View Full Version : Hybrid / Engine Swaps
- OBD2 motor in a OBD1 car?
- 2.5 inch Exhaust
- need some advice.
- engine swap question . . .
- 88 Civic Mini Me__What's it worth?
- Need help, getting a ECT CEL ?? any suggestions?
- CA SMOG Legal
- 92-95 civic head swap
- B20b block, which head?
- cost for a b20b/b16a
- Has anyone bought swaps off of ebay before??
- sir2 front clip for 2500 shipped
- Comptech icebox?
- 2nd generation integra + first gen b16a
- LS/VTEC Question: wat rod bearings to get???
- LS/VTEC, which head studs to use?
- HELPPP!!! Loose and wobbly hub and rotor??!!!
- B18B1 in CRX - HELP..... Katman, Anyone???
- Swap weight? B series engine, tranny and axles???
- EG hatch- b18c5 or forced b18b?
- ctr piston in a b16a block
- 99 hatch w/1994 obd1 b18c1
- Can't pass emissions, need suggestions!!!
- O2 sensor question
- Engine Swap
- Does anyone make a motor mount kit for a 98 dx?
- Matching Chamber on b20/vtec
- question? will a gsr dc sports 4-1 header fit on a 97 ls motor?
- HELP HELP Oil is leaking from my head gasket when I try to turn it over
- b20vtec
- What ECU for B16a1 into 94 Hatch?
- B18A1 swap
- How do I launch with LSD.
- Hasports rsx type s powered civic [B]NEW[/B] si
- ohio suxs. do i have to drive all the way to michigan
- How much power is this setup making?
- Katman I need some help 1st and 2nd gen b16 differences
- running b18c6 with an unmodified b16a2 ecu?????
- GSR brakes or ITR brakes for a VX?
- H22 - H23 head swap
- Differences between Transmissions: JDM B18C - USDM B18C1
- B18b swap parts list...am i missing anything??
- Oil Pump questions
- what type of rims are you running with 5 lugs?
- Crower cam timing!
- jus finished my first swap....
- what the best chip for a h22?
- Anyone with JDM ITR pistons?
- c1 in Eg vtec wires?help
- Just got back from the 1/4 (disappointment)...didn't hit 13's
- JDM b18c1 ECU....can't use it?
- *MAJOR* problems with my B18C1 (need help)
- Finally on the road...
- Can somebody answer this..........?
- b16a with internal mods vs. B18C1
- obd2 obd1
- B16a with mods vs B18C1
- I need a harness for an EG to an OBDII ECU
- Stock pistons & rods VS. Eagle & JE?
- power steering on a 92 dx?
- b20/vtec power numbers???
- b16 good enough ? ? ?
- C1 in eg what suspension?
- Piston question
- Hybrid Help - B18C1 OBD-II into a 94 Civic VX
- Anyone pass SMOG with JDM engine?????
- Crower Vtec stage 3 race core, streetable?
- HELP with brakes.
- Anybody deal with R&D Motorsports? Good, bad or otherwise?
- Over boring by machine shop.
- B18C5 Tranny Swap for B18C1?
- Got my Spoon tri-Y installed yesterday...
- good site to by used
- Radiator question...
- will dc2 mirrors fit on 92 cx hatch?
- my hybrid forum is up!
- Source for aftermarket A/C's ?
- Parts for my B18C swap, anything missing?
- Type r valve cover on b16a2...
- Does Any one build a b20vtec????????
- new s2000 engine in my crx
- Will a JDM Motor pass SMOG in California?
- can a 97 ex ecu run a 94 ex motor?
- Brakes feel mushy in Reverse.....
- Vin# below engine code on jdm motors????
- Price for hybrid
- B16 brackets?
- What does 'longblock' consist of? (Searchy no worky)
- B16 Head, D16Z Block?
- Knock sensor
- What header for ls/Vtec?
- need pics of EG's with RotaCirquit 8's
- PCT(CTR) pistons & CTR cams in LS/Vtec?
- GSR Into 92 Civic LX Sedan help
- Ls/Vtec HELP!!!
- B20b head on b18b block
- Tranny hydro or not? YS1
- Can a 92-95 Si Head fit a 92 CX block?
- 1st gen b16 into eg
- ZC tranny?
- 99 GSR distribitor with 2000 harness questions
- Type S h22a/Civic HB.. List of components??
- tuned b20/vtec...
- b16a2 into a 96 civic coupe
- What radiator hoses for B18C in EK
- reverse swap, from d16y8 to d16z6
- B20Z in a 92 Civic
- opinion on not boring before new sleeves?
- Will It work???
- please identifing motor
- SIR I and SIR II differences
- What parts can i use from a b16 long block in a ls vtec?
- Victor X Intake Manifold VS Skunk2 Intake Manifold
- LSVTEC motor...I hear a loud click when i start it up....???
- Trashed gears.
- 89-00 B16A all the same?
- jdm itr intake manifold on b16a
- How hard to rev, not to blow the motor?
- jdm or dc
- getting no spark
- whos running skunk 2 valvetrain?....
