PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. PLEASE look/help!! I've been searching for a half hour! Registration ?....
  2. need HELP jdmb18c-5 in gsr, having problems with IAT and TPS, check engine lights
  3. Any K20 Hybrid running the Toda N2 kit?
  4. b18c-R LS
  5. Press Release: Hasport K-series swap header
  6. Companies that ship motors
  7. h22a into 92 accord PROBLEMS
  8. JDM B18c into Canadian EG Si questions
  9. acura mtors in civics
  10. Swap pics
  11. H22 Civic $8400 FOR SALE
  12. crvtec vtec problems
  13. Would a manual hx motor work in my auto ex?
  14. ek with ls swap(need help)
  15. D16Y7 to B16A1 information.
  16. Building b18c5, which fuel pump?
  17. type R into EG question
  18. does a 96- 97 USDM B18C5 motor have a final drive?
  19. weird h22a explosion
  20. crvtec gap settings?
  21. H22a with p28 in 98-02 Accord
  22. Wiring - Is this an OBD2 V1 or V2 loom??
  23. Help with wiring!!
  24. Engine starting to surge
  25. Del sol Si
  26. 90 crx si b16a
  27. Manual VTEC
  28. JDM itr header with stock si exhaust will it fit right??
  29. which water pump !??!?
  30. american speed center- york P.A. anyone deal with them??
  31. K24(TSx Engine), or k20a type-r for my turbo integra?
  32. h22 pistons wut should i get
  33. Getting a 1999 EX Civic Coupe but don't know what swap to get.
  34. obd1 LS swap into obd2 EK...Let me get this straight. help plz
  35. D16y8 help please? What is this hose for?
  36. Please help.... JDM Distributor
  37. h22 ek problem
  38. need help on which is a better engine to get for 97 civic ex
  39. Water Temp sensor necessary on GSR?
  40. need help with a b18c1 swap
  41. GSR Question
  42. anyone have pics of cutom top radiator brackets for integra dual core full lenth rad into cx civic
  43. h22a iab help.
  44. FUEL PUmp Model NUmbers need some help!
  45. 2000 si swap into eg
  46. H22A PISTONS need ADVICE
  47. 94 LS IN A 97 CIVIC DX PLEASE H!!!
  48. CA Cars with swaps or turbo. Emissions ? and CARB/ BAR ? Curious to see whats up?
  49. 97 integra with H22a4 swap, state ref pass with BAR?
  50. 93 Civic Hatch-B20 Vtec-Del Sol Tranny-92 GSR front brakes...what CV driveshaft
  51. Obd2 LS + EF Sedan
  52. JDM B18C Wiring Harness
  53. Can a 92 Integra be converted to use a hydro transmission?
  54. 89 S1 tranny on B16A in a 92 integra...what clutch?
  55. automatic to manual
  56. JDM Engines
  57. which obdI ecu for a B18C-R
  58. 1990 civic 4 door inexpensive swap? d15 vtec?
  59. problem wit gs-r in ej1
  60. Question about Radiator before / after swap
  61. 88 CRX B18c w/USDM Type R tranny
  62. Where to buy B18B Half Shaft?
  63. how do I know if its a B18C JDM?
  64. FAST help please
  65. Jdm Engine swap legal?
  66. EH Proportioning valve with ITR brake setup...
  67. H22 into Accord-dizzy wiring problems
  68. Help!
  69. P13 ECU Bad What to use now
  70. Turbocharging
  71. LS/Vtec vs. B20/Vtec?
  72. HELP..........H22 accord issue: strange check engine light and start problem
  73. K20/K24 Swap Parts List Total cost: $2800 (See Inside)
  74. Rear engine mount doesn't fit?!?!
  75. question what is this on type R manifold
  76. v6 swap for v4?
  77. not a smart move
  78. H22a No Spark...
  79. H22 w/ LSD Axles Question
  80. 2.0 GSR or b20 bottom end?
