PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. d17?
  2. b17 gsr build questions
  3. going H2B
  4. Anyone know how similar the H22/H23VTEC heads are?
  5. b16 swap what ecu to run in obd1 eg
  6. D16Y7 with Z6 head question???
  7. Installing a motor from below
  8. k20 swap info
  9. PRCSV & EVAP solenoid question
  10. ls vtec headstud thread
  11. ITR gauge cluster into civic 96 coupe before ITR engine swap or after ??
  12. Code 8, No Start
  13. Need help with h22/eg swap. What headers can I use
  14. Need help with h22 swap!! Clutch lines?
  15. quick H22A injector question
  16. Can I Transfer the B18A1 internals to B20B4 block?
  17. d16z6 engine harness on obd1 gsr engine
  18. F23a1 Gains and drawbacks for an eg hatch, Throw all your info/pics here
  19. lsvtec coolant problem
  20. H22 eg swap axle ? what works
  21. H22 swap parts ordering ? help me
  22. quick b-series tranny question
  23. H2B h22a7 into an EK4 civic 1996
  24. H22A axle confusion
  25. b-series axles
  26. CRX + Z6 + Hydro trans question
  27. Bisimoto F2D fly wheel question
  28. S2k parts in EG HELP
  29. wiring b-series alt
  30. k series in an eg?
  31. Balance shaft ?
  32. Tips on OBD2a GSR motor into my OBD2b Civic DX
  33. awd question
  34. GSR block with ls crank?
  35. need help wiring obd1-obd0 alternator
  36. eg ls swap automatic wiring harness
  37. Resistor box ECU connection? switched 12v?
  38. Axle don't fit? (SiR First Gen in EF Hatch)
  39. Need Quick Answer to a EZ D-Series Question ???
  40. b20 vtec Quick Question
  41. qsd instructions any 1???
  42. JDM OBD2a b18c gsr swap into OBD2b em1 2000 Si help...
  43. Integra GSR OBD2 verification: OBD2a or OBD2b???????
  44. what injectors? resistor box?
  45. f20b o2 sensor
  46. H2B ...OBD1 H22 Distributer Wiring in OBD2B Integra..Need HELP ASAP
  47. my g23 vtec 92teg
  48. GSR crank Type-R block
  49. traction bar
  50. Relay Buzzing on K20 swap with relocated battery
  51. Cheap n Slow ?: K20a3 into Integra
  52. d16a6 block- d15b7 head will it work
  53. H2b
  54. civic/integra shift linkage question
  55. HHO Conversion.... Does it work?
  56. H2B - RMF replica header modified for H2B with 3" Collector
  57. H22 Prelude donor car? What to do?
  58. overlooked parts for b swap
  59. ECU for 96 del sol motor
  60. engine swap
  61. cel code 9 (CYP) even after CKF mod...SOLVED
  62. cel code 9 (CYP) even after CKF mod
  63. dehybrid? Any thoughts
  64. h2b guys using explicitspeed alt bracket kit
  65. wiring obd1 dizzy to obdo b16??
  66. P13 solid ecu cel
  67. h2b problems?
  68. D16A6 to B18C1
  69. h22 injector readings/resistance
  70. JDM GSR 99 BAR CAL ECU QUESTION
  71. igition timing question on a LS motor
  72. h22a eg6 CEL
  73. Converting a B16A into a B18C
  74. exhaust manifold situation
  75. Delete Thread!
  76. h22a rotating assembly into a f20b block?
  77. ecu problem
  78. k24/20 pistons??
  79. 99 integra shift linkage into a 93 civic with a b18, help
  80. my 1st build is a "g"
  81. SOo0o0o0oOO0o PLEASED with JDM B18C....
  82. 94 hatch automatic to manual tranny
  83. 99-00 Si engine harness = problems...need help
  84. b18c internals in a b17 block??
  85. F22 trans or H22 trans? cant decide!!
  86. can you run d series ac compressor on bseries swap ?
  87. poor gas mileage
  88. CAI on h22???
  89. is this the right hasport mount
  90. which mounts do i have? h22 ek
  91. looking for a diagram on a wire harness.
  92. what cold air intake to use for 98 civic with b20
  93. h22a4 for h2b
  94. ls ./ vtec will a p28 work ?
  95. H22 Running Rough
  96. NOOB question..rebuilding bottom end
  97. H23A VTEC (JDM engine) dyno sheets?
  98. which is a better camshaft b18 or b20
  99. Mystery T Bracket! Pics!
  100. My ITR build...plz help...=/....Really need it!!!!
  101. transmission question from a noob
  102. H2B problem please help
  103. OBD-2 wire harness
  104. Tach jumps / bad gas mileage
  105. h2b bogging..help...
  106. Can i use a VTEC harness on an LS with a planned VTEC head in the future?
  107. H22 Confusion!!!
  108. ls head on b16 block
  109. ZC engine in a 98 Integra LS swap info
  110. H22A*2000 SI*Head Rebuild*NO VTEC*
  111. EG-b18c1 swap
  112. bisi's ef h2b kit
  113. exhaust question. 97 b18c1 into 98 civic dx with SI piping.
  114. b20 ek swap help
  115. k20/k24 build help
  116. auto manual swap FA5
  117. milling the H22 head, and h22 header to accord exhaust, G23 ?'s
  118. Will my A/C system work on my b-Series swap???
  119. Insight
  120. need starter ef b16a J1 trans
  121. Bogging Problem - B20B VTEC in EF
  122. I want to blow up my honda...
  123. H-series into EK tranny mount issue
  124. Ek K swap Speedo help
  125. Can i bolt a dx tranny to a b18 ?
  126. b18c w/ b16 head vtec issue
  127. Hasport H22 EG Mounts - Real or Fake?
  128. is there a list for mixing heads and cranks?
