View Full Version : Hybrid / Engine Swaps
- ECU Question?
- B20 crank pulley
- removing axles?????
- A few questions...
- B18c bog problem - VIDEO inside.
- wut all will need to be done to the b18a???help asap please
- LS automatic into CRX
- everything inside the car is working( cd player,light and all electrical ) but car wont start
- h22 ek trans drop
- JDM B16 OBDI into EJ
- which intake do i need for itr motor in 88 crx.
- Swap Question ?
- 6th gen accord
- Code 91 solution...
- B18A Auto -> 5th Gen
- Need help with OEM MAP sensor wiring
- Will the 95 LS intake mani work with a 97 B20b?
- 99 honda accord swap
- B18C1 in 90-93 integra
- H22 Tranny codes??
- tranny and ecu for b16a2
- K series -> EG
- h22 ex coupe
- code 15 and code 41
- Pin Locations
- DA6 swapping for H22A vtec
- VSS woes... help peas
- 91ls block with 95ls head
- Prelude head swap: which head gasket to use?
- auto ls vtec
- What Compressor fits the 1st gen b16a bracket?????
- instal shops
- Which wiring harness to use for h22 swap?
- Swap Q's
- 92 eclipse injectors? Engine code 4G37 What's there flow??
- integra mounts for b16 swap this saturday???!
- Engine Dealers???
- what body could the motor from a 94 del sol vtec be put in?
- H22a eg strut bar
- OMG I am gonna sell this thing if anything else goes wrong HELP!!!!!!!!
- ZC crank gear
- Question about a friends swap
- 88 crx si with 90 teg rear discs. which ss brake line kit?
- Craziest Swap expierence ever (question)
- what could put an h22 civic in to limp mode?
- B16 2 o2 sensors >> 1 o2 sensor??
- 2000 SI 02 sensor. wires are 1-white 2-green 3-black 4-black ? on wiring
- just got the h22 started, first impression
- Does anyone have the vacuum hose diagram for an OBD II LS engine?
- Switching ECU??
- Turbo H22 CRX project pt.2 (more pics)
- B18B with b16 lsd tranny
- what size test pipe would i need when doing a ITR swap ??
- H22a Question? LOw IDle, Code 12 EGR
- how to read CEL?
- JDM D15 VTEC, information?
- question on rate
- Help me out here... Wiring Harness ECU question
- shift linkage question
- JDM itr motor idles too high!
- How do I remove pinout's from OBD2 wiring harness????
- need help with a pinout..... Katman
- Complete How-To: B18C5 into 1995 CX
- mounts for 92 civic 4dr and 93 B18a
- Need a little wiring help please. EX to GSR
- JDM Octane?
- 1994 JDM motor
- y7 block-z6 head?
- when doing a 1 wire to 4 wire O2 conversion......
- Y1 with LSD or stick with S1 tranny
- need help with h22 swapping with 95 integra ls!!!!!!
- oo si tranny ??
- Dynoed my LSVtec today
- ZC into CRX ... No spark
- broke a mount.....now i need the right one....??????
- shipping a motor..which company?
- Really confused here... Wiring question.
- best shop in SO CAL for H22 swap? help!
- Throwing Code 1 but O2 sensor is good so what's the deal?
- help gears grind
- b16a in 93x????
- which intake will fit my swap?
- My car turns on by itself *no key*
- wiring problem
- integra brakes on crx..possible?
- After market exhaust, Please help?
- arghh over heating problem....
- newman, need some parts.
- ls swap #1 and 4 cylinders not getting fuel
- Need opinions, JDM H22 or F20B?
- gsr hood clearance?
- Engine Clearance! Help!
- Sensor on the H22a
- Best place to buy swap?
- Wiring Harness
- check engine light
- i JUST put the batt in my car, and everything turned on.....
- Will the engine start without the IACV plug up?
- hasport blanks?
- JDM b16a into a 92 Civic two Intake Manifold sensor questions
- Help with secondary O2 sensor connector
- vtec chang over
- 90-93 Integra DA swap 1G B16A
- H22 Dyno plots
- Best place to buy a swap in montreal?
- Fifth time Axle pops out
- Y1 hybrid gearbox
- www.osakajdmmotors.com what da Hell!!! help me guys...
- AC vacum line off intake manifold on 00 b16
- oil in cycinder holes before starting swap?
- help on some info on swapping engine into a 94 teg
- B series motors gaining value!?
- axle snap ring
- CIVIC B18C5 SWAP WHAT WOULD I NEED TO COMPLETE SWAP???
- swappin a 91 integra motor into a 85 crx
- Ordered my swap today...
- Video of my hybrid JDM B16A hatchback
- B18a into crx HF question
- just did a swap and check light won't throw any codes...any ideas?
- ahgg, so many IAB wiring stories...
- usdm gsr axles same as JDM B18c axles?
- GSR into eg question
- Throttle cable.??
- gsr axles HELP PLEASE!
- bad synchros
- 1G B16 plugs are now available....
