
  241. H22 into a 00 ex coupe
  242. Do these vacuum lines look correctly hooked up?
  243. Will 99-00 Si rear engine mount work for this swap??
  244. b18c1 odb2 in a civic 96 ex wire harness question
  245. H22 in a del Sol
  246. almost done with swap into 88 crx and question about front mount
  247. Wiring up the motor b16a fisrt gen to 98 civic ex
  248. help with b18a vaccum digram and integra ecu
  249. B18B vs. B20Z
  250. a great new shop in MD
