View Full Version : Hybrid / Engine Swaps
- A/C into EK
- Engine/tranny brackets for b16B/A swap into EK4 ??
- d15 -> b16 Carry-over parts?
- Crank pulley issues !!
- B16A question
- 89 Civic HB project...swap help.
- jdm b16 no start tried everything nothing need help
- OBD0-1 swap on a budget, Dseries-Bseries
- intake manifold on a h22 in an eg...
- huge problem with gsr motor in my civic
- h22 civic not staying on after driving
- B20 swapped Integra loses power on hard shifts
- searched... need a diagram for obd2 to obd1 dizzy re-pin.
- b series header sizes dimensions edelbrock
- Question about LSVTEC....
- ground
- d15 block/ d16 head
- B18C Swap into 93 Ex 4dr
- LONG Block
- V-TECH valve cover
- ls/turbo question
- h22 into 88 crx si
- I'm looking into motors and would like some helpful tips
- 92 VX, JDM D15B/P08 ECU....02 sensor question
- THIS QUESTION HAS BEEN PISSEN ME OFF ALLDAY!!!!
- what torque mounts???
- 96 civic w/ b18c HELP
- Radiator hoses 4 b16 swap into civic EK4 96??
- B16 Dead what to do next???
- EG wiring questions: 2000 B18B motor OBD II into a 92 EG Civic OBD1
- is there any difference between TD-41U and TD-31U dizzy's ?
- timing question d16y8 with p28 ecu
- Using a 5 wire o2 seonsor with a 4 wire ecu????
- Radiator hoses 4 b16 swap into civic EK4 ??
- EK with B series with no header bracket on header
- From H22A to B18C in EK
- need some info
- K series
- Rcommended auto salvages 4 Honda/Acura parts !
- I NEED HELP WITH MY B18C1 Engine Swap
- ANYBODY with a EG
- OBX LSD Part #?
- Writeup: BAR'd jdm h22 in 92 civic hatch - parts needed, etc to pass BAR
- Accord Shift Cables Broke H22
- B18C5 swapped CRX, wont rev past 3800rpm *searched* -Not a normal problem
- b16a2 vs. b18c1 which has a better head....
- Head Bolt length question
- turbo h22 setup/ questions
- ITR TB + Intake Arm in EG - What airbox..?
- A/C Condenser Fan
- need help
- b18c into 93 civic
- Crx hydrolic clutch conversion questions **real deal hydro
- JDM B16 in Del Sol S - Axles?
- 98 gsr axles in b16 eg problem
- H22A dual stage VTEC/Secondary butterfly?
- EG Si w/H22A power steering loop?
- which cars\engines has a TD-41U dizzy?
- h22a1 wont rev past 6k
- MoToR MoUnTz
- NEED HELP b18a1 in crx
- h22 in DA via H2B
- b16a obd0 into 94 civic ex
- Which fuel pump to use? 94 dx with b18c.
- help me! no spark
- OBD2 ECU into a OBD1 engine
- Do I need an oil can for LS/VTEC?
- typeR swap acting funny.
- b16 into ef crx-si ---->clutch cable problem
- JDM LS block, no crankcase breather.
- ob2 h22 into obd1 prelude... problem with iac sensor!!!
- need help with JDM Type-R ECU and my 99-00 Si wiring harness... blue, green and gray dont plug in
- gsr mounts?
- ecu swap (injector impedance question...)
- LS swap 99 4 door
- dc radiator in eg????
- Idle/Open Loop Issue (B18C1 Swap)
- Transmission Swap (95 Civic Coupe w/ B18C1)
- Local Tuner Needed
- b series fpr on h22?
- total price of h22 swap into 92-95 civic ex
- how do i swap a 93 b18c into 93 civic
- Doing LS/VTEC build up what oil pump should I run? Stock, GSR, Type R, CRV?
- EK4 B series swap
- Does HMO deliver locally?
- d16a vs ZC vtec
- high idle and other problems
- F20b in a DA
- distributors
- mounts. h22 into eg
- h22 reving issues
- H2B HELP
- swaped a 91 ls bl8c1 into a automatic 91 integ..can sumone give me sum pointers on what is need
- my car wont try to start...witout pluging in the old automatic wires
- My h22 is stuck in limp mode
- swap question regarding exaust
- H22 into DC!
- ls vtec Question
- Noob here.....swap info?
- how to get a y8 block with a z6 head to base time
- Help b20/V is not running right???
- Swaped out my EK with an LS and I got CODE 0453 EVAP emissions pressure high
- ls/vtec pros and cons
- H22 crx inlet manifold question
- 1st gen GSR into CX EG hatch
- swap parts new or used ??
- jdm h22a type s swap
- GSR in an EK...which motor mount inserts should I buy?
- K20 into an EG/DC/ or EK with AC
- sohc
- swap questions
- 95 Civic /w GSR motor - having probs getting into first gear.
- B18B question
- hamp filters
- Quick question about auto-->manual swap
- B18 powered ef sedan.
- Need ek obd2b ecu pin for secondary o2 sensor
- b20 oil dipstick
- GSR into my 93 CX
- what brake line??
- TEIN Basics for DC Integra in EK Civic
- Anyone Run BLOX H-Series cams ?
