View Full Version : Hybrid / Engine Swaps
- CX to a DX swap quetions
- Obd2 to Obd1 conversion HELP! Q's
- Need help on my 5 lug!
- 1999 civic hatchback exhaust w/ ls swap
- Best H22a Civic header?
- Anyone have problems with the hasport cable to hydro clutch conversion kit?
- H22 rear mount bracket EG Civic?
- Best place to get wiring harness coverted for h22 swap..
- Whats is a good price for an H22a install into Civic?
- car wont start, 94 hatch w/ gsr swap!!!!!!!
- gsr swap into a g2 teg rear mount wont fit
- manual vs. auto ecu
- jdm b18c in 99 ek.... no tach signal
- PR3 ECU with 99 GSR top end ...not getting vtec to engage
- Update* 92 vx / 95 b18c1... Now more problems!
- swap is in.... need help with problems
- Could a bad VTEC solenoid / oil pressure switch cause...
- b16 tranny on LS motor. . pros and cons?
- battery doesnt fit with b16/ef swap.....now with pictures
- what octane gas for an ef/b16 swap?
- anyone used an hcp ef18 a/c bracket?
- fuel pressure
- OBD1 injector pin swap/removal-How-to
- yel/blk wire b18c1 into cx
- pics of my base rsx with k20a2
- i know theres been a million b20 questions but
- Egine swap
- 92 cx harness with LS swap, O2 sensor different
- How to make GSR AEM intake fit Skunk2 Manifold
- OBD2 Gurus: Convertion ?'s for JDM ITR engine to USDM OBD2a. Help
- h22 swap in eg
- Where to buy caps?
- h22 civic dyno numbers
- all pr4 ecu's the same?
- Need to change complete rear and front suspension (Please Rear)
- what does your type r tranny say s80 or s8c ?
- Which IMs fit a GSR head?
- parts list?
- idle air control
- Hasport or HCP
- B16a into CTR???
- h22 in accord CEL 17 vss please help popped up on freeway
- 91 LS swap into 94civicex
- rebuilding bottom end
- Swap'd h22 into 4th gen Accord, now tach doesn't work?
- Ecu codes help
- green sticker on tranny
- h22a usdm wiring question
- wiring - 92dx
- will a OBD I ecu work w/ an OBD 2 dizzy??
- sites for info on B20 swaps
- AF gauge install help! NOW!!!
- lsvtec into an ek - which shift linkage???
- where to get a jdm h22a type s with lsd 5 speed ?
- B18 Swap Questions...
- ITR and GS/GSR knuckle/hub compatability
- tranny problem
- vx wiring question
- Transmission Question
- Got the pins out of OBD0 injen clips!
- b16/ef swap no fuel
- Help! Mid shaft removal question.
- F/H series fuel pumps, same flow?
- got the h22 running in the accord
- mini me swap questions?
- engine swap question
- best swap?
- answer my quick question please
- Weak feeling vtec
- place racing mounts
- d15b vtec startup help!
- B16a2 and B18b1 parts swap
- B18c into EK: clutch line won't reach....???
- anybody out there have a receipt for a baker battery?
- ECU with a Z6 in a DX????
- Strut bars and exhaust
- Integra/Civic Dash conversion interior arrows/headlights on
- Anyone seen B16 swap in to 7gen EP?
- sick and tired of red lights????
- should I get an h22 engine or turbo for my del sol
- torque spec for b18A1 clutch pressure plate
- b18c eg coupe
- your first swap
- car shut off when I turn on AC
- B16A Swap problems/ questions HELP!
- 95 h22 JDM Distributor wiring into a 92 honda accord
- CKF plug
- Which CAI???
- LS to GSR gauge cluster
- how much does it cost for you guys to convert everything to usdm and pass cali ref?
- problem with my swap (b18c into civic)
- difference between b18a and b?
- Which pins on integra engine harness lead to the IACV? A12 and what else?
- Type R swap and starting up
- tapping sound in H22
- Overfueling my D15B7?
- surging idle and bucking throttle after swap in EK
- carb to fuel injection conversion
- "We got a red hatch down"...
- b16 into 98dx issues
- b18c into 99 ek... still can't figure this out
- hybrid theory
- dpfi to mpfi with an si engine harness and dx cabin harness
- Update on project RB25-240sx
- braided brake lines?
- H22 OB1/ Integra wiring harness/ Coil no sparky
- B18B1 swap in 93' civic EX
- d15 bottom end with y8 head
- itr head into a ls engine
- na dyno tuning needed in az.
- B20 and B18B timing belt same?
- Value of B16 CRX Si (desc inside)
- b20b vs b18b in a 90 integ. suggestions?
- ANY ONE FROM LOS ANGELES????
- do i need motor mounts?
- obd1 P30 ecu questions
- OBD alternator differences
- need some info on JDM motor ASAP.. thanks a lot
- H22 Wiring
- i need help!!!!!!!!!!
- Shiftlinkage question
- Found idle problem!
- IAB/Knock Wiring
- just finished b18 eg... won't fire up!!
- Whats the best H22a Civic suspension setup?
- 2001 B20 to EG wiring problem, Need Help Please!