  129. ls vtec help (dowel pin question)
  130. Help with b20z swap
  131. 98 JDM ITR distributor to 00 EX wiring harness?
  132. what ecu to use for the h23 f22 swap?
  133. Help with AP1 cluster in my EM1
  134. k24/k0 frankenstein help! kpro help!
  135. ls motor w/ jdm cable y1 what else needed?
  136. EG B16 swap with 90-93 teg axles?
  137. H22 civic filter/intake options *stock look*
  138. d16z6 turbo build
  139. Having trouble with H2b swap in Ek
  140. b20 sputtering
  141. 84 mm Gsr block with b16 head
  142. twm itb help!!!!!!!!!!!
  143. Using Prelude ECM for swap?
  144. D16a6/y8 Mini Me HELP!!!!
  145. H22A Running Like Crap Need Help
  146. D16Z6 head on D16y7 Block
  147. How to mimic a CEL? H22 EG
  148. what conversion harness, ecu, and dizzy?
  149. Need EG wiring help
  150. CRV Axles for JDM ITR (36mm)
  151. need ecu help
  152. H2B CRV
  153. f22 dizzy work for h22??
  154. which k24 block ????????
  155. Reset ECU? H22a swap 96 civic
  156. V6 question
  157. S4C into an EF with OBD1?
  158. need help picking an ecu for my g23 build
  159. H22 in eg swap questions about having to bang firewall.
  160. bb6 prelude five lug onto dc integra possible?
  161. dc obd2 engine harness wtb??
  162. B18C1 in EF swap question
  163. 2001 GSR swap into 1999 Civic EX (AUTO)
  164. 99 civic AT2MT B16 swap wiring? (PICS)
  165. sonem hydro conversion install??
  166. Any way to make my F22 Civic vibrate less?
  167. Power steering question.. B18C1 into 98 hatch
  168. how to tell a gsr crank from a ls
  169. 94 gsr integra exhaust
  170. F2D Mounts for Ek
  171. ls/v ?
  172. Can i use a b18b1 crank in a b18c1 block after i rebalance it?
  173. B20 question
  174. Rotary Civic first start
  175. Which Timing Cover
  176. h22a1 distributor help
  177. question h2b evo motor mounts
  178. Question about F20b
  179. h22aq1 distributor help plz
  180. Going 1 Wire 02 Sensor to 4 Wire 02 Sensor
  181. converting altenator help please!
  182. AEM Hybrid CAI EG B16/B18, will it fit ek?
  183. How do you pull the CEL codes from a OBDII car with an OBDI computer?
  184. b16b... with 84 mm pistons
  185. H22a1 Into 94 Integra questions
  186. Damn Code 9 driving me up a wall...please help.
  187. Whats the best honda for a v6?
  188. b18b dizzy on b18 a
  189. building the perfect 300 whp motor
  190. euro r manifold in eg h22 civic
  191. H2B in a CRV
  192. difference in pe width?
  193. F20C (S2000) crank pulley on H/F
  194. F2b build
  195. b18b intake on a b18a
  196. Instrustion for H2b QSD kit
  197. GSR Exhaust Manifold/Header to 99 EX cat???
  198. mass emissions
  199. h22/f23 hybrid
  200. lsvtec header clearances
  201. H22 eg swap axle ?
  202. will this fit
  203. k24a2 head on k24z3, is it possable?
  204. Johnnies H2B ek
  205. LS/VTEC alternator problem?
  206. What map sensor?
  207. Intake Questions?
  208. H2b problem!!!!
  209. 99 civic with gsr swap power steering
  210. integra gsr fuel pump vs civic fuel pump
  211. ECU Question
  212. EF HYDRO H2B KIT from EVOLUTION
  213. One piece Prelude shifter
  214. B series 4wd
  215. Rear mount H22 EG civic issue
  216. removing h22 tranny
  217. JDM B18C SiR-G Into EF
  218. d series swap help please???
  219. Quick Question
  220. h22a4 into ek civic...help
  221. Distributor clarification: Will it work or not?
  222. Crome tune for d16a6 mini-me
  223. b16b Map sensor
  224. h2b p28 best specs.....
  225. Will this work D15b2 pistons in D16a6 motor
  226. exhaust for gsr swapped ek
  227. D15 parts onto gsr
  228. Crankshaft/ rod combo
  229. h2b issue? maybe?
  230. Help needed badly
  231. y8 head on y5 block ???
  232. Ls/Vtec Turbo Build
  233. urgent!!!!!!!!!k20z3 into eg6 hatchback!
  234. Anyone by the name of Nell? That drives a Blue Civic Si?
  235. b20 vtec which power steering bracket?
  236. k20a or b18c type r swap
  237. Euro-R IM fitment issues in EG/DC chassis
  238. Qsd kit anyone!!!????
  239. b18c1 into 98 EK wiring harness?
  240. B16/gsr head gasket?
  241. help with obd1 h22a into a dc
  242. HELP: F20c Into Civic or EK
  243. Need Help: Obd2 D15B 3 stage vtec in 98 EX
  244. ls vtec cam seal leak cant stop it
  245. Hydro to Cable, which bracket works?(pics)
  246. Cheapest Set of Mounts...
  247. ls vtec base map
  248. Half man half machine! Well almost OBD0&OBD1 mixup
  249. Here's something different: D/B Tranny Hybrid?
  250. h2b mount kit??
