PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. d15z7 (3-stage VTEC) into 91 honda civic hatchback (d15b2)
  2. B20b with gsr head overheating when sitting at idle with A/C on
  3. CIVIC EG SWAP HELP
  4. B16B into 97 DX - question on a couple sensors
  5. d16y7 to d16y2
  6. Can you use an AWD transmission for a FWD build?
  7. beginner k24a engine swap
  8. Turbo G23
  9. h2b crank pulley options
  10. Integra with a NSX motor FWD
  11. Ckf bypass issues
  12. F22b1 with h22a head but im stuck i need some advice.
  13. f23a1 swap in 2000 civic problems
  14. Honda and Acura
  15. Help need guidance
  16. 98 Civic Coupe H22A Engine Swap
  17. fuel injectors
  18. K24 ecu choice
  19. Engine Swap
  20. 93 Del sol with f20b low compression Cylinder 4
  21. Need help my 95 eg coupe wont crank or start its a b18b1 swap
  22. cv axle help
  23. D15B7 Head on D16Y5 Block (93 Civic DX)
  24. B18/16b1 Non-Vtec Turbo. An F1 tribute
  25. 1991 Civic Si to B series
  26. B18 to B20 96 Civic EX
  27. D16Z6 Swap - What is Compatible Alternative
  28. B20 swap
  29. B20 96 civic swap, o2 help
  30. Nseries engine in hatch
  31. Fuel injectors not firing, but have power.
  32. Help what is this 99 civic/ b20vtec
  33. D16A1 swap into '87 CRX
  34. LS/vtec
  35. 1987 D15A2 swap
  36. 2017 Civic si engine swap Into 2000 Civic
  37. Need help
  38. 2 issues. B20b nonvtec engine harness and wiring
  39. D13 to d15b non vtec
  40. Need help fast
  41. Vtec Bypass Trouble
  42. 99 B18C1 Swap Into 99 EK *BARD* Help
  43. 93 civic coupe gsr swap vtec trouble
  44. D16a6/z6 timing belt question
  45. Gsr swapping my sedan, First time swapping!! Advice?
  46. B16A 1st gen block swap
  47. Budget Build thread: V6 powered J-series 98 Acura EL sedan
  48. 93 Delsol B16b motor GSR tranny... axles, half shaft help??