- b18c5 + 92 hatch jdm vs. usdm installation diffrences
- OBD-1 to NON-OBD
- what sensors are these?
- maryland hybrid laws
- GRRRR! Redshift racing is a fu*king rip-off!
- idle is high and no power at all
- JDM motor OBD rating??
- Modifing GSR block girdle to fit the b18b?
- How reliable and how much WHP???
- GC owners....what spring rates?
- B18b swap parts
- Anyone know anything about ...
- need to buy misc swap parts - from where..
- Shot pinning LS rods, good idea?
- Is the shifter for a B16 the same as the one on a D16
- F22B into a CRX
- gsr block with b16 head??
- anyone want to get rid of their rs ww kit?? for 92-95 hb?
- Integra front brake swap only on my CX hybrid...will it be good enough?
- Axle removal instructions?
- Writing an essay for class...Give me some info on JDM, etc...
- Parts list for Hybrid Swap
- b18c JDM or USDM ??
- Need info about header and gsr swap!!
- best tranny?
- B16a2 turbo...good idea??
- CR with LS/VTEC?
- cable to hydro tranny q
- What parts do i need??
- Ecu for a ITR swap in a 93 civic coupe???
- LSD
- Finaly pics of the ride
- engine check light
- Which cable tranny is best?
- Blown my B16A !
- Hybrid affordalble?
- Anyone in a CRVTEC-equipped EF ?
- SWAP parts FS....
- Need help please... VTEC head swap on a dx engine?
- Are kaaz lsd's any good?
- What kind of intake for swap??
- why does this shit happen to me
- ac in a ef with b series moter
- Exhaust Issues.
- B16 in 1st gen crx-in progress need help with fuel and vaccum connections
- Axle confusion
- what kind of rods can i use???
- what fuel pressure to air ratio are you b20/vtec, ls/vtecs running?
- Help Guys! Engine wiring harness question.
- H22 hybrids, what kinda trap speeds?
- Help with 97 ITR Shifter in a 99 Civic SI linkage. Please Help....
- Saw some kick ass Hybrids at HIN in Seattle
- HELP!
- b16a2...idle problem....help!
- b18c swap in 95 coupe
- 1/4 mile time..
- 2.0VTEC 4WD?!?!?
- Anyone mind posting some pics of EF b16 mounts??
- Best tranny for LS motor...
- H22 Ek owners! Help!
- smog in cali
- obd0 to obd1
- Brake light?
- If you know anything about Hyundi's please read this
- Which car do Bosch Platinum spark plugs model #4227 apply to?
- GSR or Type R injectors
- Need help w/ parts list
- Insurance for hybrids?
- Final Preparations for my B16 swap
- b20/vtec vs b18b/vtec
- 1 down 1 more to go
- eg to ef distributer wire conversion
- wiring for type r in crx?
- my car hasnt started in 3 *&% weeks
- h22 to dc2 integra
- really need a head
- h22 camgears
- H22 EK help!
- Just swaped in a b20b, car revs by itself when you start....
- taking advantage of LSD ?
- JDM b16a2
- B18C MOTOR SWAP TO 99 CIVIC MAJOR QUESTIONS
- Remember Me? Found out what happened with the H22 Hybrid Axle prob...WTF..
- B20Z in EG
- accord type-r injector size?
- broke my axels
- b16a or b18c5
- PCV setup on b20vtec?
- axles for si tranny on a ls??
- LOTS of auto swap questions....
- brake swap
- JDM B20B compression ratio?
- Need good Ideas
- usdm/jdm question
- h22a in a 97 coupe
- question before i do b18c swap in EG
- auto to manuel conversion
- 4G hatch with 5G SI motor and 2G teg tranny...will it work?
- what is a good price for a LSD b16a tranny?
- Stock compression on b18c1 and b16a and which is better for n/a??
- where is the site to buy crv/tec, ls/vtec long blocks...
- which altentator do I use for my b20/vtec?
- 94 p28 to 90 civic harness questions.
- h22 and ECUs?
- please help b18a wiring problems
- Quick question about smog legal engines in CA
- mini me swap
- My life story (well, not really..), your advice?
- B20 questions/Ontario jdm Importers???
- Boosting my Ls/Vtec
- Okay, thinking turbo'ing the hybrid...piece it together or go Drag Gen 3?
- 15, maybe 0 miles to the gallon. Why?
- Knock sensors with CRVTEC
- Hybrid with a turbo. Any weight issues? Understeer?
- What's a good price for a b18a motor
- VX 02 Help!
- Which OBD is better?
- O2 sensor swapping
- SoCal Meet, BBQ, and tech lecture by Oscar Jackson April 28th
- 2000 SiR starter and 93 GSR tranny
- Tech Question NEED HELP
- NO VTEC engagement.... NO CEL... Anyone know why?
- Ne one seen a viper engine in an integ?
- D series clutch B series motor
- Please Help.......H22 integra hybrid problem......
- looking for someone to do a swap
- help... b16a2 obd1, ecu code 14
- Check Engine Code......
