View Full Version : Hybrid / Engine Swaps
- before an engine swap???
- b16 head on GSR block
- Planning stages of swap.
- Has anyone dealt with redlinemotor.com?
- is it a lot easier swappin in a b16 into a vtec car than a nonvtec car?
- LS/Turbo in CRX...
- tips for passign smog in cali
- jdmclub.com
- 95 Civic Hatch Automatic to Manual changeover
- Need parts (JDM type R, Mugen, Spoon, DC sports, AEM, VOLK,....) LOOK!!!!!!!!!!!!!!
- B16A4 SiR swap
- What poblems would there be with an h22 in a crx?
- DON'T BUY FROM SCOTT@PARTSHAGGLER.COM
- Putting an H22 in EG Civic EX
- SoCal Meet This Sunday!
- What is the correct offset and lug-nut distance for a 17inch rim on a 92 civic HB??
- What Gen./Trim level Civic Master Clutch Cylinder and Pedal Assy, will fit a 6th Gen EX?
- Swapping a b18c1 or b18c5 into a 00 ek engine bay. what engine/tranny mounts do i use?
- ti bick here
- will my tranny work with an h22?
- H22a integra, which springs to use?
- H22/integra
- Swap help.
- header question
- 94 Integra B18C Swap with bad ass pics\
- Just bought a 96 hatch...
- 95 b18b into a CRX...HELP
- Valve adjustment specs on 97 b18b LS
- AC on 4th gen hybrid Accords?
- Stock rods w/ARP VS Aftermarket
- 92 Accord w/ H22A?
- How to set idle on 1st Gen b16a
- Suggestions for b18c1 engine mods?
- ATS 4.929 final drive question...
- Cable Trannys
- Acceleration
- HP loss
- B18C1, very slow?
- Header Question
- engine check light after b20b/vtec conversion. HELP
- Question bout S1 tranny
- Tomorrow is Dyno Day..
- Wiring question for a B18C...
- Header HELP!
- F20B DOHC in an Integra?
- WARNING!!!!!!! DO NOT DEAL WITH.....
- stock ls pistons in ls/vtec, any clearance problems??
- Yeah so Im a dumbass....
- has anyone put piston oil squirters in ls block for ls/vtec
- Need an answer for my civic JDM swap
- Cheapest Place to Find b18c1?
- Anyone in DFW free to help me with my LS crx swap???
- engine mounts
- ITR throttle body on a GSR Skunk2 manifold?
- Needed: Oxygen Plug
- GSR and bore or B20?
- H22/Civic Question
- B18C1 Overheating problems
- 1st gen b16
- New site up....check it
- Engine swap information/literature/websites?
- VIN NUMBER!!!!!!!
- buying a used hyrbid?
- H22A and a civic hatch (please help)
- exedy clutch..which one is for 1st gen b16?
- HELP: Can't find the IAB (Pink/Blue wire) HELP
- H22A Help
- just blow my c5 engine turbo
- my new b16 eg
- Any difference between 00 Si and GSR fuel pumps??
- has anyone bought an ecu chip from "eg6ajk"?n/m
- does anyone know the 4 digit part # for BKR7E-N-11? n/m
- DO NOT BUY FROM JSPEC ENGINES!!!
- thin fans for GSR radiator in an EG
- ATTN: Katman b17 questions??????????
- mild b20 questions...
- H22A 1996 auto ECU Search
- oil pump replacement
- Motor mount suggestions?
- Fast idle thermo valve??
- Upgrade Engineering?????????????has anyone heard of them(So. Cali.)
- B18C Swap
- Help, No reverse Lights.
- Intake Question.
- I Need a B Series Tranny and Axles in TX
- Need Two Parts for ls swap
- increasing displacment
- 5 Lug Conversion Comparo: CTR Vs. ITR... What are the differences?
- distrubitor application.
- what kind of engine should i go for?
- where's www.b-20.net gone ?
- B18c into EG coupe
- SKUNK 2 cams any good?
- zexkit question
- Recomended cam springs with CTR cams in a B16a? Couple other question too...
- CX fuel pump on B-series motor?
- Can a CRX do this:
- 12 second civic thread
- Questions about the H22
- GSR rear swaybar on 92vx question...already did a search
- Just got MY 91 Civic .....dx...... Can someone..... give me any info.....im trying to do a B18c1 sw
- wiring for h22 into 95 LS
- place racing crossmember?
- SWAP SHOPINGLIST NEEDED.....
- 1985 AWD Civic wagon head question
- JDM B18C (GSR) or B18B w/ vtech head (Frankenstein)
- Y1 axle ?
- What's the recommand setup for B20/VTEC?
- JDM Wiring.
- Need some EF head swap help please ...
- b18c into a EK
- what can i do to make a 91 rs do 200whp NA?
- axle problems "need help asap"
- CRVTec mounts
- which intake to get?
- Wiring Question....Am I Screwed???
- anyone done a h22a swap into a 6th gen civic coupe ??
- Intgra LS engine B18
- opinions on garage kwai????
- CRVTEC owners w/ITR cams what's your cam settings
- LS/VTEC buildup questions...
- does anyone have thier old head off of their 92-95 cx???
- Need AC Bracket like yesterday
- B16 Axles, and intermediate shaft which works?
- Do u need to up grade valve springs or retainers to run high compression pistons??