  49. DelSol B16b with GSR tranny... axles? Halfshaft?
  50. Potential buy on a f20b teg, help!
  51. D15b/z6 question with misfire
  52. Honda B20 - 97 Civic - Vtec issue
  53. I am buy parts for k swaping my ek hatch and i need help.
  54. Please help... Question on ICM wiring
  55. Jdm D15b/Z6 head swap questions, need help!
  56. Which sparkplugs should I be using when swapping an engine
  57. Fresh built b16a2 head with b18c1 block won't start
  58. Rough Idle help on 2000 y7
  59. Going from b18b to b20z in a ef - HELP
  60. What is this part on my fuel rail called?
  61. b16/18 hybrid to b20 swap compatibility questions
  62. Check engine light problems and main harness
  63. Assistance needed B16A1 into 93 EX coupe
  64. B20v Weird Idle Issues
  65. Obd2 b18 into obd1 civic
  66. B18B1/B20 HELP
  67. EK with B18C1 - leaking Vtec Solenoid *HELP*
  68. 1986 crx b20b wiring harness help
  69. Will a B18b1 with b20 head pass smog?
  70. Please Help H23A Vtec blue top swap ek broken AXLES!
  71. 95 honda civic getting either no gas or no something
  72. H22 swap into del sol
  73. JDM B20 IACV - No coolant lines???
  74. D15b2 to d16z6 head swal
  75. Can H2B be run in an ED/EF with a timing belt cover?
  76. Looking to build a N/A G22/3 build, help !
  77. Different size oil filters for same motor?
  78. B20 harness on a b16a2
  79. F2B F20b into a 96 integra gsr
  80. B20 vtec swap
  81. 92-00 Civic Alternator in a NON-ECU Vehicle
  82. Swapped z6 with a y7 and have crank no start
  83. Crazy thought - K2X RWD DCT / DSG
  84. Help, I wanna swap it
  85. No vtec swap b16a2
  86. B18b b20b Automatic 96-00 Civic swap help
  87. Assistance needed: Automatic Turbo D-series using obd2 to obd1 jumper harness
  88. D16y7 Swap Options
  89. 94 coupe b18 auto to manual swap high jumpy idle
  90. Eg hatch w/ b20b sat for 3 years.
  91. D non V-tec to D V-tec swap
  92. Ef b20b obd1 intermittent inoperative fans/misfire
  93. H22 Swapped Del Sol Squealing Issues/Check Engine Light in 5th gear
  94. How much to sell B18c1 swap, and what parts to keep??
  95. H23A Parts questions
  96. F20A4 jumping rpm
  97. Help j37 misfire
  98. 97 honda accord f23a swap
  99. LSVTEC ECU&Wiring Asking for feedback
  100. B18a1 swap won’t start.
  101. Big problems 98 Civic w/ B16A swap - Wiring nightmare
  102. 32mm ends on k24 36mm axles?? Is it possible??
  103. B16A2 swap in my ej9 civic
  104. 94 B18b1 swap into 95 civic
  105. B18 help
  106. B18 fluctuating rpm
  107. B18c1 emission problems (California)
  108. Help!! 99 Ex coupe H23A
  109. D16Y5 EG Swap “ help if i do sth wrong”
  110. 93’ Accord K24 Swap Pittsburgh, PA
  111. K20 rods in j32
  112. 98 Acura el jdm B20B
  113. GSR Swap Reading Code Blinks (video included)
  114. '95 Civic Hatchback Build- Completing the Plan
  115. 1995 Civic Motor Swap
  116. H2b with a h22a4
  117. Which exhaust is best for the b18b1 in a 95 civic
  118. K24A3 swap into 2002 crv
  119. Need help with AF ratio guage
  120. Re: wiring harness question - obd conversion question
  121. Honda Civic 1979 engine swap fuel system issue
  122. b18b1 swap which radiator hoses to use?
  123. Fast knock with slow throttle and poor performance
  124. Knockoff Tomei pressure gauge - Will it leak gas when it fails?
  125. 94 Civic si from LS to GSR
  126. Swap help
  127. EK LS swap P28 issues
  128. 98 integra ls swap in 97 civic ek?
  129. B20b non-VTEC(from CRV Gen 1) or D15B mini
  130. helpp!!
  131. PP Throttle Body vs. Blox Throttle Body
  132. 97 accord F20b swap NO acceleration- Need honda wizard!
  133. H22 swap eg
  134. Ek with b series swap intake
  135. B20b swap won’t start eg hatch
  136. Vtec and oil pressure switch wiring
  137. OBD! B18b1 engine wiring harness.
  138. Jdm B20B in 97 CRV
  139. Why does the JDM PS pump spin so much faster than the USDM Pump?
  140. Cabin noise after TB replacement
  141. B16 HEAD & B18B1 BLOCK
  142. Auto repair shop
  143. auto repair shop
  144. D15b1 to d16y8 swap one 90 civic hatchback
  145. B20z harness~obd2b connector not the same, PLEASE HELP
  146. Getting the Correct K-swap Engine Harness
  147. 92 H22a correct Oil Orifices Location?
  148. F23a1 automatic swap in to eg 94
  149. EG K24A swap idle fluctuate
  150. 5V Power Reads High (Please help!)
  151. 2000 Civic Si LS Vtec component identification help
  152. 1991 EF sedan/B20B SWAP???