- i have 89 civic how do i run vtech
- 1st gen b16a
- Swap Question?
- grounds= how many?
- LS motor, ecu question, and mountt question
- accord h22 too low??
- Axle Question....
- swap ?
- fuel pump ?
- IAB Vacuum Routing
- what lsd to use??? h22 in eg using accord intermediate shaft? b/h series lsd?
- kenji spec ecu?
- ???crank pulley q???
- OBDI H22 in to 97 Accord
- B16+B20!!!
- where can i find a pic of gsr axels?
- k-series?
- ITR motor in a 92-95 hatch (obd 2 motor in a odb1 car)
- best ecu for 0bd0-obd1 lsvtec conversion
- H22 into 94 automatic accord! Parts list, is this right?
- help asap b16a
- Will these pistons work?
- b16 swapped into an EK...no compression
- Automatic B20B
- where to find B18C5
- engine problems
- gsr in crx..what coilover?
- OBD2 car + OBD1 motor= extra harness hanging! HELP!
- No Vtec & 6500 rev H22 in h23 lude
- jdm itr into 94 civic cx need help
- GSR lsd?
- GSR suspension? & JDM Throttle cable
- d16z6 swap in 88 dx hatchback
- 60 ft times????
- How to Swap a B18c1 in a 93 civic si
- OBD2 GSR swap in 90 CRX?
- Where to buy wiring harness parts
- 390 crank HP possible with a crvtec?
- Total n00b question: Longblocks
- GSR swap - stock ecu - speed limiter?
- h22/h23
- where are people getting their d15b's from??
- 96 DX TO 00 SI SWAP WHICH WIRING HARNESS TO USE
- H22 into 99si
- JDM D15B into 1987 CRX Si?
- Vouch thread for me!
- Another stupid ass IAB wiring question. If searched but still having a problem.
- B16A1 SWAP IN TO 90 CRX SI///Speedo problems
- d16y7 cr vs d16y8 cr?
- charcoal canister off 00b16
- DSS Level 1 guys...
- GSR harness or cx harness?
- B21A1
- b16 vtec engagement point?
- FS: 1990 1991 CRX CALIFORNIA CLEAN TITLE
- h23 v h22
- GSR Swap Question...
- HELP.wiring ?on b16 into 96 hatch
- Which ecu would be better?
- Turbo H22 CRX project Pt. 1
- swap ?
- ZC guys need your help
- Water Pump Gurus...Have quick question
- h22a in Honda Insight (Really?)
- h22 Knock sensor hook up
- h22 Axel problems
- Blinking oil light
- B18C5 into EG, OBD1 or 2 wiring harness?
- Overheating Ls motor
- cheapest prices/hasport eg22???
- ARGGGGH
- 20si question
- 2.0si info
- 96+ D-seris upper tranny mount...
- engine mount question pls help
- will gsr heater hose fit? ( in cx hybrid)
- swapping the v-tec head
- Why did my axle explode?
- H22 guys.. OBD2 H22 in a OBD1 civic question?
- Ls/Vtec prelude?
- What power steering pump/bracket/lines in '97 Civic with B18B1?
- Looking for someone to do my harness !!!!
- B16a2 into a 94 civic ex with a gsr harness problems
- Which A/C lines do I need?
- greddy gsr header worth it on b20?
- 88-91 with b18b
- Longblock plus ???
- Will secondaries work without the Cam switch???
- H22 in 94 Teg, EVAP....
- Strong driverside vibrations.
- anyone know where to find an h22 swap cheaper then 1800?
- Wiring VTEC to 89 CRX DX??????????
- transmission rebuilt kits, where can i buy them?
- B20-VTEC in a 98 Civic 2DR
- h22a transmission?
- 88-91 dx-vtec?
- GSR secondaries, quick questions, i have searched....
- How to cap off hose for power steering?
- GSR swap into CRX DX
- can an obd0 distributor be repinned to obd1?
- crx si to zc
- GSR Swap intake question
- Who knows the truth, AEM pulley set or UR, to crank or not to crank?
- so i figure out why my engine has so much movement
- Throttle only opening to ~95%
- anyone bought a motor from flashoptions.com?
- JDM H22 swap preventative maintenance questions
- A/C and P/S on up coming swap
- Axles for B18A
- h22a civic axel vibrations...
- Removal of front HCP crossmember for traction bar
- RSX-s engine for a EK hatch question?
- B16A Turbo in a GEN 3 Integra???
- b16a is in and 100 miles later.......
- Took the H22 hatch to the track for the 1st time last night.
- Next best mod?
- o2 Sensor + b18b, wiring HELP!!!!!
- b16 in crx hf vacume line problems!!please help!!
- anyone have pics/list of all emissions equip. on usdm b16 del sol?
- obd2 b18c1 into my obd1 92 Vx HELP
- Hot Tanked a Head...How To Prevent Rust...
- h22 swap update
- NEED HELP Swap reving to 5k on startup weird whistle
- y8 swap wont even try to crank ::HELP::