  81. b16 in to EG shift linkage
  82. ls/vtec in 98 ek hatch
  83. H22 Ported head question and TURBO ?
  84. crx build for turbo
  85. P54 del sol AC bracket
  86. obd0 b18a1 into EG
  87. Car dies after fueling up??????
  88. shipping costs on complete motor swap
  89. usdm GSR SWAP jdm GSR SWAP
  90. tuner shops near nashville
  91. b16 in to EG axle problem
  92. B18B into Del Sol - Throttle Cable Question
  93. GSR w/ls crank or LS/vtec
  94. Are these CTR CAMS?
  95. OBD2B to OBD2a
  96. obd1 harness dizzy plug...but have an obd2 dizzy???searched found nothing
  97. Car dies
  98. jdm motor!!! us or jdm ecu?!?!?!?!?!? help!
  99. nasty rattle!!
  100. Brake line (hard line in engine bay) leaking...help
  101. Hasport Instructions
  102. 87 Si w/ B20BVTEC wiring harness "SWAP"
  103. Looking for a complete GSR\b16a head
  104. chipped ecu dilemma
  105. CEL no V TEC any relation?
  106. Building the Ultimate b20/vtec.
  107. d16y7 into obd1 EG HELP!
  108. ********Problem with swap******
  109. AXLE PROBLEMS
  110. Supercharger and horsepower????
  111. obd0 harness on obd1 engine?
  112. Radiator hose for EK swap?
  113. Help!!!! 92 civic VX o2 sensor wiring for b17 swap. HELP ME PLEASE>
  114. Civic Knuckle + Integra Calipers = Happy?
  115. 92' accord coupe lx jdm h22a swap
  116. CEL problem
  117. Smoke from Intake
  118. Pictures of a B16 Swap In a 1965-1970s Mini Cooper
  119. The beginning of the SWAP GUIDE that I haven't quite finished.... good tips for newbs
  120. Accord won't rev past 2k
  121. h22 oil pan hanging to low...
  122. ek9 with h22 swap dash board lighting problems
  123. post pics
  124. dizzy wiring....
  125. what wire 2 where.. alternater
  126. No presure in the clutch pedal after completing swap?
  127. b18c5 in 5 gen civic help
  128. EF Guys?
  129. 00 SI shocks on DC2 (95 Integra)??
  130. NEED:bay area shop to install h22 into 95 gsr
  131. h22 with f23 trans ?
  132. A few questions about GSR into EK swap...YES I'VE SEARCHED....
  133. civic w/B18C5 need help!!!!!!!!!
  134. 1st GEN PRELUDE ENGINE SWAP
  135. clutch pedal noise
  136. H22 Turbo! Too good to be true?
  137. j-spec h22 type-s in a 1990 accord
  138. Check Engine Light - Code 17, VSS
  139. Compression Tested my H22...
  140. H22 Integra (eg) Axle Question / Problem ~Very unique problem~
  141. best setup for dohc vtec
  142. 89 hf w/b16a wont start!
  143. h22 hatch handling
  144. Newbie Question about stolen motors.
  145. Long Term H22 EG/EK???
  146. need help with field install on 99 civic d16y8
  147. Type R 5 lug swap
  148. for everyone with ls/vtec
  149. need info for engine swap ASAP
  150. y is h22 so cheap?
  151. OBD2 B20 into an OBD1 94 Integra
  152. what radiator are you running with your H22 EG?
  153. How to wire secondary O2 sensor?
  154. Caterham S2000
  155. H22A ????
  156. Where To Buy?
  157. Bosch O2 sensors????
  158. D16y8 swap having some problems
  159. ZC motor for 86 crx swap
  160. o2 sensor mistake!?