  153. 2 bolt mount to 3 bolt mount d series
  154. Ignition problem
  155. HELP WITH POWER STEERING
  156. 96 Honda Civic
  157. I want to swap my stock 91 dx automatic into a manual
  158. F20B Auto/Manual Cam Swap?
  159. 97 CX LSV, B20 IACV
  160. Skunk2 ultra street intake fitment K24 CRX?
  161. b18b swap in a 96 auto hatch problem
  162. 93 ex with d16y8 swap already want to swap to b20b
  163. K24A w/ 2012+ Si trans in 89 CRX HF general questions/advice, trying to order parts
  164. Can you switch a k4f trans back to speedo cable?
  165. H2b best subframe
  166. Parts list for b20 into an ek. Sharable doc. Comments welcome
  167. Why am I not seeing any newer civics being swapped?
  168. 91 DX hatch, B16A, high idle/rich AFR
  169. Identifying plug?
  170. Check engine light won't flash to get code
  171. Obd1 auto f2d plate less
  172. H2b Ecu
  173. I have a 98 CRV auto awd(soon to electric assisted) nd need some questions answered.
  174. b16a block with gsr head help plz
  175. B-Series Engine Swap
  176. D16Y8 swap
  177. H22 in 00 cx hatchback
  178. Help with my main harness
  179. Swapping d15z6 into d16a6 chassis
  180. Honda Fiat swap
  181. H22a4 Atts swap into 98 civic Ex (EK)
  182. 1998 civic ek hatch DX
  183. Troubleshooting: H2B transmission location placement issue
  184. Mechanical Timing Help On B-Series USDM JDM hybrid
  185. H22a4 in Eg Hatch?
  186. Physical measurements for J30A4?
  187. 98 dx hatch with b16a swap
  188. Civic Thinks It’s In Gear
  189. EK hatch Engine swap harness install.
  190. Missing connector's
  191. H2b
  192. D-Series in a 1968 Riley Elf
  193. B16A2 block/head year
  194. is the CRV block bracket required for a k24 ek swap?
  195. Help with transmission mount
  196. b16 trans swap help please
  197. Dim battery light
  198. Help with wire harness
  199. Mysterious Japanese sticker on JDM B16a (first gen) spark plug cover
  200. Replacement Dizzy Problems
  201. Obd2b on an obd2a engine with obd1 ecu
  202. H22a swapped Eg injector question
  203. D16y7 in OBD-0 91 Hatch
  204. GSR oil pan swap
  205. Having hard cold start problems on a jdm swap b20b
  206. Anyone Running GM RWD Auto transmission Behind a J35?
  207. Help!: 95 eg h swap axle question
  208. any modification needed to use k20z3 trans in EK swap?
  209. b20v in ef hatch
  210. Swap into a 1993 Civic EG
  211. HELP: 91 civic hatch swap
  212. Any one in NJ that can help d16a6 wiring
  213. Dizzy option?
  214. EG K-Swap no power to ECU/Fuel Pump
  215. What axles do I need?
  216. D16 head zc block mini me:) send help
  217. GSR Swap Help!!!
  218. JDM 3 Stage VTEC & USDM y8 engine harness! what a mess???
  219. B18a1 from a 91 Integra swap help please
  220. B series frankinstein turbo build
  221. Help with a 1994 Honda Accord with an f20b swap
  222. Need help with engine swap
  223. Anybody that did a DA swap out there?
  224. Just a little experiment F22A6/F22B2 SOHC blocks to B20Z1 DOHC head PPA-2
  225. 93 del sol s. K swap vs b swap
  226. Making harness standalone
  227. Feels like you guys are my last hope B20Vtec
  228. parts from ep3 for eg k swap
  229. '99 B20B Hi compression swap( No Spark issues)
  230. P72 fuel pump issue.
  231. Swap options for factory J-series
  232. Help fixing CEL 22 vtec swap into non vtec car...
  233. What’s been done to my ECU? P06-A52
  234. b18c1 turbo build..right place?
  235. Swapped D16y7 distributor problem (not the usual ones)
  236. f20B manual 5sp into a 4th gen prelude
  237. Y7/y8 questions...
  238. J32A2 Swap No Spark
  239. Ls/vtec no spark
  240. B20z swap [HELP]
  241. B20 into a 2000 civic ex
  242. GS-R swap in civic smog issue NOx
  243. F23A Plateless F2B EG Sedan
  244. K24A8 from Accord PnP with Element?
  245. Crazy classic Austin Mini D16
  246. G22 Swap Tuning Help
  247. Eg b16 swap need help please
  248. Tachometer from a 3 cylinder insight for a 4 cylinder
  249. 200 Honda Civic si gsr swap
  250. 2000 Civic with a b18c swap. Overheating issue
