View Full Version : Hybrid / Engine Swaps
- B20 Non-VTEC
- p28 reprogram for b18c1
- A little blue smoke from exhaust...don't say piston rings!!!
- crvtec oil pressure
- Need help wiring B18C1 into 93 Vx hatch!!
- Handling Characteristics for Hybrid CRX
- A/C system disconnected...info on recharge
- a little wiring help for a 1st gen b16 in a DA teg.
- question about flywheel.
- b18b n/a in a 92 cx stupid or smart???
- b16 in crx, ignition timing questions
- B18b obd-1 or obd-2
- automatic to manual conversion
- gsr in a 4gen hatch
- I'm about ready to cry over my B18C swap...
- B16a swap into 91 hatch. What ecu and potential wiring problems can be expected?
- Idle problem with H22
- Flywheels
- Which mount pieces do I need for 2k si engine in 97 hb?
- 2000 si engine > 97 hb: Guide to rewiring harness?
- obd2 --->obd1
- Which Helms Manual?
- Not starting...
- 4th gen B18 probs.
- Some hybrid ?'s
- help from experienced hybriders
- Daily Driven Crvtec motor...How to Drive it?
- NEED everyones opinion on Edlebrock header
- 88-91 CRX is it hard to swap in a SOHC 92-95 SI motor in to it?
- A/C ? Re:B16A1 into 91 CRX
- Distributor shopping...
- Which B16 is easiest to swap into 98 EX?
- 5G hatchback owners with rear sway bars installed. Please post pics of you exhaust
- '97 JDM H22 in a '97 integra, what kind of wiring harness is needed??
- B-series A/C Compressors
- Help!!!! '94 GSR motor and '91 LS header into '91 CRX?
- blown gsr motor
- b20/vtec reliability, part 436.
- D16z6 swap in a 88-91crx?
- How many people can I stump with 1983 accord swap questions?
- OG Civic Type R in the Us for Sale. 18Gs
- Can you make large amounts of tourqe with B16s?
- Labor for swap cost?
- Problem with swap. Help
- 92vx hatchback 95 gsr swap. wont rev up past 3rpms. help
- how much
- how long do carbon fiber hoods last?
- And God said"let me chirp in 2nd" and it was so...
- ECU compatibility
- how hard is it
- Purchasing Engines?
- swap/lsvtec or turbo ls witch is best for daily driver
- B16a into EF Q'
- Car won't move
- B18b VS B18c1 ( on an SI )
- does this setup seem ok???
- B16 B-tech engine questions
- jdm b16a fuel system
- b20 a/c mount ?
- MSD 6a wiring problem on a OBDII GSR distribtutor
- Integra rear sway-bar in an EG hatchback
- Any more news on the bolt in kit for the RSX engine into the 7g civic?
- 2nd gen B16a "Timing Belt" mount (HELP!!!)
- h22 shifter cables and shifter mounting questions??
- Questions about b16a2 into 97 dx hb (clarification)
- how this price sound for a 92hybrid hatch?????
- who makes a stroker kit for a 1.8
- sirII into a 92-95 hatch
- anyone who has bought a swap from hondamotorsonline- look inside quick ?
- h22 in my slow ex
- d16a1 to b16a1 help please
- Any shops in so cal for wiring?
- please need help asap!!!!!!!!!!!!!!
- How did you go about building your b20?
- Did I get Scammed?
- Will a JDM P72 ecu run an H22A dangerously lean ??
- tranny/ecu for h23a4
- trany help
- help 1988 honda crx with GSR
- GSR ECU running a B16A2??
- is P75 the later gen ls's?
- auto to manual. what do with the console??
- D16y8 in EF!
- FS: 1998 Honda Civic EX/ITR hybrid
- 12.5 @ 107mph with my new crvtec set up.........
- Please help 91 Accord needs swap info
- zc in a eg
- whos running the d15b sohc vtec 130hp?
- best shop for b16 in so cal
- VX tranny with D16z6 long block?
- MASTER CYLINDER UPGRADE for a 90 teg RS ?? type R ??
- anyone run b16 head & typeR block
- Anyone know where I can get a K20A2??
- 95 civic coupe with 94 gsr swap
- B20 Internals
- 2nd gen.jdm b16a
- P28 Ecu questions ?
- water pump for B20 & the laws of physics...
- engine swap in old civic?????????????????
- what evap purge sol/canister for jdm r swap?
- B18a in 4th gen 4dr civic
- for the B20B crank pulley people
- Please post pics of your B20 swap
- H22 hesitates on initial throttle
- Engine mount question...
- is it possible
- scoe 36 help
- distributor = gas problems?
- Need help guys! Pw0 ECu work on obd2 GS-R engine?
- B18b Obd-1 vs Obd-2
- need help on distributor?
- HELP B16 is stuttering an sounds like vw bug!!!
- Im new to the board and was wondering about swapping h22 into my accord.
- GSR in 2nd gen CRX
- Just put my b18c1 in....
- best crank to use on a ls/vtec?
- Damn distributor..please help
- Engine Swap Help
- Help with Wire ID Please
- I am buying a JDM GSR W/LSD(full swap) and putting it in my '93 Hatch. What else will I need?
- grinding under load, please help.
- installing kill switches
- Swap Options
- swapping an h22 into 94 civic coupe, which cai's fit?
- New web-board!
- eg speed sensor on gsr tranny?