- 01 gsr swap into my 94 gsr
- HELP ME FIND A NEW MOTOR
- obdI b18c1 into 97 civic dx wiring
- ANY B20/VTEC'ERS GOT ?
- obd0 to obd1 conversion ?
- Can somebody do the swap for me in Orlando, FL??
- ??? For CA people.... 96 LS motor into 94 Civic... Do I need to keep it OBD2 for BAR Cert??
- dc2 H22A engine + passing ref questions
- Fuel Problem
- Help with swap PLEASE~ WIRING problems
- B series into 91 accord
- H22 shifter cables on 93 accord
- Best spark plugs for my b20z/b16vtec head setup?
- b18 into del sol
- crx hf or crx si and hf,which one is the lightes
- AEBS Head Stud Question
- h22 in Eg?
- h22 shifter cables
- sohc zc vtec
- Whats the Best stock B-series Cable tranny with lsd?
- My poor little D15B7
- need help what intake manifold gasket????
- Backfiring problem
- P13 WIRING DIAGRAMS
- does a b18c1 fit in a 98 hatch without replacing the motor mounts??
- AnyOne in HERE have a 96+ Civic with A H22 Motor????
- What OBD are these engine plugs?(Civic/Integra related)
- Integra LS ECU not working with LS swap in Civic with Si Harness????
- b16 tranny in b18 shell
- final help with wiring please
- Injector question
- ITR Stock Intake On D16Z6
- H22A1 ===> DA integra....
- WHY IS IT A POOR MAN'S "TYPE R" ???
- OT: whaddup from lackland afb
- B16A2 into 96 EX with 96 ex harness. what ecu to use?
- IAT Sensor Question
- b16a1 into 98dx hatch
- Happy New Years from Hybrid Racing
- if anyone knows wiring harnesses it would be you guys HELP !!
- secondaries opening early
- help with taking out abs brake system, in 94 integra LS
- Cold Air intake for 92 hatch w/ swap
- Distributor problems?
- 4g63 in eg6 :P I know what you guys are thinking...but advice please
- How do you put a h22 in a 97 Civic Hatchback?
- F20C in 98 integra
- NORTH END BLEW UP MY ENGINE
- VERY easy question, I just can remember.
- Which ECU do I Have?
- what would LS cams do to a B20?
- b18b question
- causes of worn/bad vavle stem seals
- 02 Pinout for ITR into EK
- EK/ITR hybrid---which cat length??
- b18c5 eg swap question?
- EG/B16 Swap Question
- b16 automatic into 98 ex civic
- crvtec info
- What powersteering pump and bracket do i need?????? (Please help)
- LSD Trans for D16Z6?
- the #'s on B20 nonvtec
- 90-93 integra suspension in my 91 crx? what do i need
- B18 into 2nd gen prelude
- how can you tell if a head has been milled?
- ITR into EG. Which ECU?
- O2 sensor swap question...
- will engine work without charcoal canister hooked up
- Q's about mini-me swap that I haven't found in searches....
- radiator
- help please: parts checklist for b18c into ej8 (ek)
- civic got jacked, need ultra techie assistance
- swap question-99-00 obd2b LS engine in a 1999 civic hatch..secondary o2 (wired?)
- OBD1 / OBDII swap questions
- b18 into a CRX?
- Header Heat shield Bolts?
- GSR swap w/turbo and P28 hondata into LS wiring question
- kindaO.T.,anybody got sr20det info?
- D16B swap to a ZC
- Another shift linakge question
- Which Carsound model # should I get???
- keep my C1 or go B20Vtec
- 92 h23 to 91 accord
- REPLACEMENT HCP MOUNT BUSHINGS FOR EK-22 (Part no. 2056)
- anyone dealt with 5150 autosports?
- Is my GSR slow or are Civic EX's just fast on take off???
- another swap in an ek
- are there any engine dealers that sale their motors with free shipping?
- pics of my swizaap, i need help asap please.
- 97 OBD2a B18 swap into a 99 OBD2b EK complete
- timing question
- GSR B18C1 Engine Value
- 92 civic CX USDM b18c1 to JDM h22 HELP
- LS FD and ITR LSD
- help out with my header collector size thread
- one more injector question
- h22 v tec head on h 23 ?
- need help w/Gsr in a Ek hatch
- Koyo Rad B18C EG What rad fan do I need?
- To those running a B18C1 EG/EH...
- lsvtec setup
- (did search) question about b20vtec
- h22a timing HELP!
- K series
- Poor Mans swap
- JDM H22 into USDM H22 Lude
- itr swap- ek vacuum ??
- swapping into 88 lude
- Z6 head
- Just purchased a DB1 Integra, what next besides the usual?
- Pm6 in a 90 integra?? Is this possible
- zc differences
- 88-91 b16 in 92-95 eg
- most ideal swap...
- obd2-->obd1 conversion can screw up your idle??
- Which belts should i use?
- 94 JDM GSR motor into EF Hesitates at times
- Mounting a d15(5th gen.) sohc vtec to dx(5th gen.) tranny?
- 00 p73 on my 99 si no worky
- Best swap/motor for my 89 accord?
- ok b series swaps into 92-95 civic. what do u all do about gap in exhaust?
- will 96 ls obd2 intake work on 94 obd1 motor
- is 5000$ a good deal?
- my b20 idles funny after going OBD1!