- my new type-r motor
- How much would you pay for B20 long block?
- Help with wiring...EG with B18c1 odb2
- Quick Question
- master cyl. swap for EG
- b20 block w/ cable tranny on crx..possible?
- auto b18a to Manual????
- Sleeving...
- Axles to swap b16a?
- Wiring Question
- Gsr t/b on a sohc
- anyone seen this??
- HELP with B16a2 in 92 hatch...
- $$$ in your hybrids?
- b18b VS. B16a2 ????
- Ordered my motor and startedpulling the stock one.
- 1'st gen integra motor in a 92-95 hatch??
- OBD-I and OBD-II questions.. help.
- How much???
- Rear Stiff mount.....
- ITR internals in a 94 LS?????
- Ls/Vtec Question Please READ!!!!!!!!!
- Desperately need wiring diagram for JDM B16B CTR engine! heeeelp!!
- anyone in TX have a B series tranny they can spare???
- H22 mount kit
- Radiator for an EG6 with a B18C5 Swap
- jdm b18cR longblock Q's: What if I was gonna do a swap into a crx? No intake manifold...
- EG rear engine mount
- Anyone from TX do an LS swap in a CRX si???
- Going CRVTEC....what cams should I get?
- Need Help ASAP!! 5-lug conversion to EK (Master Cylinder questions)
- Riceboy 1/4 mile question...
- Need a ZC in NJ
- OBDII to OBDI wirign
- What trim level?
- Fuel pressure on D16Z6???
- Mount Question: read something I want verified
- Where can i buy ctr piston rings?
- Header Question
- does anyone have thier old engine???
- CALI HYBRIDS: GOOD AND BAD
- CX with 4 wire o2 sensor?
- H22a into civic 94 civic Coupe
- ghetto drop!
- how do you id a tranny if the tranny code label is missing?
- CX to EX
- CODE?
- Need help wiring a 00 nonvtec sohc harness for a 96 JDM b16 motor (obd2?)
- Does civic EG fuel line from fuel filter fit GSR fuel rail?
- GSR Header on an LS???
- B18C1 into 6th Gen. Civic, transmission-side motor mount query.
- will hasport b16 mounts work on ls/vtec with y1 trans in crx?
- JDM wiring....again...
- prelude engine in '95 accord
- zex install need help
- JDM B16 VS B18C1
- Are the .2 extra liters worth the money...?
- Import Builders Package 2 Motor
- TX people...Where's your old motor???
- H22 in 94-97 accord
- B20Z or B16A?
- FS: B18B short block for sale.. $400
- how much is my motor worth, i want to sell!?
- Classified source for hybrid projects and other various projects
- k series motors and hybrid.
- i need a motor within a week
- jdmclub a reliable source?
- torque specs for B18c1 or 5 main bearing...need ASAP
- Does anyone know if a JDM ecu and wire harness for a Dohc Vtec will fit on a civic non vtec sohc.
- How do i tell if my new motor is really JDM??
- Power and Torque from this set up?
- ECU safe mode?
- Been waiting for a month
- Need your opinion - Honda 92 civic hatchback and a gsr
- Hybrid and Emission testing.
- 88-91 civic si seats in ek
- Can I keep air in a 99-00 Hatch
- what compression with jdm b16 pistons in ls/vtec?
- B20 block! how much would this cost? whats the general price to swap a bottem end..
- need info on 'honda graveyard' in SoCal
- how fast would a B20 w/ B16a head be in a 95 civic coupe?
- JDM b16a to us wiring.
- Question about shift linkage
- Need help with b18 ECUs
- will 98itr ecu fit 99/00 si harness
- want to rebuild my 94 ls teg with 120k miles for a turbo
- Stage two: What to do next.....?
- Questions on an LS swap
- possible to put a 1990 Si motor into my 92 EG cx?
- JDM Trannys
- B16a2 Question
- seperate or complete change over???
- JDM ITR 4x110 conversion
- B20 block availibility and Price
- Need some wiring diagrams.
- B18C5 Head on GSR bottom
- Good price?? Opinions please
- Do GSR calipers fit on 92-95 Ex rotors??
- Logical 6th gen Civic Swap
- trans. for D16Y8 EF swap
- wet or dry nitrous for turbo?
- ls/vtec auction...can i get some opinions on it?
- Lifting engine and tranny by the intake manifold???
- 92 CIVIC HB Automatic trans to Integra GSR Manual swap
- engine swizap
- What else do I need for b18c swap? Please help
- 9o integ rs should I convert to LS/VTEC
- i ahve a 94 ls with 110k miles on it what now??????
- B18C1 into 91 HB: Why or Why not?
- Engine
- JDM 1 Engine questions
- H22A into a 95 Accord EX (SOHC VTEC)
- b18c5 into 90 crx si...what parts do i need?
- GSR into EG
- What car and what engine should I get
- Why hatchback?
- What is the highest RPM i can run a JDM GSR engine on all stock internals?
- P72 head on a B16A block?
- RSX engine in a 94 teg
- On gsr bottom/b16 head swap ...best ecu gsr or p28????(both chipped)
- Post pics of your eg's with rota slipstreams!!
- differences b/w B18a and b18b as far as wiring the ECU
- ls in eg?
- JDM H22a people... ignition question
- B16A Fuel pressure, Tranny fluid, and a hybrid hybrid.