- homemade performance parts?
- cure for the eg's lame headlights?
- JDM B16A2 in 93 Civic DX. ECU Wire problem PLEASE READ
- Answer needed please
- Integra GSR B18C1 Engine Swap.. Now what to do???
- Importautosalvage?
- Where can I find a type R or gsr tranny?
- What are the pros & cons?
- Will the JG IM benifit my setup?
- DYNO result for my B18C1 EG.
- Aftermarket Crank pulley for CRV........
- What can be done to 02 CRV?
- obd1&obd2 ??? with b16a2
- sppon engines
- Did search not much help...b16 into an EG????
- F20B Help In Accord
- skuk2 intake mani..???
- Motor mounts
- B16Z6 engine problems
- JDM B18C5 in a 5th gen si hatch
- Automatic swap ls into ex
- jdm b18c1 wiring help???
- Checkin for clean flowing Injectors ?
- will advancing the timming
- Correct Gap for JDM B16A sparkplugs ??
- If I have an auto ecu on my b16 -
- call me crazy..b20 in an EF?? help!!
- I need help with a 1992 civic cx hatchback!
- ATTENTION......all owners who have a AEM-CAI
- How can you tell if it is a 2k si engine.
- IAC problems on my b16a1 in my CRX si... Please Help
- GSR motor, CRX CIVIC questions.
- hybrid dyno post
- wiring schematic for a ITR ecu??
- LS block girdle...
- teg vs si rear mount
- ECU question
- injectors/resistors/distributor?h22 swap,help!
- h22a in 99 civic si
- **BENEN car stolen!!!!**
- b20 vtec or stroker kit on a GSR
- Lookin for B16a2 that needs to be rebuilt!
- Anyone have a b20 that they are still running?
- B16 flooding
- B16a w/ OBD issues into a 5th gen
- Who has a gen 2 integra with a swap?
- Do I need to replace the oil and water pump in a b20?
- somebody tell me the pin outs on the ITR ECU in a 99 SI there are two that must be switched right
- POwer steering in a 93 cx
- Ls/Vtec in a 89 CRX SI: What shift linkage??
- 86 crx si stock i wana go all i can go with turbo what should i do??
- who has/knows jdm type r to 5g swap? 'i need your help please
- Last decision before my swap!!
- B18C into 92 Si -- minor wiring issue
- ls/vtec setup from others?
- cam caps LS and vtec head the same?
- 00 gsr in to 96 ek *wiring*
- Took type r in my eg to the dyno tonite
- please help fast!!!!! b16 swap
- '95 or '96 Civic H/B, which body is lighter?
- 88-91 b16a1 swap- which timing belt do i use?
- b16a(type r cams) chattering valves
- YS1 transmission oil lines? Help!
- what set p woul be faster?
- jdm b18c1????????
- Question for eg owners
- can you tell a 1st generation b16 and a 2nd generation b16 apart by looking at them?
- weird vtec problem???
- 00 b18c5 into 96 hatch ecu questions
- ls auto hybrid help
- Stock '96 CX radiator enough to cool a B20 swap?
- Gauage Cluster
- Good Motor shops in the Philadelphia Area?
- mini me swap, reccomendations for motor swaps into a 97 dx
- H22, EGR
- about to buy a b16b(ctr) engine..suggestions to what else i would need?
- D16y8 into a 92 VX hatch....
- knocksensor engine code what to do?????
- anyone have a b16a, with pr3 ecu?
- LS/V-TEC Internals..
- radiator fan decided it didnt want to turn on
- difficulty level? b16a3 into 93 hb cx vis versa sohc vtec into Del sol
- GSR cams in 1st gen B16???
- Ls/Vtec headgasket w/ B18b Bottom & B18c head?
- how to tell engine year?
- Info please!!!!!
- intermediate shaft?
- getting a crx soon, suggested swaps please
- Most reputable site for B series engine?
- Differences between B20 and GSR driverside mount
- LS Crix times(I know its been talked about b4)
- Anyone see the article in Import Tuner with the interview with Mr. Spoon
- Post - search question....
- Z10 VS. GSR & ITR (block guridle)
- help!!! need motor
- second gen B16 in to a 93 ex coupe
- your basic mini me wonders with a transmission twist
- Those with B16's what fuel pressure are you running?
- Engine Mount Companys
- Type R in to EG question ?
- getting Code 19, lockup code solenoid? on a p28??? WTF
- minneme swap on d15
- QUESTION: I need you guys expertise!
- creates more power 1.8 ls or 2.0 prelude motor
- LS/Vtec in a '93 Del Sol Si????
- Starter Issue on DOHC 1.6 into 91 crx*******Please try to help!
- Wiring Troubles
- Good Motor Shops in Orange County?
- wiring harness question
- jdm b18 wiring harness???????
- JDM B16A into my american 97 civic ex
- b18 vs. b20?..
- b20b with b18b tranny?
- b16a motor mount bolts......
- 97 USDM ITR in a 97 DX Hatch troubleshooting
- b16a spark plugs/plug wires
- Attention h22 civics!!!!!
- whats a good site for b18a into 88-91 civic?
- B16 swap into EG question
- Rear engine bracket woes...
- JUN motor
- need answer ASAP...gsr axle in del sol hub...does it work?
- D15 to D16 swithover on a 91 crx?????????????????/
- need instructions to keep A/C in my DC with an H22....
