PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 [151] 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Mobil One oil filters......
  2. Stupid Former Owner
  3. Right Hand Drive Conversion....shop in Southern California?
  4. ??? can you fit a sr20det fwd motor in a 2001 itr
  5. How much for a 92-93 GSR TRANNY(cable)
  6. import race- summer duck VA june 30th (sunday)
  7. 98 ex shoc in a 93 ex coupe
  8. Source for LS/CRVtec VTEC activation kit?
  9. B18C5 Shortblock Engine Part Number
  10. Is the LS wiring harness prewired for vtec?
  11. k20 hybrid help!!
  12. b20 in to an Eg hatch
  13. mount kit in h22 in 5th gen cvic hb
  14. tapping oil line....
  15. Engine blue printing ? ? ? ??
  16. what is Juns website?
  17. website needed..please look
  18. does/did Jun make this
  19. what catalytic converter should i get for....
  20. What is need to make CrvTec OR lsVTEC Reliable?
  21. crooked motor
  22. vtec no workie for me!!!
  23. Intake Manifold Which One & WHY?
  24. What is the maximum cam timing variance(from factory setting) you can use without getting into a....
  25. Need Smog Help
  26. 98-00 gsr motor in 96 hatchback?
  27. '95 Civic DX D15B7 to B18C1 - ECU wiring Q
  28. h22 into a '93 4 door civic
  29. WTB chipped ecu's, used ground control, and B hydro tranny...
  30. vtec head on my dx engine
  31. What is the stamp or code for GSR tranny?
  32. Really high idle???It also fluctuates???PLease help
  33. GSR throttle cable and bracket
  34. My integra wont start. I troubleshooted and found No power to injectors!!! argghh help!
  35. d16z6 in 93 civic dx
  36. obd-0 to obd-1 problems
  37. AEM CAI on B18C in 92 Hatch??
  38. jdm front clip
  39. Ground Controls and everyday driving...
  40. Fields SFC and problems with MAP Sensor?
  41. My Hydro tranny in my 93 Integra
  42. Crvtec. Power and Smog Questions.
  43. need help knowing if my swap is at full capability???
  44. lsvtec ecu questions...in a crx
  45. JDM B18C-R into '92 Integra....
  46. JDM B18C-R Into '92 Integra....
  47. Which intake fits my car???
  48. how to build an ls vtec !!RIGHT!!
  49. what injetors to use in b16
  50. RSX type S with s2ooo head? any info on this?
  51. B16 first start prep work
  52. help me out guys!
  53. got a swap or gsrsol for sale! new lowered price
  54. Im pissed! What should I do?
  55. adjusting TPS
  56. do d series starters work with b series trannies?
  57. I saw max rev makes mounts now do they make them for...
  58. which helms manual for 1st gen jdm b16?
  59. B18B head on B18A block... ?
  60. the best engine to put in my 98 dx
  61. ls/crvtec in 4th gen civic - obd0
  62. clutch for fly wheel or tranny???????
  63. Mini me on 90 HB STD............. PLEASE READ
  64. A few B20 swap and performance Qs
  65. Where to get a Full Sppon Spec Engine
  66. Problem with inner joint popping out with an XSi motor in a 94 Hatch
  67. 95 GSR Into 92 VX Questions before swap!
  68. HELP..NJ people that can do B series swaps on EF's
  69. H22 swap radiator fan
  70. pistons rings to use for a jdm b16a
  71. major problem please read
  72. jdm engine dont got obd2
  73. Swap Times for those who've swapped themselves
  74. LSvtec?
  75. B16A1 in CRX problem... sporatic bog after oil change
  76. Alternator in '97 civic with ls motor?
  77. EG/B series tranny mount (help please)
  78. crv/ls/vtec... how to install oil squirters in the pistons, and more questions...
  79. ls/vtec wiring harness???
  80. obd2 b18b what is the diffrence to obd1 b18b
  81. Anyone have an H22 powered DC2 GSR?
  82. will a b18a1 Ls intake manifold fit on a zc?
  83. Which harness to use?
  84. how to make an ls/vtec or cr/vtec reliable?...