  161. TB question for all the LS/Vtec owners out there
  162. type-r j-spec in a 1990 accord
  163. JDM B18C into UK VTi (EK civic)
  164. H22 Vid.....
  165. B16A2 - B18C1 questions (sleeve, pistons, compression, rods)
  166. Prelude Injectors and Integra Fuel Rail
  167. ITR Swap or Ls/Vtech Swap in 92-95 Civic Ex
  168. Problems with B16 swap in DA9
  169. RPM JUMPING...
  170. HELP!!! CODE 22...
  171. Can you change gears/diff's from a hydro tranny into a cable tranny?
  172. How do I know if I have an integra cat or civic cat??
  173. having problems with swap (99Si B16A2 into 96 coupe euro spec)
  174. LSVTEC Begining Questions
  175. MPFI help PLEASE!!
  176. Auto to Manual transmission swap
  177. HELP ME PLEASE!
  178. h22 civic or crx?
  179. why?
  180. f23(h23) swap into 96 civic, injector/ resister ????
  181. suggested spring rates with H22 EG.
  182. Hey 4 door swappers!
  183. getting pistons off rods
  184. Question about guages.
  185. need help....
  186. Cylinder 4 misfiring. Help please...!
  187. B20 ECU problems!
  188. H22 with hytech header...o2 problem
  189. crazy engine swap idea...
  190. Help me identify this header (possible h22 in civic header)
  191. Question: Swap a B-series in a EG, ILLEGAL? OPTIONS?
  192. 89 CRX Si wiring problems need help.
  193. H22 EG's with DSS Axles Step In
  194. D16 or D15 w/ z6 head mini me? which would be better?
  195. throttle cable help! please
  196. Tranny Model on a 94-01 Gsr and LS?
  197. hondata ?
  198. OBD2 Distributor
  199. TP sensor ?
  200. hard to shift into 4th
  201. Car won't start redlines early
  202. ls / b20 what is best
  203. idle surge on h22 in civic vx
  204. HELP!!!!!!!!!!!!
  205. Water Temp Guage
  206. WHAT IS A GOOD BRAND OF ADJ SHOCKS FOR EK9 HATCH W/ B18C1?
  207. J-Spec ITR Swap in 92-95 Ex Civic.....Helpful hints needed please...
  208. prelude injectors specs and howto!?
  209. itr JDM tranny
  210. 96-98 Civic EX harness question
  211. k20 into new Fit?
  212. B16A2 swap into 92 hatch, simple question....
  213. D15B swap won't start.... (Pics 56k may not be worth it)
  214. Need help with b16 swap
  215. Swapping B16 from 94 EG ---> 91 DA ???
  216. shaking after 15 mph
  217. ITR diff in B16 transmission... Did search already
  218. auto to manual Integra Question????????????????
  219. what 1/4 mile times to expect with an h22a in a ek hatch
  220. p72 question
  221. ls/vtec question
  222. Quick questions about OBD1 engine into OBD0 car!
  223. Converting to a b16a but need help
  224. b20vtec, help clarify some of the myths.
  225. Clutch Concern
  226. K20 ITR VS. B18CR ITR SWAP
  227. H22a4 HELLP!
  228. Car dies as soon as i turn it on.. Fuel pressure related?
  229. any K20 EG videos ??
  230. h23/f22
  231. HELP!!! electrical help with speedometer!!
  232. Question about prelude h22 and h23 intermediate shafts?!?!?
  233. Skunk 2 manifold in Accord/H22 HELP!!!!!!!!!!!!!!!!!!!!
  234. Good deals or no deals????
  235. Power Steering Bracket LS/Vtec swap
  236. turbo h23 eg??
  237. bad prelude IACV!
  238. EK K20A belt problem......
  239. King Motorsports Announces Hasport as Associate Sponsor for Road America World Challenge Effort
  240. ECU REMAPPING?!? NO VTEC!!!! HELP!!!
  241. K20A2 swap
  242. Tranny Gears
  243. JDM 96 ITR Brakes - I need some information!
  244. b18c into 97civic ex mount guestions?
  245. egr lift sensor
  246. will jdm itr axles fit on my ej1?
  247. gsr swap into 90 hatch or ls/vtec
  248. AIB question ?
  249. h22 swap having problems
  250. Vtec and SI