- help
- OBD II H22 Swap - EK Civic Questions - Yes I searched and read the link above..
- Quick question.
- is my intake manifold supposed to hit the proportioning valve/firewall??
- Thinking about switching frome d16z6-t to b16-t???
- What ECU do i use to bar'd a b16a2 into an obd2a chassis???
- HMOTORS
- zc block with vtec head
- H22 in civic
- itr head on gsr block wiring question
- ITR LSD-B16 tranny help.
- Trouble shooting
- best transmission to go with jdm gsr?
- GSR Block w/B16 head?
- b20 vtec
- integra rack and pinion in a 5g civic?
- h2b or h22 in EF
- my mounts are wrong, what mounts do I need??
- What Axles??
- B18c1 Build NA Need to know part suggestions for a full build
- Swapping b20vtec to b18c in 1990 crx si
- Honda motor in Saturn
- door panels
- civic sedan hybrid
- F20b head gasket
- Jdm d15b and obd2 p2p ecu??? Which ecu is the best to chip and control the d15b...
- KS Code 23. (Searched)
- Im confused! Can B18a go with B16a head vtec????
- power steering line hose fitment question for an ek, please help!
- trouble with h22
- Oil Pressure help
- can i use a y8 dist on a z6 head??? help fast i need helopp!!@@#!
- oil pan gasket?
- type r head sr block
- Price difference between complete ls and gsr swaps?
- GSR swap into ek?
- vtec pressure code??????????????? help
- D16Z6 with D16A3 head?
- LS-VTEC DEAD!! H2B CRX RISES FROM THE ASHES!!
- alternator belt problems with my b18
- h22 help
- 2000 Honda Insight ( What engine would you put in a (B-series or K-series)
- B20/VTEC in CRX with tranny & LSD to use for road racing?
- got a b18c5 but dont know where to put it.
- crx si cabin harness in dx hatch question
- JDM Harley Davidson
- looking for an engine
- cometic head gasket
- B-18C into 89ED
- B18 in EK hatch, electronic or head problem???
- throttle cable adjust and throttle plate position
- v8 240sx project beginning
- gs-r TB fit on a type r manifold??
- my hatch was stolen recovered now i need help
- Simple Question/Accord H22 Powersteering
- RWD drivetrains that take counter-clockwise input
- desperate. . . need smog help in san diego/so cal. please, please please
- LS/VTEC questions...
- Idle's funny no check engine
- best trans fluid to fix grinds/pop outs ??
- help picking heads
- $$$Will Pay someone for motor swap in So Cal$$$
- HELP! Honda civic swap....94B18B integra into 92 honda civic hatch
- s2000 cluster swap, then no turn signals??
- B18b1 installation
- 1" MC and booster
- what would you do?
- i'm about to torch a 50k car.... if I don't have an answer...... point of no return..... i've had en
- B18C1 ->88CRX Coolant and vacuume diagrams?
- ls/vtec cranks.....
- engine swap 95 B18B1LS into 97 Civic
- jdm B20b totally stock in 99 Ek ...worth it??
- need link to ecu description
- engine swap for a ek
- b18c5 into civic eg
- jdm b18c5 into 93 civic si
- Need Hekp Stock B20 Swap In Eg Coupe
- Swap posterior brake DC2 -> EE8
- motorswap
- can somone PLEASE confirm which one of these two is a p28 pinout\diagrem?
- H22 ek civic MPG
- B16a or B16b ?
- Will this engine harness work with the swap? Help please!
- Need help with a unusual CEL
- 86 accord need some power
- ac for a k swaped eg
- B16 Sir II Into 99 civic Si
- gsr internals in an LS block??????
- Fuel pump question. DO you change with a swap? Experts? Kat?
- GSR Vacuum help
- good block for b16
- 1.5 auto to h22 manuel project
- GSR swap
- obd1 swap. what to do with immobilizer?
- 95 Integra h22a Power Steering
- anyone have a obd-1 td-42u distributor pinout diagram?
- odd stumble or constant hesitation between 2000rpm and 3000, then clears off?
- b16b engine... with another block
- ej6 swaped b18b1 having problems...help thanks!
- h22a in a dc2
- f23 crank into h22a4 block
- B18C JDM Type R into a ef9 Install Question???
- H22A Resource Guide?
- dumb clutch change? h22 EG
- IS IT A GSR OR TYPE R????
- h22 into an EK
- h22 in EK Swap.. won't start.
- d16a1 pistons into d16z6
- OT Q: re-use head bolts for b20b engine?
- B16a into '99 LX Civic engine swap
- d16y7 into an eg
- b16a main rod bearing compatibility
- Crower B18B Springs & Retainers in a B20 P8R head?
- 98ex B16B swap help
- 91 b16
- B18C JDM Type R into a EG6 Install Question???
- Full skunk2 head .. stage 2 or turbo cams
- h22 vtec engagement issue
- 2.25" or 2.5"
- oil leak after ls vtec build...HELP!!!!
- swap question please help ls in civic eg
- idle problem
- D series distributor on B series head?
- B16A1 swap into 1996 Civic HB - mounts/brackets
- Swap help?!!
- HASPORT MOUNTS after 5yrs of abuse.
- Buzzing from shifter/cat area
- h22a1 won't rev past 6k