  85. ABS in a hatch?
  86. !!!!!!!!!!Please Help With Oil Leak Problem!!!!!!!!!!!!!!!!!!!!! Please Read!!!!!!!!!!!!!!!!!
  87. LS/Vtec question
  88. b16a2 swap
  89. D16a1 into a 3G civic
  90. what is a good shop in south jersey?
  91. CRVTEC-what would be the best solution for a cable trans car?
  92. who is "waffles" - did he change his nick?
  93. Any good shops in Cincinnati area
  94. 11.4 Fastbrakes in the rear, but...
  95. b18c1 into a 90 Integra LS
  96. b16a into 90 crx
  97. Question about RPM's.
  98. What distributer to use?
  99. Swap Shops
  100. Engine swap questions about the law in va/dc/md area
  101. 94+ Teg and Del Sol VTEC AC bracket the same?
  102. bay area shop to do hybrid swap?
  103. honda hybrid webpage?
  104. brake mc questions, help.
  105. ITR/CTR cams in gs-r... valve adj. specs?
  106. Dowel Pin Locations LS/VTEC
  107. b20 in90 teg?
  108. TYPE R hatches..
  109. Anybody Seen this hybid 1st gen CRX???
  110. LS/VTEC distributor argument!
  111. Ouuch!!.....Someone has commited Hondacide (Take a look)
  112. Anyone do a auto to 5 speed swap in a LS ?
  113. 5 Wire 02 Sensor in VX's..
  114. distributor....do I need one from a 95 b18c?
  115. making axles for a H22 swap?
  116. Where can I find a bone stock 97-00 complete CX motor and how much?
  117. Question about putting H22 in fifth gen accord!
  118. Running SO SO Rich
  119. Need 90-93 accord mid shaft A.S.A.P.!!
  120. what is the thread size for new oil passage?LS/VTEC
  121. swaps
  122. S Cali People Read Free Venom Nitrous Kit!
  123. Bay area shops for valve adjustment?
  124. Honda Motors Online (long)
  125. ecu problems...please help...i dont know what to do
  126. question on a crx swap
  127. Really stupid question here but need help.
  128. compression with b18b block/pistons, b16a2 head, stock single layer gasket?
  129. hybrid parts or whole car for sale
  130. B20z allmotor? In a 6gen Civic?
  131. need new rings?
  132. ZC into 1st gen CRX Si
  133. Adjustable Cam gear and Ingnition timing.
  134. Obd1 speed sensor pinout needed.
  135. will the power steering pump from a d16y8 fit the bracket on a b18c?
  136. 96 hatch with 2000 si motor, harness question one plug on dash harness?
  137. S1, J1, Y1, What is the difference???!!
  138. Manual ex chasis to Auto dx chasis in a 95 coupe any diff.
  139. B20 swap Qs
  140. normal Idle of a jdm b16a(5 series)
  141. Whats the average 1/4 mile of a b16a2
  142. jdmclub.com
  143. wiring harness for jdm type r engine?
  144. B16a1 has no spark????? Please Help!!!
  145. Is $800 a good price for a 2000 ex civic motor w'trans?
  146. Can i use a Ls head on a B16a2 block
  147. mini me.. please look if you can help!!!
  148. engines out of wrecked cars
  149. skunk2 intake question
  150. shops in va/md/dc area..
  151. i need help with my b18c1 motor
  152. 93' Civic Ex Sedan Hybrid Headers
  153. hybrid ys1 tranny
  154. B16 Pistons in B18A
  155. question about ls/vtec...
  156. Will a B16A2 tranny fit a B16A1 ????????
  157. prep work for an h22
  158. Here are some picts of Raxles' broken H22 axles
  159. mini me question
  160. Fuel Rail B18C1...what the heck is that thing on the left of it?
  161. Sloppy shifter??????
  162. 90' prelude 2.0 crank can you use...
  163. best place to purchase a swap?
  164. Who has actually performed a stock b20 swap on a 96-00 civic? Favor needed.
  165. motor skips....
  166. p28.gsr?
  167. jdm b18c1 parts ?????
  168. 2.5 diameter B-pipe flange??????
  169. Quick question... i have a mad idea
  170. What can I put in a 91 Honda Prelude 2.0 Liter Si
  171. 6th Gen with H22
  172. Ls head w/zc block?
  173. Head Gasket ISSUES!!! LS/VTEC
  174. H22 in 6th Gen Hatch?? Anyone with info/sites??
  175. "What if questions" -hybrids look inside
  176. ? about my B20B, the dipstick is about twice as long as normal...
  177. I really have no idea about this.
  178. help! skunk2 intake manifod install
  179. 92-95 w/o factory sway bars, ST sway bar installation probs, please help!
  180. cr-nsx from atlanta georgia
  181. b18c1 into 90 integra ls...
  182. B18A1 into a 91 civic 4 door
  183. where to buy swap parts?
  184. Would a Si or EX civic Cat work with ITR US MOTOR? (GETTING CAR REF)
  185. Big Throttlebody: Options?
  186. What could happen?
  187. If I could get a hatchback for free......
  188. Rack and pinion...what do I need?
  189. Anyone with a 96+ dx w/ dx aftermarket exhaust on a b18B?!?
  190. b20 swap
  191. ITR tranny with LS
  192. Question: anyone w/ a B18B 5g hatch
  193. IAC help please
  194. Hybrid b18cs in EKs i need help. PLEASE!
  195. 99 SI into a 99 DX
  196. what do guys think i should do next.
  197. what's so special about the p28 ecu?
  198. b16 into 94 civic lx
  199. What Ecu program would be good for NA built B17a swap?
  200. if someone could tell me WHY IT WONT MOVE!!!!!!!
  201. need haelp with pistons!!!
  202. Wiring sucks
  203. California Engine Swap Smog Information
  204. CRX B16, off time? Code 23 and idle prob.
  205. SoCal PCH run anyone?
  206. nsx calipers on eg6
  207. calling all b16a gurus
  208. HELP, will a B series fit...
  209. D16A6 into 3rd gen Prelude? can you do it
  210. hooking up a heated O2 sensor to a OBDO car.
  211. anyone use a d-series map sensor on an h22?
  212. what year GSRs are OBDI and OBDII?
  213. 92 civic b18c1 hatch a/c ?
  214. S1 tranny seals
  215. anyone in cali get their h22a legalized by the smog ref? (did search)
  216. jdm b16 what usdm parts work
  217. 2nd gen teg - b17a (gsr) into gs
  218. D16....... are all the parts interchangeable? THIS IS WHY.........>>>>>
  219. gsr head on b16 block.
  220. using LS internals on a b18c1......
  221. Non-OBD to OBD-1 jumper...
  222. Just joined the ranks of Hybrids
  223. best swap for 96 hatch??
  224. Cheapest power
  225. B20z swap into a 99 dx....throwing codes 7 and 65...any help?
  226. B16: odb1 injectors on odbo 1stgen b16 HELP!
  227. Can i use the same starter with my swap?
  228. which mounts to use
  229. LS/vtec, Crvtec, or full b18c? Which one shall choose?
  230. Wanna be Hybrid but have a problem...
  231. What's better, a swap or turbo
  232. Question about mounts '96 B18B into a '94 cx
  233. Plug and Play Wiring - Tell me if this works..
  234. ITR head on b18b block...
  235. ASAP - need HASport mount info!!
  236. Ls/vtec with GS-R Motor
  237. HCP Engineering mounts sale
  238. please answer this for me
  239. OBD2 converted to OBD1 swaps - Anyone ever pass emissions?
  240. Crvtec...Which Wiring Harness & Which ECU
  241. Question about Shift Linkage: '96 B18B in '94 CX
  242. obd1 ecu and obd2 engine...will it work?
  243. What parts do I need for swap??
  244. ls/vtec
  245. swap done.. wont start.. no fuel or spark....
  246. b18 Ls block w/b16vtec head in a 93 hatch. need help
  247. hf harness wiring problems with b16
  248. JDM and USDM changeover price diifferences??
  249. d16a6 manifold wiring to d16y8 manifold wiring
  250. what to do next?
